[U-Boot] [PATCH] x86: Fix various code format issues in start16.S
Various minor code format issues are fixed in start16.S: - U-boot -> U-Boot - 32bit -> 32-bit - Use TAB instead of SPACE to indent - Move the indention location of the GDT comment block
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/start16.S | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/start16.S b/arch/x86/cpu/start16.S index 9550502..826e2b4 100644 --- a/arch/x86/cpu/start16.S +++ b/arch/x86/cpu/start16.S @@ -1,5 +1,5 @@ /* - * U-boot - x86 Startup Code + * U-Boot - x86 Startup Code * * (C) Copyright 2008-2011 * Graeme Russ, graeme.russ@gmail.com @@ -28,7 +28,7 @@ start16: movl $GD_FLG_COLD_BOOT, %ebx
xorl %eax, %eax - movl %eax, %cr3 /* Invalidate TLB */ + movl %eax, %cr3 /* Invalidate TLB */
/* Turn off cache (this might require a 486-class CPU) */ movl %cr0, %eax @@ -49,7 +49,7 @@ o32 cs lgdt gdt_ptr jmp ff ff:
- /* Finally restore BIST and jump to the 32bit initialization code */ + /* Finally restore BIST and jump to the 32-bit initialization code */ movw $code32start, %ax movw %ax, %bp movl %ecx, %eax @@ -64,17 +64,17 @@ idt_ptr: .word 0 /* limit */ .long 0 /* base */
-/* - * The following Global Descriptor Table is just enough to get us into - * 'Flat Protected Mode' - It will be discarded as soon as the final - * GDT is setup in a safe location in RAM - */ + /* + * The following Global Descriptor Table is just enough to get us into + * 'Flat Protected Mode' - It will be discarded as soon as the final + * GDT is setup in a safe location in RAM + */ gdt_ptr: .word 0x1f /* limit (31 bytes = 4 GDT entries - 1) */ .long BOOT_SEG + gdt /* base */
-/* Some CPUs are picky about GDT alignment... */ -.align 16 + /* Some CPUs are picky about GDT alignment... */ + .align 16 gdt: /* * The GDT table ...
- U-boot -> U-Boot
- 32bit -> 32-bit
- U-boot -> U-Boot
- 32bit -> 32-bit
Applied to u-boot-x86, thanks!
Bin Meng
