[U-Boot] [PATCH 1/3] configs: k2g_hs_evm: Resync defconfig with non-HS defconfig
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/k2g_hs_evm_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 5402cd3214..b0c0e08584 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set @@ -20,6 +21,9 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/k2e_hs_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index a79ce6060f..6224222129 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set @@ -21,6 +22,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/k2hk_hs_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 09ac21e8f3..1cca0caef8 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set @@ -21,6 +22,8 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y
I understand you just synced with gp defconfig, but wondering why we require DTB_RESELECT for k2hk? If not required we should probably disable it in gp as well.
Thanks and regards, Lokesh
I'm not sure if it is needed either, but I'm not sure which one of these fixed the boot issue, so as you noticed I just did a full sync and the board started booting again.
If that config is removed for GP it should be removed for HS, I'll check for any further breaks later, but so far what works for GP works for HS.
If I didn't have plans for merging the GP and HS configs at some point I would say defconfig fragments for U-Boot would be something to look into..
Thanks, Andrew
commit 3107696784d59 ("defconfig: keystone2: Enable U-boot runtime DTB detection") enabled these configs. Looks like it is enforced to use RESELECT on all K2 platforms.
For the entire series: Reviewed-by: Lokesh vutla lokeshvutla@ti.com
Thanks, Andrew
On Thu, Mar 22, 2018 at 03:44:40PM -0500, Andrew F. Davis wrote:
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Lokesh vutla lokeshvutla@ti.com
Andrew F. Davis
Lokesh Vutla
