Please pull u-boot-x86
Hi Tom,
This PR includes the following x86 changes for v2021.04:
- Fix CMD_ACPI dependency in Kconfig - Correct overflow in __udelay() in TSC timer driver - Add a devicetree node for eMMC for Coral - Minor improvements on image loading - Reduce size of Samus image
Azure results: PASS https://dev.azure.com/bmeng/GitHub/_build/results?buildId=316&view=resul...
The following changes since commit b4804cdd5747d1d932bd338e0ca102ade51b8b6b:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-usb (2021-01-31 14:24:35 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to 77f898d04095cdccb69c476ba0aa19f257fca64d:
x86: Reduce size of samus image (2021-02-01 15:33:26 +0800)
---------------------------------------------------------------- Heinrich Schuchardt (1): cmd: CMD_ACPI depends on ACPIGEN
Simon Glass (14): x86: tsc_timer: Correct overflow in __udelay() x86: coral: Add a devicetree node for eMMC acpi: Tidy up documentation for struct acpi_gpio x86: acpi_gpe: Update driver name to match devicetree x86: spl: Add a function to find the text base x86: apl: Enhance debugging in the SPL loader x86: Make sure the SPL image ends on a suitable boundary x86: spl: Make moving BSS conditional x86: Update Chromium OS GNVS names x86: zimage: Allow dumping the image from outside the module x86: zimage: Improve command-line debug handling x86: spl: Clear BSS unconditionally x86: tpl: Show next stage being booted x86: Reduce size of samus image
arch/x86/cpu/acpi_gpe.c | 6 ++++-- arch/x86/cpu/apollolake/spl.c | 12 +++++++----- arch/x86/cpu/u-boot-spl.lds | 12 ++++++++++++ arch/x86/dts/chromebook_coral.dts | 6 ++++++ arch/x86/include/asm/intel_gnvs.h | 34 ++++++++++++++++++++++++++++------ arch/x86/include/asm/zimage.h | 10 ++++++++++ arch/x86/lib/spl.c | 2 +- arch/x86/lib/tpl.c | 7 ++++++- arch/x86/lib/zimage.c | 33 ++++++++++++++++++++++----------- cmd/Kconfig | 3 ++- common/spl/spl.c | 6 ++++++ configs/chromebook_samus_defconfig | 1 + drivers/timer/tsc_timer.c | 2 +- include/acpi/acpi_device.h | 9 +++++---- include/configs/chromebook_samus.h | 3 +++ include/spl.h | 10 ++++++++++ 16 files changed, 124 insertions(+), 32 deletions(-)
Regards, Bin
On Mon, Feb 01, 2021 at 05:37:17PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
