[U-Boot] [PATCH v2 2/4] x86: Do TSC MSR calibration only for known/supported CPUs
Using MSR_PLATFORM_INFO (0xCE) to calibrate TSR will cause #GP on processors which do not have this MSR. Instead only doing the MSR calibration for known/supported CPUs.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/x86/lib/tsc_timer.c | 116 ++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 109 insertions(+), 7 deletions(-)
diff --git a/arch/x86/lib/tsc_timer.c b/arch/x86/lib/tsc_timer.c index 8b38702..fafbbfc 100644 --- a/arch/x86/lib/tsc_timer.c +++ b/arch/x86/lib/tsc_timer.c @@ -1,6 +1,9 @@ /* * Copyright (c) 2012 The Chromium OS Authors. * + * TSC calibration codes are adapted from Linux kernel + * arch/x86/kernel/tsc_msr.c and arch/x86/kernel/tsc.c + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -12,8 +15,108 @@ #include <asm/msr.h> #include <asm/u-boot-x86.h>
+/* CPU reference clock frequency: in KHz */ +#define FREQ_83 83200 +#define FREQ_100 99840 +#define FREQ_133 133200 +#define FREQ_166 166400 + +#define MAX_NUM_FREQS 8 + DECLARE_GLOBAL_DATA_PTR;
+/* + * According to Intel 64 and IA-32 System Programming Guide, + * if MSR_PERF_STAT[31] is set, the maximum resolved bus ratio can be + * read in MSR_PLATFORM_ID[12:8], otherwise in MSR_PERF_STAT[44:40]. + * Unfortunately some Intel Atom SoCs aren't quite compliant to this, + * so we need manually differentiate SoC families. This is what the + * field msr_plat does. + */ +struct freq_desc { + u8 x86_family; /* CPU family */ + u8 x86_model; /* model */ + u8 msr_plat; /* 1: use MSR_PLATFORM_INFO, 0: MSR_IA32_PERF_STATUS */ + u32 freqs[MAX_NUM_FREQS]; +}; + +static struct freq_desc freq_desc_tables[] = { + /* PNW */ + { 6, 0x27, 0, { 0, 0, 0, 0, 0, FREQ_100, 0, FREQ_83 } }, + /* CLV+ */ + { 6, 0x35, 0, { 0, FREQ_133, 0, 0, 0, FREQ_100, 0, FREQ_83 } }, + /* TNG */ + { 6, 0x4a, 1, { 0, FREQ_100, FREQ_133, 0, 0, 0, 0, 0 } }, + /* VLV2 */ + { 6, 0x37, 1, { FREQ_83, FREQ_100, FREQ_133, FREQ_166, 0, 0, 0, 0 } }, + /* ANN */ + { 6, 0x5a, 1, { FREQ_83, FREQ_100, FREQ_133, FREQ_100, 0, 0, 0, 0 } }, +}; + +static int match_cpu(u8 family, u8 model) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(freq_desc_tables); i++) { + if ((family == freq_desc_tables[i].x86_family) && + (model == freq_desc_tables[i].x86_model)) + return i; + } + + return -1; +} + +/* Map CPU reference clock freq ID(0-7) to CPU reference clock freq(KHz) */ +#define id_to_freq(cpu_index, freq_id) \ + (freq_desc_tables[cpu_index].freqs[freq_id]) + +/* + * Do MSR calibration only for known/supported CPUs. + * + * Returns the calibration value or 0 if MSR calibration failed. + */ +static unsigned long try_msr_calibrate_tsc(void) +{ + u32 lo, hi, ratio, freq_id, freq; + unsigned long res; + int cpu_index; + + cpu_index = match_cpu(gd->arch.x86, gd->arch.x86_model); + if (cpu_index < 0) + return 0; + + if (freq_desc_tables[cpu_index].msr_plat) { + rdmsr(MSR_PLATFORM_INFO, lo, hi); + ratio = (lo >> 8) & 0x1f; + } else { + rdmsr(MSR_IA32_PERF_STATUS, lo, hi); + ratio = (hi >> 8) & 0x1f; + } + debug("Maximum core-clock to bus-clock ratio: 0x%x\n", ratio); + + if (!ratio) + goto fail; + + /* Get FSB FREQ ID */ + rdmsr(MSR_FSB_FREQ, lo, hi); + freq_id = lo & 0x7; + freq = id_to_freq(cpu_index, freq_id); + debug("Resolved frequency ID: %u, frequency: %u KHz\n", + freq_id, freq); + if (!freq) + goto fail; + + /* TSC frequency = maximum resolved freq * maximum resolved bus ratio */ + res = freq * ratio / 1000; + debug("TSC runs at %lu MHz\n", res); + + return res; + +fail: + debug("Fast TSC calibration using MSR failed\n"); + return 0; +} + void timer_set_base(u64 base) { gd->arch.tsc_base = base; @@ -34,17 +137,16 @@ u64 __attribute__((no_instrument_function)) get_ticks(void) return now_tick - gd->arch.tsc_base; }
-#define PLATFORM_INFO_MSR 0xce - /* Get the speed of the TSC timer in MHz */ unsigned __attribute__((no_instrument_function)) long get_tbclk_mhz(void) { - u32 ratio; - u64 platform_info = native_read_msr(PLATFORM_INFO_MSR); + unsigned long fast_calibrate; + + fast_calibrate = try_msr_calibrate_tsc(); + if (!fast_calibrate) + panic("TSC frequency is ZERO");
- /* 100MHz times Max Non Turbo ratio */ - ratio = (platform_info >> 8) & 0xff; - return 100 * ratio; + return fast_calibrate; }
unsigned long get_tbclk(void)
Hi Bin,
Applied to u-boot-x86/master, thanks!
(Please see note below)
- Copyright (c) 2012 The Chromium OS Authors.
- TSC calibration codes are adapted from Linux kernel
- arch/x86/kernel/tsc_msr.c and arch/x86/kernel/tsc.c
- According to Intel 64 and IA-32 System Programming Guide,
- if MSR_PERF_STAT[31] is set, the maximum resolved bus ratio can be
- read in MSR_PLATFORM_ID[12:8], otherwise in MSR_PERF_STAT[44:40].
- Unfortunately some Intel Atom SoCs aren't quite compliant to this,
- so we need manually differentiate SoC families. This is what the
- field msr_plat does.
+struct freq_desc {
/* PNW */
/* CLV+ */
/* TNG */
/* VLV2 */
/* ANN */
int i;
return i;
return -1;
- Do MSR calibration only for known/supported CPUs.
- Returns the calibration value or 0 if MSR calibration failed.
unsigned long res;
int cpu_index;
if (cpu_index < 0)
} else {
if (!ratio)
goto fail;
freq_id = lo & 0x7;
freq_id, freq);
if (!freq)
goto fail;
return res;
+fail:
u32 ratio;
return 100 * ratio;
What happens for platforms that have this MSR? Do we ignore it now? For my current platform this code is needed.
Hi Simon,
On Tue, Nov 11, 2014 at 2:54 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
+struct freq_desc {
/* PNW */
/* CLV+ */
/* TNG */
/* VLV2 */
/* ANN */
int i;
return i;
return -1;
unsigned long res;
int cpu_index;
if (cpu_index < 0)
} else {
if (!ratio)
goto fail;
freq_id = lo & 0x7;
freq_id, freq);
if (!freq)
goto fail;
return res;
+fail:
u32 ratio;
return 100 * ratio;
In Linux the MSR calibration is only available on several Atom platforms. If that fails, it falls back to use fast PIT calibration. However, I think you can add an entry in the freq_desc_tables[] for your platform if you want to use MSR calibration.
Regards, Bin
Hi Bin,
On 11 November 2014 01:25, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
+struct freq_desc {
/* PNW */
/* CLV+ */
/* TNG */
/* VLV2 */
/* ANN */
int i;
return i;
return -1;
unsigned long res;
int cpu_index;
if (cpu_index < 0)
} else {
if (!ratio)
goto fail;
freq_id = lo & 0x7;
freq_id, freq);
if (!freq)
goto fail;
return res;
+fail:
u32 ratio;
return 100 * ratio;
I can add exceptions, but I wonder why this fails on my platform? Is your method supposed to work on any platform?
Hi Simon,
On Wed, Nov 12, 2014 at 12:10 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
+struct freq_desc {
/* PNW */
/* CLV+ */
/* TNG */
/* VLV2 */
/* ANN */
int i;
return i;
return -1;
unsigned long res;
int cpu_index;
if (cpu_index < 0)
} else {
if (!ratio)
goto fail;
freq_id = lo & 0x7;
freq_id, freq);
if (!freq)
goto fail;
return res;
+fail:
u32 ratio;
return 100 * ratio;
Which one fails? Do you mean the quick_pit_calibrate() fails? Is that because your platform does not has the legacy 8254 integrated?
Regards, Bin
Hi Bin,
On 11 November 2014 18:16, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
+struct freq_desc {
/* PNW */
/* CLV+ */
/* TNG */
/* VLV2 */
/* ANN */
int i;
return i;
return -1;
unsigned long res;
int cpu_index;
if (cpu_index < 0)
} else {
if (!ratio)
goto fail;
freq_id = lo & 0x7;
freq_id, freq);
if (!freq)
goto fail;
return res;
+fail:
u32 ratio;
return 100 * ratio;
I'll have to have another look at this. We dropped some of the old timer stuff a while ago and it would be a shame to bring it back when newer platforms apparently don't need it. But I may be talking about a different timer.
Bin Meng
