[PATCH 0/3] binman: Make FIT image subentries respect offset, alignment and padding
I've been automating the process in doc/README.chromium-chainload and while experimenting with whether a "kernel" image with u-boot-spl and u-boot would work, noticed I couldn't align/offset/pad the two parts.
E.g. in something like the following, binman doesn't add the necessary padding to place the "u-boot" to the correct offset within the "kernel-1" data:
fit { description = "example";
images { kernel-1 { description = "U-Boot with SPL"; type = "kernel"; arch = "arm64"; os = "linux"; compression = "none";
u-boot-spl { }; u-boot { offset = <CONFIG_SPL_PAD_TO>; }; }; }; };
Not sure if that'll ever be really necessary besides my experiment, but it doesn't seem like skipping the padding was a deliberate choice, so here are some fixes I wrote for that.
Alper Nebi Yasak (3): binman: Ignore hash*, signature* nodes in sections binman: Respect pad-before property of section subentries binman: Build FIT image subentries with the section etype
tools/binman/etype/fit.py | 22 +++---- tools/binman/etype/section.py | 4 +- tools/binman/ftest.py | 32 +++++++++++ tools/binman/test/165_pad_in_sections.dts | 26 +++++++++ .../test/166_fit_image_subentry_alignment.dts | 57 +++++++++++++++++++ 5 files changed, 129 insertions(+), 12 deletions(-) create mode 100644 tools/binman/test/165_pad_in_sections.dts create mode 100644 tools/binman/test/166_fit_image_subentry_alignment.dts
Switch to str.startswith for matching like the FIT etype does since the current version doesn't ignore 'hash-1', 'hash-2', etc.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
tools/binman/etype/section.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 73c5553c81..c5166a5b57 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -83,7 +83,7 @@ class Entry_section(Entry):
def _ReadEntries(self): for node in self._node.subnodes: - if node.name == 'hash': + if node.name.startswith('hash') or node.name.startswith('signature'): continue entry = Entry.Create(self, node) entry.ReadNode()
Hi Alper,
On Tue, 25 Aug 2020 at 12:01, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
-- 2.28.0
This looks like right but please add a test or update an existing one, since code coverage is missing with this patch (binman test -T).
-- 2.28.0
Other relevant properties (pad-after, offset, size, align, align-size, align-end) already work since Pack() sets correct ranges for subentries' data (.offset, .size variables), but some padding here is necessary to align the data within this range to match the pad-before property.
tools/binman/etype/section.py | 2 +- tools/binman/ftest.py | 8 +++++++ tools/binman/test/165_pad_in_sections.dts | 26 +++++++++++++++++++++++ 3 files changed, 35 insertions(+), 1 deletion(-) create mode 100644 tools/binman/test/165_pad_in_sections.dts
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index c5166a5b57..72600b1ef3 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -152,7 +152,7 @@ class Entry_section(Entry): for entry in self._entries.values(): data = entry.GetData() base = self.pad_before + (entry.offset or 0) - self._skip_at_start - pad = base - len(section_data) + pad = base - len(section_data) + (entry.pad_before or 0) if pad > 0: section_data += tools.GetBytes(self._pad_byte, pad) section_data += data diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 5f650b5f94..8edf85c89f 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -1269,6 +1269,14 @@ class TestFunctional(unittest.TestCase): U_BOOT_DATA + tools.GetBytes(ord('&'), 4)) self.assertEqual(expected, data)
+ def testPadInSections(self): + """Test pad-before, pad-after for entries in sections""" + data = self._DoReadFile('165_pad_in_sections.dts') + expected = (U_BOOT_DATA + tools.GetBytes(ord('!'), 12) + + U_BOOT_DATA + tools.GetBytes(ord('!'), 6) + + U_BOOT_DATA) + self.assertEqual(expected, data) + def testMap(self): """Tests outputting a map of the images""" _, _, map_data, _ = self._DoReadFileDtb('055_sections.dts', map=True) diff --git a/tools/binman/test/165_pad_in_sections.dts b/tools/binman/test/165_pad_in_sections.dts new file mode 100644 index 0000000000..f2b327ff9f --- /dev/null +++ b/tools/binman/test/165_pad_in_sections.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + pad-byte = <0x26>; + section { + pad-byte = <0x21>; + + before { + type = "u-boot"; + }; + u-boot { + pad-before = <12>; + pad-after = <6>; + }; + after { + type = "u-boot"; + }; + }; + }; +};
Hi Alper,
- def testPadInSections(self):
Can you put this test last please? I'd like to keep the tests in rough order of .dts test files.
REgards, Simon
When reading subentries of each image, the FIT entry type directly concatenates their contents without padding them according to their offset, size, align, align-size, align-end, pad-before, pad-after properties.
This patch makes sure these properties are respected by offloading this image-data building to the section etype, where each subnode of the "images" node is processed as a section. Alignments and offsets are respective to the beginning of each image. For example, the following fragment can end up having "u-boot-spl" start at 0x88 within the final FIT binary, while "u-boot" would then end up starting at e.g. 0x20088.
u-boot-spl { }; u-boot { align = <0x10000>; }; }; }; }
tools/binman/etype/fit.py | 22 +++---- tools/binman/ftest.py | 24 ++++++++ .../test/166_fit_image_subentry_alignment.dts | 57 +++++++++++++++++++ 3 files changed, 93 insertions(+), 10 deletions(-) create mode 100644 tools/binman/test/166_fit_image_subentry_alignment.dts
diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index 75712f4409..f136a2c254 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -62,7 +62,7 @@ class Entry_fit(Entry): """ super().__init__(section, etype, node) self._fit = None - self._fit_content = defaultdict(list) + self._fit_images = {} self._fit_props = {}
def ReadNode(self): @@ -91,15 +91,18 @@ class Entry_fit(Entry):
rel_path = node.path[len(base_node.path):] has_images = depth == 2 and rel_path.startswith('/images/') + if has_images: + entry = Entry.Create(self.section, node, etype='section') + entry.ReadNode() + self._fit_images[rel_path] = entry + for subnode in node.subnodes: if has_images and not (subnode.name.startswith('hash') or subnode.name.startswith('signature')): # This is a content node. We collect all of these together # and put them in the 'data' property. They do not appear # in the FIT. - entry = Entry.Create(self.section, subnode) - entry.ReadNode() - self._fit_content[rel_path].append(entry) + pass else: with fsw.add_node(subnode.name): _AddNode(base_node, depth + 1, subnode) @@ -150,13 +153,12 @@ class Entry_fit(Entry): Returns: New fdt contents (bytes) """ - for path, entries in self._fit_content.items(): + for path, image in self._fit_images.items(): node = fdt.GetNode(path) - data = b'' - for entry in entries: - if not entry.ObtainContents(): - return False - data += entry.GetData() + if not image.ObtainContents(): + return False + image.Pack(0) + data = image.GetData() node.AddData('data', data)
fdt.Sync(auto_resize=True) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 8edf85c89f..ed573d8991 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -3485,5 +3485,29 @@ class TestFunctional(unittest.TestCase): fnode = dtb.GetNode('/images/kernel') self.assertNotIn('data', fnode.props)
+ def testFitImageSubentryAlignment(self): + """Test relative alignability of FIT image subentries""" + entry_args = { + 'test-id': TEXT_DATA, + } + data, _, _, _ = self._DoReadFileDtb('166_fit_image_subentry_alignment.dts', + entry_args=entry_args) + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + + node = dtb.GetNode('/images/kernel') + data = dtb.GetProps(node)["data"].bytes + align_pad = 0x10 - (len(U_BOOT_SPL_DATA) % 0x10) + expected = (tools.GetBytes(0, 0x20) + U_BOOT_SPL_DATA + + tools.GetBytes(0, align_pad) + U_BOOT_DATA) + self.assertEqual(expected, data) + + node = dtb.GetNode('/images/fdt-1') + data = dtb.GetProps(node)["data"].bytes + expected = (U_BOOT_SPL_DTB_DATA + tools.GetBytes(0, 20) + + tools.ToBytes(TEXT_DATA) + tools.GetBytes(0, 30) + + U_BOOT_DTB_DATA) + self.assertEqual(expected, data) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/166_fit_image_subentry_alignment.dts b/tools/binman/test/166_fit_image_subentry_alignment.dts new file mode 100644 index 0000000000..360cac5266 --- /dev/null +++ b/tools/binman/test/166_fit_image_subentry_alignment.dts @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test-desc"; + #address-cells = <1>; + + images { + kernel { + description = "Offset-Align Test"; + type = "kernel"; + arch = "arm64"; + os = "linux"; + compression = "none"; + load = <00000000>; + entry = <00000000>; + u-boot-spl { + offset = <0x20>; + }; + u-boot { + align = <0x10>; + }; + }; + fdt-1 { + description = "Pad-Before-After Test"; + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + u-boot-spl-dtb { + }; + text { + text-label = "test-id"; + pad-before = <20>; + pad-after = <30>; + }; + u-boot-dtb { + }; + }; + }; + + configurations { + default = "conf-1"; + conf-1 { + description = "Kernel with FDT blob"; + kernel = "kernel"; + fdt = "fdt-1"; + }; + }; + }; + }; +};
Hi Alper,
fit { description = "example"; images { kernel-1 { description = "U-Boot with SPL"; type = "kernel"; arch = "arm64"; os = "linux"; compression = "none"; u-boot-spl { }; u-boot { align = <0x10000>; }; }; }; }
This is a nice enhancement.
A few nits below.
Can you add a Properties comment above for this?
self._fit_props = {} def ReadNode(self):
if has_images:
entry.ReadNode()
This comment should move along with the code you moved. Perhaps here you can mention that it is not a content node.
entry.ReadNode()
I think section is a better name than image. In binman, 'image' means the final output file, containing a collection of binaries. The FIT itself therefore ends up in an image, so calling the components of the FIT 'images' is confusing.
data = b''
return False
return False
image.Pack(0)
data = image.GetData() node.AddData('data', data) fdt.Sync(auto_resize=True)
Please also do check code coverage: binman test -T
There's already a Members comment that I forgot to adjust for the _fit_content variable I renamed, changing it would be like this:
def __init__(self, section, etype, node): """ Members: _fit: FIT file being built - _fit_content: dict: + _fit_sections: dict: key: relative path to entry Node (from the base of the FIT) - value: List of Entry objects comprising the contents of this + value: Entry_section object comprising the contents of this node """ super().__init__(section, etype, node) self._fit = None - self._fit_content = defaultdict(list) + self._fit_sections = {} self._fit_props = {
Would that be enough? Putting that in the Properties sounds weird to me since it isn't the same kind of thing as "fit,external-offset", but section.py documents its _allow_missing in its Properties as well.
OTOH, nothing except fit.py has an __init__ docstring, so I think I can move the entire thing into the class docstring. Either into the Properties, or next to the Properties still under a Members heading. What would you prefer?
I tried to clarify and elaborate the comments a bit, because it sounded ambiguous to me when I just moved it. How about:
has_images = depth == 2 and rel_path.startswith('/images/') if has_images: # This node is a FIT subimage node (e.g. "/images/kernel") # containing content nodes. We collect the subimage nodes and # section entries for them here to merge the content subnodes # together and put the merged contents in the subimage node's # 'data' property later. entry = Entry.Create(self.section, node, etype='section') entry.ReadNode() self._fit_sections[rel_path] = entry
for subnode in node.subnodes: if has_images and not (subnode.name.startswith('hash') or subnode.name.startswith('signature')): # This subnode is a content node not meant to appear in the # FIT (e.g. "/images/kernel/u-boot"), so don't call # fsw.add_node() or _AddNode() for it. pass else: with fsw.add_node(subnode.name): _AddNode(base_node, depth + 1, subnode)
I'm changing it to section and also _fit_images to _fit_sections, in order to match that.
Entry_section.ObtainContents() never returns False, so I'm removing the checks for that, which contained the statements the test didn't cover.
Hi Alper,
On Sun, 30 Aug 2020 at 12:17, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
_fit_content: dict:
That's fine.
Up to you, so long as it is documented.
Looks good!
entry = Entry.Create(self.section, node, etype='section') entry.ReadNode() self._fit_sections[rel_path] = entry for subnode in node.subnodes: if has_images and not (subnode.name.startswith('hash') or subnode.name.startswith('signature')): # This subnode is a content node not meant to appear in the # FIT (e.g. "/images/kernel/u-boot"), so don't call # fsw.add_node() or _AddNode() for it. pass else: with fsw.add_node(subnode.name): _AddNode(base_node, depth + 1, subnode)
OK
If you put something in the FIT that depends on something else, it will return False on the first pass. So you can't remove that code.
Instead, use the _testing etype with a 'return-contents-later' property. to ensure the path is testing. See 162_fit_external.dts for how this works.
Section etype already does three passes over its subentries and either returns True or raises an exception. Maybe it should return False instead, but that breaks the 057_unknown_contents.dts test.
Since section does multiple passes, this appears to only add some more data to wherever it's inserted, with no change in coverage.
I can get the exception with 'return-unknown-contents'. If I replace the raise with 'return False', it fails in section etype's GetData(). If I fix that (section_data += data or b''), the FIT entry returns b'' as its entire data due to those checks and only then I can cover them with a new test. More trouble than it's worth?
Hi Alper,
On Sun, 30 Aug 2020 at 16:38, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
We do want to detect when an entry does not get around to producing its contents, so this is correct.
OK I see. But if we later change entry_Section to be more flexible we will get into trouble. Still, that is what test coverage is for, so I think it is OK to not check the return value and add a comment as to why.
Regards, SImon
Alper Nebi Yasak
