[PATCH v2 1/4] smbios: type2: contained object handles
The type 2 structure must include information about the contained objects. It is fine to set the number of contained object handles to 0.
Add the missing field.
Fixes: 721e992a8af5 ("x86: Add SMBIOS table support") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v2: email address updated --- include/smbios.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/smbios.h b/include/smbios.h index b507b9d9d72..98bb9e52cdf 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -139,6 +139,7 @@ struct __packed smbios_type2 { u8 chassis_location; u16 chassis_handle; u8 board_type; + u8 number_contained_objects; char eos[SMBIOS_STRUCT_EOS_BYTES]; };
U-Boot can either generated an SMBIOS table or copy it from a prior boot stage, e.g. QEMU.
Provide a command to display the SMBIOS information.
Currently only type 1 and 2 are translated to human readable text. Other types may be added later. Currently only a hexdump and the list of strings is provided for these.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: email address updated --- cmd/Kconfig | 7 ++ cmd/Makefile | 1 + cmd/smbios.c | 191 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 199 insertions(+) create mode 100644 cmd/smbios.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 26aeeeed03b..43c9c20c8fa 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -227,6 +227,13 @@ config CMD_SBI help Display information about the SBI implementation.
+config CMD_SMBIOS + bool "smbios" + depends on SMBIOS + default y + help + Display the SMBIOS information. + endmenu
menu "Boot commands" diff --git a/cmd/Makefile b/cmd/Makefile index e2a2b16ab25..87133cc27a8 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -168,6 +168,7 @@ obj-$(CONFIG_CMD_SETEXPR) += setexpr.o obj-$(CONFIG_CMD_SETEXPR_FMT) += printf.o obj-$(CONFIG_CMD_SPI) += spi.o obj-$(CONFIG_CMD_STRINGS) += strings.o +obj-$(CONFIG_CMD_SMBIOS) += smbios.o obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o obj-$(CONFIG_CMD_STACKPROTECTOR_TEST) += stackprot_test.o diff --git a/cmd/smbios.c b/cmd/smbios.c new file mode 100644 index 00000000000..63f908e92ce --- /dev/null +++ b/cmd/smbios.c @@ -0,0 +1,191 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * The 'smbios' command displays information from the SMBIOS table. + * + * Copyright (c) 2023, Heinrich Schuchardt heinrich.schuchardt@canonical.com + */ + +#include <command.h> +#include <hexdump.h> +#include <mapmem.h> +#include <smbios.h> +#include <tables_csum.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * smbios_get_string() - get SMBIOS string from table + * + * @table: SMBIOS table + * @index: index of the string + * Return: address of string, may point to empty string + */ +static const char *smbios_get_string(void *table, int index) +{ + const char *str = (char *)table + + ((struct smbios_header *)table)->length; + + if (!*str) + ++str; + for (--index; *str && index; --index) + str += strlen(str) + 1; + + return str; +} + +static struct smbios_header *next_table(struct smbios_header *table) +{ + const char *str; + + if (table->type == SMBIOS_END_OF_TABLE) + return NULL; + + str = smbios_get_string(table, 0); + return (struct smbios_header *)(++str); +} + +static void smbios_print_generic(struct smbios_header *table) +{ + char *str = (char *)table + table->length; + + if (CONFIG_IS_ENABLED(HEXDUMP)) { + printf("Header and Data:\n"); + print_hex_dump("\t", DUMP_PREFIX_OFFSET, 16, 1, + table, table->length, false); + } + if (*str) { + printf("Strings:\n"); + for (int index = 1; *str; ++index) { + printf("\tString %u: %s\n", index, str); + str += strlen(str) + 1; + } + } +} + +void smbios_print_str(const char *label, void *table, u8 index) +{ + printf("\t%s: %s\n", label, smbios_get_string(table, index)); +} + +static void smbios_print_type1(struct smbios_type1 *table) +{ + printf("System Information\n"); + smbios_print_str("Manufacturer", table, table->manufacturer); + smbios_print_str("Product Name", table, table->product_name); + smbios_print_str("Version", table, table->version); + smbios_print_str("Serial Number", table, table->serial_number); + if (table->length >= 0x19) { + printf("\tUUID %pUl\n", table->uuid); + smbios_print_str("Wake Up Type", table, table->serial_number); + } + if (table->length >= 0x1b) { + smbios_print_str("Serial Number", table, table->serial_number); + smbios_print_str("SKU Number", table, table->sku_number); + } +} + +static void smbios_print_type2(struct smbios_type2 *table) +{ + u16 *handle; + + printf("Base Board Information\n"); + smbios_print_str("Manufacturer", table, table->manufacturer); + smbios_print_str("Product Name", table, table->product_name); + smbios_print_str("Version", table, table->version); + smbios_print_str("Serial Number", table, table->serial_number); + smbios_print_str("Asset Tag", table, table->asset_tag_number); + printf("\tFeature Flags: 0x%2x\n", table->feature_flags); + smbios_print_str("Chassis Location", table, table->chassis_location); + printf("\tChassis Handle: 0x%2x\n", table->chassis_handle); + smbios_print_str("Board Type", table, table->board_type); + printf("\tContained Object Handles: "); + handle = (void *)table->eos; + for (int i = 0; i < table->number_contained_objects; ++i) + printf("0x%04x ", handle[i]); + printf("\n"); +} + +static void smbios_print_type127(struct smbios_type127 *table) +{ + printf("End Of Table\n"); +} + +static int do_smbios(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + ulong addr; + void *entry; + u32 size; + char version[12]; + struct smbios_header *table; + static const char smbios_sig[] = "_SM_"; + static const char smbios3_sig[] = "_SM3_"; + size_t count = 0; + u32 max_struct_size; + + addr = gd_smbios_start(); + if (!addr) { + log_warning("SMBIOS not available\n"); + return CMD_RET_FAILURE; + } + entry = map_sysmem(addr, 0); + if (!memcmp(entry, smbios3_sig, sizeof(smbios3_sig) - 1)) { + struct smbios3_entry *entry3 = entry; + + table = (void *)(uintptr_t)entry3->struct_table_address; + snprintf(version, sizeof(version), "%d.%d.%d", + entry3->major_ver, entry3->minor_ver, entry3->doc_rev); + table = (void *)(uintptr_t)entry3->struct_table_address; + size = entry3->length; + max_struct_size = entry3->max_struct_size; + } else if (!memcmp(entry, smbios_sig, sizeof(smbios_sig) - 1)) { + struct smbios_entry *entry2 = entry; + + snprintf(version, sizeof(version), "%d.%d", + entry2->major_ver, entry2->minor_ver); + table = (void *)(uintptr_t)entry2->struct_table_address; + size = entry2->length; + max_struct_size = entry2->max_struct_size; + } else { + log_err("Unknown SMBIOS anchor format\n"); + return CMD_RET_FAILURE; + } + if (table_compute_checksum(entry, size)) { + log_err("Invalid anchor checksum\n"); + return CMD_RET_FAILURE; + } + printf("SMBIOS %s present.\n", version); + + for (struct smbios_header *pos = table; pos; pos = next_table(pos)) + ++count; + printf("%zd structures occupying %d bytes\n", count, max_struct_size); + printf("Table at 0x%llx\n", (unsigned long long)map_to_sysmem(table)); + + for (struct smbios_header *pos = table; pos; pos = next_table(pos)) { + printf("\nHandle 0x%04x, DMI type %d, %d bytes at 0x%llx\n", + pos->handle, pos->type, pos->length, + (unsigned long long)map_to_sysmem(pos)); + switch (pos->type) { + case 1: + smbios_print_type1((struct smbios_type1 *)pos); + break; + case 2: + smbios_print_type2((struct smbios_type2 *)pos); + break; + case 127: + smbios_print_type127((struct smbios_type127 *)pos); + break; + default: + smbios_print_generic(pos); + break; + } + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_LONGHELP(smbios, "- display SMBIOS information"); + +U_BOOT_CMD(smbios, 1, 0, do_smbios, "display SMBIOS information", + smbios_help_text);
Hi Heinrich,
A few nits below
v2:
email address updated +static struct smbios_header *next_table(struct smbios_header *table) +{
- const char *str;
- if (table->type == SMBIOS_END_OF_TABLE)
return NULL;
- str = smbios_get_string(table, 0);
- return (struct smbios_header *)(++str);
That can lead to unaligned access when we dereference that pointer, do we care?
- char *str = (char *)table + table->length;
Do we want the header below printed if there are no strings? IOW can we exit early if (!*str) ?
- if (CONFIG_IS_ENABLED(HEXDUMP)) {
- if (*str) {
- printf("\t%s: %s\n", label, smbios_get_string(table, index));
Other than that, LGTM
Thanks /Ilias
On 1/18/24 13:39, Ilias Apalodimas wrote:
Hi Heinrich,
A few nits below
v2:
- const char *str;
return NULL;
SMBIOS tables are always byte aligned. This is why struct smbios_header is marked as packed. The GCCj documentation has this sentence:
"The packed attribute specifies that a variable or structure field should have the smallest possible alignment - one byte for a variable, and one bit for a field, unless you specify a larger value with the aligned attribute."
So shouldn't the compiler care about non-alignment? If there were a problematic usage, GCC would throw -Waddress-of-packed-member.
Best regards
Heinrich
- if (*str) {
Thanks /Ilias
On Thu, 18 Jan 2024 at 14:54, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
A few nits below
v2:
- const char *str;
return NULL;
I don't think we have the strict alignment enabled in our makefiles. But, that won't be a problem, I missed the packed attribute in the smbios header.
with or without the change in smbios_print_generic() Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
[snip]
+config CMD_SMBIOS
- bool "smbios"
- depends on SMBIOS
- default y
- help
So this would be enabled (today) on 888 boards and is a bit more than a kilobyte. I think we can just let this be enabled as needed in defconfigs?
[snip]
+config CMD_SMBIOS
- bool "smbios"
- depends on SMBIOS
- default y
- help
As needed would be the boards where we want to run the related Python test. Sandbox and QEMU should be good enough?
Best regards
Heinrich
[snip]
@@ -227,6 +227,13 @@ config CMD_SBI help Display information about the SBI implementation. +config CMD_SMBIOS
- bool "smbios"
- depends on SMBIOS
- default y
- help
And the test needs the pytest mark for cmd_smbios, yes.
On Thu, 25 Jan 2024 at 03:02, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
[snip]
+config CMD_SMBIOS
- bool "smbios"
- depends on SMBIOS
- default y
- help
Yes, I think for most users seeing the smbios tables is probably not particularly useful.
Provide a man-page for the smbios command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v2: no change --- doc/usage/cmd/smbios.rst | 93 ++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 94 insertions(+) create mode 100644 doc/usage/cmd/smbios.rst
diff --git a/doc/usage/cmd/smbios.rst b/doc/usage/cmd/smbios.rst new file mode 100644 index 00000000000..1ffd706d7de --- /dev/null +++ b/doc/usage/cmd/smbios.rst @@ -0,0 +1,93 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later: + +smbios command +============== + +Synopsis +-------- + +:: + + smbios + +Description +----------- + +The smbios command displays information from the SMBIOS tables. + +Examples +-------- + +The example below shows an example output of the smbios command. + +:: + + => smbios + SMBIOS 2.8.0 present. + 8 structures occupying 81 bytes + Table at 0x6d35018 + + Handle 0x0100, DMI type 1, 27 bytes at 0x6d35018 + System Information + Manufacturer: QEMU + Product Name: Standard PC (i440FX + PIIX, 1996) + Version: pc-i440fx-2.5 + Serial Number: + UUID 00000000-0000-0000-0000-000000000000 + Wake Up Type: + Serial Number: + SKU Number: + + Handle 0x0300, DMI type 3, 22 bytes at 0x6d35069 + Header and Data: + 00000000: 03 16 00 03 01 01 02 00 00 03 03 03 02 00 00 00 + 00000010: 00 00 00 00 00 00 + Strings: + String 1: QEMU + String 2: pc-i440fx-2.5 + + Handle 0x0400, DMI type 4, 42 bytes at 0x6d35093 + Header and Data: + 00000000: 04 2a 00 04 01 03 01 02 63 06 00 00 fd ab 81 07 + 00000010: 03 00 00 00 d0 07 d0 07 41 01 ff ff ff ff ff ff + 00000020: 00 00 00 01 01 01 02 00 01 00 + Strings: + String 1: CPU 0 + String 2: QEMU + String 3: pc-i440fx-2.5 + + Handle 0x1000, DMI type 16, 23 bytes at 0x6d350d7 + Header and Data: + 00000000: 10 17 00 10 01 03 06 00 00 02 00 fe ff 01 00 00 + 00000010: 00 00 00 00 00 00 00 + + Handle 0x1100, DMI type 17, 40 bytes at 0x6d350f0 + Header and Data: + 00000000: 11 28 00 11 00 10 fe ff ff ff ff ff 80 00 09 00 + 00000010: 01 00 07 02 00 00 00 02 00 00 00 00 00 00 00 00 + 00000020: 00 00 00 00 00 00 00 00 + Strings: + String 1: DIMM 0 + String 2: QEMU + + Handle 0x1300, DMI type 19, 31 bytes at 0x6d35125 + Header and Data: + 00000000: 13 1f 00 13 00 00 00 00 ff ff 01 00 00 10 01 00 + 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 + + Handle 0x2000, DMI type 32, 11 bytes at 0x6d35146 + Header and Data: + 00000000: 20 0b 00 20 00 00 00 00 00 00 00 + + Handle 0x7f00, DMI type 127, 4 bytes at 0x6d35153 + End Of Table + +Configuration +------------- + +The command is only available if CONFIG_CMD_SMBIOS=y. + +Return value +------------ + +The return value $? is 0 (true) on success, 1 (false) otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index c171c029b80..0d174eefaa5 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -103,6 +103,7 @@ Shell commands cmd/size cmd/sleep cmd/sm + cmd/smbios cmd/sound cmd/source cmd/temperature
Provide a unit test for the smbios command.
Provide different test functions for QEMU, sandbox, and other systems.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: for generic boards we only can assume that a type 127 table exists email address updated --- test/py/tests/test_smbios.py | 41 ++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+) create mode 100644 test/py/tests/test_smbios.py
diff --git a/test/py/tests/test_smbios.py b/test/py/tests/test_smbios.py new file mode 100644 index 00000000000..82b0b689830 --- /dev/null +++ b/test/py/tests/test_smbios.py @@ -0,0 +1,41 @@ +# SPDX-License-Identifier: GPL-2.0-or-later + +"""Test smbios command""" + +import pytest + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.notbuildconfigspec('qfw_smbios') +@pytest.mark.notbuildconfigspec('sandbox') +def test_cmd_smbios(u_boot_console): + """Run the smbios command""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 127,' in output + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.buildconfigspec('qfw_smbios') +@pytest.mark.notbuildconfigspec('sandbox') +# TODO: +# QEMU v8.2.0 lacks SMBIOS support for RISC-V +# Once support is available in our Docker image we can remove the constraint. +@pytest.mark.notbuildconfigspec('riscv') +def test_cmd_smbios_qemu(u_boot_console): + """Run the smbios command on QEMU""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 1,' in output + assert 'Manufacturer: QEMU' in output + assert 'DMI type 127,' in output + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.buildconfigspec('sandbox') +def test_cmd_smbios_sandbox(u_boot_console): + """Run the smbios command on the sandbox""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 0,' in output + assert 'String 1: U-Boot' in output + assert 'DMI type 1,' in output + assert 'Manufacturer: sandbox' in output + assert 'DMI type 2,' in output + assert 'DMI type 3,' in output + assert 'DMI type 4,' in output + assert 'DMI type 127,' in output
Hi Heinrich,
On Wed, 17 Jan 2024 at 17:34, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
+import pytest
- """Run the smbios command"""
- output = u_boot_console.run_command('smbios')
- assert 'DMI type 127,' in output
- """Run the smbios command on QEMU"""
- assert 'DMI type 1,' in output
- assert 'Manufacturer: QEMU' in output
Is there an easy way to run this test with and without the SMBIOS tables provided by QEMU? We could test the u-boot generated ones that way
Thanks /Ilias
- """Run the smbios command on the sandbox"""
- assert 'DMI type 0,' in output
- assert 'String 1: U-Boot' in output
- assert 'Manufacturer: sandbox' in output
- assert 'DMI type 2,' in output
- assert 'DMI type 3,' in output
- assert 'DMI type 4,' in output
-- 2.43.0
On 1/18/24 12:51, Ilias Apalodimas wrote:
Hi Heinrich,
+import pytest
We already test the sandbox without QFW. I would not want to duplicated QEMU defconfigs.
Best regards
Heinrich
Thanks /Ilias
-- 2.43.0
Hi Heinrich,
+import pytest
Ah fair enough, I can add the generic tests in that one
Best regards
Heinrich
Thanks /Ilias
-- 2.43.0
U-Boot may supply an SMBIOS table or they may be copied from QEMU.
The following prerequisites had to be fixed:
* The definition of SMBIOS type 2 lacked a field.
v2: merged patch remove for generic boards we only can assume that a type 127 table exists my email address updated in all patches
Heinrich Schuchardt (4): smbios: type2: contained object handles cmd: provide command to display SMBIOS information doc: man-page for smbios command test: unit test for smbios command
cmd/Kconfig | 7 ++ cmd/Makefile | 1 + cmd/smbios.c | 191 +++++++++++++++++++++++++++++++++++ doc/usage/cmd/smbios.rst | 93 +++++++++++++++++ doc/usage/index.rst | 1 + include/smbios.h | 1 + test/py/tests/test_smbios.py | 41 ++++++++ 7 files changed, 335 insertions(+) create mode 100644 cmd/smbios.c create mode 100644 doc/usage/cmd/smbios.rst create mode 100644 test/py/tests/test_smbios.py
Ilias Apalodimas
Peter Robinson
