[U-Boot] [PATCH] arm: armv7m: clean up armv7m unified code compilation
unified syntax should be selected by config ARM_ASM_UNIFIED
Signed-off-by: Vikas Manocha vikas.manocha@st.com --- arch/arm/include/asm/armv7m.h | 5 ----- arch/arm/lib/crt0.S | 4 +--- arch/arm/lib/relocate.S | 1 + arch/arm/lib/vectors_m.S | 2 +- 4 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/armv7m.h b/arch/arm/include/asm/armv7m.h index 278f302..ad67b4f 100644 --- a/arch/arm/include/asm/armv7m.h +++ b/arch/arm/include/asm/armv7m.h @@ -10,11 +10,6 @@ #ifndef ARMV7M_H #define ARMV7M_H
-#if defined(__ASSEMBLY__) -.syntax unified -.thumb -#endif - /* armv7m fixed base addresses */ #define V7M_SCS_BASE 0xE000E000 #define V7M_NVIC_BASE (V7M_SCS_BASE + 0x0100) diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index d7ff9f0..fe312db 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -8,9 +8,7 @@ #include <config.h> #include <asm-offsets.h> #include <linux/linkage.h> -#ifdef CONFIG_CPU_V7M -#include <asm/armv7m.h> -#endif +#include <asm/assembler.h>
/* * This file handles the target-independent stages of the U-Boot diff --git a/arch/arm/lib/relocate.S b/arch/arm/lib/relocate.S index c5b135d..e5f7267 100644 --- a/arch/arm/lib/relocate.S +++ b/arch/arm/lib/relocate.S @@ -6,6 +6,7 @@ */
#include <asm-offsets.h> +#include <asm/assembler.h> #include <config.h> #include <elf.h> #include <linux/linkage.h> diff --git a/arch/arm/lib/vectors_m.S b/arch/arm/lib/vectors_m.S index d75e477..7d2d55c 100644 --- a/arch/arm/lib/vectors_m.S +++ b/arch/arm/lib/vectors_m.S @@ -5,7 +5,7 @@ */
#include <config.h> -#include <asm/armv7m.h> +#include <asm/assembler.h> #include <linux/linkage.h>
.type __hard_fault_entry, %function
Vikas Manocha
