Re: [PATCH 07/11] net: dwc_eth_qos: Use consistent logging prints
On 3/9/24 03:11, Marek Vasut wrote:
Use dev_*() only to print all the logs from this glue code, instead of mixing dev_*(), log_*(), pr_*() all in one code.
Signed-off-by: Marek Vasut marex@denx.de
Cc: Christophe Roullier christophe.roullier@st.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Ramon Fried rfried.dev@gmail.com Cc: u-boot@dh-electronics.com Cc: uboot-stm32@st-md-mailman.stormreply.com
drivers/net/dwc_eth_qos_stm32.c | 52 ++++++++++++++++++--------------- 1 file changed, 28 insertions(+), 24 deletions(-)
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 38037c47954..72f65f80540 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -63,36 +63,36 @@ static int eqos_start_clks_stm32(struct udevice *dev) if (!CONFIG_IS_ENABLED(CLK)) return 0;
debug("%s(dev=%p):\n", __func__, dev);
dev_dbg(dev, "%s:\n", __func__); ret = clk_enable(&eqos->clk_master_bus); if (ret < 0) {
pr_err("clk_enable(clk_master_bus) failed: %d", ret);
dev_err(dev, "clk_enable(clk_master_bus) failed: %d\n", ret); goto err; } ret = clk_enable(&eqos->clk_rx); if (ret < 0) {
pr_err("clk_enable(clk_rx) failed: %d", ret);
dev_err(dev, "clk_enable(clk_rx) failed: %d\n", ret); goto err_disable_clk_master_bus; } ret = clk_enable(&eqos->clk_tx); if (ret < 0) {
pr_err("clk_enable(clk_tx) failed: %d", ret);
dev_err(dev, "clk_enable(clk_tx) failed: %d\n", ret); goto err_disable_clk_rx; } if (clk_valid(&eqos->clk_ck) && !eqos->clk_ck_enabled) { ret = clk_enable(&eqos->clk_ck); if (ret < 0) {
pr_err("clk_enable(clk_ck) failed: %d", ret);
dev_err(dev, "clk_enable(clk_ck) failed: %d\n", ret); goto err_disable_clk_tx; } eqos->clk_ck_enabled = true; }
debug("%s: OK\n", __func__);
dev_dbg(dev, "%s: OK\n", __func__); return 0;
err_disable_clk_tx:
@@ -102,7 +102,8 @@ err_disable_clk_rx: err_disable_clk_master_bus: clk_disable(&eqos->clk_master_bus); err:
debug("%s: FAILED: %d\n", __func__, ret);
dev_dbg(dev, "%s: FAILED: %d\n", __func__, ret);
}return ret;
@@ -113,13 +114,14 @@ static int eqos_stop_clks_stm32(struct udevice *dev) if (!CONFIG_IS_ENABLED(CLK)) return 0;
dev_dbg(dev, "%s:\n", __func__); clk_disable(&eqos->clk_tx); clk_disable(&eqos->clk_rx); clk_disable(&eqos->clk_master_bus);
}return 0;
@@ -143,20 +145,20 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev,
switch (interface_type) { case PHY_INTERFACE_MODE_MII:
log_debug("PHY_INTERFACE_MODE_MII\n");
dev_dbg(dev, "PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL; break; case PHY_INTERFACE_MODE_GMII:
log_debug("PHY_INTERFACE_MODE_GMII\n");
dev_dbg(dev, "PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); if (eth_clk_sel_reg) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; case PHY_INTERFACE_MODE_RMII:
log_debug("PHY_INTERFACE_MODE_RMII\n");
dev_dbg(dev, "PHY_INTERFACE_MODE_RMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RMII); if (eth_ref_clk_sel_reg)
@@ -166,15 +168,15 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_RGMII_RXID: case PHY_INTERFACE_MODE_RGMII_TXID:
log_debug("PHY_INTERFACE_MODE_RGMII\n");
dev_dbg(dev, "PHY_INTERFACE_MODE_RGMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RGMII); if (eth_clk_sel_reg) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; default:
log_debug("Do not manage %d interface\n",
interface_type);
dev_dbg(dev, "Do not manage %d interface\n",
interface_type); /* Do not manage others interfaces */ return -EINVAL; }
@@ -194,12 +196,12 @@ static int eqos_probe_resources_stm32(struct udevice *dev) phy_interface_t interface; int ret;
dev_dbg(dev, "%s:\n", __func__); interface = eqos->config->interface(dev); if (interface == PHY_INTERFACE_MODE_NA) {
pr_err("Invalid PHY interface\n");
dev_err(dev, "Invalid PHY interface\n"); return -EINVAL; }
@@ -209,39 +211,41 @@ static int eqos_probe_resources_stm32(struct udevice *dev)
ret = clk_get_by_name(dev, "stmmaceth", &eqos->clk_master_bus); if (ret) {
pr_err("clk_get_by_name(master_bus) failed: %d", ret);
dev_err(dev, "clk_get_by_name(master_bus) failed: %d\n", ret); goto err_probe; } ret = clk_get_by_name(dev, "mac-clk-rx", &eqos->clk_rx); if (ret) {
pr_err("clk_get_by_name(rx) failed: %d", ret);
dev_err(dev, "clk_get_by_name(rx) failed: %d\n", ret); goto err_probe; } ret = clk_get_by_name(dev, "mac-clk-tx", &eqos->clk_tx); if (ret) {
pr_err("clk_get_by_name(tx) failed: %d", ret);
dev_err(dev, "clk_get_by_name(tx) failed: %d\n", ret); goto err_probe; } /* Get ETH_CLK clocks (optional) */ ret = clk_get_by_name(dev, "eth-ck", &eqos->clk_ck); if (ret)
pr_warn("No phy clock provided %d", ret);
dev_warn(dev, "No phy clock provided %d\n", ret);
debug("%s: OK\n", __func__); return 0;
err_probe:
debug("%s: returns %d\n", __func__, ret);
dev_dbg(dev, "%s: returns %d\n", __func__, ret);
return ret;
static int eqos_remove_resources_stm32(struct udevice *dev) {
dev_dbg(dev, "%s:\n", __func__); return 0;
Reviewed-by: Christophe ROULLIER christophe.roullier@foss.st.com
Christophe ROULLIER
