[U-Boot] [PATCH 1/3] dm: cros_ec: Convert to Kconfig
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses.
LPC will need to wait until driver mode PCI is available.
configs/peach-pi_defconfig | 4 ++++ configs/peach-pit_defconfig | 4 ++++ configs/sandbox_defconfig | 5 ++++ configs/snow_defconfig | 5 ++++ drivers/input/Kconfig | 6 +++++ drivers/misc/Kconfig | 48 ++++++++++++++++++++++++++++++++++++- include/configs/exynos5-dt-common.h | 3 --- include/configs/peach-pi.h | 1 - include/configs/peach-pit.h | 1 - include/configs/sandbox.h | 4 ---- include/configs/snow.h | 2 -- 11 files changed, 71 insertions(+), 12 deletions(-)
diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 8ada0db..333e335 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -3,3 +3,7 @@ CONFIG_SPL=y +S:CONFIG_ARCH_EXYNOS=y +S:CONFIG_TARGET_PEACH_PI=y CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" +CONFIG_CROS_EC=y +CONFIG_CROS_EC_SPI=y +CONFIG_CROS_EC_KEYB=y +CONFIG_CMD_CROS_EC=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index b944b3b..cf84444 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -3,3 +3,7 @@ CONFIG_SPL=y +S:CONFIG_ARCH_EXYNOS=y +S:CONFIG_TARGET_PEACH_PIT=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" +CONFIG_CROS_EC=y +CONFIG_CROS_EC_SPI=y +CONFIG_CROS_EC_KEYB=y +CONFIG_CMD_CROS_EC=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0bf5ea3..70f5b86 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -7,3 +7,8 @@ CONFIG_DM=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" CONFIG_SYS_MALLOC_F=y CONFIG_SYS_MALLOC_F_LEN=0x400 +CONFIG_CROS_EC=y +CONFIG_DM_CROS_EC=y +CONFIG_CROS_EC_SANDBOX=y +CONFIG_CROS_EC_KEYB=y +CONFIG_CMD_CROS_EC=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 14ed793..353ddb0 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -3,3 +3,8 @@ CONFIG_SPL=y +S:CONFIG_ARCH_EXYNOS=y +S:CONFIG_TARGET_SNOW=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" +CONFIG_CROS_EC=y +CONFIG_DM_CROS_EC=y +CONFIG_CROS_EC_I2C=y +CONFIG_CROS_EC_KEYB=y +CONFIG_CMD_CROS_EC=y diff --git a/drivers/input/Kconfig b/drivers/input/Kconfig index e69de29..bb00de7 100644 --- a/drivers/input/Kconfig +++ b/drivers/input/Kconfig @@ -0,0 +1,6 @@ +config CROS_EC_KEYB + bool "Enable Chrome OS EC keyboard support" + help + Most ARM Chromebooks use an EC to provide access to the keyboard. + Messages are used to request key scans from the EC and these are + then decoded into keys by this driver. diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 813d1c2..0df25c3 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -1,3 +1,49 @@ +config CMD_CROS_EC + bool "Enable crosec command" + depends on CROS_EC + help + Enable command-line access to the Chrome OS EC (Embedded + Controller). This provides the 'crosec' command which has + a number of sub-commands for performing EC tasks such as + updating its flash, accessing a small saved context area + and talking to the I2C bus behind the EC (if there is one). + +config CROS_EC + bool "Enable Chrome OS EC" + help + Enable access to the Chrome OS EC. This is a separate + microcontroller typically available on a SPI bus on Chromebooks. It + provides access to the keyboard, some internal storage and may + control access to the battery and main PMIC depending on the + device. You can use the 'crosec' command to access it. + +config CROS_EC_I2C + bool "Enable Chrome OS EC I2C driver" + depends on CROS_EC + help + Enable I2C access to the Chrome OS EC. This is used on older + ARM Chromebooks such as snow and spring before the standard bus + changed to SPI. The EC will accept commands across the I2C using + a special message protocol, and provide responses. + +config CROS_EC_LPC + bool "Enable Chrome OS EC LPC driver" + depends on CROS_EC + help + Enable I2C access to the Chrome OS EC. This is used on x86 + Chromebooks such as link and falco. The keyboard is provided + through a legacy port interface, so on x86 machines the main + function of the EC is power and thermal management. + +config CROS_EC_SPI + bool "Enable Chrome OS EC SPI driver" + depends on CROS_EC + help + Enable SPI access to the Chrome OS EC. This is used on newer + ARM Chromebooks such as pit, pi and nyan-big. The SPI interface + provides a faster and more robust interface than I2C but the bugs + are less interesting. + config DM_CROS_EC bool "Enable Driver Model for Chrome OS EC" depends on DM @@ -5,5 +51,5 @@ config DM_CROS_EC Enable driver model for the Chrome OS EC interface. This allows the cros_ec SPI driver to operate with CONFIG_DM_SPI but otherwise makes few changes. Since cros_ec also supports - I2C and LPC (which don't support driver model yet), a full + LPC (which doesn't support driver model yet), a full conversion is not yet possible. diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 9cef0b0..b1b8e1a 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -24,9 +24,6 @@ #define CONFIG_POWER_TPS65090
/* Enable keyboard */ -#define CONFIG_CROS_EC /* CROS_EC protocol */ -#define CONFIG_CROS_EC_KEYB /* CROS_EC keyboard input */ -#define CONFIG_CMD_CROS_EC #define CONFIG_KEYBOARD
#endif diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index f724164..f04f061 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -43,7 +43,6 @@ #endif
#define CONFIG_POWER_TPS65090_EC -#define CONFIG_CROS_EC_SPI /* Support CROS_EC over SPI */
#define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_EXYNOS diff --git a/include/configs/peach-pit.h b/include/configs/peach-pit.h index de12a9e..b5efbdc 100644 --- a/include/configs/peach-pit.h +++ b/include/configs/peach-pit.h @@ -43,7 +43,6 @@ #endif
#define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_EXYNOS diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 5c11650..febbfb6 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -141,9 +141,6 @@
#define CONFIG_BOOTARGS ""
-#define CONFIG_CROS_EC -#define CONFIG_CMD_CROS_EC -#define CONFIG_CROS_EC_SANDBOX #define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_BOARD_LATE_INIT
@@ -166,7 +163,6 @@ #define LCD_BPP LCD_COLOR16 #define CONFIG_LCD_BMP_RLE8
-#define CONFIG_CROS_EC_KEYB #define CONFIG_KEYBOARD
#define CONFIG_EXTRA_ENV_SETTINGS "stdin=serial,cros-ec-keyb\0" \ diff --git a/include/configs/snow.h b/include/configs/snow.h index ce6676e..fe802f2 100644 --- a/include/configs/snow.h +++ b/include/configs/snow.h @@ -20,9 +20,7 @@ #include <configs/exynos5-dt-common.h>
-#define CONFIG_CROS_EC_I2C /* Support CROS_EC over I2C */ #define CONFIG_POWER_TPS65090_I2C -#define CONFIG_DM_CROS_EC
#define CONFIG_BOARD_COMMON #define CONFIG_ARCH_EARLY_INIT_R
Make this option available in Kconfig and clean up the board that uses it. Note there is also an entry in exynos5-common.h but this affects multiple boards and should be dropped as part of the Samsung I2C migration to driver model.
configs/odroid_defconfig | 2 ++ drivers/i2c/Kconfig | 9 +++++++++ include/configs/exynos5-common.h | 2 ++ include/configs/odroid.h | 2 -- 4 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index a842837..816a3fa 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -3,3 +3,5 @@ CONFIG_ARCH_EXYNOS=y CONFIG_TARGET_ODROID=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" +CONFIG_DM_I2C=y +CONFIG_DM_I2C_COMPAT=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 2cc776c..692810d 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -13,6 +13,15 @@ config DM_I2C enabled together (it is not possible to use driver model for one and not the other).
+config DM_I2C_COMPAT + bool "Enable I2C compatibility layer" + depends on DM + help + Enable old-style I2C functions for compatibility with existing code. + This option can be enabled as a temporary measure to avoid needing + to convert all code for a board in a single commit. It should not + be enabled for any board in an official release. + config SYS_I2C_UNIPHIER bool "UniPhier I2C driver" depends on ARCH_UNIPHIER && DM_I2C diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 0ba39a2..3ab8d55 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -126,6 +126,8 @@ #define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE)
/* I2C */ + +/* TODO(sjg@chromium.org): Move these two options to Kconfig */ #define CONFIG_DM_I2C #define CONFIG_DM_I2C_COMPAT #define CONFIG_CMD_I2C diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 9d5dbdc..8b47537 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -177,8 +177,6 @@
/* I2C */ #define CONFIG_CMD_I2C -#define CONFIG_DM_I2C -#define CONFIG_DM_I2C_COMPAT #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 #define CONFIG_SYS_I2C_S3C24X0_SLAVE 0
Applied to u-boot-dm.
Use Kconfig instead of board config for DM and DM_THERMAL.
configs/mx6sxsabresd_defconfig | 2 ++ configs/mx6sxsabresd_spl_defconfig | 2 ++ include/configs/mx6sxsabresd.h | 2 -- 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 72e0f10..cc82322 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -3,3 +3,5 @@ CONFIG_ARM=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_MALLOC_F=y CONFIG_SYS_MALLOC_F_LEN=0x400 +CONFIG_DM=y +CONFIG_DM_THERMAL=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 6b36e06..901b01b 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -2,3 +2,5 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6SX" +S:CONFIG_ARM=y +S:CONFIG_TARGET_MX6SXSABRESD=y +CONFIG_DM=y +CONFIG_DM_THERMAL=y diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 1005b9e..a290129 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -227,8 +227,6 @@ #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif
-#define CONFIG_DM -#define CONFIG_DM_THERMAL #define CONFIG_IMX6_THERMAL
#define CONFIG_CMD_FUSE
