[PATCH] imx8m: ddr_init: Move ddr_init() messages to debug level
Currently inside ddr_init() there is a mix of printf() and debug() level messages.
Since this type of information is useful for debug purposes, convert all of them to debug level for consistency.
Signed-off-by: Fabio Estevam festevam@gmail.com --- drivers/ddr/imx/imx8m/ddr_init.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index d6e915c9b9..21af66e4e7 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -24,7 +24,7 @@ void ddr_init(struct dram_timing_info *dram_timing) { unsigned int tmp, initial_drate, target_freq;
- printf("DDRINFO: start DRAM init\n"); + debug("DDRINFO: start DRAM init\n");
/* Step1: Follow the power up procedure */ if (is_imx8mq()) { @@ -109,7 +109,7 @@ void ddr_init(struct dram_timing_info *dram_timing) tmp = reg32_read(DDRPHY_CalBusy(0)); } while ((tmp & 0x1));
- printf("DDRINFO:ddrphy calibration done\n"); + debug("DDRINFO:ddrphy calibration done\n");
/* Step15: Set SWCTL.sw_done to 0 */ reg32_write(DDRC_SWCTL(0), 0x00000000); @@ -161,7 +161,7 @@ void ddr_init(struct dram_timing_info *dram_timing)
/* enable port 0 */ reg32_write(DDRC_PCTRL_0(0), 0x00000001); - printf("DDRINFO: ddrmix config done\n"); + debug("DDRINFO: ddrmix config done\n");
/* save the dram timing config into memory */ dram_config_save(dram_timing, CONFIG_SAVED_DRAM_TIMING_BASE);
Subject: [PATCH] imx8m: ddr_init: Move ddr_init() messages to debug level
Reviewed-by: Peng Fan peng.fan@nxp.com
2.17.1
Currently inside ddr_init() there is a mix of printf() and debug() level messages. Since this type of information is useful for debug purposes, convert all of them to debug level for consistency. Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
sbabic@denx.de
