[PATCH] rpi: Conditionally add simple-framebuffer node
It appears that RPi firmware has already added framebuffer node under /chosen, at least on RPi 2 versions. So check for this and don't add duplicate node.
Signed-off-by: Ivan T. Ivanov iivanov@suse.de --- board/raspberrypi/rpi/rpi.c | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index df52a4689f..372b26b6f2 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -497,12 +497,11 @@ void *board_fdt_blob_setup(void)
int ft_board_setup(void *blob, struct bd_info *bd) { - /* - * For now, we simply always add the simplefb DT node. Later, we - * should be more intelligent, and e.g. only do this if no enabled DT - * node exists for the "real" graphics driver. - */ - lcd_dt_simplefb_add_node(blob); + int node; + + node = fdt_node_offset_by_compatible(blob, -1, "simple-framebuffer"); + if (node < 0) + lcd_dt_simplefb_add_node(blob);
#ifdef CONFIG_EFI_LOADER /* Reserve the spin table */
Quoting Ivan T. Ivanov (2021-08-10 17:31:14)
int node;
if (node < 0)
Could someone take a look into this fix, please.
BTW, original message still awaits list moderator approval.
Thank you! Ivan
Applied to rpi-next now.
Thanks, Matthias
int node;
if (node < 0)
Ivan T. Ivanov
Matthias Brugger
