[U-Boot] [PATCH v3] arm926ejs: add NXP LPC32x0 cpu series support
This change adds initial support for NXP LPC32x0 SoC series.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- Changes from v2 to v3: * checkpatch.pl reports zero errors and warnings
Changes from v1 to v2: * BIT(n) and SBF(s, v) macro are not used anymore * removed NS16550 and 14-clock UART definitions from uart.h * added devices.c file, which contains standard UART preinitialization routine * added get_serial_clock() function, it returns actual frequency of UART clock * __udelay() realization is simplified, no need of interrupt handling
arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 45 ++++++++ arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c | 101 ++++++++++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 46 ++++++++ arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 47 +++++++++ arch/arm/cpu/arm926ejs/lpc32xx/timer.c | 94 +++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/clk.h | 155 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/config.h | 50 +++++++++ arch/arm/include/asm/arch-lpc32xx/cpu.h | 62 +++++++++++ arch/arm/include/asm/arch-lpc32xx/timer.h | 74 +++++++++++++ arch/arm/include/asm/arch-lpc32xx/uart.h | 54 ++++++++++ arch/arm/include/asm/arch-lpc32xx/wdt.h | 51 +++++++++ 11 files changed, 779 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/devices.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/timer.c create mode 100644 arch/arm/include/asm/arch-lpc32xx/clk.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/config.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/cpu.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/timer.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/uart.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/wdt.h
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile new file mode 100644 index 0000000..29b4dc8 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS = cpu.o clkpwr.o devices.o timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c b/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c new file mode 100644 index 0000000..adae8b0 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <div64.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/io.h> + +static struct clk_t *clk = (struct clk_t *)CLK_PM_BASE; + +unsigned int get_sys_clk_rate(void) +{ + if (readl(&clk->sysclk_ctrl) & CLK_SYSCLK_PLL397) + return RTC_CLK_FREQUENCY * 397; + else + return OSC_CLK_FREQUENCY; +} + +unsigned int get_hclk_pll_rate(void) +{ + unsigned long long fin, fref, fcco, fout; + u32 val, m_div, n_div, p_div; + + /* + * Valid frequency ranges: + * 1 * 10^6 <= Fin <= 20 * 10^6 + * 1 * 10^6 <= Fref <= 27 * 10^6 + * 156 * 10^6 <= Fcco <= 320 * 10^6 + * + * Due to these frequency constraints and divider values it could be + * shown that 32bit values used here for operations are not overflowed + */ + + fref = fin = get_sys_clk_rate(); + if (fin > 20000000ULL || fin < 1000000ULL) + return 0; + + val = readl(&clk->hclkpll_ctrl); + m_div = ((val & CLK_HCLK_PLL_FEEDBACK_DIV_MASK) >> 1) + 1; + n_div = ((val & CLK_HCLK_PLL_PREDIV_MASK) >> 9) + 1; + if (val & CLK_HCLK_PLL_DIRECT) + p_div = 0; + else + p_div = ((val & CLK_HCLK_PLL_POSTDIV_MASK) >> 11) + 1; + p_div = 1 << p_div; + + if (val & CLK_HCLK_PLL_BYPASS) { + do_div(fin, p_div); + return fin; + } + + do_div(fref, n_div); + if (fref > 27000000ULL || fref < 1000000ULL) + return 0; + + if (val & CLK_HCLK_PLL_FEEDBACK) { + fout = fcco = fref * m_div; + do_div(fout, p_div); + } else { + fout = fref * m_div; + fcco = fout * p_div; + } + + if (fcco > 320000000ULL || fcco < 156000000ULL) + return 0; + + return fout; +} + +unsigned int get_periph_clk_rate(void) +{ + u32 val; + + if (!(readl(&clk->pwr_ctrl) & CLK_PWR_NORMAL_RUN)) + return get_sys_clk_rate(); + + val = (readl(&clk->hclkdiv_ctrl) & CLK_HCLK_PERIPH_DIV_MASK) >> 2; + return get_hclk_pll_rate() / (val + 1); +} + +int get_serial_clock(void) +{ + return get_periph_clk_rate(); +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c new file mode 100644 index 0000000..39684d7 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/wdt.h> +#include <asm/io.h> + +static struct clk_t *clk = (struct clk_t *)CLK_PM_BASE; +static struct wdtim_t *wdt = (struct wdtim_t *)WDT_BASE; + +void reset_cpu(ulong addr) +{ + u32 val; + + /* Enable watchdog clock */ + val = readl(&clk->timclk_ctrl); + writel(val | CLKPWR_TIMCLK_WATCHDOG, &clk->timclk_ctrl); + + /* Reset pulse length is 13005 PERIPH_CLKs */ + writel(13000, &wdt->pulse); + + /* Force WDOG_RESET2 and RESOUT_N signal active */ + writel(WDTIM_MCTRL_RESFRC2 | WDTIM_MCTRL_RESFRC1 | WDTIM_MCTRL_M_RES2, + &wdt->mctrl); + + while (1) + /* NOP */; +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c new file mode 100644 index 0000000..5616e53 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/uart.h> +#include <asm/io.h> + +static struct clk_t *clk = (struct clk_t *)CLK_PM_BASE; +static struct uart_ctrl_t *uart_control = (struct uart_ctrl_t *)UART_CTRL_BASE; + +void lpc32xx_uart_init(unsigned int uart_id) +{ + u32 val; + + if (uart_id < 3 || uart_id > 6) + return; + + /* Enable UART system clock */ + val = readl(&clk->uartclk_ctrl); + writel(val | CLKPWR_UART(uart_id), &clk->uartclk_ctrl); + + /* Place UART in autoclock mode */ + val = readl(&uart_control->clkmode) & ~UART_CLKMODE_MASK(uart_id); + writel(val | UART_CLKMODE_AUTO(uart_id), &uart_control->clkmode); + + /* Bypass pre-divider of UART clock */ + val = CLKPWR_UART_X_DIV(1) | CLKPWR_UART_Y_DIV(1); + writel(val, &clk->u3clk + (uart_id - 3)); +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/timer.c b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c new file mode 100644 index 0000000..725c036 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c @@ -0,0 +1,94 @@ +/* + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/timer.h> +#include <asm/io.h> + +static struct timer_t *timer0 = (struct timer_t *)TIMER0_BASE; +static struct timer_t *timer1 = (struct timer_t *)TIMER1_BASE; +static struct clk_t *clk = (struct clk_t *)CLK_PM_BASE; + +static void lpc32xx_timer_clock(u32 bit, int enable) +{ + u32 val = readl(&clk->timclk_ctrl1); + + if (enable) + val |= bit; + else + val &= ~bit; + + writel(val, &clk->timclk_ctrl1); +} + +static void lpc32xx_timer_reset(struct timer_t *timer, u32 freq) +{ + writel(TIMER_TCR_COUNTER_RESET, &timer->tcr); + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); + writel(0, &timer->tc); + writel(0, &timer->pr); + + /* Count mode is every rising PCLK edge */ + writel(TIMER_CTCR_MODE_TIMER, &timer->ctcr); + + /* Set prescale counter value */ + writel((get_periph_clk_rate() / freq) - 1, &timer->pr); +} + +static void lpc32xx_timer_count(struct timer_t *timer, int enable) +{ + if (enable) + writel(TIMER_TCR_COUNTER_ENABLE, &timer->tcr); + else + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); +} + +int timer_init(void) +{ + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER0, 1); + lpc32xx_timer_reset(timer0, CONFIG_SYS_HZ); + lpc32xx_timer_count(timer0, 1); + + return 0; +} + +ulong get_timer(ulong base) +{ + return readl(&timer0->tc) - base; +} + +void __udelay(unsigned long usec) +{ + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 1); + lpc32xx_timer_reset(timer1, CONFIG_SYS_HZ * 1000); + lpc32xx_timer_count(timer1, 1); + + while (readl(&timer1->tc) < usec) + /* NOP */; + + lpc32xx_timer_count(timer1, 0); + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 0); +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/include/asm/arch-lpc32xx/clk.h b/arch/arm/include/asm/arch-lpc32xx/clk.h new file mode 100644 index 0000000..d42f06f --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/clk.h @@ -0,0 +1,155 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#ifndef _LPC32XX_CLK_H +#define _LPC32XX_CLK_H + +#include <asm/types.h> + +#define OSC_CLK_FREQUENCY 13000000 +#define RTC_CLK_FREQUENCY 32768 + +/* Clocking and Power Control Registers */ +struct clk_t { + u32 reserved0[5]; + u32 boot_map; /* Boot Map Control Register */ + u32 p0_intr_er; /* Port 0/1 Start and interrupt Enable Register */ + u32 usbdiv_ctrl; /* USB Clock Pre-Divide Register */ + /* Internal Start Signal Sources Registers */ + u32 start_er_int; /* Start Enable Register */ + u32 start_rsr_int; /* Start Raw Status Register */ + u32 start_sr_int; /* Start Status Register */ + u32 start_apr_int; /* Start Activation Polarity Register */ + /* Device Pin Start Signal Sources Registers */ + u32 start_er_pin; /* Start Enable Register */ + u32 start_rsr_pin; /* Start Raw Status Register */ + u32 start_sr_pin; /* Start Status Register */ + u32 start_apr_pin; /* Start Activation Polarity Register */ + /* Clock Control Registers */ + u32 hclkdiv_ctrl; /* HCLK Divider Control Register */ + u32 pwr_ctrl; /* Power Control Register */ + u32 pll397_ctrl; /* PLL397 Control Register */ + u32 osc_ctrl; /* Main Oscillator Control Register */ + u32 sysclk_ctrl; /* SYSCLK Control Register */ + u32 lcdclk_ctrl; /* LCD Clock Control Register */ + u32 hclkpll_ctrl; /* HCLK PLL Control Register */ + u32 reserved1; + u32 adclk_ctrl1; /* ADC Clock Control1 Register */ + u32 usb_ctrl; /* USB Control Register */ + u32 sdramclk_ctrl; /* SDRAM Clock Control Register */ + u32 ddr_lap_nom; /* DDR Calibration Nominal Value */ + u32 ddr_lap_count; /* DDR Calibration Measured Value */ + u32 ddr_cal_delay; /* DDR Calibration Delay Value */ + u32 ssp_ctrl; /* SSP Control Register */ + u32 i2s_ctrl; /* I2S Clock Control Register */ + u32 ms_ctrl; /* Memory Card Control Register */ + u32 reserved2[3]; + u32 macclk_ctrl; /* Ethernet MAC Clock Control Register */ + u32 reserved3[4]; + u32 test_clk; /* Test Clock Selection Register */ + u32 sw_int; /* Software Interrupt Register */ + u32 i2cclk_ctrl; /* I2C Clock Control Register */ + u32 keyclk_ctrl; /* Keyboard Scan Clock Control Register */ + u32 adclk_ctrl; /* ADC Clock Control Register */ + u32 pwmclk_ctrl; /* PWM Clock Control Register */ + u32 timclk_ctrl; /* Timer Clock Control Register */ + u32 timclk_ctrl1; /* Timer Clock Control1 and MCPWM Register */ + u32 spi_ctrl; /* SPI Control Register */ + u32 flashclk_ctrl; /* NAND Flash Clock Control Register */ + u32 reserved4; + u32 u3clk; /* UART 3 Clock Control Register */ + u32 u4clk; /* UART 4 Clock Control Register */ + u32 u5clk; /* UART 5 Clock Control Register */ + u32 u6clk; /* UART 6 Clock Control Register */ + u32 irdaclk; /* IrDA Clock Control Register */ + u32 uartclk_ctrl; /* UART Clock Control Register */ + u32 dmaclk_ctrl; /* DMA Clock Control Register */ + u32 autoclk_ctrl; /* Autoclock Control Register */ +}; + +/* HCLK Divider Control Register bits */ +#define CLK_HCLK_DDRAM_HALF (0x2 << 7) +#define CLK_HCLK_DDRAM_NOMINAL (0x1 << 7) +#define CLK_HCLK_DDRAM_STOPPED (0x0 << 7) +#define CLK_HCLK_PERIPH_DIV_MASK (0x1F << 2) +#define CLK_HCLK_PERIPH_DIV(n) (((n - 1) & 0x1F) << 2) +#define CLK_HCLK_ARM_PLL_DIV_4 (0x2 << 0) +#define CLK_HCLK_ARM_PLL_DIV_2 (0x1 << 0) +#define CLK_HCLK_ARM_PLL_DIV_1 (0x0 << 0) + +/* Power Control Register bits */ +#define CLK_PWR_HCLK_RUN_PERIPH (1 << 10) +#define CLK_PWR_EMC_SREFREQ (1 << 9) +#define CLK_PWR_EMC_SREFREQ_UPDATE (1 << 8) +#define CLK_PWR_SDRAM_SREFREQ (1 << 7) +#define CLK_PWR_HIGHCORE_LEVEL (1 << 5) +#define CLK_PWR_SYSCLKEN_LEVEL (1 << 4) +#define CLK_PWR_SYSCLKEN_CTRL (1 << 3) +#define CLK_PWR_NORMAL_RUN (1 << 2) +#define CLK_PWR_HIGHCORE_CTRL (1 << 1) +#define CLK_PWR_STOP_MODE (1 << 0) + +/* SYSCLK Control Register bits */ +#define CLK_SYSCLK_PLL397 (1 << 1) +#define CLK_SYSCLK_MUX (1 << 0) + +/* HCLK PLL Control Register bits */ +#define CLK_HCLK_PLL_OPERATING (1 << 16) +#define CLK_HCLK_PLL_BYPASS (1 << 15) +#define CLK_HCLK_PLL_DIRECT (1 << 14) +#define CLK_HCLK_PLL_FEEDBACK (1 << 13) +#define CLK_HCLK_PLL_POSTDIV_MASK (0x3 << 11) +#define CLK_HCLK_PLL_POSTDIV_16 (0x3 << 11) +#define CLK_HCLK_PLL_POSTDIV_8 (0x2 << 11) +#define CLK_HCLK_PLL_POSTDIV_4 (0x1 << 11) +#define CLK_HCLK_PLL_POSTDIV_2 (0x0 << 11) +#define CLK_HCLK_PLL_PREDIV_MASK (0x3 << 9) +#define CLK_HCLK_PLL_PREDIV_4 (0x3 << 9) +#define CLK_HCLK_PLL_PREDIV_3 (0x2 << 9) +#define CLK_HCLK_PLL_PREDIV_2 (0x1 << 9) +#define CLK_HCLK_PLL_PREDIV_1 (0x0 << 9) +#define CLK_HCLK_PLL_FEEDBACK_DIV_MASK (0xFF << 1) +#define CLK_HCLK_PLL_FEEDBACK_DIV(n) (((n - 1) & 0xFF) << 1) +#define CLK_HCLK_PLL_LOCKED (1 << 0) + +/* Timer Clock Control1 Register bits */ +#define CLKPWR_TIMCLK_MOTOR (1 << 5) +#define CLKPWR_TIMCLK_TIMER3 (1 << 5) +#define CLKPWR_TIMCLK_TIMER2 (1 << 4) +#define CLKPWR_TIMCLK_TIMER1 (1 << 3) +#define CLKPWR_TIMCLK_TIMER0 (1 << 2) +#define CLKPWR_TIMCLK_TIMER5 (1 << 1) +#define CLKPWR_TIMCLK_TIMER4 (1 << 0) + +/* Timer Clock Control Register bits */ +#define CLKPWR_TIMCLK_HSTIMER (1 << 1) +#define CLKPWR_TIMCLK_WATCHDOG (1 << 0) + +/* UART Clock Control Register bits */ +#define CLKPWR_UART(n) (1 << ((n) - 3)) + +/* UARTn Clock Select Registers bits */ +#define CLKPWR_UART_HCLK (1 << 16) +#define CLKPWR_UART_X_DIV(n) (((n) & 0xFF) << 8) +#define CLKPWR_UART_Y_DIV(n) (((n) & 0xFF) << 0) + +unsigned int get_sys_clk_rate(void); +unsigned int get_hclk_pll_rate(void); +unsigned int get_periph_clk_rate(void); + +#endif /* _LPC32XX_CLK_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h new file mode 100644 index 0000000..2d46673 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -0,0 +1,50 @@ +/* + * Common definitions for LPC32XX board configurations + * + * (C) Copyright 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_CONFIG_H +#define _LPC32XX_CONFIG_H + +/* Basic CPU architecture */ +#define CONFIG_ARM926EJS 1 + +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +/* 1KHz clock tick */ +#define CONFIG_SYS_HZ 1000 + +/* + * UART configuration + */ +#if defined(CONFIG_SYS_NS16550_SERIAL) +#define CONFIG_SYS_NS16550 + +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_CLK get_serial_clock() + +#define CONFIG_SYS_NS16550_COM1 UART3_BASE +#define CONFIG_SYS_NS16550_COM2 UART4_BASE +#define CONFIG_SYS_NS16550_COM3 UART5_BASE +#define CONFIG_SYS_NS16550_COM4 UART6_BASE + +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#endif + +#endif /* _LPC32XX_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/cpu.h b/arch/arm/include/asm/arch-lpc32xx/cpu.h new file mode 100644 index 0000000..b02dc38 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/cpu.h @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_CPU_H +#define _LPC32XX_CPU_H + +/* LPC32XX Memory map */ + +/* AHB physical base addresses */ +#define SLC_NAND_BASE 0x20020000 /* SLC NAND Flash registers base */ +#define SSP0_BASE 0x20084000 /* SSP0 registers base */ +#define SD_CARD_BASE 0x20098000 /* SD card interface registers base */ +#define MLC_NAND_BASE 0x200A8000 /* MLC NAND Flash registers base */ +#define DMA_BASE 0x31000000 /* DMA controller registers base */ +#define USB_BASE 0x31020000 /* USB registers base */ +#define ETHERNET_BASE 0x31060000 /* Ethernet registers base */ +#define EMC_BASE 0x31080000 /* EMC configuration registers base */ + +/* FAB peripherals base addresses */ +#define CLK_PM_BASE 0x40004000 /* System control registers base */ +#define HS_UART1_BASE 0x40014000 /* High speed UART 1 registers base */ +#define HS_UART2_BASE 0x40018000 /* High speed UART 2 registers base */ +#define HS_UART7_BASE 0x4001C000 /* High speed UART 7 registers base */ +#define GPIO_BASE 0x40028000 /* GPIO registers base */ +#define WDT_BASE 0x4003C000 /* Watchdog timer registers base */ +#define TIMER0_BASE 0x40044000 /* Timer0 registers base */ +#define TIMER1_BASE 0x4004C000 /* Timer1 registers base */ +#define UART_CTRL_BASE 0x40054000 /* UART control regsisters base */ + +/* APB peripherals base addresses */ +#define UART3_BASE 0x40080000 /* UART 3 registers base */ +#define UART4_BASE 0x40088000 /* UART 4 registers base */ +#define UART5_BASE 0x40090000 /* UART 5 registers base */ +#define UART6_BASE 0x40098000 /* UART 6 registers base */ + +/* External SDRAM Memory Bank base addresses */ +#define EMC_DYCS0_BASE 0x80000000 /* SDRAM DYCS0 base address */ +#define EMC_DYCS1_BASE 0xA0000000 /* SDRAM DYCS1 base address */ + +/* External Static Memory Bank base addresses */ +#define EMC_CS0_BASE 0xE0000000 +#define EMC_CS1_BASE 0xE1000000 +#define EMC_CS2_BASE 0xE2000000 +#define EMC_CS3_BASE 0xE3000000 + +#endif /* _LPC32XX_CPU_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/timer.h b/arch/arm/include/asm/arch-lpc32xx/timer.h new file mode 100644 index 0000000..c11401b --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/timer.h @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_TIMER_H +#define _LPC32XX_TIMER_H + +#include <asm/types.h> + +/* Timer/Counter Registers */ +struct timer_t { + u32 ir; /* Interrupt Register */ + u32 tcr; /* Timer Control Register */ + u32 tc; /* Timer Counter */ + u32 pr; /* Prescale Register */ + u32 pc; /* Prescale Counter */ + u32 mcr; /* Match Control Register */ + u32 mr[4]; /* Match Registers */ + u32 ccr; /* Capture Control Register */ + u32 cr[4]; /* Capture Registers */ + u32 emr; /* External Match Register */ + u32 reserved[12]; + u32 ctcr; /* Count Control Register */ +}; + +/* Timer/Counter Interrupt Register bits */ +#define TIMER_IR_CR(n) (1 << ((n) + 4)) +#define TIMER_IR_MR(n) (1 << (n)) + +/* Timer/Counter Timer Control Register bits */ +#define TIMER_TCR_COUNTER_RESET (1 << 1) +#define TIMER_TCR_COUNTER_ENABLE (1 << 0) +#define TIMER_TCR_COUNTER_DISABLE 0x00 + +/* Timer/Counter Match Control Register bits */ +#define TIMER_MCR_STOP(n) (1 << (3 * (n) + 2)) +#define TIMER_MCR_RESET(n) (1 << (3 * (n) + 1)) +#define TIMER_MCR_INTERRUPT(n) (1 << (3 * (n))) + +/* Timer/Counter Capture Control Register bits */ +#define TIMER_CCR_INTERRUPT(n) (1 << (3 * (n) + 2)) +#define TIMER_CCR_FALLING_EDGE(n) (1 << (3 * (n) + 1)) +#define TIMER_CCR_RISING_EDGE(n) (1 << (3 * (n))) + +/* Timer/Counter External Match Register bits */ +#define TIMER_EMR_EMC_TOGGLE(n) (0x3 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_SET(n) (0x2 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_CLEAR(n) (0x1 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_NOTHING(n) (0x0 << (2 * (n) + 4)) +#define TIMER_EMR_EM(n) (1 << (n)) + +/* Timer/Counter Count Control Register bits */ +#define TIMER_CTCR_INPUT(n) ((n) << 2) +#define TIMER_CTCR_MODE_COUNTER_BOTH (0x3 << 0) +#define TIMER_CTCR_MODE_COUNTER_FALLING (0x2 << 0) +#define TIMER_CTCR_MODE_COUNTER_RISING (0x1 << 0) +#define TIMER_CTCR_MODE_TIMER (0x0 << 0) + +#endif /* _LPC32XX_TIMER_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/uart.h b/arch/arm/include/asm/arch-lpc32xx/uart.h new file mode 100644 index 0000000..f20c66a --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/uart.h @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_UART_H +#define _LPC32XX_UART_H + +#include <asm/types.h> + +/* UART Control Registers */ +struct uart_ctrl_t { + u32 ctrl; /* Control Register */ + u32 clkmode; /* Clock Mode Register */ + u32 loop; /* Loopback Control Register */ +}; + +/* UART Control Register bits */ +#define UART_CTRL_UART3_MD_CTRL (1 << 11) +#define UART_CTRL_HDPX_INV (1 << 10) +#define UART_CTRL_HDPX_EN (1 << 9) +#define UART_CTRL_UART6_IRDA (1 << 5) +#define UART_CTRL_IR_TX6_INV (1 << 4) +#define UART_CTRL_IR_RX6_INV (1 << 3) +#define UART_CTRL_IR_RX_LENGTH (1 << 2) +#define UART_CTRL_IR_TX_LENGTH (1 << 1) +#define UART_CTRL_UART5_USB_MODE (1 << 0) + +/* UART Clock Mode Register bits */ +#define UART_CLKMODE_STATX(n) (1 << ((n) + 16)) +#define UART_CLKMODE_STAT (1 << 14) +#define UART_CLKMODE_MASK(n) (0x3 << (2 * (n) - 2)) +#define UART_CLKMODE_AUTO(n) (0x2 << (2 * (n) - 2)) +#define UART_CLKMODE_ON(n) (0x1 << (2 * (n) - 2)) +#define UART_CLKMODE_OFF(n) (0x0 << (2 * (n) - 2)) + +/* UART Loopback Control Register bits */ +#define UART_LOOPBACK(n) (1 << ((n) - 1)) + +#endif /* _LPC32XX_UART_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/wdt.h b/arch/arm/include/asm/arch-lpc32xx/wdt.h new file mode 100644 index 0000000..e869135 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/wdt.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_WDT_H +#define _LPC32XX_WDT_H + +#include <asm/types.h> + +/* Watchdog Timer Registers */ +struct wdtim_t { + u32 isr; /* Interrupt Status Register */ + u32 ctrl; /* Control Register */ + u32 counter; /* Counter Value Register */ + u32 mctrl; /* Match Control Register */ + u32 match0; /* Match 0 Register */ + u32 emr; /* External Match Control Register */ + u32 pulse; /* Reset Pulse Length Register */ + u32 res; /* Reset Source Register */ +}; + +/* Watchdog Timer Control Register bits */ +#define WDTIM_CTRL_PAUSE_EN (1 << 2) +#define WDTIM_CTRL_RESET_COUNT (1 << 1) +#define WDTIM_CTRL_COUNT_ENAB (1 << 0) + +/* Watchdog Timer Match Control Register bits */ +#define WDTIM_MCTRL_RESFRC2 (1 << 6) +#define WDTIM_MCTRL_RESFRC1 (1 << 5) +#define WDTIM_MCTRL_M_RES2 (1 << 4) +#define WDTIM_MCTRL_M_RES1 (1 << 3) +#define WDTIM_MCTRL_STOP_COUNT0 (1 << 2) +#define WDTIM_MCTRL_RESET_COUNT0 (1 << 1) +#define WDTIM_MCTRL_MR0_INT (1 << 0) + +#endif /* _LPC32XX_WDT_H */
Hi Vladimir,
Signed-off-by: Vladimir Zapolskiyvz@mleia.com
- checkpatch.pl reports zero errors and warnings
- BIT(n) and SBF(s, v) macro are not used anymore
- removed NS16550 and 14-clock UART definitions from uart.h
- added devices.c file, which contains standard UART preinitialization routine
- added get_serial_clock() function, it returns actual frequency of UART clock
- __udelay() realization is simplified, no need of interrupt handling
As it stands, this is dead code until some board uses it; I imagine you have board waiting for this support. Can you submit the SoC and board code as a patch set? This way, it will be obvious for all that the SoC code in this patch has actual use.
Amicalement,
Hi Albert,
On 22.10.2011 02:31, Albert ARIBAUD wrote:
Hi Vladimir,
routine
UART clock
you're right, I have a board to make support for. However I presume that U-boot maintainers won't be happy to include a board with CONFIG_ENV_IS_NOWHERE, and unfortunately flash driver isn't yet ready for publishing.
I'd like to get an advice, if you think that weakly supported but working U-boot on the board has chances to be included to arm-next I can send the patchset right now for review, otherwise I'll spend some time (one week approximately) to finish NAND driver.
Dear Vladimir Zapolskiy,
In message 4EA49D8E.2050704@mleia.com you wrote:
you're right, I have a board to make support for. However I presume that > U-boot maintainers won't be happy to include a board with > CONFIG_ENV_IS_NOWHERE, and unfortunately flash driver isn't yet ready >
Why not? There are other boards with CONFIG_ENV_IS_NOWHERE :
-> grep CONFIG_ENV_IS_NOWHERE include/configs/* | wc -l 68
I'd like to get an advice, if you think that weakly supported but > working U-boot on the board has chances to be included to arm-next I can > send the patchset right now for review, otherwise I'll spend some time > (one week approximately) to finish NAND driver.
Release early, release often.
Hi Vladimir,
Le 24/10/2011 01:04, Vladimir Zapolskiy a écrit :
Hi Albert,
Hi Vladimir,
routine
UART clock
CONFIG_ENV_IS_NOWHERE is the board( maintainer)'s business.
Ditto for the FLASH driver, if it is not required for use of the board (e.g., if U-Boot can fire up and does not need the FLASH to boot an OS, then a broken FLASH driver is an inconvenience, not a showstopper).
IMO, the acceptable state of a board is the board maintainer's affair, with a bare minimum that U-Boot must be able to play its role as a bootloader.
Anyway, since that is for next, not master, and since you think you can add the missing support far before the next merge window, I suggest you complete board support and add it to V4.
Amicalement,
Hi Albert,
On 31.10.2011 19:42, Albert ARIBAUD wrote:
Hi Vladimir,
Hi Albert,
Hi Vladimir,
routine
UART clock
I've added CFI flash support to the board, however the environment is supposed to be stored in NAND flash, and that requires some more LPC32XX specific stuff to be developed for U-boot soon (basically that's NAND controller and DMA drivers).
It's done in my understanding. Hopefully some more addons still should be implemented, and I'd like to concentrate on them being assured that the SoC and basic board support are pulled in.
The initial board support was done and published a week ago, please check http://lists.denx.de/pipermail/u-boot/2011-October/106991.html
And that's my expression of willing to become a board maintainer, sorry it hasn't been included to the board changeset originally - http://lists.denx.de/pipermail/u-boot/2011-October/107069.html
I'd like to encourage you to check that the board specific compilation has zero warnings and checkpatch.pl output is clean.
Albert ARIBAUD
Vladimir Zapolskiy
