[U-Boot] [PATCH] s5p-mmc: Fix ambiguous setting of data transfer width
mmc data transfer width is set as following: WIDE8[5]: 0 = Depend on WIDE4 1 = 8-bit mode WIDE4[1]: 1 = 4-bit mode 0 = 1-bit mode
In case of 4-bit mode reset 8-bit mode and in case of 1-bit mode reset 8-bit mode and 4-bit mode
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- drivers/mmc/s5p_mmc.c | 10 +++++++--- 1 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/s5p_mmc.c b/drivers/mmc/s5p_mmc.c index 7786ecf..6e6ad08 100644 --- a/drivers/mmc/s5p_mmc.c +++ b/drivers/mmc/s5p_mmc.c @@ -368,12 +368,16 @@ static void mmc_set_ios(struct mmc *mmc) * 1 = 4-bit mode * 0 = 1-bit mode */ - if (mmc->bus_width == 8) + if (mmc->bus_width == 8) { ctrl |= (1 << 5); - else if (mmc->bus_width == 4) + ctrl &= ~(1 << 1); + } else if (mmc->bus_width == 4) { ctrl |= (1 << 1); - else + ctrl &= ~(1 << 5); + } else { ctrl &= ~(1 << 1); + ctrl &= ~(1 << 5); + }
/* * OUTEDGEINV[2]
Hi Chander.
this patch is correct.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
- if (mmc->bus_width == 8) { ctrl |= (1 << 5);
ctrl &= ~(1 << 1);
- } else if (mmc->bus_width == 4) { ctrl |= (1 << 1);
- else
ctrl &= ~(1 << 5);
ctrl &= ~(1 << 5);
- OUTEDGEINV[2]
On Tue, Aug 30, 2011 at 5:55 AM, Chander Kashyap chander.kashyap@linaro.org wrote:
ctrl |= (1 << 5);
- ctrl &= ~(1 << 1);
I know these were like this before, but those numbers are awfully magical. You should really define constants for them.
Also, this seems like a very confusing way to do this? Why not clear both bits at the start, and then set the one that is needed?
Andy
Dear Andy Fleming,
ctrl |= (1 << 5);
We decided to use comments instead of defines.
Agreed.
Thanks Minkyu Kang
Dear Minkyu Kang,
In message CALrBrZ3H+k8bu-1OwF5C5BNHuphj_J8jXXV2xgu6jPO5gmJELg@mail.gmail.com you wrote:
And now we ask you to fix this, because we don;t want such magic constants. So please go on and change this.
Thanks.
Dear Wolfgang Denk,
On 1 September 2011 14:51, Wolfgang Denk wd@denx.de wrote:
Dear Minkyu Kang,
OK.
Thanks. Minkyu Kang
participants (5)
Andy Fleming
Chander Kashyap
Jaehoon Chung
Minkyu Kang
