[U-Boot] [PATCH] Introduce CONFIG_4xx_HAS_OPB
The lib_ppc/board.c file will fill in the bi_opbfreq variable in the bd_t structure for PowerPC 4xx platforms. However, it currently seems to be coupled together with the bi_pci_busfreq variable under a series of ifdefs for particular CPU types. As a result, it is rather easy to miss getting bi_opbfreq populated on boards when doing a board port. This is the case for CONFIG_405EZ for example.
This patch introduces a CONFIG_4xx_HAS_OPB option that is set to indicate that the platform uses that variable in the bd_t structure. It decouples this from the PCI bus setting and sets is properly for CPUs that have this defined.
Signed-off-by: Josh Boyer jwboyer@linux.vnet.ibm.com
diff --git a/include/asm-ppc/u-boot.h b/include/asm-ppc/u-boot.h index 54ac01d..6673cd4 100644 --- a/include/asm-ppc/u-boot.h +++ b/include/asm-ppc/u-boot.h @@ -112,12 +112,14 @@ typedef struct bd_info { unsigned char bi_enet3addr[6]; #endif
+#if defined(CONFIG_4xx_HAS_OPB) + unsigned int bi_opbfreq; /* OPB clock in Hz */ +#endif #if defined(CONFIG_405GP) || defined(CONFIG_405EP) || \ defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) - unsigned int bi_opbfreq; /* OPB clock in Hz */ int bi_iic_fast[2]; /* Use fast i2c mode */ #endif #if defined(CONFIG_NX823) diff --git a/include/ppc4xx.h b/include/ppc4xx.h index e216663..be6696d 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -46,6 +46,15 @@ #define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */ #endif
+/* Configure the OPB variable */ +#if defined(CONFIG_405GP) || defined(CONFIG_405EP) || \ + defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \ + defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define CONFIG_4xx_HAS_OPB +#endif + /* PLB4 CrossBar Arbiter Core supported across PPC4xx families */ #if defined(CONFIG_405EX) || \ defined(CONFIG_440EP) || defined(CONFIG_440EPX) || \ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index c02ac62..977fc19 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -611,10 +611,12 @@ void board_init_f (ulong bootflag) defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) bd->bi_pci_busfreq = get_PCI_freq (); - bd->bi_opbfreq = get_OPB_freq (); #elif defined(CONFIG_XILINX_405) bd->bi_pci_busfreq = get_PCI_freq (); #endif +#if defined(CONFIG_4xx_HAS_OPB) + bd->bi_opbfreq = get_OPB_freq (); +#endif #endif
debug ("New Stack Pointer is: %08lx\n", addr_sp);
Josh,
I thought about it a little more. Some comments below...
It just occurred to me that this change break Linux compatibility. Usually you can just copy this file to the include/asm-ppc directory in Linux to have the same bd_info as in U-Boot (that's old arch/ppc of course). But Linux doesn't know about this CONFIG_4xx_HAS_OPB define. So this will not work.
You should probably better leave this file untouched as the 405EZ is correct.
- defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \
- defined(CONFIG_440EP) || defined(CONFIG_440GR) || \
- defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \
- defined(CONFIG_460EX) || defined(CONFIG_460GT)
Hmmm. Why not something like this:
#if !defined(CONFIG_XILINX_405) && !defined(CONFIG_XILINX_440) #define CONFIG_4xx_HAS_OPB #endif
Does this work?
+#endif #endif
Best regards, Stefan
On Fri, 10 Oct 2008 09:33:03 +0200 Stefan Roese sr@denx.de wrote:
Josh,
Except the list that was originally here isn't really complete. And as far as Linux compatibility, it already is incompatible. The ppcboot.h file simply has bi_opbfreq under a #if defined(TARGET_4xx), which is how I ran into this problem to begin with.
Does this work?
It would in theory, yes. I had something like that originally, but I did not know if boards with CPUs that weren't in the original list of CONFIG_4nn options would break if this member suddenly showed up. I can't see why it would, but I have no way of testing.
josh
Josh Boyer
Stefan Roese
