[U-Boot] [PATCH] imx: iomux-v3: fix pad setup on i.MX6DQP when CONFIG_MX6QDL is defined
The CPU detection macro is_mx6dq returns 0 on an i.MX6DQP, so we need to check for it explicitly in order to correctly initialize the pads when CONFIG_MX6QDL is defined.
Signed-off-by: Filip Brozovic fbrozovic@gmail.com --- arch/arm/imx-common/iomux-v3.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/imx-common/iomux-v3.c b/arch/arm/imx-common/iomux-v3.c index 66137d1..2612e09 100644 --- a/arch/arm/imx-common/iomux-v3.c +++ b/arch/arm/imx-common/iomux-v3.c @@ -83,7 +83,7 @@ void imx_iomux_v3_setup_multiple_pads(iomux_v3_cfg_t const *pad_list,
#if defined(CONFIG_MX6QDL) stride = 2; - if (!is_mx6dq()) + if (!is_mx6dq() && !is_mx6dqp()) p += 1; #else stride = 1;
- if (!is_mx6dq())
- if (!is_mx6dq() && !is_mx6dqp()) p += 1;
#else stride = 1;
Best regards, Stefano Babic
Filip Brozovic
Stefano Babic
