[U-Boot] [RFC v2 PATCH] get_maintainer: fix perl 5.22/5.24 deprecated/incompatible "\C" use
from linux commit ce8155f7a3d5:
Perl 5.22 emits a deprecated message when "\C" is used in a regex. Perl 5.24 will disallow it altogether.
Fix it by using [A-Z] instead of \C.
From linux adapted to U-Boot by:
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Andre Przywara andre.przywara@arm.com --- running get_maintainer.pl drops warnings with PERL > 5.22 . In linux this is fixed though above commit.
But ... I get differences when running the python script: import os import subprocess
root_dir = '.'
for directory, subdirectories, files in os.walk(root_dir): for file in files: tmp=os.path.join(directory, file) print(tmp) ret = subprocess.call(["scripts/get_maintainer.pl", "-f", tmp])
and comparing the output from it, based on the original u-boot code and the code with this patch ...
I have no PERL experience, so made this patch as RFC, maybe someone with better PERL skills can fix it correct.
Changes in v2: - add Reviewed-by from Andre Przywara - remove wrong backslash before [A-Z] - remove change in MAINTAINERS as no longer needed
scripts/get_maintainer.pl | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/scripts/get_maintainer.pl b/scripts/get_maintainer.pl index 4707dfd..83a4e5b 100755 --- a/scripts/get_maintainer.pl +++ b/scripts/get_maintainer.pl @@ -298,7 +298,7 @@ sub read_maintainers { while (<$maint>) { my $line = $_;
- if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2;
@@ -533,7 +533,7 @@ sub range_is_maintained {
for (my $i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'S') { @@ -551,7 +551,7 @@ sub range_has_maintainer {
for (my $i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'M') { @@ -600,7 +600,7 @@ sub get_maintainers {
for ($i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'X') { @@ -615,7 +615,7 @@ sub get_maintainers { if (!$exclude) { for ($i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'F') { @@ -917,7 +917,7 @@ sub find_first_section {
while ($index < @typevalue) { my $tv = $typevalue[$index]; - if (($tv =~ m/^(\C):\s*(.*)/)) { + if (($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++; @@ -931,7 +931,7 @@ sub find_starting_index {
while ($index > 0) { my $tv = $typevalue[$index]; - if (!($tv =~ m/^(\C):\s*(.*)/)) { + if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index--; @@ -945,7 +945,7 @@ sub find_ending_index {
while ($index < @typevalue) { my $tv = $typevalue[$index]; - if (!($tv =~ m/^(\C):\s*(.*)/)) { + if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++; @@ -971,7 +971,7 @@ sub get_maintainer_role {
for ($i = $start + 1; $i < $end; $i++) { my $tv = $typevalue[$i]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "S") { @@ -1030,7 +1030,7 @@ sub add_categories {
for ($i = $start + 1; $i < $end; $i++) { my $tv = $typevalue[$i]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "L") { @@ -1072,7 +1072,7 @@ sub add_categories { if ($name eq "") { if ($i > 0) { my $tv = $typevalue[$i - 1]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { if ($1 eq "P") { $name = $2; $pvalue = format_email($name, $address, $email_usename);
Dear Heiko,
ACK.
So the Python script ...
...basically does the equivalent of running
scripts/get_maintainer.pl -f <directory>/<file>
on the command line.
What exactly do you mean by "I get differences"? What are the used values for "directory" and "file" in your test case, and which exact differences do you get?
Hello Wolfgang,
Am 07.01.2016 um 17:13 schrieb Wolfgang Denk:
Dear Heiko,
ACK.
Yes... the script does this just for *all* files in the u-boot tree.
I do exactly (should have written this to the commit text ... sorry):
- python2.7 check_get.py > ../gnlmpf_org - Apply this patch (with "patch" not with "git am") to the u-boot tree - python2.7 check_get.py > ../gnlmpf_new - diff -purN ../gnlmpf_org ../gnlmpf_new > ../gnlmpf
So I expect only a difference in the "scripts/get_maintainer.pl" file, as no other file has changed, also no change in the git files... First difference:
--- ../gnlmpf_org 2016-01-07 13:39:39.059124449 +0100 +++ ../gnlmpf_new 2016-01-07 13:41:57.937391203 +0100 @@ -1,12 +1,11 @@ -Masahiro Yamada yamada.masahiro@socionext.com (commit_signer:1/1=100%) Jagan Teki jteki@openedev.com (commit_signer:1/1=100%,authored:1/1=100%) +Masahiro Yamada yamada.masahiro@socionext.com (commit_signer:1/1=100%) u-boot@lists.denx.de (open list) Masahiro Yamada yamada.masahiro@socionext.com (commit_signer:2/4=50%,authored:2/4=50%) +Stefan Roese sr@denx.de (commit_signer:1/4=25%) Joe Hershberger joe.hershberger@ni.com (commit_signer:1/4=25%,authored:1/4=25%) Marek Vasut marex@denx.de (commit_signer:1/4=25%) -Stefan Roese sr@denx.de (commit_signer:1/4=25%) -York Sun yorksun@freescale.com (commit_signer:1/4=25%) -Simon Glass sjg@chromium.org (authored:1/4=25%) +Simon Glass sjg@chromium.org (commit_signer:1/4=25%,authored:1/4=25%) u-boot@lists.denx.de (open list) Masahiro Yamada yamada.masahiro@socionext.com (commit_signer:14/24=58%,authored:14/24=58%) Stefan Roese sr@denx.de (commit_signer:4/24=17%)
The "Masahiro" and the "Simon" diff are only a diff in the order, but "York Sun" is missing complete ...
bye, Heiko
Heiko Schocher
