[U-Boot] [PATCH] rockchip: rk3399: Add Libre Computer Board ROC-RK3399-PC
Add initial support for Libre Computer Board ROC-RK3399-PC.
Specification - Rockchip RK3399 - 4GB LPDDR4 dual-channel 64-bit RAM - SD card slot - eMMC socket - 16M Byte SPI Flash - Gigabit ethernet - PCIe 4X slot - WiFI/BT module socket - HDMI Out, DP, MIPI DSI/CSI, eDP - USB 2.0 Hostx3 Type-Cx2 - USB Type C power - M-Key to expand SSD
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: Linux need to merge this dts, so please wait so-that I will send v2 with sync commit.
arch/arm/dts/Makefile | 1 + ...rk3399-libretech-roc-rk3399-pc-u-boot.dtsi | 7 + .../dts/rk3399-libretech-roc-rk3399-pc.dts | 680 ++++++++++++++++++ arch/arm/dts/rk3399-roc-pc.dts | 2 + board/rockchip/evb_rk3399/MAINTAINERS | 6 + configs/libretech-rock-rk3399-pc_defconfig | 45 ++ 6 files changed, 741 insertions(+) create mode 100644 arch/arm/dts/rk3399-libretech-roc-rk3399-pc-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-libretech-roc-rk3399-pc.dts create mode 100644 configs/libretech-rock-rk3399-pc_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 62da168ef8..0aff6918dd 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -111,6 +111,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-khadas-edge.dtb \ rk3399-khadas-edge-captain.dtb \ rk3399-khadas-edge-v.dtb \ + rk3399-libretech-roc-rk3399-pc.dtb \ rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ rk3399-nanopi-neo4.dtb \ diff --git a/arch/arm/dts/rk3399-libretech-roc-rk3399-pc-u-boot.dtsi b/arch/arm/dts/rk3399-libretech-roc-rk3399-pc-u-boot.dtsi new file mode 100644 index 0000000000..dbfa4ba9f8 --- /dev/null +++ b/arch/arm/dts/rk3399-libretech-roc-rk3399-pc-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr4-100.dtsi" diff --git a/arch/arm/dts/rk3399-libretech-roc-rk3399-pc.dts b/arch/arm/dts/rk3399-libretech-roc-rk3399-pc.dts new file mode 100644 index 0000000000..fecbd362a4 --- /dev/null +++ b/arch/arm/dts/rk3399-libretech-roc-rk3399-pc.dts @@ -0,0 +1,680 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Libre Computer Board ROC-RK3399-PC"; + compatible = "libretech,roc-rk3399-pc", "firefly,roc-rk3399-pc", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm0 0 25000 0>; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + vcc_vbus_typec0: vcc-vbus-typec0 { + compatible = "regulator-fixed"; + regulator-name = "vcc_vbus_typec0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + /* + * should be placed inside mp8859, but not until mp8859 has + * its own dt-binding. + */ + dc_12v: mp8859-dcdc1 { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <&vcc_vbus_typec0>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en &hub_rst>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc_vbus_typec1: vcc-vbus-typec1 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc_vbus_typec1_en>; + regulator-name = "vcc_vbus_typec1"; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + vin-supply = <&vcc3v3_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc1v8_pmu>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_codec: LDO_REG1 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_hdmi: LDO_REG2 { + regulator-name = "vcc1v8_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG3 { + regulator-name = "vcc1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca0v9_hdmi: LDO_REG7 { + regulator-name = "vcca0v9_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: vcc_lan: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel1_gpio>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel2_gpio>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <300>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + fusb1: usb-typec@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb1_int>; + vbus-supply = <&vcc_vbus_typec1>; + status = "okay"; + }; +}; + +&i2c7 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + fusb0: usb-typec@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vcc_vbus_typec0>; + status = "okay"; + }; +}; + +&i2s0 { + rockchip,playback-channels = <8>; + rockchip,capture-channels = <8>; + status = "okay"; +}; + +&i2s1 { + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + status = "okay"; +}; + +&i2s2 { + status = "okay"; +}; + +&io_domains { + audio-supply = <&vcca1v8_codec>; + bt656-supply = <&vcc_3v0>; + gpio1830-supply = <&vcc_3v0>; + sdmmc-supply = <&vcc_sdio>; + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pinctrl { + lcd-panel { + lcd_panel_reset: lcd-panel-reset { + rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + vsel1_gpio: vsel1-gpio { + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + hub_rst: hub-rst { + rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + usb-typec { + vcc_vbus_typec1_en: vcc-vbus-typec1-en { + rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + fusb30x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + fusb1_int: fusb1-int { + rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + phy-supply = <&vcc_vbus_typec0>; + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + phy-supply = <&vcc_vbus_typec1>; + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3399-roc-pc.dts b/arch/arm/dts/rk3399-roc-pc.dts index 19f7732d72..c53f3d5716 100644 --- a/arch/arm/dts/rk3399-roc-pc.dts +++ b/arch/arm/dts/rk3399-roc-pc.dts @@ -548,6 +548,8 @@ };
&pwm2 { + pinctrl-names = "active"; + pinctrl-0 = <&pwm2_pin_pull_down>; status = "okay"; };
diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index f8299d9460..16ed0d3e3d 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -24,6 +24,12 @@ S: Maintained F: configs/khadas-edge-v-rk3399_defconfig F: arch/arm/dts/rk3399-khadas-edge-v-u-boot.dtsi
+LIBRETECH ROC-RK3399-PC +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/libretech-rock-rk3399-pc_defconfig +F: arch/arm/dts/rk3399-libretech-roc-rk3399-pc-u-boot.dtsi + NANOPC-T4 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/libretech-rock-rk3399-pc_defconfig b/configs/libretech-rock-rk3399-pc_defconfig new file mode 100644 index 0000000000..78a1209bee --- /dev/null +++ b/configs/libretech-rock-rk3399-pc_defconfig @@ -0,0 +1,45 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x50000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-libretech-roc-rk3399-pc.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-libretech-roc-rk3399-pc" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
Jagan,
Specification
- Rockchip RK3399
- SD card slot
- eMMC socket
- Gigabit ethernet
- PCIe 4X slot
- USB Type C power
Are you going to update v2 for this patch?
Thanks,
- Kever
- rk3399-libretech-roc-rk3399-pc.dtb \ rk3399-nanopc-t4.dtb \ rk3399-nanopi-m4.dtb \ rk3399-nanopi-neo4.dtb \
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
- Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd
- model = "Libre Computer Board ROC-RK3399-PC";
- compatible = "libretech,roc-rk3399-pc", "firefly,roc-rk3399-pc", "rockchip,rk3399";
- chosen {
- backlight: backlight {
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- sdio_pwrseq: sdio-pwrseq {
- vcc_vbus_typec0: vcc-vbus-typec0 {
regulator-boot-on;
- dc_12v: mp8859-dcdc1 {
regulator-boot-on;
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
- vcc_vbus_typec1: vcc-vbus-typec1 {
enable-active-high;
- vcc_sys: vcc-sys {
regulator-boot-on;
- vdd_log: vdd-log {
regulator-boot-on;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc_lan>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
+&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
+&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- status = "okay";
+&i2c4 {
- i2c-scl-rising-time-ns = <600>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- fusb1: usb-typec@22 {
reg = <0x22>;
status = "okay";
+&i2c7 {
- status = "okay";
- fusb0: usb-typec@22 {
reg = <0x22>;
status = "okay";
+&i2s0 {
- rockchip,playback-channels = <8>;
- rockchip,capture-channels = <8>;
- status = "okay";
+&i2s1 {
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>;
- status = "okay";
+&i2s2 {
- status = "okay";
+&io_domains {
- audio-supply = <&vcca1v8_codec>;
- bt656-supply = <&vcc_3v0>;
- gpio1830-supply = <&vcc_3v0>;
- sdmmc-supply = <&vcc_sdio>;
- status = "okay";
+&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0>;
- status = "okay";
+&pinctrl {
- lcd-panel {
- pmic {
- sdio-pwrseq {
- pmic {
- usb2 {
hub_rst: hub-rst {
- usb-typec {
- fusb30x {
+&pwm0 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
+&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- rockchip,hw-tshut-mode = <1>;
- /* tshut polarity 0:LOW 1:HIGH */
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
+&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
+&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
- u2phy1_host: host-port {
status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
&pwm2 {
- pinctrl-names = "active";
- pinctrl-0 = <&pwm2_pin_pull_down>; status = "okay"; };
- NANOPC-T4 M: Jagan Teki jagan@amarulasolutions.com S: Maintained
Jagan Teki
Kever Yang
