[U-Boot-Users] Issues with u-boot on PPC440EP Bamboo
Hi All,
I seem to have a Bamboo board that U-Boot hates. Using any version newer than 1.1.4, I get the following error on boot up:
U-Boot 1.2.0-gb23b5475-dirty (Aug 9 2007 - 09:49:20)
CPU: AMCC PowerPC 440EP Rev. B at 400 MHz (PLB=100, OPB=50, EBC=25 MHz) I2C boot EEPROM disabled Bootstrap Option D - Boot ROM Location EBC (16 bits) Internal PCI arbiter disabled, PCI async ext clock used 32 kB I-Cache 32 kB D-Cache Board: Bamboo - AMCC PPC440EP Evaluation Board I2C: ready DRAM: ERROR: DIMM 0, unsupported refresh rate/type. Replace the DIMM module with a supported DIMM. ERROR: Tcyc incorrect for DIMM in slot 0 ### ERROR ### Please RESET the board ###
This is a stock board from AMCC from a couple years ago. I haven't done anything with the DIMMs in it, so they are whatever came with the board. Both PIBS and U-Boot 1.1.4 report a DRAM size of 192 MB, so I'm assuming something with the SDRAM probing in newer versions of U-Boot is causing the error above.
Any ideas?
josh
On 8/9/07, Josh Boyer jwboyer@gmail.com wrote:
Hi All,
Nevermind. Stefan pointed me to his u-boot-4xx git repo and that has a fix for this issue in it.
All is well.
josh
Josh Boyer
