[U-Boot] [PATCH] mtd: nand: denali_spl: Program spare area skip bytes
This register is not configured on Altera SoCFPGA incarnation of the Denali NAND flash block. Unless this register is initialized, the IP will return corrupted data upon any read attempt from the NAND.
Initialize the register to the same value is the one used in full U-Boot to fix this issue.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Scott Wood scottwood@freescale.com --- drivers/mtd/nand/denali_spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/nand/denali_spl.c b/drivers/mtd/nand/denali_spl.c index 1587413..8c707d2 100644 --- a/drivers/mtd/nand/denali_spl.c +++ b/drivers/mtd/nand/denali_spl.c @@ -168,6 +168,10 @@ void nand_init(void) page_size = readl(denali_flash_reg + DEVICE_MAIN_AREA_SIZE); oob_size = readl(denali_flash_reg + DEVICE_SPARE_AREA_SIZE); pages_per_block = readl(denali_flash_reg + PAGES_PER_BLOCK); + + /* Spare area skip bytes is NOT programmed by hardware %^( */ + writel(CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES, + denali_flash_reg + SPARE_AREA_SKIP_BYTES); }
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst)
Hi Marek,
2015-12-20 11:58 GMT+09:00 Marek Vasut marex@denx.de:
As for UniPhier SoCs, this register has been set to 8 by the boot ROM when booting from a NAND device.
So, my SoCs work with/without this patch because CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES is defined 8 in my defconfigs.
Anyway, I am OK with this patch.
What is "%^(" ? Do you need this comment?
Otherwise,
Acked-by: Masahiro Yamada yamada.masahiro@socionext.com
On Monday, December 21, 2015 at 09:29:27 AM, Masahiro Yamada wrote:
Hi Marek,
Hi Masahiro!
Mine left the register at 0x0 %^(
It clarifies why the register needs to be inited, that's all %^)
Otherwise,
Best regards, Marek Vasut
Masahiro Yamada
