[PATCH] doc: build: update description of build dependencies for Alpine Linux
--- doc/build/gcc.rst | 24 ++++++++++++++++++++++-- 1 file changed, 22 insertions(+), 2 deletions(-)
diff --git a/doc/build/gcc.rst b/doc/build/gcc.rst index a0650a51db..e73f24a304 100644 --- a/doc/build/gcc.rst +++ b/doc/build/gcc.rst @@ -60,8 +60,28 @@ For building U-Boot on Alpine Linux at least the following packages are needed:
.. code-block:: bash
- apk add alpine-sdk bc bison dtc flex linux-headers ncurses-dev \ - openssl-dev perl python3 py3-setuptools python3-dev sdl2-dev + apk add alpine-sdk bc bison dtc flex gnutls-dev linux-headers \ + openssl-dev py3-elftools py3-setuptools python3-dev swig util-linux-dev + +Dependeing on the build target further packages may be needed + +For build sandbox with lcd + +.. code-block:: bash + + apk add sdl2-dev + +For build riscv64 targets + +.. code-block:: bash + + apk add opensbi + +For build some arm64 targets + +.. code-block:: bash + + apk add arm-trusted-firmware
Prerequisites -------------
Milan P. Stanić
