[PATCH v2 1/2] cli: panic when failed to allocate memory for the history buffer
This commit simply modifies the history initialize function, replacing the return value by panic with reasons. The calling chains of hist_init don't have steps explicitly throwing or dealing with the ENOMEM error, and once the init fails, the whole system is died. Using panic here to provide error information instead.
Signed-off-by: Hanyuan Zhao hanyuan-z@qq.com --- This is v2 of patch series cli: allow users to disable history if unused at all --- Changes v1 -> v2: - Remove the lines surrounded by macro CONFIG_CMD_HISTORY, since if the user says N to CMD_HISTORY, the whole C file won't be compiled, i.e. the history is disabled already. - Remove default y to CMD_HISTORY. Here we should follow the original one. --- common/cli_readline.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cli_readline.c b/common/cli_readline.c index 2507be2295..99e7efdfe5 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -110,7 +110,7 @@ static int hist_init(void)
hist = calloc(HIST_MAX, HIST_SIZE + 1); if (!hist) - return -ENOMEM; + panic("%s: calloc: out of memory!\n", __func__);
for (i = 0; i < HIST_MAX; i++) hist_list[i] = hist + (i * (HIST_SIZE + 1));
Hanyuan Zhao
