[U-Boot] [PATCH V2] ppc4xx: use SPRN_TCR macro instead of tcr
This patch migrates 4xx code from using the lowercase tcr macro to the SPRN_TCR macro. Both macros have been defined in the past. So one is to much and uppercase macros are much more common.
The lowercase macro conflicts with the upcoming introduction of the ppc4xx_gpio struct and it's tcr field.
Doing more such migration and getting rid of many defines from include/ppc405.h and include/ppc440.h should be put on our TODO list.
patch v2: better use SPRN_TCR instead of TCR
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- cpu/ppc4xx/cpu_init.c | 4 ++-- cpu/ppc4xx/interrupts.c | 8 ++++---- cpu/ppc4xx/start.S | 2 +- include/ppc405.h | 1 - include/ppc440.h | 1 - 5 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index bbd795d..58b23a0 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -248,7 +248,7 @@ cpu_init_f (void) #endif
#if defined(CONFIG_WATCHDOG) - val = mfspr(tcr); + val = mfspr(SPRN_TCR); #if defined(CONFIG_440EP) || defined(CONFIG_440GR) val |= 0xb8000000; /* generate system reset after 1.34 seconds */ #elif defined(CONFIG_440EPX) @@ -260,7 +260,7 @@ cpu_init_f (void) val &= ~0x30000000; /* clear WRC bits */ val |= CONFIG_SYS_4xx_RESET_TYPE << 28; /* set board specific WRC type */ #endif - mtspr(tcr, val); + mtspr(SPRN_TCR, val);
val = mfspr(tsr); val |= 0x80000000; /* enable watchdog timer */ diff --git a/cpu/ppc4xx/interrupts.c b/cpu/ppc4xx/interrupts.c index 494bd8c..9883903 100644 --- a/cpu/ppc4xx/interrupts.c +++ b/cpu/ppc4xx/interrupts.c @@ -102,9 +102,9 @@ int interrupt_init_cpu (unsigned *decrementer_count) * Init PIT */ #if defined(CONFIG_440) - val = mfspr( tcr ); + val = mfspr( SPRN_TCR ); val &= (~0x04400000); /* clear DIS & ARE */ - mtspr( tcr, val ); + mtspr( SPRN_TCR, val ); mtspr( dec, 0 ); /* Prevent exception after TSR clear*/ mtspr( decar, 0 ); /* clear reload */ mtspr( tsr, 0x08000000 ); /* clear DEC status */ @@ -126,9 +126,9 @@ int interrupt_init_cpu (unsigned *decrementer_count) /* * Enable PIT */ - val = mfspr(tcr); + val = mfspr(SPRN_TCR); val |= 0x04400000; - mtspr(tcr, val); + mtspr(SPRN_TCR, val);
/* * Set EVPR to 0 diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 582c781..0476b5e 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -626,7 +626,7 @@ _start: mtspr tbl,r0 /* prevent fit & wdt exceptions */ mtspr tbu,r0 mtspr tsr,r1 /* clear all timer exception status */ - mtspr tcr,r0 /* disable all */ + mtspr SPRN_TCR,r0 /* disable all */ mtspr esr,r0 /* clear exception syndrome register */ mtxer r0 /* clear integer exception register */
diff --git a/include/ppc405.h b/include/ppc405.h index 917afec..50fc7be 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -61,7 +61,6 @@ #define dear 0x3d5 /* data exeption address register */ #define evpr 0x3d6 /* exeption vector prefix register */ #define tsr 0x3d8 /* timer status register */ - #define tcr 0x3da /* timer control register */ #define pit 0x3db /* programmable interval timer */ #define sgr 0x3b9 /* storage guarded reg */ #define dcwr 0x3ba /* data cache write-thru reg*/ diff --git a/include/ppc440.h b/include/ppc440.h index 01f6eaf..df78eea 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -90,7 +90,6 @@ #define dvc1 0x13e /* data value compare 1 */ #define dvc2 0x13f /* data value compare 2 */ #define tsr 0x150 /* timer status register */ -#define tcr 0x154 /* timer control register */ #define ivor0 0x190 /* interrupt vector offset register 0 */ #define ivor1 0x191 /* interrupt vector offset register 1 */ #define ivor2 0x192 /* interrupt vector offset register 2 */
Dear Matthias Fuchs,
Hm... why are you just fixing this single register? It's not the only one...
_ALL_ these #defines for Special Purpose Registers should go away. They are redundant.
You are right. As you might think of, I want to get my PMC405DE board support patch accepted in this closing merge window. I also noticed that there are other macros that are obsolete and tha't why I netioned this in my commit message. So I am aware of this. But that's another story.
I will see if I find some time later today.
Matthias
Matthias Fuchs
