[U-Boot-Users] Problem using cfi_flash driver for s29GL512N flashes
Hi folks,
Greetings everybody..I am using u-boot1.1.5 for at91rm9200ek type board(arm). The flash memory used here is s29GL512N(128k sectors).I am able to configure the board/config flle properly it seems. The driver also erases/writes properly it seems. The problem is when I am trying to save environment variables it is getting set but in some cases after a reset it is showing Bad CRC and getting to the default environment. The other thing is I am not able to boot the kernel image from the flash due to some bad checksum error. Everywhere the problem is related to crc. I am a bit confused why the CRC check fails everytime? Is it not writing properly and if it is not writing properly then how it is able to get the u-boot prompt..
The required configurations defined
#define CFG_ENV_ADDR (CFG_FLASH_BASE + 0x20000) #define CFG_ENV_SIZE 0x2000 #define CFG_ENV_SECT_SIZE 0x20000 #define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) #define CONFIG_STACKSIZE (32 * 1024)
The TEXT_BASE in config.mk :
TEXT_BASE 0x21F00000
Please help as soon as possible...
Thanks in advance and cheers
U-Boot 1.1.5 is *old*. I suggest upgrading to the current version. Lot's of things got fixed here.
Debugging this problem in the old U-Boot version doesn't seem to make sense to me. Please try to upgrade.
Best regards, Stefan
Hi Stephan , Thanks for your help. The same problem remains with the upgraded version also.
Is it something to do with the TEXT_BASE. The probelm is the data for environment is written to flash properly. But when it checks for crc in env_init() the crc32 function fails. the env_ptr->crc is correct.
The environment sector when allocated in malloc area in main memory seems to get corrupted because the crc field does not seem to be correct.
the Ram is 32 MB TEXT_BASE 21F00000 CFG_GBL_DATA_SIZE 128 CFG_ENV_ADDR (CFG_FLASH_BASE + 0x20000) CFG_ENV_SIZE 0x2000 CFG_ENV_SECT_SIZE 0x20000 CONFIG_STACKSIZE (32 * 1024) CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024)
thanks & regards santi gopal
Santi Gopal Mondal Senior Engineer, R&D Services Mindtree Consulting Mobile: 09886325167
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: Tue 11/27/2007 11:41 AM To: u-boot-users@lists.sourceforge.net Cc: Santigopal Mondal Subject: Re: [U-Boot-Users] Problem using cfi_flash driver for s29GL512N flashes
DISCLAIMER: This message (including attachment if any) is confidential and may be privileged. If you have received this message by mistake please notify the sender by return e-mail and delete this message from your system. Any unauthorized use or dissemination of this message in whole or in part is strictly prohibited. E-mail may contain viruses. Before opening attachments please check them for viruses and defects. While MindTree Consulting Limited (MindTree) has put in place checks to minimize the risks, MindTree will not be responsible for any viruses or defects or any forwarded attachments emanating either from within MindTree or outside. Please note that e-mails are susceptible to change and MindTree shall not be liable for any improper, untimely or incomplete transmission. MindTree reserves the right to monitor and review the content of all messages sent to or from MindTree e-mail address. Messages sent to or from this e-mail address may be stored on the MindTree e-mail system or else where.
Hi Santi Gopal,
Here the CFI settings I currently use on some AMCC eval boards like sequoia.h:
#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ #define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */
/*----------------------------------------------------------------------- * FLASH related *----------------------------------------------------------------------*/ #define CFG_FLASH_CFI /* The flash is CFI compatible */ #define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */
#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE }
#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */
#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ #define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */
#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#ifdef CFG_ENV_IS_IN_FLASH #define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ #define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) #endif
Please note that on these PPC4xx platforms, U-Boot is located at the *end* of the FLASH, since the reset vector has to be at 0xfffffffc. So with an U-Boot image size of 0x60000 the location is 0xfffa0000...0xffffffff.
Santigopal Mondal
Stefan Roese
