[U-Boot] [PATCH] powerpc/85xx: Add the workaround for erratum ELBC-A001 (enable on P4080)
Simultaneous FCM and GPCM or UPM operation may erroneously trigger bus monitor timeout. Set timeout to maximum to avoid.
Based on a patch from Lan Chunhe b25806@freescale.com
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc8xxx/fsl_lbc.c | 7 ++++++- arch/powerpc/include/asm/fsl_lbc.h | 4 +++- include/configs/P4080DS.h | 1 + 4 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index e44a38f..de73310 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -68,6 +68,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A003 puts("Work-around for Erratum CPC-A003 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_ELBC_A001 + puts("Work-around for Erratum ELBC-A001 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_lbc.c b/arch/powerpc/cpu/mpc8xxx/fsl_lbc.c index 6f401e7..7598ebf 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_lbc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_lbc.c @@ -1,5 +1,5 @@ /* - * Copyright 2010 Freescale Semiconductor, Inc. + * Copyright 2010-2011 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -34,6 +34,11 @@ void init_early_memctl_regs(void) { uint init_br1 = 1;
+#ifdef CONFIG_SYS_FSL_ERRATUM_ELBC_A001 + /* Set the local bus monitor timeout value to the maximum */ + clrsetbits_be32(&(LBC_BASE_ADDR)->lbcr, LBCR_BMT|LBCR_BMTPS, 0xf); +#endif + #ifdef CONFIG_MPC85xx /* if cs1 is already set via debugger, leave cs0/cs1 alone */ if (get_lbc_br(1) & BR_V) diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index c504732..8695a62 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2004-2008,2010 Freescale Semiconductor, Inc. + * Copyright (C) 2004-2008,2010-2011 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -295,6 +295,8 @@ void lbc_sdram_init(void); #define LBCR_EPAR_SHIFT 16 #define LBCR_BMT 0x0000FF00 #define LBCR_BMT_SHIFT 8 +#define LBCR_BMTPS 0x0000000F +#define LBCR_BMTPS_SHIFT 0
/* LCRR - Clock Ratio Register */ diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 216f6fb..34d5851 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -44,5 +44,6 @@ #define CONFIG_SYS_FSL_ERRATUM_CPC_A003 #define CONFIG_SYS_P4080_ERRATUM_SERDES8 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 +#define CONFIG_SYS_FSL_ERRATUM_ELBC_A001
#include "corenet_ds.h"
applied
- k
Kumar Gala
