[U-Boot] [PATCH 1/2] net: phy: marvell: Call phy_reset() where possible
Instead of coding the soft PHY reset function multiple times in marvell.c, lets call the common phy_reset() function from phy.c.
Signed-off-by: Stefan Roese sr@denx.de Cc: Stefan Agner stefan@agner.ch Cc: Hao Zhang hzhang@ti.com Cc: Michal Simek monstr@monstr.eu Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/marvell.c | 23 ++--------------------- 1 file changed, 2 insertions(+), 21 deletions(-)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index eab1558..6e3dc85 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -172,7 +172,6 @@ static int m88e1011s_startup(struct phy_device *phydev) static int m88e1111s_config(struct phy_device *phydev) { int reg; - int timeout;
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII) || (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || @@ -236,16 +235,7 @@ static int m88e1111s_config(struct phy_device *phydev) MIIM_88E1111_PHY_EXT_SR, reg);
/* soft reset */ - timeout = 1000; - phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); - udelay(1000); - reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); - while ((reg & BMCR_RESET) && --timeout) { - udelay(1000); - reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); - } - if (!timeout) - printf("%s: phy soft reset timeout\n", __func__); + phy_reset(phydev);
reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1111_PHY_EXT_SR); @@ -258,16 +248,7 @@ static int m88e1111s_config(struct phy_device *phydev) }
genphy_config_aneg(phydev);
With commit a058052c [net: phy: do not read configuration register on reset], phy_reset() will clear the BMCR register. Resulting in bit 12 being cleared (A/N enable). This leads to autonegotiation link problems, at least on the Marvell Armada ClearFog board. I suspect that other boards using this driver will be affected as well.
At the of m88e1111s_config(), phy_reset() is called. This is not needed for the PHY to load the changed configuration, as phy_reset() is called a few lines before already. So lets call genphy_restart_aneg() here instead to start the AN correctly.
Tested on clearfog.
Signed-off-by: Stefan Roese sr@denx.de Cc: Stefan Agner stefan@agner.ch Cc: Hao Zhang hzhang@ti.com Cc: Michal Simek monstr@monstr.eu Cc: Andy Fleming afleming@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/marvell.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index 6e3dc85..b8b1157 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -251,8 +251,7 @@ static int m88e1111s_config(struct phy_device *phydev) phy_reset(phydev);
genphy_config_aneg(phydev); - - phy_reset(phydev); + genphy_restart_aneg(phydev);
return 0; }
Tested on clearfog.
Joe Hershberger
Joe Hershberger
Stefan Roese
