Pull request: u-boot-rockchip/for-next
Hi Tom,
This is for next; Please pull the updates for rockchip platform: - Add board: rk3588 Generic, Cool Pi CM5, Theobroma-Systems RK3588 Jaguar SBC, Toybrick TB-RK3588X; rk3588s Cool Pi 4B; rk3566 Pine64 PineTab2; - Add saradc v2 support; - Add PMIC RK806 support; - rk3588 disable force_jtag by default; - Migrate to use IO-domain driver for all boards; - Use common bss and stack addresses for rk33xx and rk35xx boards; - Other updates for driver, config and dts;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/19951
Thanks, - Kever
The following changes since commit 20a0ce574d6642e0dfe651467159039fac48cc4f:
Merge tag 'v2024.04-rc4' into next (2024-03-11 15:27:20 -0400)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20240315
for you to fetch changes up to 12bc1a5462a22f6dc5b91ecbf092cbaf94e66820:
rockchip: boot_mode: fix rockchip_dnl_key_pressed requiring ADC support (2024-03-14 18:20:04 +0800)
---------------------------------------------------------------- Andy Yan (2): board: rockchip: Add support for rk3588s based Cool Pi 4B board: rockchip: Add support for rk3588 based Cool Pi CM5 EVB
Ben Wolsieffer (1): rockchip: load env from boot MMC device
Chen-Yu Tsai (5): rockchip: rk3328: Read cpuid and generate MAC address from efuse rockchip: rk3399: Read cpuid and generate MAC address from efuse rockchip: rk3328: regenerate defconfigs rockchip: rk3399: regenerate defconfigs rockchip: nanopi-r4s: Drop ROCKCHIP_OTP
Chris Morgan (4): arm: dts: rockchip: rk3566: Remove unnecessary clks from rgxx3 board: rockchip: Add support for Powkiddy RGB10MAX3 configs: Remove unnecessary options from RGxx3 config board: rockchip: Add early ADC button detect for RGxx3
Elon Zhang (1): board: rockchip: add Rockchip Toybrick TB-RK3588X board
Jonas Karlman (42): rockchip: rk3328: Update default u-boot, spl-boot-order prop rockchip: rk3328-evb: Update defconfig rockchip: rk3328-rock64: Update defconfig rockchip: rk3328-roc-cc: Update defconfig rockchip: rk3328-rock-pi-e: Update defconfig rockchip: rk3328-nanopi-r2: Update defconfig rockchip: rk3328-orangepi-r1-plus: Update defconfig rockchip: rk3328: Fix loading FIT from SD-card when booting from eMMC gpio: rockchip: Use gpio alias id as gpio bank id rng: rockchip: Use same compatible as linux rockchip: rk3328: Sync device tree from linux v6.8-rc1 Revert "rockchip: Allow booting from SPI" rockchip: rk3328: Add support to build bootable SPI image rockchip: rk3328-rock64: Enable boot from SPI NOR flash rockchip: rk3328-orangepi-r1-plus: Enable boot from SPI NOR flash rockchip: spl: Enable caches to speed up checksum validation phy: rockchip-inno-usb2: Write to correct GRF phy: rockchip-inno-usb2: Limit changes made to regs rockchip: board: Add minimal generic RK3588S/RK3588 board board: rockchip: Add Pine64 PineTab2 rockchip: Add common default bss and stack addresses rockchip: Use common bss and stack addresses on RK3308 rockchip: Use common bss and stack addresses on RK3328 rockchip: Use common bss and stack addresses on RK3399 rockchip: Use common bss and stack addresses on RK356x rockchip: Use common bss and stack addresses on RK3588 rockchip: Update the default USB Product ID value rockchip: board: Prepare for use of DM_USB_GADGET with DWC2_OTG rockchip: board: Use a common USB Product ID for UMS rockchip: Migrate to use DM_USB_GADGET on RK3328 board: rockchip: rk3399: Add device tree files to MAINTAINERS board: rockchip: rk3399: Add myself as reviewer to MAINTAINERS board: rockchip: rk3399: Remove unused board_early_init_f functions board: rockchip: Add a common ROCK Pi 4 target rockchip: io-domain: Add support for RK3399 rockchip: pine64: rockpro64: Migrate to use IO-domain driver rockchip: pine64: pinebook-pro: Migrate to use IO-domain driver rockchip: pine64: pinephone-pro: Migrate to use IO-domain driver rockchip: vamrs: rock960: Migrate to use IO-domain driver rockchip: theobroma-systems: puma: Migrate to use IO-domain driver rockchip: google: gru: Migrate to use IO-domain driver rockchip: board: Move gpt_capsule_update_setup() call
Quentin Schulz (35): rockchip: avoid out-of-bounds when computing cpuid rockchip: add weak function symbol called at the beginning of misc_init_r rockchip: google: gru: migrate to rockchip_early_misc_init_r rockchip: pine64: pinebook-pro: migrate to rockchip_early_misc_init_r rockchip: pine64: pinephone-pro: migrate to rockchip_early_misc_init_r rockchip: pine64: rockpro64: migrate to rockchip_early_misc_init_r rockchip: theobroma-systems: puma: migrate to rockchip_early_misc_init_r rockchip: theobroma-systems: ringneck: migrate to rockchip_early_misc_init_r rockchip: merge misc.c into board.c rockchip: transform rockchip_capsule_update_board_setup into a weak function symbol rockchip: rk3588: disable force_jtag by default rockchip: rk3588: add constants for some register address spaces rockchip: migrate hardware.h inclusion into appropriate files rockchip: include asm/io.h directly in asm/arch-rockchip/hardware.h rockchip: rk3588: bind MMC controllers in U-Boot proper pre-reloc board: rockchip: add Theobroma-Systems RK3588 Jaguar SBC rockchip: puma-rk3399: MAINTAINERS: use glob for dtses rockchip: rk3399-puma: migrate README to doc/board in rST format rockchip: ringneck_px30: migrate README to doc/board in rST format rockchip: ringneck_px30: update website link rockchip: spi: rk_spi: do not write bytes when in read-only mode regulator: rk8xx: remove unused functions regulator: rk8xx: add indirection level for some ldo callbacks power: rk8xx: add support for RK806 pmic: reword help text rockchip: adc: rockchip-saradc: use union for preparing for v2 rockchip: adc: rockchip-saradc: factor out channel_data callback rockchip: adc: rockchip-saradc: factor out start_channel callback rockchip: adc: rockchip-saradc: factor out stop callback rockchip: adc: rockchip-saradc: add support for RK3588 power: pmic: rk8xx: fix duplicate prompt rockchip: jaguar-rk3588: enable SARADC and derivatives adc: add missing depends on ADC for controller drivers button: add missing ADC dependency for BUTTON_ADC rockchip: boot_mode: fix rockchip_dnl_key_pressed requiring ADC support
William Wu (1): regulator: rk8xx: fix SWITCH enable on RK809
Kconfig | 2 +- arch/arm/dts/Makefile | 10 +- arch/arm/dts/rk3328-evb-u-boot.dtsi | 4 + arch/arm/dts/rk3328-evb.dts | 1 + arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi | 6 - arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 24 +- arch/arm/dts/rk3328-nanopi-r2s.dts | 3 +- .../dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi | 34 +- arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts | 4 +- arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi | 34 +- arch/arm/dts/rk3328-orangepi-r1-plus.dts | 1 + arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 22 +- arch/arm/dts/rk3328-roc-cc.dts | 3 +- arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 18 +- arch/arm/dts/rk3328-rock-pi-e.dts | 55 ++ arch/arm/dts/rk3328-rock64-u-boot.dtsi | 32 +- arch/arm/dts/rk3328-rock64.dts | 1 + arch/arm/dts/rk3328-u-boot.dtsi | 106 ++- arch/arm/dts/rk3328.dtsi | 105 ++- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 31 - arch/arm/dts/rk3566-anbernic-rgxx3.dts | 16 +- arch/arm/dts/rk3566-pinetab2-u-boot.dtsi | 44 + arch/arm/dts/rk3566-pinetab2-v0.1-u-boot.dtsi | 3 + arch/arm/dts/rk3566-pinetab2-v0.1.dts | 28 + arch/arm/dts/rk3566-pinetab2-v2.0-u-boot.dtsi | 3 + arch/arm/dts/rk3566-pinetab2-v2.0.dts | 48 ++ arch/arm/dts/rk3566-pinetab2.dtsi | 943 +++++++++++++++++++++ arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi | 29 + arch/arm/dts/rk3588-coolpi-cm5-evb.dts | 216 +++++ arch/arm/dts/rk3588-coolpi-cm5.dtsi | 649 ++++++++++++++ arch/arm/dts/rk3588-generic-u-boot.dtsi | 3 + arch/arm/dts/rk3588-generic.dts | 44 + arch/arm/dts/rk3588-jaguar-u-boot.dtsi | 33 + arch/arm/dts/rk3588-jaguar.dts | 803 ++++++++++++++++++ arch/arm/dts/rk3588-toybrick-x0-u-boot.dtsi | 12 + arch/arm/dts/rk3588-toybrick-x0.dts | 688 +++++++++++++++ arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi | 29 + arch/arm/dts/rk3588s-coolpi-4b.dts | 812 ++++++++++++++++++ arch/arm/dts/rk3588s-u-boot.dtsi | 2 + arch/arm/include/asm/arch-rockchip/cru_rk3588.h | 2 + arch/arm/include/asm/arch-rockchip/grf_rk3588.h | 24 + arch/arm/include/asm/arch-rockchip/hardware.h | 2 + arch/arm/include/asm/arch-rockchip/ioc_rk3588.h | 6 + arch/arm/include/asm/arch-rockchip/misc.h | 14 - arch/arm/mach-rockchip/Kconfig | 85 ++ arch/arm/mach-rockchip/Makefile | 1 - arch/arm/mach-rockchip/board.c | 199 ++++- arch/arm/mach-rockchip/boot_mode.c | 4 + arch/arm/mach-rockchip/cpu-info.c | 1 - arch/arm/mach-rockchip/misc.c | 135 --- arch/arm/mach-rockchip/px30/px30.c | 1 - arch/arm/mach-rockchip/rk3036/rk3036.c | 1 - arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 1 - arch/arm/mach-rockchip/rk3066/rk3066.c | 2 +- arch/arm/mach-rockchip/rk3188/rk3188.c | 1 - arch/arm/mach-rockchip/rk322x/rk322x.c | 1 - arch/arm/mach-rockchip/rk3288/rk3288.c | 1 - arch/arm/mach-rockchip/rk3308/Kconfig | 7 +- arch/arm/mach-rockchip/rk3308/rk3308.c | 1 - arch/arm/mach-rockchip/rk3328/Kconfig | 11 +- arch/arm/mach-rockchip/rk3328/rk3328.c | 2 +- arch/arm/mach-rockchip/rk3368/rk3368.c | 1 - arch/arm/mach-rockchip/rk3399/Kconfig | 13 +- arch/arm/mach-rockchip/rk3399/rk3399.c | 1 - arch/arm/mach-rockchip/rk3568/Kconfig | 7 +- arch/arm/mach-rockchip/rk3568/rk3568.c | 1 - arch/arm/mach-rockchip/rk3588/Kconfig | 62 +- arch/arm/mach-rockchip/rk3588/rk3588.c | 16 +- arch/arm/mach-rockchip/rv1126/rv1126.c | 1 - arch/arm/mach-rockchip/spl-boot-order.c | 3 - arch/arm/mach-rockchip/spl.c | 16 +- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 72 ++ board/elgin/elgin_rv1108/elgin_rv1108.c | 1 - board/firefly/firefly-rk3308/roc_cc_rk3308.c | 1 - board/firefly/roc-pc-rk3399/MAINTAINERS | 1 + board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 22 +- board/google/gru/gru.c | 52 -- board/pine64/pinebook-pro-rk3399/MAINTAINERS | 6 +- board/pine64/pinebook-pro-rk3399/Makefile | 1 - .../pinebook-pro-rk3399/pinebook-pro-rk3399.c | 76 -- board/pine64/pinephone-pro-rk3399/MAINTAINERS | 5 +- board/pine64/pinephone-pro-rk3399/Makefile | 1 - .../pinephone-pro-rk3399/pinephone-pro-rk3399.c | 78 -- board/pine64/quartz64_rk3566/MAINTAINERS | 11 + board/pine64/rockpro64_rk3399/MAINTAINERS | 3 +- board/pine64/rockpro64_rk3399/Makefile | 7 - board/pine64/rockpro64_rk3399/rockpro64-rk3399.c | 56 -- board/radxa/rockpi4-rk3399/Kconfig | 15 + board/radxa/rockpi4-rk3399/MAINTAINERS | 22 + .../evb_rk3399 => radxa/rockpi4-rk3399}/Makefile | 2 +- .../rockpi4-rk3399/rockpi4-rk3399.c} | 33 +- board/rockchip/evb_rk3328/MAINTAINERS | 11 + board/rockchip/evb_rk3328/README | 70 -- board/rockchip/evb_rk3399/MAINTAINERS | 48 +- board/rockchip/evb_rk3588/MAINTAINERS | 22 + board/rockchip/evb_rv1108/evb_rv1108.c | 1 - board/rockchip/tinker_rk3288/tinker-rk3288.c | 12 - board/rockchip/toybrick_rk3588/Kconfig | 12 + board/rockchip/toybrick_rk3588/MAINTAINERS | 8 + board/rockchip/toybrick_rk3588/Makefile | 6 + board/rockchip/toybrick_rk3588/toybrick-rk3588.c | 39 + board/theobroma-systems/common/common.c | 30 - board/theobroma-systems/jaguar_rk3588/Kconfig | 16 + board/theobroma-systems/jaguar_rk3588/MAINTAINERS | 13 + board/theobroma-systems/jaguar_rk3588/Makefile | 10 + .../jaguar_rk3588/jaguar_rk3588.c | 53 ++ board/theobroma-systems/puma_rk3399/MAINTAINERS | 3 +- board/theobroma-systems/puma_rk3399/README | 90 +- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 42 +- board/theobroma-systems/ringneck_px30/MAINTAINERS | 3 +- board/theobroma-systems/ringneck_px30/README | 70 +- .../ringneck_px30/ringneck-px30.c | 20 +- board/vamrs/rock960_rk3399/MAINTAINERS | 2 + board/vamrs/rock960_rk3399/Makefile | 6 - board/vamrs/rock960_rk3399/rock960-rk3399.c | 28 - cmd/pmic.c | 4 +- configs/anbernic-rgxx3-rk3566_defconfig | 28 +- configs/bpi-r2-pro-rk3568_defconfig | 13 - configs/chromebook_bob_defconfig | 4 +- configs/chromebook_kevin_defconfig | 4 +- configs/coolpi-4b-rk3588s_defconfig | 100 +++ configs/coolpi-cm5-evb-rk3588_defconfig | 100 +++ configs/eaidk-610-rk3399_defconfig | 11 - configs/evb-rk3308_defconfig | 13 - configs/evb-rk3328_defconfig | 45 +- configs/evb-rk3399_defconfig | 11 - configs/evb-rk3568_defconfig | 13 - configs/evb-rk3588_defconfig | 13 - configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3399_defconfig | 13 - configs/generic-rk3568_defconfig | 13 - configs/generic-rk3588_defconfig | 53 ++ configs/jaguar-rk3588_defconfig | 109 +++ configs/khadas-edge-captain-rk3399_defconfig | 11 - configs/khadas-edge-rk3399_defconfig | 11 - configs/khadas-edge-v-rk3399_defconfig | 11 - configs/leez-rk3399_defconfig | 11 - configs/lubancat-2-rk3568_defconfig | 13 - configs/nanopc-t4-rk3399_defconfig | 11 - configs/nanopc-t6-rk3588_defconfig | 13 - configs/nanopi-m4-2gb-rk3399_defconfig | 11 - configs/nanopi-m4-rk3399_defconfig | 11 - configs/nanopi-m4b-rk3399_defconfig | 11 - configs/nanopi-neo4-rk3399_defconfig | 11 - configs/nanopi-r2c-plus-rk3328_defconfig | 43 +- configs/nanopi-r2c-rk3328_defconfig | 43 +- configs/nanopi-r2s-rk3328_defconfig | 43 +- configs/nanopi-r4s-rk3399_defconfig | 14 - configs/nanopi-r5c-rk3568_defconfig | 13 - configs/nanopi-r5s-rk3568_defconfig | 13 - configs/neu6a-io-rk3588_defconfig | 13 - configs/neu6b-io-rk3588_defconfig | 13 - configs/odroid-m1-rk3568_defconfig | 13 - configs/orangepi-5-plus-rk3588_defconfig | 13 - configs/orangepi-5-rk3588s_defconfig | 13 - configs/orangepi-r1-plus-lts-rk3328_defconfig | 52 +- configs/orangepi-r1-plus-rk3328_defconfig | 52 +- configs/orangepi-rk3399_defconfig | 11 - configs/pinebook-pro-rk3399_defconfig | 14 +- configs/pinephone-pro-rk3399_defconfig | 14 +- configs/pinetab2-rk3566_defconfig | 105 +++ configs/puma-rk3399_defconfig | 4 +- configs/quartz64-a-rk3566_defconfig | 13 - configs/quartz64-b-rk3566_defconfig | 13 - configs/quartzpro64-rk3588_defconfig | 13 - configs/radxa-cm3-io-rk3566_defconfig | 13 - configs/radxa-e25-rk3568_defconfig | 13 - configs/roc-cc-rk3308_defconfig | 13 - configs/roc-cc-rk3328_defconfig | 38 +- configs/roc-pc-mezzanine-rk3399_defconfig | 13 - configs/roc-pc-rk3399_defconfig | 13 - configs/rock-3a-rk3568_defconfig | 13 - configs/rock-4c-plus-rk3399_defconfig | 15 +- configs/rock-4se-rk3399_defconfig | 15 +- configs/rock-pi-4-rk3399_defconfig | 15 +- configs/rock-pi-4c-rk3399_defconfig | 15 +- configs/rock-pi-e-rk3328_defconfig | 42 +- configs/rock-pi-n10-rk3399pro_defconfig | 12 - configs/rock-pi-s-rk3308_defconfig | 13 - configs/rock5a-rk3588s_defconfig | 13 - configs/rock5b-rk3588_defconfig | 13 - configs/rock64-rk3328_defconfig | 47 +- configs/rock960-rk3399_defconfig | 13 +- configs/rockpro64-rk3399_defconfig | 14 +- configs/soquartz-blade-rk3566_defconfig | 13 - configs/soquartz-cm4-rk3566_defconfig | 13 - configs/soquartz-model-a-rk3566_defconfig | 13 - configs/toybrick-rk3588_defconfig | 68 ++ configs/turing-rk1-rk3588_defconfig | 13 - doc/board/anbernic/rgxx3.rst | 1 + doc/board/index.rst | 1 + doc/board/rockchip/rockchip.rst | 15 +- doc/board/theobroma-systems/index.rst | 11 + doc/board/theobroma-systems/jaguar_rk3588.rst | 100 +++ doc/board/theobroma-systems/puma_rk3399.rst | 126 +++ doc/board/theobroma-systems/ringneck_px30.rst | 95 +++ drivers/adc/Kconfig | 4 + drivers/adc/rockchip-saradc.c | 202 ++++- drivers/button/Kconfig | 1 + drivers/clk/rockchip/clk_pll.c | 1 - drivers/clk/rockchip/clk_px30.c | 1 - drivers/clk/rockchip/clk_rk3036.c | 1 - drivers/clk/rockchip/clk_rk3066.c | 1 - drivers/clk/rockchip/clk_rk3128.c | 1 - drivers/clk/rockchip/clk_rk3188.c | 1 - drivers/clk/rockchip/clk_rk322x.c | 1 - drivers/clk/rockchip/clk_rk3288.c | 1 - drivers/clk/rockchip/clk_rk3308.c | 1 - drivers/clk/rockchip/clk_rk3328.c | 1 - drivers/clk/rockchip/clk_rk3368.c | 1 - drivers/clk/rockchip/clk_rk3399.c | 1 - drivers/clk/rockchip/clk_rk3568.c | 1 - drivers/clk/rockchip/clk_rk3588.c | 1 - drivers/clk/rockchip/clk_rv1108.c | 1 - drivers/clk/rockchip/clk_rv1126.c | 1 - drivers/gpio/rk_gpio.c | 8 +- drivers/misc/rockchip-io-domain.c | 79 +- drivers/net/gmac_rockchip.c | 1 - drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 158 +--- drivers/power/pmic/Kconfig | 2 +- drivers/power/pmic/rk8xx.c | 91 ++ drivers/power/regulator/rk8xx.c | 595 ++++++++++++- drivers/ram/rockchip/dmc-rk3368.c | 2 +- drivers/ram/rockchip/sdram_px30.c | 1 - drivers/ram/rockchip/sdram_rk3066.c | 1 - drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 1 - drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 1 - drivers/ram/rockchip/sdram_rv1126.c | 1 - drivers/rng/rockchip_rng.c | 11 +- drivers/spi/rk_spi.c | 20 +- drivers/sysreset/sysreset_rockchip.c | 1 - drivers/usb/gadget/Kconfig | 15 +- drivers/video/rockchip/dw_mipi_dsi_rockchip.c | 1 - drivers/video/rockchip/rk3288_hdmi.c | 1 - drivers/video/rockchip/rk3288_mipi.c | 1 - drivers/video/rockchip/rk3288_vop.c | 1 - drivers/video/rockchip/rk3399_hdmi.c | 1 - drivers/video/rockchip/rk3399_mipi.c | 1 - drivers/video/rockchip/rk3399_vop.c | 1 - drivers/video/rockchip/rk_edp.c | 1 - drivers/video/rockchip/rk_hdmi.c | 1 - drivers/video/rockchip/rk_lvds.c | 1 - include/configs/jaguar_rk3588.h | 15 + include/configs/rk3036_common.h | 1 - include/configs/rk3066_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 16 - include/configs/rockpi4-rk3399.h | 32 + include/configs/rv1108_common.h | 1 - include/configs/toybrick_rk3588.h | 15 + include/power/rk8xx_pmic.h | 21 +- 257 files changed, 7611 insertions(+), 2336 deletions(-) create mode 100644 arch/arm/dts/rk3566-pinetab2-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-pinetab2-v0.1-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-pinetab2-v0.1.dts create mode 100644 arch/arm/dts/rk3566-pinetab2-v2.0-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-pinetab2-v2.0.dts create mode 100644 arch/arm/dts/rk3566-pinetab2.dtsi create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-evb.dts create mode 100644 arch/arm/dts/rk3588-coolpi-cm5.dtsi create mode 100644 arch/arm/dts/rk3588-generic-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-generic.dts create mode 100644 arch/arm/dts/rk3588-jaguar-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-jaguar.dts create mode 100644 arch/arm/dts/rk3588-toybrick-x0-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-toybrick-x0.dts create mode 100644 arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-coolpi-4b.dts delete mode 100644 arch/arm/include/asm/arch-rockchip/misc.h delete mode 100644 arch/arm/mach-rockchip/misc.c delete mode 100644 board/pine64/pinebook-pro-rk3399/Makefile delete mode 100644 board/pine64/pinebook-pro-rk3399/pinebook-pro-rk3399.c delete mode 100644 board/pine64/pinephone-pro-rk3399/Makefile delete mode 100644 board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c delete mode 100644 board/pine64/rockpro64_rk3399/Makefile delete mode 100644 board/pine64/rockpro64_rk3399/rockpro64-rk3399.c create mode 100644 board/radxa/rockpi4-rk3399/Kconfig create mode 100644 board/radxa/rockpi4-rk3399/MAINTAINERS rename board/{rockchip/evb_rk3399 => radxa/rockpi4-rk3399}/Makefile (79%) rename board/{rockchip/evb_rk3399/evb-rk3399.c => radxa/rockpi4-rk3399/rockpi4-rk3399.c} (65%) delete mode 100644 board/rockchip/evb_rk3328/README create mode 100644 board/rockchip/toybrick_rk3588/Kconfig create mode 100644 board/rockchip/toybrick_rk3588/MAINTAINERS create mode 100644 board/rockchip/toybrick_rk3588/Makefile create mode 100644 board/rockchip/toybrick_rk3588/toybrick-rk3588.c create mode 100644 board/theobroma-systems/jaguar_rk3588/Kconfig create mode 100644 board/theobroma-systems/jaguar_rk3588/MAINTAINERS create mode 100644 board/theobroma-systems/jaguar_rk3588/Makefile create mode 100644 board/theobroma-systems/jaguar_rk3588/jaguar_rk3588.c delete mode 100644 board/vamrs/rock960_rk3399/Makefile delete mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/coolpi-4b-rk3588s_defconfig create mode 100644 configs/coolpi-cm5-evb-rk3588_defconfig create mode 100644 configs/generic-rk3588_defconfig create mode 100644 configs/jaguar-rk3588_defconfig create mode 100644 configs/pinetab2-rk3566_defconfig create mode 100644 configs/toybrick-rk3588_defconfig create mode 100644 doc/board/theobroma-systems/index.rst create mode 100644 doc/board/theobroma-systems/jaguar_rk3588.rst create mode 100644 doc/board/theobroma-systems/puma_rk3399.rst create mode 100644 doc/board/theobroma-systems/ringneck_px30.rst create mode 100644 include/configs/jaguar_rk3588.h create mode 100644 include/configs/rockpi4-rk3399.h create mode 100644 include/configs/toybrick_rk3588.h
On Fri, Mar 15, 2024 at 08:57:34AM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
