[U-Boot] [PATCH] tegra: remove IRDA pinmux synonym
IRDA is a synonym for UARTB in tegra pinmux, remove all usage of this synonym and replace with UARTB to disambiguate.
Signed-off-by: Allen Martin amartin@nvidia.com --- arch/arm/cpu/tegra-common/board.c | 2 +- arch/arm/cpu/tegra20-common/funcmux.c | 4 ++-- arch/arm/cpu/tegra20-common/pinmux.c | 2 +- arch/arm/include/asm/arch-tegra20/funcmux.h | 2 +- arch/arm/include/asm/arch-tegra20/pinmux.h | 1 - arch/arm/include/asm/arch-tegra30/pinmux.h | 1 - board/nvidia/cardhu/pinmux-config-cardhu.h | 4 ++-- 7 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/tegra-common/board.c b/arch/arm/cpu/tegra-common/board.c index af1879c..1ec6c06 100644 --- a/arch/arm/cpu/tegra-common/board.c +++ b/arch/arm/cpu/tegra-common/board.c @@ -113,7 +113,7 @@ static int uart_configs[] = { #else FUNCMUX_UART1_IRRX_IRTX, #endif - FUNCMUX_UART2_IRDA, + FUNCMUX_UART2_UARTB, -1, FUNCMUX_UART4_GMC, -1, diff --git a/arch/arm/cpu/tegra20-common/funcmux.c b/arch/arm/cpu/tegra20-common/funcmux.c index ece7ad9..a1c55a6 100644 --- a/arch/arm/cpu/tegra20-common/funcmux.c +++ b/arch/arm/cpu/tegra20-common/funcmux.c @@ -98,8 +98,8 @@ int funcmux_select(enum periph_id id, int config) break;
case PERIPH_ID_UART2: - if (config == FUNCMUX_UART2_IRDA) { - pinmux_set_func(PINGRP_UAD, PMUX_FUNC_IRDA); + if (config == FUNCMUX_UART2_UARTB) { + pinmux_set_func(PINGRP_UAD, PMUX_FUNC_UARTB); pinmux_tristate_disable(PINGRP_UAD); } break; diff --git a/arch/arm/cpu/tegra20-common/pinmux.c b/arch/arm/cpu/tegra20-common/pinmux.c index a2a0916..5ad2121 100644 --- a/arch/arm/cpu/tegra20-common/pinmux.c +++ b/arch/arm/cpu/tegra20-common/pinmux.c @@ -390,7 +390,7 @@ const struct tegra_pingroup_desc tegra_soc_pingroups[PINGRP_COUNT] = { PIN(UAA, BB, SPI3, MIPI_HS, UARTA, ULPI, MIPI_HS), PIN(UAB, BB, SPI2, MIPI_HS, UARTA, ULPI, MIPI_HS), PIN(UAC, BB, OWR, RSVD, RSVD, RSVD, RSVD4), - PIN(UAD, UART, IRDA, SPDIF, UARTA, SPI4, SPDIF), + PIN(UAD, UART, UARTB, SPDIF, UARTA, SPI4, SPDIF), PIN(UCA, UART, UARTC, RSVD, GMI, RSVD, RSVD4), PIN(UCB, UART, UARTC, PWM, GMI, RSVD, RSVD4),
diff --git a/arch/arm/include/asm/arch-tegra20/funcmux.h b/arch/arm/include/asm/arch-tegra20/funcmux.h index 1bac25e..963f021 100644 --- a/arch/arm/include/asm/arch-tegra20/funcmux.h +++ b/arch/arm/include/asm/arch-tegra20/funcmux.h @@ -35,7 +35,7 @@ enum { FUNCMUX_UART1_UAA_UAB, FUNCMUX_UART1_GPU, FUNCMUX_UART1_SDIO1, - FUNCMUX_UART2_IRDA = 0, + FUNCMUX_UART2_UARTB = 0, FUNCMUX_UART4_GMC = 0,
/* I2C configs */ diff --git a/arch/arm/include/asm/arch-tegra20/pinmux.h b/arch/arm/include/asm/arch-tegra20/pinmux.h index 797e158..a9b4eda 100644 --- a/arch/arm/include/asm/arch-tegra20/pinmux.h +++ b/arch/arm/include/asm/arch-tegra20/pinmux.h @@ -204,7 +204,6 @@ enum pmux_func { PMUX_FUNC_I2C2, PMUX_FUNC_I2C3, PMUX_FUNC_IDE, - PMUX_FUNC_IRDA, PMUX_FUNC_KBC, PMUX_FUNC_MIO, PMUX_FUNC_MIPI_HS, diff --git a/arch/arm/include/asm/arch-tegra30/pinmux.h b/arch/arm/include/asm/arch-tegra30/pinmux.h index de1fc12..341951b 100644 --- a/arch/arm/include/asm/arch-tegra30/pinmux.h +++ b/arch/arm/include/asm/arch-tegra30/pinmux.h @@ -349,7 +349,6 @@ enum pmux_func { PMUX_FUNC_I2C2, PMUX_FUNC_I2C3, PMUX_FUNC_IDE, - PMUX_FUNC_IRDA, PMUX_FUNC_KBC, PMUX_FUNC_MIO, PMUX_FUNC_MIPI_HS, diff --git a/board/nvidia/cardhu/pinmux-config-cardhu.h b/board/nvidia/cardhu/pinmux-config-cardhu.h index 3162219..8428bba 100644 --- a/board/nvidia/cardhu/pinmux-config-cardhu.h +++ b/board/nvidia/cardhu/pinmux-config-cardhu.h @@ -176,8 +176,8 @@ static struct pingroup_config tegra3_pinmux_common[] = { LV_PINMUX(VI_D7, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_D10, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_MCLK, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), - DEFAULT_PINMUX(UART2_RXD, IRDA, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(UART2_TXD, IRDA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_RXD, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD, UARTB, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(UART2_RTS_N, UARTB, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(UART2_CTS_N, UARTB, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(UART3_TXD, UARTC, NORMAL, NORMAL, OUTPUT),
Reviewed-by: Stephen Warren swarren@nvidia.com
Allen Martin
Stephen Warren
