[U-Boot] [v2 patch] net: fman: Support both new and legacy FMan Compatibles
Recently the FMan Port and MAC compatibles were changed. This patch aligns the FMan Port and MAC compatibles to the new FMan device tree binding document. The FMan device tree binding document can be found in the Linux kernel: version 3.18.0 commit 297d35fd2a7d3fbd4e5c0f0c1c18213117ba11ba ./Documentation/devicetree/bindings/powerpc/fsl/fman.txt
This patch doesn't affect legacy compatibles support.
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- Changes for v2 - add kernel version and commit id modifing the binding
drivers/net/fm/init.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 71c3abe..48344f0 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -329,7 +329,8 @@ void fdt_fixup_fman_ethernet(void *blob) ft_fixup_port(blob, &fm_info[i], "fsl,fman-1g-mac"); } else { - if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) + if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec") && + ft_fixup_port(blob, &fm_info[i], "fsl,fman-xgec")) ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac"); }
Changes for v2
Is this logic correct? You want success return from fixing up _both_ fman-tgec and fman-xgec before fixup fman-10-mac?
York
fman-10-mac, tgec and xgec is the different version compatible, it used fman-10-mac at the first time, then modified to tgec and now xgec. If it fix up successfully with fman-10-mac, it will return 0, and doesn't fix up for the other two compatible. If failed with fman-tgec, then to fix up for fsl,fman-xgec, if success, return 0 and doesn't fix up for fman-10-mac.
BR Qiang Zhao
Joe Hershberger
Qiang Zhao
York Sun
Zhao Qiang
