[U-Boot-Users] [PATCH 09/18] include/configs: Use new CONFIG_CMD_* in various M* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/M5271EVB.h | 15 +++++++--- include/configs/M5272C3.h | 17 ++++++++--- include/configs/M5282EVB.h | 13 ++++++--- include/configs/MBX.h | 19 ++++++++----- include/configs/MBX860T.h | 2 +- include/configs/METROBOX.h | 48 ++++++++++++++------------------ include/configs/MHPC.h | 27 ++++++++++-------- include/configs/MIP405.h | 61 ++++++++++++++++++----------------------- include/configs/ML2.h | 36 +++++++++++++----------- include/configs/MOUSSE.h | 16 ++++++++--- include/configs/MPC8260ADS.h | 4 +- include/configs/MUSENKI.h | 10 +++--- include/configs/MVBLUE.h | 25 ++++++++++++----- include/configs/MVS1.h | 33 +++++++++++----------- 14 files changed, 181 insertions(+), 145 deletions(-)
diff --git a/include/configs/M5271EVB.h b/include/configs/M5271EVB.h index f0fc013..1907a3c 100644 --- a/include/configs/M5271EVB.h +++ b/include/configs/M5271EVB.h @@ -65,15 +65,22 @@ #define CFG_ENV_IS_IN_FLASH 1 #endif
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_PING | CFG_CMD_NET ) & ~(CFG_CMD_LOADS | CFG_CMD_LOADB)) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_NET + +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h>
#define CFG_PROMPT "=> " #define CFG_LONGHELP /* undef to save memory */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 5fd6a95..4171665 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -60,17 +60,24 @@ #define CFG_ENV_IS_IN_FLASH 1 #endif
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL & ~(CFG_CMD_LOADS | CFG_CMD_LOADB) | \ - CFG_CMD_MII)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_MII + +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB + + #define CONFIG_BOOTDELAY 5
#define CFG_PROMPT "-> " #define CFG_LONGHELP /* undef to save memory */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index cbb3e3b..cf3076e 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -51,16 +51,21 @@ #define CFG_ENV_IS_IN_FLASH 1
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL & ~(CFG_CMD_LOADS | CFG_CMD_LOADB) ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB +
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> #define CONFIG_BOOTDELAY 5
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/MBX.h b/include/configs/MBX.h index d6e3fb8..ae8913c 100644 --- a/include/configs/MBX.h +++ b/include/configs/MBX.h @@ -71,13 +71,18 @@
#undef CONFIG_WATCHDOG /* watchdog disabled */
-#define CONFIG_COMMANDS ( CFG_CMD_NET | CONFIG_CMD_DFL | CFG_CMD_SDRAM | \ - CFG_CMD_PCMCIA | CFG_CMD_IDE )
-#define CONFIG_DOS_PARTITION +/* + * Command line configuration. + */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_PCMCIA +#define CONFIG_CMD_IDE
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +#define CONFIG_DOS_PARTITION
/* * Miscellaneous configurable options @@ -88,7 +93,7 @@ #ifdef CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #endif -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -187,7 +192,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/MBX860T.h b/include/configs/MBX860T.h index 0ca0970..69d195d 100644 --- a/include/configs/MBX860T.h +++ b/include/configs/MBX860T.h @@ -151,7 +151,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/METROBOX.h b/include/configs/METROBOX.h index 7aae2bd..e9aaedb 100644 --- a/include/configs/METROBOX.h +++ b/include/configs/METROBOX.h @@ -242,26 +242,24 @@ #define CFG_RX_ETH_BUFFER 32 /* #eth rx buff & descrs */
-/*----------------------------------------------------------------------- - * Console/Commands/Parser - *----------------------------------------------------------------------*/ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_I2C | \ - CFG_CMD_DHCP | \ - CFG_CMD_DATE | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_PING | \ - CFG_CMD_DIAG | \ - CFG_CMD_MII | \ - CFG_CMD_NET | \ - CFG_CMD_ELF | \ - CFG_CMD_IDE | \ - CFG_CMD_FAT) - -/* tbs 09-March-2005 Removed to be able to use 2nd serial */ -/* CFG_CMD_KGDB | \ */ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DATE +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_PING +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT
/* Include NetConsole support */ @@ -272,10 +270,6 @@ #define CONFIG_AUTO_COMPLETE 1 #define CFG_ALT_MEMTEST 1 /* use real memory test */
- -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "MetroBox=> " /* Monitor Command Prompt */
@@ -286,7 +280,7 @@ /*----------------------------------------------------------------------- * Console Buffer *----------------------------------------------------------------------*/ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -348,7 +342,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above */ #endif
@@ -360,7 +354,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal PowerOn: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port baud */ #define CONFIG_KGDB_SER_INDEX 2 /* kgdb serial port */ #endif diff --git a/include/configs/MHPC.h b/include/configs/MHPC.h index 53684ca..a8dd36d 100644 --- a/include/configs/MHPC.h +++ b/include/configs/MHPC.h @@ -115,25 +115,28 @@
#define CONFIG_BR0_WORKAROUND 1
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DATE | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_I2C | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_REGINFO )
-#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | CONFIG_BOOTP_BOOTFILESIZE) +/* + * Command line configuration. + */ +#include <config_cmd_default.h>
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#define CONFIG_CMD_DATE +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_REGINFO + + +#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | CONFIG_BOOTP_BOOTFILESIZE)
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -225,7 +228,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 7e57a0f..192998e 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -50,41 +50,34 @@ ***********************************************************/ #define CONFIG_SYS_CLK_FREQ 33000000 /* external frequency to pll */
-/*********************************************************** - * Command definitions - ***********************************************************/ -#define MIP405_COMMON_CMDS \ - (CONFIG_CMD_DFL | \ - CFG_CMD_CACHE | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_IRQ | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_MII | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SAVES | \ - CFG_CMD_BSP )
-#if defined(CONFIG_MIP405T) -#define CONFIG_COMMANDS \ - MIP405_COMMON_CMDS -#else -#define CONFIG_COMMANDS \ - (MIP405_COMMON_CMDS | \ - CFG_CMD_USB | \ - CFG_CMD_DOC ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_BSP
+#if !defined(CONFIG_MIP405T) + #define CONFIG_CMD_USB + #define CONFIG_CMD_DOC #endif
#define CFG_NAND_LEGACY
@@ -165,7 +158,7 @@ **********************************************************/ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -260,7 +253,7 @@ */ #define CFG_DCACHE_SIZE 0x4000 /* For AMCC 405GPr CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
@@ -426,7 +419,7 @@ /************************************************************ * Debug support ************************************************************/ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/ML2.h b/include/configs/ML2.h index d8805ea..8d61d48 100644 --- a/include/configs/ML2.h +++ b/include/configs/ML2.h @@ -76,20 +76,22 @@ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL & \ - ~( CFG_CMD_NET | \ - CFG_CMD_RTC | \ - CFG_CMD_PCI | \ - CFG_CMD_I2C \ - ) ) | \ - CFG_CMD_IRQ | \ - CFG_CMD_KGDB | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_ELF | \ - CFG_CMD_JFFS2 ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_KGDB +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_ELF +#define CONFIG_CMD_JFFS2 + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_RTC +#undef CONFIG_CMD_PCI +#undef CONFIG_CMD_I2C +
@@ -102,7 +104,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -195,7 +197,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
@@ -236,7 +238,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/MOUSSE.h b/include/configs/MOUSSE.h index 6ad2feb..518bf12 100644 --- a/include/configs/MOUSSE.h +++ b/include/configs/MOUSSE.h @@ -58,14 +58,22 @@ #endif #define CONFIG_BOOTARGS "console=ttyS0 root=/dev/nfs rw nfsroot=209.128.93.133:/boot nfsaddrs=209.128.93.133:209.128.93.138" #define CONFIG_BOOTDELAY 3 -#define CONFIG_COMMANDS (CONFIG_CMD_DFL|CFG_CMD_ASKENV|CFG_CMD_DATE) + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE + + #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ETH_ADDR "00:10:18:10:00:06"
#define CONFIG_DOS_PARTITION 1 /* MSDOS bootable partitiion support */ -/* This must be included AFTER the definition of CONFIG_COMMANDS (if any) - */ -#include <cmd_confdefs.h> + #include "../board/mousse/mousse.h"
/* diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index 69d4c28..b41866f 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -250,7 +250,7 @@ #define CONFIG_BOOTCOMMAND "bootm fff80000" /* autoboot command */ #define CONFIG_BOOTARGS "root=/dev/mtdblock2"
-#if defined(CONFIG_CMD_KGDB) || (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -268,7 +268,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) || (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/MUSENKI.h b/include/configs/MUSENKI.h index da52e0e..d6dafb2 100644 --- a/include/configs/MUSENKI.h +++ b/include/configs/MUSENKI.h @@ -52,11 +52,11 @@
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ - -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h>
/* @@ -280,7 +280,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/MVBLUE.h b/include/configs/MVBLUE.h index 88eefa1..bea8cb1 100644 --- a/include/configs/MVBLUE.h +++ b/include/configs/MVBLUE.h @@ -76,15 +76,26 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 60
-#define CONFIG_COMMANDS ( CFG_CMD_ASKENV | CFG_CMD_BOOTD | CFG_CMD_CACHE | CFG_CMD_DHCP | \ - CFG_CMD_ECHO | CFG_CMD_ENV | CFG_CMD_FLASH | CFG_CMD_IMI | \ - CFG_CMD_IRQ | CFG_CMD_NET | CFG_CMD_PCI | CFG_CMD_RUN )
-#define CONFIG_BOOTP_MASK ( 0xffffffff ) +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_IMI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#define CONFIG_CMD_RUN
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +#define CONFIG_BOOTP_MASK ( 0xffffffff )
/* * Miscellaneous configurable options @@ -310,7 +321,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/MVS1.h b/include/configs/MVS1.h index 5995918..709ee86 100644 --- a/include/configs/MVS1.h +++ b/include/configs/MVS1.h @@ -70,20 +70,21 @@
#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
-/* MVsensor uses a really minimal U-Boot ! */ -#define CONFIG_COMMANDS (CFG_CMD_LOADS | \ - CFG_CMD_LOADB | \ - CFG_CMD_IMI | \ - CFG_CMD_FLASH | \ - CFG_CMD_MEMORY | \ - CFG_CMD_NET | \ - CFG_CMD_DHCP | \ - CFG_CMD_ENV | \ - CFG_CMD_BOOTD | \ - CFG_CMD_RUN ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_IMI +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_RUN +
/* * Miscellaneous configurable options @@ -96,7 +97,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -172,7 +173,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
Jon Loeliger
