[PATCH 1/2] mtd: nand: spi: Only one dummy byte in QUADIO
From: Reto Schneider reto.schneider@husqvarnagroup.com
The datasheet only lists one dummy byte in the 0xEH operation for the following chips: * GD5F1GQ4xBxxG * GD5F1GQ4xExxG * GD5F1GQ4xFxxG * GD5F1GQ4UAYIG * GD5F4GQ4UAYIG
This patch and its commit message reflects what has been done in Linux and has not been tested by me.
Signed-off-by: Reto Schneider reto.schneider@husqvarnagroup.com CC: Stefan Roese sr@denx.de --- drivers/mtd/nand/spi/gigadevice.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/spi/gigadevice.c b/drivers/mtd/nand/spi/gigadevice.c index 0b228dcb5b..5de0ebbb7b 100644 --- a/drivers/mtd/nand/spi/gigadevice.c +++ b/drivers/mtd/nand/spi/gigadevice.c @@ -20,7 +20,7 @@ #define GD5FXGQ4XEXXG_REG_STATUS2 0xf0
static SPINAND_OP_VARIANTS(read_cache_variants, - SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 2, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0),
The relevant changes to the already existing GD5F1GQ4UExxG support has been determined by consulting the GigaDevice product change notice AN-0392-10, version 1.0 from November 30, 2020.
As the overlaps are huge, variable names have been generalized accordingly.
Apart form the lowered ECC strength (4 instead of 8 bits per 512 bytes), the new device ID, and the extra quad IO dummy byte, no changes had to be taken into account.
New hardware features are not supported, namely: - Power on reset - Unique ID - Double transfer rate (DTR) - Parameter page - Random data quad IO
The inverted semantic of the "driver strength" register bits, defaulting to 100% instead of 50% for the Q5 devices, got ignored as the driver has never touched them anyway.
The no longer supported "read from cache during block erase" functionality I do not know how to reflect.
Implementation has been tested on MediaTek MT7688 based GARDENA smart Gateways using both, GigaDevice GD5F1GQ5UEYIG and GD5F1GQ4UBYIG.
Signed-off-by: Reto Schneider reto.schneider@husqvarnagroup.com CC: Stefan Roese sr@denx.de --- drivers/mtd/nand/spi/gigadevice.c | 79 +++++++++++++++++++++++++++---- 1 file changed, 69 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/nand/spi/gigadevice.c b/drivers/mtd/nand/spi/gigadevice.c index 5de0ebbb7b..a2c93486f4 100644 --- a/drivers/mtd/nand/spi/gigadevice.c +++ b/drivers/mtd/nand/spi/gigadevice.c @@ -17,9 +17,13 @@ #define GD5FXGQ4XA_STATUS_ECC_1_7_BITFLIPS (1 << 4) #define GD5FXGQ4XA_STATUS_ECC_8_BITFLIPS (3 << 4)
-#define GD5FXGQ4XEXXG_REG_STATUS2 0xf0 +#define GD5FXGQ5XE_STATUS_ECC_1_4_BITFLIPS (1 << 4) +#define GD5FXGQ5XE_STATUS_ECC_4_BITFLIPS (3 << 4)
-static SPINAND_OP_VARIANTS(read_cache_variants, +#define GD5FXGQXXEXXG_REG_STATUS2 0xf0 + +/* Q4 devices, QUADIO: Dummy bytes valid for 1 and 2 GBit variants */ +static SPINAND_OP_VARIANTS(gd5fxgq4_read_cache_variants, SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), @@ -27,6 +31,15 @@ static SPINAND_OP_VARIANTS(read_cache_variants, SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0));
+/* Q5 devices, QUADIO: Dummy bytes only valid for 1 GBit variants */ +static SPINAND_OP_VARIANTS(gd5f1gq5_read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 2, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + static SPINAND_OP_VARIANTS(write_cache_variants, SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), SPINAND_PROG_LOAD(true, 0, NULL, 0)); @@ -35,7 +48,7 @@ static SPINAND_OP_VARIANTS(update_cache_variants, SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), SPINAND_PROG_LOAD(false, 0, NULL, 0));
-static int gd5fxgq4xexxg_ooblayout_ecc(struct mtd_info *mtd, int section, +static int gd5fxgqxxexxg_ooblayout_ecc(struct mtd_info *mtd, int section, struct mtd_oob_region *region) { if (section) @@ -47,7 +60,7 @@ static int gd5fxgq4xexxg_ooblayout_ecc(struct mtd_info *mtd, int section, return 0; }
-static int gd5fxgq4xexxg_ooblayout_free(struct mtd_info *mtd, int section, +static int gd5fxgqxxexxg_ooblayout_free(struct mtd_info *mtd, int section, struct mtd_oob_region *region) { if (section) @@ -64,7 +77,7 @@ static int gd5fxgq4xexxg_ecc_get_status(struct spinand_device *spinand, u8 status) { u8 status2; - struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQ4XEXXG_REG_STATUS2, + struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQXXEXXG_REG_STATUS2, &status2); int ret;
@@ -102,21 +115,67 @@ static int gd5fxgq4xexxg_ecc_get_status(struct spinand_device *spinand, return -EINVAL; }
-static const struct mtd_ooblayout_ops gd5fxgq4xexxg_ooblayout = { - .ecc = gd5fxgq4xexxg_ooblayout_ecc, - .rfree = gd5fxgq4xexxg_ooblayout_free, +static int gd5fxgq5xexxg_ecc_get_status(struct spinand_device *spinand, + u8 status) +{ + u8 status2; + struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQXXEXXG_REG_STATUS2, + &status2); + int ret; + + switch (status & STATUS_ECC_MASK) { + case STATUS_ECC_NO_BITFLIPS: + return 0; + + case GD5FXGQ5XE_STATUS_ECC_1_4_BITFLIPS: + /* + * Read status2 register to determine a more fine grained + * bit error status + */ + ret = spi_mem_exec_op(spinand->slave, &op); + if (ret) + return ret; + + /* + * 1 ... 4 bits are flipped (and corrected) + */ + /* bits sorted this way (1...0): ECCSE1, ECCSE0 */ + return ((status2 & STATUS_ECC_MASK) >> 4) + 1; + + case STATUS_ECC_UNCOR_ERROR: + return -EBADMSG; + + default: + break; + } + + return -EINVAL; +} + +static const struct mtd_ooblayout_ops gd5fxgqxxexxg_ooblayout = { + .ecc = gd5fxgqxxexxg_ooblayout_ecc, + .rfree = gd5fxgqxxexxg_ooblayout_free, };
static const struct spinand_info gigadevice_spinand_table[] = { SPINAND_INFO("GD5F1GQ4UExxG", 0xd1, NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), - SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + SPINAND_INFO_OP_VARIANTS(&gd5fxgq4_read_cache_variants, &write_cache_variants, &update_cache_variants), 0, - SPINAND_ECCINFO(&gd5fxgq4xexxg_ooblayout, + SPINAND_ECCINFO(&gd5fxgqxxexxg_ooblayout, gd5fxgq4xexxg_ecc_get_status)), + SPINAND_INFO("GD5F1GQ5UExxG", 0x51, + NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), + NAND_ECCREQ(4, 512), + SPINAND_INFO_OP_VARIANTS(&gd5f1gq5_read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&gd5fxgqxxexxg_ooblayout, + gd5fxgq5xexxg_ecc_get_status)), };
static int gigadevice_spinand_detect(struct spinand_device *spinand)
- Power on reset
- Unique ID
- Parameter page
Looks good, so:
Thanks, Stefan
- static SPINAND_OP_VARIANTS(write_cache_variants, SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), SPINAND_PROG_LOAD(true, 0, NULL, 0));
- struct spi_mem_op op = SPINAND_GET_FEATURE_OP(GD5FXGQXXEXXG_REG_STATUS2, &status2); int ret;
u8 status)
- u8 status2;
&status2);
- int ret;
- switch (status & STATUS_ECC_MASK) {
- case STATUS_ECC_NO_BITFLIPS:
- case GD5FXGQ5XE_STATUS_ECC_1_4_BITFLIPS:
* bit error status
if (ret)
return ret;
- case STATUS_ECC_UNCOR_ERROR:
return -EBADMSG;
- default:
break;
- return -EINVAL;
0,
Viele Grüße, Stefan
- GD5F1GQ4xBxxG
- GD5F1GQ4xExxG
- GD5F1GQ4xFxxG
- GD5F1GQ4UAYIG
- GD5F4GQ4UAYIG
AFAICT, you are posting a Linux patch ported to U-Boot here. Which is good of course. But if you didn't do substantial changes to this patch, then please keep the original (Linux) authorship of Hauke for this patch (From: ...). You might want to add something like:
Reto Schneider: Linux patch ported to U-Boot
to the end of the commit text and add your Sob of course.
Other than this:
Thanks, Stefan
SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0),SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 1, NULL, 0),
Viele Grüße, Stefan
Reto Schneider
Stefan Roese
