[U-Boot] [PATCH] configs: am3517_evm: Use default OMAP3 memory settings
The AM3517 is mostly am omap3, so this partch removes the custom memory configurations and just uses the default common entries for omap3 and armv7.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 0463e42048..4e7e5209d4 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -12,16 +12,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* - * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM - * 64 bytes before this address should be set aside for u-boot.img's - * header. That is 0x800FFFC0--0x80100000 should not be used for any - * other needs. - */ - -#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 - #include <configs/ti_omap3_common.h>
#undef CONFIG_DM_I2C_COMPAT @@ -176,8 +166,6 @@
/* Physical Memory Map */ #define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) -#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 -#define CONFIG_SYS_INIT_RAM_SIZE 0x800
/* FLASH and environment organization */
@@ -203,10 +191,6 @@ #undef CONFIG_SPL_TEXT_BASE #define CONFIG_SPL_TEXT_BASE 0x40200000
-#undef CONFIG_SPL_BSS_START_ADDR -#define CONFIG_SPL_BSS_START_ADDR 0x80000000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ - #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
Adam Ford
