[U-Boot-Users] [PATCH 4/5 RESEND] Fix MSB check in Xilinx Spartan slave serial mode
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- common/spartan2.c | 2 +- common/spartan3.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spartan2.c b/common/spartan2.c index ef107bc..2f1ea2c 100644 --- a/common/spartan2.c +++ b/common/spartan2.c @@ -441,7 +441,7 @@ static int Spartan2_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) int ret_val = FPGA_FAIL; /* assume the worst */ Xilinx_Spartan2_Slave_Serial_fns *fn = desc->iface_fns; int i; - char val; + unsigned char val;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); diff --git a/common/spartan3.c b/common/spartan3.c index 56a172e..d329e70 100644 --- a/common/spartan3.c +++ b/common/spartan3.c @@ -446,7 +446,7 @@ static int Spartan3_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) int ret_val = FPGA_FAIL; /* assume the worst */ Xilinx_Spartan3_Slave_Serial_fns *fn = desc->iface_fns; int i; - char val; + unsigned char val;
Applied, thanks.
Matthias Fuchs
