[U-Boot] [PATCH] S5PC2XX: GPIO Macro Values Corrected.
Macro values for Pull Up and Driver Strength were wrong.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/include/asm/arch-s5pc2xx/gpio.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc2xx/gpio.h b/arch/arm/include/asm/arch-s5pc2xx/gpio.h index 05e5b3e..7bfa8e8 100644 --- a/arch/arm/include/asm/arch-s5pc2xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc2xx/gpio.h @@ -99,12 +99,12 @@ void gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); /* Pull mode */ #define GPIO_PULL_NONE 0x0 #define GPIO_PULL_DOWN 0x1 -#define GPIO_PULL_UP 0x2 +#define GPIO_PULL_UP 0x3
/* Drive Strength level */ #define GPIO_DRV_1X 0x0 -#define GPIO_DRV_2X 0x1 -#define GPIO_DRV_3X 0x2 +#define GPIO_DRV_2X 0x2 +#define GPIO_DRV_3X 0x1 #define GPIO_DRV_4X 0x3 #define GPIO_DRV_FAST 0x0 #define GPIO_DRV_SLOW 0x1
Dear Chander Kashyap,
Please make orders correctly (0x0, 0x1, 0x2, 0x3)
Nice catch : )
Could please fix s5pc1xx also? Please make it one patch.
Thanks. Minkyu Kang.
Dear Minkyu,
gpio, int mode);
Will do the same.
Nice catch : )
No need to change. As existing gpio configuration is as per s5pc1xx specification.
Thanks. Minkyu Kang. -- from. prom. www.promsoft.net
regards, Chander
According to S5PC110 TRM, DRV levels are as following,
00 = 1x 10 = 2x 01 = 3x 11 = 4x
Please fix it at s5pc1xx also.
Thanks Minkyu Kang.
Dear Minkyu,
As per the s5pc110 user manual I have existing configuration is right. If you are sure then I will change it and resubmit the patch.
Thanks Minkyu Kang. -- from. prom. www.promsoft.net
regards, Chander
Chander Kashyap
Minkyu Kang
