[U-Boot] [RFC PATCH 1/2] kconfig: re-sync with Linux 4.17-rc4
Align Kconfig to Linux 4.17-rc4 with minimal impact on non-kconfig files.
Previous Kconfig sync was done by commit bf7ab1e70fd762 ("kconfig: re-sync with Linux 4.10") and it achieved almost perfect alignment with a few (intended) exceptions, caused by below U-boot commits:
[A] v2015.04 5f9eb2207500 ("kbuild: remove scripts/multiconfig.sh") [B] v2015.07 20c20826efab ("Kconfig: Enable usage of escape char '' in string values") [C] v2016.01 da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") [D] v2016.03 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") [E] v2016.03 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.")
Here is the list of Kconfig commits which followed the v4.10 alignment:
[F] v2018.01 0931ed3c0d0f ("kconfig/symbol.c: use correct pointer type argument for sizeof") [G] v2018.03 1414e09b4f25 ("kconfig: revert change that was not needed for -Wformat-security") [H] v2018.05 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style")
Commit [F] was subsequently applied to Linux kernel as commit [I] with the same patch id, so it won't contribute to further misalignment.
[I] v4.15-rc1 88127dae6ed9 ("kconfig/symbol.c: use correct pointer type argument for sizeof")
Commit [G] is a Kconfig-specific revert of commit [E]. Commit [H] relocated and reformatted the license doing no functional change.
In summary, the only functional change that makes U-boot Kconfig diverge from Linux Kconfig is commit [B]. After a brief analysis, the purpose of [B] seems to be placing "\n" literals in string symbols like CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" in order to pass them directly to printf and expect correct output at runtime. Currently, Linux doesn't seem to have this requirement, so for the moment [B] looks like a U-boot specific feature/fix. From point of view of further Kconfig alignment and backporting efforts, it is highly desired that commits like [B] are propagated to Linux and any Kconfig fixes/features are contributed to Linux kernel first. This specific Kconfig re-sync just keeps [B] in place.
Contrary to 4.10 Kconfig re-sync (which achieves zero non-kconfig changes), 4.17-rc4 re-sync does some amount of updates in Kbuild (striving to keep them at minimum), due to a number of reasons: * Kbuild is affected by the removal of Kconfig "*shipped" files and now requires flex and bison pre-installed on the host. * PYTHON{2,3} variables are defined in top-level Makefile as prerequisite for running the newly developed Kconfig unit tests. * silentoldconfig becomes an "internal implementation detail" deprecated for external use, being renamed to syncconfig.
The exact non-kconfig files touched by this commit are:
$ git show --format="" --stat -- ':!scripts/kconfig' .gitignore | 2 ++ Makefile | 9 +++++++-- scripts/Makefile.build | 11 +++++++++++ scripts/Makefile.lib | 41 ++++++++++++-----------------------------
The imported Linux commits touching the above files are:
c054be10ffdbd5 ("remove gperf left-overs from build system") 73a4f6dbe70a1b ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ("kbuild: prepare to remove C files pre-generated by flex and bison") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 911a91c39cabcb H ("kconfig: rename silentoldconfig to syncconfig") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e H ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 H ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") e9781b52d4e0e3 H ("kbuild: add PYTHON2 and PYTHON3 variables")
The commits marked with 'H' are assessed as "hard" (build will fail) prerequisites and the rest of them are assessed as "soft" prerequisites for the re-sync. In spite of relatively high number of non-H commits, they belong to this Kconfig update topic-wise and decrease the number of cherry pick conflicts for many commits in this series. Additional effort can be put in eliminating the soft prerequisites, if really needed.
The commits which contributed to this Kconfig re-sync are listed below. Whenever a conflict resolution has been performed (mostly by hand, but sometimes automatically by git), it is revealed by the '!' sign in the second column, which means a patch id mismatch between Linux and U-boot commits:
9be3213b14d44f ("gconfig: remove misleading parentheses around a condition") ff85a1a80e0034 ("kconfig: Check for libncurses before menuconfig") ad8181060788c8 ("kconfig: fix sparse warnings in nconfig") cb77f0d623ff33 ! ("scripts: Switch to more portable Perl shebang") bb3290d91695bb ! ("Remove gperf usage from toolchain") c054be10ffdbd5 ("remove gperf left-overs from build system") b24413180f5600 ! ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") 9059a3493efea6 ! ("kconfig: fix relational operators for bool and tristate symbols") 2c37e08464a850 ("kconfig: Warn if choice default is not in choice") 33ca1a24866373 ("kconfig: Document the 'menu' struct") 52aede4ba5efd1 ("kconfig: Document the 'symbol' struct") c873443430ebd1 ("kconfig: Sync zconf.y with zconf.tab.c_shipped") 9a826842ff2fbd ("kconfig: Rename menu_check_dep() to rewrite_m()") fa8cedaef814ce ("kconfig: Clarify expression rewriting") f77850d3fe0c96 ("kconfig: Clean up modules handling and fix crash") e3b03bf29d6b99 ("kconfig: display recursive dependency resolution hint just once") 73a4f6dbe70a1b ! ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ! ("kbuild: prepare to remove C files pre-generated by flex and bison") 29c833061c1d8c ("kconfig: generate lexer and parser during build instead of shipping") 26e47a3c11a25c ("kconfig: Don't leak symbol names during parsing") 24161a6711c945 ("kconfig: Don't leak 'source' filenames during parsing") bc28fe1d5ede88 ("kconfig: Don't leak 'option' arguments during parsing") 0724a7c32a54e3 ("kconfig: Don't leak main menus during parsing") ae7440ef0c8013 ("kconfig: Fix automatic menu creation mem leak") 5b1374b3b3c2fc ("kconfig: Fix expr_free() E_NOT leak") 7cf33f88e29410 ("kconfig: Fix choice symbol expression leak") 05cccce580456d ("kconfig: Document automatic submenu creation code") 0735f7e5def2ab ("kconfig: Document important expression functions") df60f4b92d3d0b ("kconfig: Remove menu_end_entry()") b92d804a51796b ("kconfig: drop 'boolean' keyword") 6479f327dea60d ("kconfig: Warn if there is more than one help text") 52e58a3caeba5d ("kconfig: make input_mode static") 5a3dc717b3c785 ("kconfig: make xfgets() really static") 84dd95d4f87a0d ("kconfig: make conf_unsaved a local variable of conf_read()") 765f4cdef6f80d ("kconfig: use default 'yy' prefix for lexer and parser") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ! ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 3e41ba05b6d60c ("kconfig: Document SYMBOL_OPTIONAL logic") d3465af60f4471 ("kconfig: Clarify choice dependency propagation") 9d1a9e8bc18bea ("kconfig: Document 'if' flattening logic") b53688014e3325 ("kconfig: Clarify menu and 'if' dependency propagation") d0fd0428ecf04b ("kconfig: fix make xconfig when gettext is missing") 312ee68752faaa ("kconfig: announce removal of oldnoconfig if used") 1ccb27143360bd ("kconfig: make "Selected by:" and "Implied by:" readable") cedd55d49dee94 ! ("kconfig: Remove silentoldconfig from help and docs; fix kconfig/conf's help") 1b9eda2e4892cb ("kconfig: Warn if help text is blank") cb67ab2cd2b8ab ("kconfig: do not write choice values when their dependency becomes n") 4f208f392103e8 ("kconfig: show '?' prompt even if no help text is available") cd58a91def2acc ("kconfig: remove 'config*' pattern from .gitignnore") d2a04648a5dbc3 ("kconfig: remove check_stdin()") f3ff6fb5db68bc ("kconfig: echo stdin to stdout if either is redirected") 9e3e10c725360b ("kconfig: send error messages to stderr") d717f24d8c6808 ("kconfig: add xrealloc() helper") 523ca58b7db2e3 ("kconfig: remove const qualifier from sym_expand_string_value()") cd81fc82b93fa4 ("kconfig: add xstrdup() helper") f4bc1eefc1608e ("kconfig: set SYMBOL_AUTO to the symbol marked with defconfig_list") bf0bbdcf100322 ("kconfig: Don't leak choice names during parsing") 1a90ce36c6eff6 ("kconfig: Update ncurses package names for menuconfig") 5ae6fcc4bb82bd ("kconfig: fix line number in recursive inclusion error message") 07a422bb213adb ! ("kbuild: restore autoksyms.h touch to the top Makefile") 9a47ceec543bfb ("kconfig: clean-up reverse dependency help implementation") d9119b5925a03b ("kconfig: Print reverse dependencies in groups") f467c5640c29ad ("kconfig: only write '# CONFIG_FOO is not set' for visible symbols") 59a80b5e892dde ("kconfig: do not call check_conf() for olddefconfig") 4bb3a5b085cd6f ("kconfig: remove unneeded input_mode test in conf()") 99f0b6578bab44 ("kconfig: remove redundant input_mode test for check_conf() loop") 2aad9b89621386 ("kconfig: hide irrelevant sub-menus for oldconfig") 81d2bc2273052e ("kconfig: invoke oldconfig instead of silentoldconfig from local*config") 911a91c39cabcb ! ("kconfig: rename silentoldconfig to syncconfig") 2a61625835c7c8 ! ("kconfig: remove redundant streamline_config.pl prerequisite") 022a4bf6b59dfd ("kconfig: tests: add framework for Kconfig unit testing") 1903c511905984 ("kconfig: tests: add basic choice tests") 49ac3c0c3aa3b7 ("kconfig: tests: test automatic submenu creation") b76960c0f6b25d ("kconfig: tests: test if new symbols in choice are asked") 930c429a656fdb ("kconfig: tests: check unneeded "is not set" with unmet dependency") ee236610653ede ("kconfig: tests: check visibility of tristate choice values in y choice") beaaddb625400e ("kconfig: tests: test defconfig when two choices interact") 3e4888c2e3d77d ("kconfig: tests: test randconfig for choice in choice") 29c434f367ea7b ("kconfig: tests: test if recursive dependencies are detected") e2c75e7667c737 ("kconfig: tests: test if recursive inclusion is detected") f622f827958162 ("kconfig: warn unmet direct dependency of tristate symbols selected by y") f8f69dc0b4e070 ("kconfig: make unmet dependency warnings readable") 26561514cc9def ("kconfig: do not include both curses.h and ncurses.h for nconfig") 32a94b8b0c3e5a ("kconfig: remove duplicated file name and lineno of recursive inclusion") 379a8eb8eb1a55 ("kconfig: detect recursive inclusion earlier") 18492685e479fd ("kconfig: use yylineno option instead of manual lineno increments") 59889300274569 ! (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ! ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e ! ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 ! ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 17baab68d337a0 ("kconfig: extend output of 'listnewconfig'") e9781b52d4e0e3 ! ("kbuild: add PYTHON2 and PYTHON3 variables")
The current Kconfig update generates below build-time warnings: YACC scripts/dtc/dtc-parser.tab.h scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] YACC scripts/dtc/dtc-parser.tab.c scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr]
This seems to happen because the Kbuild updates apparently didn't make room for both "*shipped"-based builds and flex/bison-based builds. A similar problem has been reported for genksyms parser in v4.17-rc1 commit 833e622459432e ("genksyms: generate lexer and parser during build instead of shipping"). I have figured out empirically that the warnings are healed after updating the in-tree U-boot DTC to upstream v1.4.6-9, same as done by Linux v4.17-rc1 commit 9130ba88464032 ("scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987"). Whether fixing the DTC-related yacc warnings should be done together with the Kconfig re-sync, I would like to hear from community.
My testing was limited to: - make defconfig all - make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- r8a7795_ulcb_defconfig all - comparing .config before and after the re-sync - running the newly imported Kconfig unit tests as seen below:
$ make testconfig
============================= test session starts ============================= scripts/kconfig/tests/auto_submenu/__init__.py::test PASSED [ 7%] scripts/kconfig/tests/choice/__init__.py::test_oldask0 PASSED [ 14%] scripts/kconfig/tests/choice/__init__.py::test_oldask1 PASSED [ 21%] scripts/kconfig/tests/choice/__init__.py::test_allyes PASSED [ 28%] scripts/kconfig/tests/choice/__init__.py::test_allmod PASSED [ 35%] scripts/kconfig/tests/choice/__init__.py::test_allno PASSED [ 42%] scripts/kconfig/tests/choice/__init__.py::test_alldef PASSED [ 50%] scripts/kconfig/tests/choice_value_with_m_dep/__init__.py::test PASSED [ 57%] scripts/kconfig/tests/err_recursive_inc/__init__.py::test PASSED [ 64%] scripts/kconfig/tests/inter_choice/__init__.py::test PASSED [ 71%] scripts/kconfig/tests/new_choice_with_dep/__init__.py::test PASSED [ 78%] scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py::test PASSED [ 85%] scripts/kconfig/tests/rand_nested_choice/__init__.py::test PASSED [ 92%] scripts/kconfig/tests/warn_recursive_dep/__init__.py::test PASSED [100%] ========================== 14 passed in 0.34 seconds ==========================
Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com --- .gitignore | 2 + Makefile | 9 +- scripts/Makefile.build | 11 + scripts/Makefile.lib | 41 +- scripts/kconfig/.gitignore | 5 - scripts/kconfig/Makefile | 49 +- scripts/kconfig/check.sh | 1 + scripts/kconfig/conf.c | 110 +- scripts/kconfig/confdata.c | 10 +- scripts/kconfig/expr.c | 193 +- scripts/kconfig/expr.h | 93 +- scripts/kconfig/gconf.c | 2 +- scripts/kconfig/kconf_id.c | 53 + scripts/kconfig/kxgettext.c | 2 +- scripts/kconfig/list.h | 1 + scripts/kconfig/lkc.h | 6 +- scripts/kconfig/lkc_proto.h | 3 +- scripts/kconfig/lxdialog/check-lxdialog.sh | 4 +- scripts/kconfig/mconf.c | 2 +- scripts/kconfig/menu.c | 195 +- scripts/kconfig/nconf.c | 12 +- scripts/kconfig/nconf.gui.c | 7 +- scripts/kconfig/nconf.h | 4 +- scripts/kconfig/streamline_config.pl | 3 +- scripts/kconfig/symbol.c | 80 +- scripts/kconfig/tests/auto_submenu/Kconfig | 50 + .../kconfig/tests/auto_submenu/__init__.py | 12 + .../tests/auto_submenu/expected_stdout | 10 + scripts/kconfig/tests/choice/Kconfig | 54 + scripts/kconfig/tests/choice/__init__.py | 40 + .../tests/choice/alldef_expected_config | 5 + .../tests/choice/allmod_expected_config | 9 + .../tests/choice/allno_expected_config | 5 + .../tests/choice/allyes_expected_config | 9 + .../tests/choice/oldask0_expected_stdout | 10 + scripts/kconfig/tests/choice/oldask1_config | 2 + .../tests/choice/oldask1_expected_stdout | 15 + .../tests/choice_value_with_m_dep/Kconfig | 19 + .../tests/choice_value_with_m_dep/__init__.py | 15 + .../tests/choice_value_with_m_dep/config | 2 + .../choice_value_with_m_dep/expected_config | 3 + .../choice_value_with_m_dep/expected_stdout | 4 + scripts/kconfig/tests/conftest.py | 291 ++ .../kconfig/tests/err_recursive_inc/Kconfig | 1 + .../tests/err_recursive_inc/Kconfig.inc1 | 4 + .../tests/err_recursive_inc/Kconfig.inc2 | 3 + .../tests/err_recursive_inc/Kconfig.inc3 | 1 + .../tests/err_recursive_inc/__init__.py | 10 + .../tests/err_recursive_inc/expected_stderr | 6 + scripts/kconfig/tests/inter_choice/Kconfig | 23 + .../kconfig/tests/inter_choice/__init__.py | 14 + scripts/kconfig/tests/inter_choice/defconfig | 1 + .../tests/inter_choice/expected_config | 4 + .../kconfig/tests/new_choice_with_dep/Kconfig | 37 + .../tests/new_choice_with_dep/__init__.py | 14 + .../kconfig/tests/new_choice_with_dep/config | 3 + .../tests/new_choice_with_dep/expected_stdout | 10 + .../tests/no_write_if_dep_unmet/Kconfig | 14 + .../tests/no_write_if_dep_unmet/__init__.py | 19 + .../tests/no_write_if_dep_unmet/config | 1 + .../no_write_if_dep_unmet/expected_config | 5 + scripts/kconfig/tests/pytest.ini | 7 + .../kconfig/tests/rand_nested_choice/Kconfig | 33 + .../tests/rand_nested_choice/__init__.py | 16 + .../tests/rand_nested_choice/expected_stdout0 | 2 + .../tests/rand_nested_choice/expected_stdout1 | 4 + .../tests/rand_nested_choice/expected_stdout2 | 5 + .../kconfig/tests/warn_recursive_dep/Kconfig | 62 + .../tests/warn_recursive_dep/__init__.py | 9 + .../tests/warn_recursive_dep/expected_stderr | 30 + scripts/kconfig/util.c | 26 +- scripts/kconfig/zconf.gperf | 50 - scripts/kconfig/zconf.hash.c_shipped | 297 -- scripts/kconfig/zconf.l | 78 +- scripts/kconfig/zconf.lex.c_shipped | 2473 ----------------- scripts/kconfig/zconf.tab.c_shipped | 2471 ---------------- scripts/kconfig/zconf.y | 126 +- 77 files changed, 1692 insertions(+), 5620 deletions(-) create mode 100644 scripts/kconfig/kconf_id.c create mode 100644 scripts/kconfig/tests/auto_submenu/Kconfig create mode 100644 scripts/kconfig/tests/auto_submenu/__init__.py create mode 100644 scripts/kconfig/tests/auto_submenu/expected_stdout create mode 100644 scripts/kconfig/tests/choice/Kconfig create mode 100644 scripts/kconfig/tests/choice/__init__.py create mode 100644 scripts/kconfig/tests/choice/alldef_expected_config create mode 100644 scripts/kconfig/tests/choice/allmod_expected_config create mode 100644 scripts/kconfig/tests/choice/allno_expected_config create mode 100644 scripts/kconfig/tests/choice/allyes_expected_config create mode 100644 scripts/kconfig/tests/choice/oldask0_expected_stdout create mode 100644 scripts/kconfig/tests/choice/oldask1_config create mode 100644 scripts/kconfig/tests/choice/oldask1_expected_stdout create mode 100644 scripts/kconfig/tests/choice_value_with_m_dep/Kconfig create mode 100644 scripts/kconfig/tests/choice_value_with_m_dep/__init__.py create mode 100644 scripts/kconfig/tests/choice_value_with_m_dep/config create mode 100644 scripts/kconfig/tests/choice_value_with_m_dep/expected_config create mode 100644 scripts/kconfig/tests/choice_value_with_m_dep/expected_stdout create mode 100644 scripts/kconfig/tests/conftest.py create mode 100644 scripts/kconfig/tests/err_recursive_inc/Kconfig create mode 100644 scripts/kconfig/tests/err_recursive_inc/Kconfig.inc1 create mode 100644 scripts/kconfig/tests/err_recursive_inc/Kconfig.inc2 create mode 100644 scripts/kconfig/tests/err_recursive_inc/Kconfig.inc3 create mode 100644 scripts/kconfig/tests/err_recursive_inc/__init__.py create mode 100644 scripts/kconfig/tests/err_recursive_inc/expected_stderr create mode 100644 scripts/kconfig/tests/inter_choice/Kconfig create mode 100644 scripts/kconfig/tests/inter_choice/__init__.py create mode 100644 scripts/kconfig/tests/inter_choice/defconfig create mode 100644 scripts/kconfig/tests/inter_choice/expected_config create mode 100644 scripts/kconfig/tests/new_choice_with_dep/Kconfig create mode 100644 scripts/kconfig/tests/new_choice_with_dep/__init__.py create mode 100644 scripts/kconfig/tests/new_choice_with_dep/config create mode 100644 scripts/kconfig/tests/new_choice_with_dep/expected_stdout create mode 100644 scripts/kconfig/tests/no_write_if_dep_unmet/Kconfig create mode 100644 scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py create mode 100644 scripts/kconfig/tests/no_write_if_dep_unmet/config create mode 100644 scripts/kconfig/tests/no_write_if_dep_unmet/expected_config create mode 100644 scripts/kconfig/tests/pytest.ini create mode 100644 scripts/kconfig/tests/rand_nested_choice/Kconfig create mode 100644 scripts/kconfig/tests/rand_nested_choice/__init__.py create mode 100644 scripts/kconfig/tests/rand_nested_choice/expected_stdout0 create mode 100644 scripts/kconfig/tests/rand_nested_choice/expected_stdout1 create mode 100644 scripts/kconfig/tests/rand_nested_choice/expected_stdout2 create mode 100644 scripts/kconfig/tests/warn_recursive_dep/Kconfig create mode 100644 scripts/kconfig/tests/warn_recursive_dep/__init__.py create mode 100644 scripts/kconfig/tests/warn_recursive_dep/expected_stderr delete mode 100644 scripts/kconfig/zconf.gperf delete mode 100644 scripts/kconfig/zconf.hash.c_shipped delete mode 100644 scripts/kconfig/zconf.lex.c_shipped delete mode 100644 scripts/kconfig/zconf.tab.c_shipped
diff --git a/.gitignore b/.gitignore index f1b801579ce7..860b17931794 100644 --- a/.gitignore +++ b/.gitignore @@ -13,6 +13,7 @@ *.su *.mod.c *.i +*.lex.c *.lst *.order *.elf @@ -20,6 +21,7 @@ *.bin *.patch *.cfgtmp +*.tab.[ch]
# host programs on Cygwin *.exe diff --git a/Makefile b/Makefile index f31ee60e4cca..349c99fe8ceb 100644 --- a/Makefile +++ b/Makefile @@ -344,9 +344,13 @@ LDR = $(CROSS_COMPILE)ldr STRIP = $(CROSS_COMPILE)strip OBJCOPY = $(CROSS_COMPILE)objcopy OBJDUMP = $(CROSS_COMPILE)objdump +LEX = flex +YACC = bison AWK = awk PERL = perl PYTHON ?= python +PYTHON2 = python2 +PYTHON3 = python3 DTC ?= $(objtree)/scripts/dtc/dtc CHECK = sparse
@@ -369,7 +373,7 @@ export VERSION PATCHLEVEL SUBLEVEL UBOOTRELEASE UBOOTVERSION export ARCH CPU BOARD VENDOR SOC CPUDIR BOARDDIR export CONFIG_SHELL HOSTCC HOSTCFLAGS HOSTLDFLAGS CROSS_COMPILE AS LD CC export CPP AR NM LDR STRIP OBJCOPY OBJDUMP -export MAKE AWK PERL PYTHON +export MAKE LEX YACC AWK PERL PYTHON PYTHON2 PYTHON3 export HOSTCXX HOSTCXXFLAGS CHECK CHECKFLAGS DTC DTC_FLAGS
export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE OBJCOPYFLAGS LDFLAGS @@ -505,7 +509,7 @@ $(KCONFIG_CONFIG) include/config/auto.conf.cmd: ; # if auto.conf.cmd is missing then we are probably in a cleaned tree so # we execute the config step to be sure to catch updated Kconfig files include/config/%.conf: $(KCONFIG_CONFIG) include/config/auto.conf.cmd - $(Q)$(MAKE) -f $(srctree)/Makefile silentoldconfig + $(Q)$(MAKE) -f $(srctree)/Makefile syncconfig @# If the following part fails, include/config/auto.conf should be @# deleted so "make silentoldconfig" will be re-run on the next build. $(Q)$(MAKE) -f $(srctree)/scripts/Makefile.autoconf || \ @@ -1608,6 +1612,7 @@ clean: $(clean-dirs) ( -name '*.[oas]' -o -name '*.ko' -o -name '.*.cmd' \ -o -name '*.ko.*' -o -name '*.su' -o -name '*.cfgtmp' \ -o -name '.*.d' -o -name '.*.tmp' -o -name '*.mod.c' \ + -o -name '*.lex.c' -o -name '*.tab.[ch]' \ -o -name '*.symtypes' -o -name 'modules.order' \ -o -name modules.builtin -o -name '.tmp_*.o.*' \ -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 4a6ed345928e..482ed0c8d804 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -415,6 +415,17 @@ $(call multi_depend, $(multi-used-m), .o, -objs -y) targets += $(multi-used-y) $(multi-used-m)
+# Add intermediate targets: +# When building objects with specific suffix patterns, add intermediate +# targets that the final targets are derived from. +intermediate_targets = $(foreach sfx, $(2), \ + $(patsubst %$(strip $(1)),%$(sfx), \ + $(filter %$(strip $(1)), $(targets)))) +# %.lex.o <- %.lex.c <- %.l +# %.tab.o <- %.tab.[ch] <- %.y +targets += $(call intermediate_targets, .lex.o, .lex.c) \ + $(call intermediate_targets, .tab.o, .tab.c .tab.h) + # Descending # ---------------------------------------------------------------------------
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index f9809ce7cef5..ef7604c46381 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -209,47 +209,30 @@ $(foreach m, $(notdir $1), \ $(addprefix $(obj)/, $(foreach s, $3, $($(m:%$(strip $2)=%$(s))))))) endef
-ifdef REGENERATE_PARSERS - -# GPERF -# --------------------------------------------------------------------------- -quiet_cmd_gperf = GPERF $@ - cmd_gperf = gperf -t --output-file $@ -a -C -E -g -k 1,3,$$ -p -t $< - -.PRECIOUS: $(src)/%.hash.c_shipped -$(src)/%.hash.c_shipped: $(src)/%.gperf - $(call cmd,gperf) - # LEX # --------------------------------------------------------------------------- -LEX_PREFIX = $(if $(LEX_PREFIX_${baseprereq}),$(LEX_PREFIX_${baseprereq}),yy) - quiet_cmd_flex = LEX $@ - cmd_flex = flex -o$@ -L -P $(LEX_PREFIX) $< + cmd_flex = $(LEX) -o$@ -L $<
-.PRECIOUS: $(src)/%.lex.c_shipped -$(src)/%.lex.c_shipped: $(src)/%.l - $(call cmd,flex) +.PRECIOUS: $(obj)/%.lex.c +$(obj)/%.lex.c: $(src)/%.l FORCE + $(call if_changed,flex)
# YACC # --------------------------------------------------------------------------- -YACC_PREFIX = $(if $(YACC_PREFIX_${baseprereq}),$(YACC_PREFIX_${baseprereq}),yy) - quiet_cmd_bison = YACC $@ - cmd_bison = bison -o$@ -t -l -p $(YACC_PREFIX) $< + cmd_bison = $(YACC) -o$@ -t -l $<
-.PRECIOUS: $(src)/%.tab.c_shipped -$(src)/%.tab.c_shipped: $(src)/%.y - $(call cmd,bison) +.PRECIOUS: $(obj)/%.tab.c +$(obj)/%.tab.c: $(src)/%.y FORCE + $(call if_changed,bison)
quiet_cmd_bison_h = YACC $@ - cmd_bison_h = bison -o/dev/null --defines=$@ -t -l -p $(YACC_PREFIX) $< + cmd_bison_h = $(YACC) -o/dev/null --defines=$@ -t -l $<
-.PRECIOUS: $(src)/%.tab.h_shipped -$(src)/%.tab.h_shipped: $(src)/%.y - $(call cmd,bison_h) - -endif +.PRECIOUS: $(obj)/%.tab.h +$(obj)/%.tab.h: $(src)/%.y FORCE + $(call if_changed,bison_h)
# Shipped files # =========================================================================== diff --git a/scripts/kconfig/.gitignore b/scripts/kconfig/.gitignore index be603c4fef62..2da579edcbaf 100644 --- a/scripts/kconfig/.gitignore +++ b/scripts/kconfig/.gitignore @@ -1,11 +1,6 @@ # # Generated files # -config* -*.lex.c -*.tab.c -*.tab.h -zconf.hash.c *.moc gconf.glade.h *.pot diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index 2542b38af36f..1e4b7619d9fe 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -3,7 +3,7 @@ # Kernel configuration targets # These targets are used from top-level makefile
-PHONY += xconfig gconfig menuconfig config silentoldconfig update-po-config \ +PHONY += xconfig gconfig menuconfig config syncconfig update-po-config \ localmodconfig localyesconfig
# Added for U-Boot @@ -40,24 +40,24 @@ config: $(obj)/conf nconfig: $(obj)/nconf $< $(silent) $(Kconfig)
-silentoldconfig: $(obj)/conf +# This has become an internal implementation detail and is now deprecated +# for external use. +syncconfig: $(obj)/conf $(Q)mkdir -p include/config include/generated - $(Q)test -e include/generated/autoksyms.h || \ - touch include/generated/autoksyms.h $< $(silent) --$@ $(Kconfig)
-localyesconfig localmodconfig: $(obj)/streamline_config.pl $(obj)/conf +localyesconfig localmodconfig: $(obj)/conf $(Q)mkdir -p include/config include/generated - $(Q)perl $< --$@ $(srctree) $(Kconfig) > .tmp.config + $(Q)perl $(srctree)/$(src)/streamline_config.pl --$@ $(srctree) $(Kconfig) > .tmp.config $(Q)if [ -f .config ]; then \ cmp -s .tmp.config .config || \ (mv -f .config .config.old.1; \ mv -f .tmp.config .config; \ - $(obj)/conf $(silent) --silentoldconfig $(Kconfig); \ + $< $(silent) --oldconfig $(Kconfig); \ mv -f .config.old.1 .config.old) \ else \ mv -f .tmp.config .config; \ - $(obj)/conf $(silent) --silentoldconfig $(Kconfig); \ + $< $(silent) --oldconfig $(Kconfig); \ fi $(Q)rm -f .tmp.config
@@ -92,12 +92,21 @@ PHONY += $(simple-targets) $(simple-targets): $(obj)/conf $< $(silent) --$@ $(Kconfig)
-PHONY += oldnoconfig savedefconfig defconfig +PHONY += oldnoconfig silentoldconfig savedefconfig defconfig
# oldnoconfig is an alias of olddefconfig, because people already are dependent # on its behavior (sets new symbols to their default value but not 'n') with the # counter-intuitive name. oldnoconfig: olddefconfig + @echo " WARNING: "oldnoconfig" target will be removed after Linux 4.19" + @echo " Please use "olddefconfig" instead, which is an alias." + +# We do not expect manual invokcation of "silentoldcofig" (or "syncconfig"). +silentoldconfig: syncconfig + @echo " WARNING: "silentoldconfig" has been renamed to "syncconfig"" + @echo " and is now an internal implementation detail." + @echo " What you want is probably "oldconfig"." + @echo " "silentoldconfig" will be removed after Linux 4.19"
savedefconfig: $(obj)/conf $< $(silent) --$@=defconfig $(Kconfig) @@ -141,6 +150,14 @@ PHONY += tinyconfig tinyconfig: $(Q)$(MAKE) -f $(srctree)/Makefile allnoconfig tiny.config
+# CHECK: -o cache_dir=<path> working? +PHONY += testconfig +testconfig: $(obj)/conf + $(PYTHON3) -B -m pytest $(srctree)/$(src)/tests \ + -o cache_dir=$(abspath $(obj)/tests/.cache) \ + $(if $(findstring 1,$(KBUILD_VERBOSE)),--capture=no) +clean-dirs += tests/.cache + # Help text used by make help help: @echo ' config - Update current config utilising a line-oriented program' @@ -152,7 +169,6 @@ help: @echo ' oldconfig - Update current config utilising a provided .config as base' @echo ' localmodconfig - Update current config disabling modules not loaded' @echo ' localyesconfig - Update current config converting local mods to core' - @echo ' silentoldconfig - Same as oldconfig, but quietly, additionally update deps' @echo ' defconfig - New config with default from ARCH supplied defconfig' @echo ' savedefconfig - Save current config as ./defconfig (minimal config)' @echo ' allnoconfig - New config where all options are answered with no' @@ -161,7 +177,7 @@ help: @echo ' alldefconfig - New config with all symbols set to default' @echo ' randconfig - New config with random answer to all options' @echo ' listnewconfig - List new options' - @echo ' olddefconfig - Same as silentoldconfig but sets new symbols to their' + @echo ' olddefconfig - Same as oldconfig but sets new symbols to their' @echo ' default value' # @echo ' kvmconfig - Enable additional options for kvm guest kernel support' # @echo ' xenconfig - Enable additional options for xen dom0 and guest kernel support' @@ -201,13 +217,14 @@ gconf-objs := gconf.o zconf.tab.o
hostprogs-y := conf nconf mconf kxgettext qconf gconf
+targets += zconf.lex.c clean-files := qconf.moc .tmp_qtcheck .tmp_gtkcheck -clean-files += zconf.tab.c zconf.lex.c zconf.hash.c gconf.glade.h +clean-files += gconf.glade.h clean-files += config.pot linux.pot
# Check that we have the required ncurses stuff installed for lxdialog (menuconfig) PHONY += $(obj)/dochecklxdialog -$(addprefix $(obj)/,$(lxdialog)): $(obj)/dochecklxdialog +$(addprefix $(obj)/, mconf.o $(lxdialog)): $(obj)/dochecklxdialog $(obj)/dochecklxdialog: $(Q)$(CONFIG_SHELL) $(check-lxdialog) -check $(HOSTCC) $(HOST_EXTRACFLAGS) $(HOSTLOADLIBES_mconf)
@@ -215,14 +232,12 @@ always := dochecklxdialog
# Add environment specific flags HOST_EXTRACFLAGS += $(shell $(CONFIG_SHELL) $(srctree)/$(src)/check.sh $(HOSTCC) $(HOSTCFLAGS)) +HOST_EXTRACXXFLAGS += $(shell $(CONFIG_SHELL) $(srctree)/$(src)/check.sh $(HOSTCXX) $(HOSTCXXFLAGS))
# generated files seem to need this to find local include files HOSTCFLAGS_zconf.lex.o := -I$(src) HOSTCFLAGS_zconf.tab.o := -I$(src)
-LEX_PREFIX_zconf := zconf -YACC_PREFIX_zconf := zconf - HOSTLOADLIBES_qconf = $(KC_QT_LIBS) HOSTCXXFLAGS_qconf.o = $(KC_QT_CFLAGS)
@@ -291,7 +306,7 @@ $(obj)/.tmp_gtkcheck: fi endif
-$(obj)/zconf.tab.o: $(obj)/zconf.lex.c $(obj)/zconf.hash.c +$(obj)/zconf.tab.o: $(obj)/zconf.lex.c
$(obj)/qconf.o: $(obj)/qconf.moc
diff --git a/scripts/kconfig/check.sh b/scripts/kconfig/check.sh index 55b79ba1ba2a..97f0fee7d173 100755 --- a/scripts/kconfig/check.sh +++ b/scripts/kconfig/check.sh @@ -1,4 +1,5 @@ #!/bin/sh +# SPDX-License-Identifier: GPL-2.0 # Needed for systems without gettext $* -x c -o /dev/null - > /dev/null 2>&1 << EOF #include <libintl.h> diff --git a/scripts/kconfig/conf.c b/scripts/kconfig/conf.c index 866369f10ff8..283eeedaa4fa 100644 --- a/scripts/kconfig/conf.c +++ b/scripts/kconfig/conf.c @@ -20,11 +20,10 @@
static void conf(struct menu *menu); static void check_conf(struct menu *menu); -static void xfgets(char *str, int size, FILE *in);
enum input_mode { oldaskconfig, - silentoldconfig, + syncconfig, oldconfig, allnoconfig, allyesconfig, @@ -35,11 +34,11 @@ enum input_mode { savedefconfig, listnewconfig, olddefconfig, -} input_mode = oldaskconfig; +}; +static enum input_mode input_mode = oldaskconfig;
static int indent = 1; static int tty_stdio; -static int valid_stdin = 1; static int sync_kconfig; static int conf_cnt; static char line[PATH_MAX]; @@ -72,14 +71,14 @@ static void strip(char *str) *p-- = 0; }
-static void check_stdin(void) +/* Helper function to facilitate fgets() by Jean Sacren. */ +static void xfgets(char *str, int size, FILE *in) { - if (!valid_stdin) { - printf(_("aborted!\n\n")); - printf(_("Console input/output is redirected. ")); - printf(_("Run 'make oldconfig' to update configuration.\n\n")); - exit(1); - } + if (!fgets(str, size, in)) + fprintf(stderr, "\nError in reading or end of file.\n"); + + if (!tty_stdio) + printf("%s", str); }
static int conf_askvalue(struct symbol *sym, const char *def) @@ -101,18 +100,15 @@ static int conf_askvalue(struct symbol *sym, const char *def)
switch (input_mode) { case oldconfig: - case silentoldconfig: + case syncconfig: if (sym_has_value(sym)) { printf("%s\n", def); return 0; } - check_stdin(); /* fall through */ case oldaskconfig: fflush(stdout); xfgets(line, sizeof(line), stdin); - if (!tty_stdio) - printf("\n"); return 1; default: break; @@ -192,9 +188,7 @@ static int conf_sym(struct menu *menu) printf("/m"); if (oldval != yes && sym_tristate_within_range(sym, yes)) printf("/y"); - if (menu_has_help(menu)) - printf("/?"); - printf("] "); + printf("/?] "); if (!conf_askvalue(sym, sym_get_string_value(sym))) return 0; strip(line); @@ -296,19 +290,15 @@ static int conf_choice(struct menu *menu) printf("[1]: 1\n"); goto conf_childs; } - printf("[1-%d", cnt); - if (menu_has_help(menu)) - printf("?"); - printf("]: "); + printf("[1-%d?]: ", cnt); switch (input_mode) { case oldconfig: - case silentoldconfig: + case syncconfig: if (!is_new) { cnt = def; printf("%d\n", cnt); break; } - check_stdin(); /* fall through */ case oldaskconfig: fflush(stdout); @@ -368,10 +358,11 @@ static void conf(struct menu *menu)
switch (prop->type) { case P_MENU: - if ((input_mode == silentoldconfig || - input_mode == listnewconfig || - input_mode == olddefconfig) && - rootEntry != menu) { + /* + * Except in oldaskconfig mode, we show only menus that + * contain new symbols. + */ + if (input_mode != oldaskconfig && rootEntry != menu) { check_conf(menu); return; } @@ -431,10 +422,20 @@ static void check_conf(struct menu *menu) if (sym_is_changable(sym) || (sym_is_choice(sym) && sym_get_tristate_value(sym) == yes)) { if (input_mode == listnewconfig) { - if (sym->name && !sym_is_choice_value(sym)) { - printf("%s%s\n", CONFIG_, sym->name); + if (sym->name) { + const char *str; + + if (sym->type == S_STRING) { + str = sym_get_string_value(sym); + str = sym_escape_string_value(str); + printf("%s%s=%s\n", CONFIG_, sym->name, str); + free((void *)str); + } else { + str = sym_get_string_value(sym); + printf("%s%s=%s\n", CONFIG_, sym->name, str); + } } - } else if (input_mode != olddefconfig) { + } else { if (!conf_cnt++) printf(_("*\n* Restart config...\n*\n")); rootEntry = menu_get_parent_menu(menu); @@ -450,7 +451,7 @@ static void check_conf(struct menu *menu) static struct option long_opts[] = { {"oldaskconfig", no_argument, NULL, oldaskconfig}, {"oldconfig", no_argument, NULL, oldconfig}, - {"silentoldconfig", no_argument, NULL, silentoldconfig}, + {"syncconfig", no_argument, NULL, syncconfig}, {"defconfig", optional_argument, NULL, defconfig}, {"savedefconfig", required_argument, NULL, savedefconfig}, {"allnoconfig", no_argument, NULL, allnoconfig}, @@ -477,8 +478,9 @@ static void conf_usage(const char *progname) printf(" --listnewconfig List new options\n"); printf(" --oldaskconfig Start a new configuration using a line-oriented program\n"); printf(" --oldconfig Update a configuration using a provided .config as base\n"); - printf(" --silentoldconfig Same as oldconfig, but quietly, additionally update deps\n"); - printf(" --olddefconfig Same as silentoldconfig but sets new symbols to their default value\n"); + printf(" --syncconfig Similar to oldconfig but generates configuration in\n" + " include/{generated/,config/}\n"); + printf(" --olddefconfig Same as oldconfig but sets new symbols to their default value\n"); printf(" --oldnoconfig An alias of olddefconfig\n"); printf(" --defconfig <file> New config with default defined in <file>\n"); printf(" --savedefconfig <file> Save the minimal current configuration to <file>\n"); @@ -500,7 +502,7 @@ int main(int ac, char **av) bindtextdomain(PACKAGE, LOCALEDIR); textdomain(PACKAGE);
- tty_stdio = isatty(0) && isatty(1) && isatty(2); + tty_stdio = isatty(0) && isatty(1);
while ((opt = getopt_long(ac, av, "s", long_opts, NULL)) != -1) { if (opt == 's') { @@ -509,7 +511,7 @@ int main(int ac, char **av) } input_mode = (enum input_mode)opt; switch (opt) { - case silentoldconfig: + case syncconfig: sync_kconfig = 1; break; case defconfig: @@ -557,7 +559,7 @@ int main(int ac, char **av) } } if (ac == optind) { - printf(_("%s: Kconfig file missing\n"), av[0]); + fprintf(stderr, _("%s: Kconfig file missing\n"), av[0]); conf_usage(progname); exit(1); } @@ -582,14 +584,16 @@ int main(int ac, char **av) if (!defconfig_file) defconfig_file = conf_get_default_confname(); if (conf_read(defconfig_file)) { - printf(_("***\n" - "*** Can't find default configuration "%s"!\n" - "***\n"), defconfig_file); + fprintf(stderr, + _("***\n" + "*** Can't find default configuration "%s"!\n" + "***\n"), + defconfig_file); exit(1); } break; case savedefconfig: - case silentoldconfig: + case syncconfig: case oldaskconfig: case oldconfig: case listnewconfig: @@ -642,7 +646,6 @@ int main(int ac, char **av) return 1; } } - valid_stdin = tty_stdio; }
switch (input_mode) { @@ -670,24 +673,24 @@ int main(int ac, char **av) case oldaskconfig: rootEntry = &rootmenu; conf(&rootmenu); - input_mode = silentoldconfig; + input_mode = oldconfig; /* fall through */ case oldconfig: case listnewconfig: - case olddefconfig: - case silentoldconfig: + case syncconfig: /* Update until a loop caused no more changes */ do { conf_cnt = 0; check_conf(&rootmenu); - } while (conf_cnt && - (input_mode != listnewconfig && - input_mode != olddefconfig)); + } while (conf_cnt); + break; + case olddefconfig: + default: break; }
if (sync_kconfig) { - /* silentoldconfig is used during the build so we shall update autoconf. + /* syncconfig is used during the build so we shall update autoconf. * All other commands are only used to generate a config. */ if (conf_get_changed() && conf_write(NULL)) { @@ -712,12 +715,3 @@ int main(int ac, char **av) } return 0; } - -/* - * Helper function to facilitate fgets() by Jean Sacren. - */ -void xfgets(char *str, int size, FILE *in) -{ - if (fgets(str, size, in) == NULL) - fprintf(stderr, "\nError in reading or end of file.\n"); -} diff --git a/scripts/kconfig/confdata.c b/scripts/kconfig/confdata.c index 745cb93050ef..e4cbb87d760b 100644 --- a/scripts/kconfig/confdata.c +++ b/scripts/kconfig/confdata.c @@ -28,7 +28,7 @@ static void conf_message(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
static const char *conf_filename; -static int conf_lineno, conf_warnings, conf_unsaved; +static int conf_lineno, conf_warnings;
const char conf_defname[] = "arch/$ARCH/defconfig";
@@ -174,7 +174,7 @@ static int conf_set_sym_val(struct symbol *sym, int def, int def_flags, char *p) case S_HEX: done: if (sym_string_valid(sym, p)) { - sym->def[def].val = strdup(p); + sym->def[def].val = xstrdup(p); sym->flags |= def_flags; } else { if (def != S_DEF_AUTO) @@ -197,7 +197,7 @@ static int add_byte(int c, char **lineptr, size_t slen, size_t *n) if (new_size > *n) { new_size += LINE_GROWTH - 1; new_size *= 2; - nline = realloc(*lineptr, new_size); + nline = xrealloc(*lineptr, new_size); if (!nline) return -1;
@@ -286,7 +286,6 @@ load: conf_filename = name; conf_lineno = 0; conf_warnings = 0; - conf_unsaved = 0;
def_flags = SYMBOL_DEF << def; for_all_symbols(i, sym) { @@ -405,6 +404,7 @@ setsym: int conf_read(const char *name) { struct symbol *sym; + int conf_unsaved = 0; int i;
sym_set_change_count(0); @@ -1121,7 +1121,7 @@ void set_all_choice_values(struct symbol *csym) bool conf_set_all_new_symbols(enum conf_def_mode mode) { struct symbol *sym, *csym; - int i, cnt, pby, pty, ptm; /* pby: probability of boolean = y + int i, cnt, pby, pty, ptm; /* pby: probability of bool = y * pty: probability of tristate = y * ptm: probability of tristate = m */ diff --git a/scripts/kconfig/expr.c b/scripts/kconfig/expr.c index cbf4996dd9c1..e1a39e90841d 100644 --- a/scripts/kconfig/expr.c +++ b/scripts/kconfig/expr.c @@ -94,7 +94,7 @@ struct expr *expr_copy(const struct expr *org) e->right.expr = expr_copy(org->right.expr); break; default: - printf("can't copy type %d\n", e->type); + fprintf(stderr, "can't copy type %d\n", e->type); free(e); e = NULL; break; @@ -113,7 +113,7 @@ void expr_free(struct expr *e) break; case E_NOT: expr_free(e->left.expr); - return; + break; case E_EQUAL: case E_GEQ: case E_GTH: @@ -127,7 +127,7 @@ void expr_free(struct expr *e) expr_free(e->right.expr); break; default: - printf("how to free type %d?\n", e->type); + fprintf(stderr, "how to free type %d?\n", e->type); break; } free(e); @@ -138,8 +138,18 @@ static int trans_count; #define e1 (*ep1) #define e2 (*ep2)
+/* + * expr_eliminate_eq() helper. + * + * Walks the two expression trees given in 'ep1' and 'ep2'. Any node that does + * not have type 'type' (E_OR/E_AND) is considered a leaf, and is compared + * against all other leaves. Two equal leaves are both replaced with either 'y' + * or 'n' as appropriate for 'type', to be eliminated later. + */ static void __expr_eliminate_eq(enum expr_type type, struct expr **ep1, struct expr **ep2) { + /* Recurse down to leaves */ + if (e1->type == type) { __expr_eliminate_eq(type, &e1->left.expr, &e2); __expr_eliminate_eq(type, &e1->right.expr, &e2); @@ -150,12 +160,18 @@ static void __expr_eliminate_eq(enum expr_type type, struct expr **ep1, struct e __expr_eliminate_eq(type, &e1, &e2->right.expr); return; } + + /* e1 and e2 are leaves. Compare them. */ + if (e1->type == E_SYMBOL && e2->type == E_SYMBOL && e1->left.sym == e2->left.sym && (e1->left.sym == &symbol_yes || e1->left.sym == &symbol_no)) return; if (!expr_eq(e1, e2)) return; + + /* e1 and e2 are equal leaves. Prepare them for elimination. */ + trans_count++; expr_free(e1); expr_free(e2); switch (type) { @@ -172,6 +188,35 @@ static void __expr_eliminate_eq(enum expr_type type, struct expr **ep1, struct e } }
+/* + * Rewrites the expressions 'ep1' and 'ep2' to remove operands common to both. + * Example reductions: + * + * ep1: A && B -> ep1: y + * ep2: A && B && C -> ep2: C + * + * ep1: A || B -> ep1: n + * ep2: A || B || C -> ep2: C + * + * ep1: A && (B && FOO) -> ep1: FOO + * ep2: (BAR && B) && A -> ep2: BAR + * + * ep1: A && (B || C) -> ep1: y + * ep2: (C || B) && A -> ep2: y + * + * Comparisons are done between all operands at the same "level" of && or ||. + * For example, in the expression 'e1 && (e2 || e3) && (e4 || e5)', the + * following operands will be compared: + * + * - 'e1', 'e2 || e3', and 'e4 || e5', against each other + * - e2 against e3 + * - e4 against e5 + * + * Parentheses are irrelevant within a single level. 'e1 && (e2 && e3)' and + * '(e1 && e2) && e3' are both a single level. + * + * See __expr_eliminate_eq() as well. + */ void expr_eliminate_eq(struct expr **ep1, struct expr **ep2) { if (!e1 || !e2) @@ -197,6 +242,12 @@ void expr_eliminate_eq(struct expr **ep1, struct expr **ep2) #undef e1 #undef e2
+/* + * Returns true if 'e1' and 'e2' are equal, after minor simplification. Two + * &&/|| expressions are considered equal if every operand in one expression + * equals some operand in the other (operands do not need to appear in the same + * order), recursively. + */ static int expr_eq(struct expr *e1, struct expr *e2) { int res, old_count; @@ -243,6 +294,17 @@ static int expr_eq(struct expr *e1, struct expr *e2) return 0; }
+/* + * Recursively performs the following simplifications in-place (as well as the + * corresponding simplifications with swapped operands): + * + * expr && n -> n + * expr && y -> expr + * expr || n -> expr + * expr || y -> y + * + * Returns the optimized expression. + */ static struct expr *expr_eliminate_yn(struct expr *e) { struct expr *tmp; @@ -516,12 +578,21 @@ static struct expr *expr_join_and(struct expr *e1, struct expr *e2) return NULL; }
+/* + * expr_eliminate_dups() helper. + * + * Walks the two expression trees given in 'ep1' and 'ep2'. Any node that does + * not have type 'type' (E_OR/E_AND) is considered a leaf, and is compared + * against all other leaves to look for simplifications. + */ static void expr_eliminate_dups1(enum expr_type type, struct expr **ep1, struct expr **ep2) { #define e1 (*ep1) #define e2 (*ep2) struct expr *tmp;
+ /* Recurse down to leaves */ + if (e1->type == type) { expr_eliminate_dups1(type, &e1->left.expr, &e2); expr_eliminate_dups1(type, &e1->right.expr, &e2); @@ -532,6 +603,9 @@ static void expr_eliminate_dups1(enum expr_type type, struct expr **ep1, struct expr_eliminate_dups1(type, &e1, &e2->right.expr); return; } + + /* e1 and e2 are leaves. Compare and process them. */ + if (e1 == e2) return;
@@ -568,6 +642,17 @@ static void expr_eliminate_dups1(enum expr_type type, struct expr **ep1, struct #undef e2 }
+/* + * Rewrites 'e' in-place to remove ("join") duplicate and other redundant + * operands. + * + * Example simplifications: + * + * A || B || A -> A || B + * A && B && A=y -> A=y && B + * + * Returns the deduplicated expression. + */ struct expr *expr_eliminate_dups(struct expr *e) { int oldcount; @@ -584,6 +669,7 @@ struct expr *expr_eliminate_dups(struct expr *e) ; } if (!trans_count) + /* No simplifications done in this pass. We're done */ break; e = expr_eliminate_yn(e); } @@ -591,6 +677,12 @@ struct expr *expr_eliminate_dups(struct expr *e) return e; }
+/* + * Performs various simplifications involving logical operators and + * comparisons. + * + * Allocates and returns a new expression. + */ struct expr *expr_transform(struct expr *e) { struct expr *tmp; @@ -805,6 +897,20 @@ bool expr_depends_symbol(struct expr *dep, struct symbol *sym) return false; }
+/* + * Inserts explicit comparisons of type 'type' to symbol 'sym' into the + * expression 'e'. + * + * Examples transformations for type == E_UNEQUAL, sym == &symbol_no: + * + * A -> A!=n + * !A -> A=n + * A && B -> !(A=n || B=n) + * A || B -> !(A=n && B=n) + * A && (B || C) -> !(A=n || (B=n && C=n)) + * + * Allocates and returns a new expression. + */ struct expr *expr_trans_compare(struct expr *e, enum expr_type type, struct symbol *sym) { struct expr *e1, *e2; @@ -893,7 +999,10 @@ static enum string_value_kind expr_parse_string(const char *str, switch (type) { case S_BOOLEAN: case S_TRISTATE: - return k_string; + val->s = !strcmp(str, "n") ? 0 : + !strcmp(str, "m") ? 1 : + !strcmp(str, "y") ? 2 : -1; + return k_signed; case S_INT: val->s = strtoll(str, &tail, 10); kind = k_signed; @@ -1028,49 +1137,9 @@ static int expr_compare_type(enum expr_type t1, enum expr_type t2) return 0; }
-static inline struct expr * -expr_get_leftmost_symbol(const struct expr *e) -{ - - if (e == NULL) - return NULL; - - while (e->type != E_SYMBOL) - e = e->left.expr; - - return expr_copy(e); -} - -/* - * Given expression `e1' and `e2', returns the leaf of the longest - * sub-expression of `e1' not containing 'e2. - */ -struct expr *expr_simplify_unmet_dep(struct expr *e1, struct expr *e2) -{ - struct expr *ret; - - switch (e1->type) { - case E_OR: - return expr_alloc_and( - expr_simplify_unmet_dep(e1->left.expr, e2), - expr_simplify_unmet_dep(e1->right.expr, e2)); - case E_AND: { - struct expr *e; - e = expr_alloc_and(expr_copy(e1), expr_copy(e2)); - e = expr_eliminate_dups(e); - ret = (!expr_eq(e, e1)) ? e1 : NULL; - expr_free(e); - break; - } - default: - ret = e1; - break; - } - - return expr_get_leftmost_symbol(ret); -} - -void expr_print(struct expr *e, void (*fn)(void *, struct symbol *, const char *), void *data, int prevtoken) +void expr_print(struct expr *e, + void (*fn)(void *, struct symbol *, const char *), + void *data, int prevtoken) { if (!e) { fn(data, NULL, "y"); @@ -1204,3 +1273,33 @@ void expr_gstr_print(struct expr *e, struct gstr *gs) { expr_print(e, expr_print_gstr_helper, gs, E_NONE); } + +/* + * Transform the top level "||" tokens into newlines and prepend each + * line with a minus. This makes expressions much easier to read. + * Suitable for reverse dependency expressions. + */ +static void expr_print_revdep(struct expr *e, + void (*fn)(void *, struct symbol *, const char *), + void *data, tristate pr_type, const char **title) +{ + if (e->type == E_OR) { + expr_print_revdep(e->left.expr, fn, data, pr_type, title); + expr_print_revdep(e->right.expr, fn, data, pr_type, title); + } else if (expr_calc_value(e) == pr_type) { + if (*title) { + fn(data, NULL, *title); + *title = NULL; + } + + fn(data, NULL, " - "); + expr_print(e, fn, data, E_NONE); + fn(data, NULL, "\n"); + } +} + +void expr_gstr_print_revdep(struct expr *e, struct gstr *gs, + tristate pr_type, const char *title) +{ + expr_print_revdep(e, expr_print_gstr_helper, gs, pr_type, &title); +} diff --git a/scripts/kconfig/expr.h b/scripts/kconfig/expr.h index a73f762c48d6..94a383b21df6 100644 --- a/scripts/kconfig/expr.h +++ b/scripts/kconfig/expr.h @@ -74,17 +74,60 @@ enum { S_DEF_COUNT };
+/* + * Represents a configuration symbol. + * + * Choices are represented as a special kind of symbol and have the + * SYMBOL_CHOICE bit set in 'flags'. + */ struct symbol { + /* The next symbol in the same bucket in the symbol hash table */ struct symbol *next; + + /* The name of the symbol, e.g. "FOO" for 'config FOO' */ char *name; + + /* S_BOOLEAN, S_TRISTATE, ... */ enum symbol_type type; + + /* + * The calculated value of the symbol. The SYMBOL_VALID bit is set in + * 'flags' when this is up to date. Note that this value might differ + * from the user value set in e.g. a .config file, due to visibility. + */ struct symbol_value curr; + + /* + * Values for the symbol provided from outside. def[S_DEF_USER] holds + * the .config value. + */ struct symbol_value def[S_DEF_COUNT]; + + /* + * An upper bound on the tristate value the user can set for the symbol + * if it is a boolean or tristate. Calculated from prompt dependencies, + * which also inherit dependencies from enclosing menus, choices, and + * ifs. If 'n', the user value will be ignored. + * + * Symbols lacking prompts always have visibility 'n'. + */ tristate visible; + + /* SYMBOL_* flags */ int flags; + + /* List of properties. See prop_type. */ struct property *prop; + + /* Dependencies from enclosing menus, choices, and ifs */ struct expr_value dir_dep; + + /* Reverse dependencies through being selected by other symbols */ struct expr_value rev_dep; + + /* + * "Weak" reverse dependencies through being implied by other symbols + */ struct expr_value implied; };
@@ -133,7 +176,7 @@ enum prop_type { P_UNKNOWN, P_PROMPT, /* prompt "foo prompt" or "BAZ Value" */ P_COMMENT, /* text associated with a comment */ - P_MENU, /* prompt associated with a menuconfig option */ + P_MENU, /* prompt associated with a menu or menuconfig symbol */ P_DEFAULT, /* default y */ P_CHOICE, /* choice value */ P_SELECT, /* select BAR */ @@ -166,22 +209,67 @@ struct property { for (st = sym->prop; st; st = st->next) \ if (st->text)
+/* + * Represents a node in the menu tree, as seen in e.g. menuconfig (though used + * for all front ends). Each symbol, menu, etc. defined in the Kconfig files + * gets a node. A symbol defined in multiple locations gets one node at each + * location. + */ struct menu { + /* The next menu node at the same level */ struct menu *next; + + /* The parent menu node, corresponding to e.g. a menu or choice */ struct menu *parent; + + /* The first child menu node, for e.g. menus and choices */ struct menu *list; + + /* + * The symbol associated with the menu node. Choices are implemented as + * a special kind of symbol. NULL for menus, comments, and ifs. + */ struct symbol *sym; + + /* + * The prompt associated with the node. This holds the prompt for a + * symbol as well as the text for a menu or comment, along with the + * type (P_PROMPT, P_MENU, etc.) + */ struct property *prompt; + + /* + * 'visible if' dependencies. If more than one is given, they will be + * ANDed together. + */ struct expr *visibility; + + /* + * Ordinary dependencies from e.g. 'depends on' and 'if', ANDed + * together + */ struct expr *dep; + + /* MENU_* flags */ unsigned int flags; + + /* Any help text associated with the node */ char *help; + + /* The location where the menu node appears in the Kconfig files */ struct file *file; int lineno; + + /* For use by front ends that need to store auxiliary data */ void *data; };
+/* + * Set on a menu node when the corresponding symbol changes state in some way. + * Can be checked by front ends. + */ #define MENU_CHANGED 0x0001 + #define MENU_ROOT 0x0002
struct jump_key { @@ -217,11 +305,12 @@ struct expr *expr_transform(struct expr *e); int expr_contains_symbol(struct expr *dep, struct symbol *sym); bool expr_depends_symbol(struct expr *dep, struct symbol *sym); struct expr *expr_trans_compare(struct expr *e, enum expr_type type, struct symbol *sym); -struct expr *expr_simplify_unmet_dep(struct expr *e1, struct expr *e2);
void expr_fprint(struct expr *e, FILE *out); struct gstr; /* forward */ void expr_gstr_print(struct expr *e, struct gstr *gs); +void expr_gstr_print_revdep(struct expr *e, struct gstr *gs, + tristate pr_type, const char *title);
static inline int expr_is_yes(struct expr *e) { diff --git a/scripts/kconfig/gconf.c b/scripts/kconfig/gconf.c index 26d208b435a0..cfddddb9c9d7 100644 --- a/scripts/kconfig/gconf.c +++ b/scripts/kconfig/gconf.c @@ -914,7 +914,7 @@ on_treeview2_button_press_event(GtkWidget * widget, current = menu; display_tree_part(); gtk_widget_set_sensitive(back_btn, TRUE); - } else if ((col == COL_OPTION)) { + } else if (col == COL_OPTION) { toggle_sym_value(menu); gtk_tree_view_expand_row(view, path, TRUE); } diff --git a/scripts/kconfig/kconf_id.c b/scripts/kconfig/kconf_id.c new file mode 100644 index 000000000000..3ea9c5f9f730 --- /dev/null +++ b/scripts/kconfig/kconf_id.c @@ -0,0 +1,53 @@ + +static struct kconf_id kconf_id_array[] = { + { "mainmenu", T_MAINMENU, TF_COMMAND }, + { "menu", T_MENU, TF_COMMAND }, + { "endmenu", T_ENDMENU, TF_COMMAND }, + { "source", T_SOURCE, TF_COMMAND }, + { "choice", T_CHOICE, TF_COMMAND }, + { "endchoice", T_ENDCHOICE, TF_COMMAND }, + { "comment", T_COMMENT, TF_COMMAND }, + { "config", T_CONFIG, TF_COMMAND }, + { "menuconfig", T_MENUCONFIG, TF_COMMAND }, + { "help", T_HELP, TF_COMMAND }, + { "---help---", T_HELP, TF_COMMAND }, + { "if", T_IF, TF_COMMAND|TF_PARAM }, + { "endif", T_ENDIF, TF_COMMAND }, + { "depends", T_DEPENDS, TF_COMMAND }, + { "optional", T_OPTIONAL, TF_COMMAND }, + { "default", T_DEFAULT, TF_COMMAND, S_UNKNOWN }, + { "prompt", T_PROMPT, TF_COMMAND }, + { "tristate", T_TYPE, TF_COMMAND, S_TRISTATE }, + { "def_tristate", T_DEFAULT, TF_COMMAND, S_TRISTATE }, + { "bool", T_TYPE, TF_COMMAND, S_BOOLEAN }, + { "def_bool", T_DEFAULT, TF_COMMAND, S_BOOLEAN }, + { "int", T_TYPE, TF_COMMAND, S_INT }, + { "hex", T_TYPE, TF_COMMAND, S_HEX }, + { "string", T_TYPE, TF_COMMAND, S_STRING }, + { "select", T_SELECT, TF_COMMAND }, + { "imply", T_IMPLY, TF_COMMAND }, + { "range", T_RANGE, TF_COMMAND }, + { "visible", T_VISIBLE, TF_COMMAND }, + { "option", T_OPTION, TF_COMMAND }, + { "on", T_ON, TF_PARAM }, + { "modules", T_OPT_MODULES, TF_OPTION }, + { "defconfig_list", T_OPT_DEFCONFIG_LIST, TF_OPTION }, + { "env", T_OPT_ENV, TF_OPTION }, + { "allnoconfig_y", T_OPT_ALLNOCONFIG_Y, TF_OPTION }, +}; + +#define KCONF_ID_ARRAY_SIZE (sizeof(kconf_id_array)/sizeof(struct kconf_id)) + +static const struct kconf_id *kconf_id_lookup(register const char *str, register unsigned int len) +{ + int i; + + for (i = 0; i < KCONF_ID_ARRAY_SIZE; i++) { + struct kconf_id *id = kconf_id_array+i; + int l = strlen(id->name); + + if (len == l && !memcmp(str, id->name, len)) + return id; + } + return NULL; +} diff --git a/scripts/kconfig/kxgettext.c b/scripts/kconfig/kxgettext.c index 2858738b22d5..240880a89111 100644 --- a/scripts/kconfig/kxgettext.c +++ b/scripts/kconfig/kxgettext.c @@ -101,7 +101,7 @@ static struct message *message__new(const char *msg, char *option, if (self->files == NULL) goto out_fail;
- self->msg = strdup(msg); + self->msg = xstrdup(msg); if (self->msg == NULL) goto out_fail_msg;
diff --git a/scripts/kconfig/list.h b/scripts/kconfig/list.h index 2cf23f002d3f..45cb237ab7ef 100644 --- a/scripts/kconfig/list.h +++ b/scripts/kconfig/list.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 */ #ifndef LIST_H #define LIST_H
diff --git a/scripts/kconfig/lkc.h b/scripts/kconfig/lkc.h index 91ca126ea080..f4394af6e4b8 100644 --- a/scripts/kconfig/lkc.h +++ b/scripts/kconfig/lkc.h @@ -62,12 +62,13 @@ enum conf_def_mode { #define T_OPT_ALLNOCONFIG_Y 4
struct kconf_id { - int name; + const char *name; int token; unsigned int flags; enum symbol_type stype; };
+extern int yylineno; void zconfdump(FILE *out); void zconf_starthelp(void); FILE *zconf_fopen(const char *name); @@ -100,7 +101,6 @@ void menu_warn(struct menu *menu, const char *fmt, ...); struct menu *menu_add_menu(void); void menu_end_menu(void); void menu_add_entry(struct symbol *sym); -void menu_end_entry(void); void menu_add_dep(struct expr *dep); void menu_add_visibility(struct expr *dep); struct property *menu_add_prompt(enum prop_type type, char *prompt, struct expr *dep); @@ -115,6 +115,8 @@ struct file *file_lookup(const char *name); int file_write_dep(const char *name); void *xmalloc(size_t size); void *xcalloc(size_t nmemb, size_t size); +void *xrealloc(void *p, size_t size); +char *xstrdup(const char *s);
struct gstr { size_t len; diff --git a/scripts/kconfig/lkc_proto.h b/scripts/kconfig/lkc_proto.h index d5398718ec2a..9dc8abfb1dc3 100644 --- a/scripts/kconfig/lkc_proto.h +++ b/scripts/kconfig/lkc_proto.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 */ #include <stdarg.h>
/* confdata.c */ @@ -30,7 +31,7 @@ extern struct symbol * symbol_hash[SYMBOL_HASHSIZE];
struct symbol * sym_lookup(const char *name, int flags); struct symbol * sym_find(const char *name); -const char * sym_expand_string_value(const char *in); +char *sym_expand_string_value(const char *in); const char * sym_escape_string_value(const char *in); struct symbol ** sym_re_search(const char *pattern); const char * sym_type_name(enum symbol_type type); diff --git a/scripts/kconfig/lxdialog/check-lxdialog.sh b/scripts/kconfig/lxdialog/check-lxdialog.sh index 5075ebf2d3b9..6c0bcd9c472d 100755 --- a/scripts/kconfig/lxdialog/check-lxdialog.sh +++ b/scripts/kconfig/lxdialog/check-lxdialog.sh @@ -1,4 +1,5 @@ #!/bin/sh +# SPDX-License-Identifier: GPL-2.0 # Check ncurses compatibility
# What library to link @@ -54,7 +55,8 @@ EOF echo " *** required header files." 1>&2 echo " *** 'make menuconfig' requires the ncurses libraries." 1>&2 echo " *** " 1>&2 - echo " *** Install ncurses (ncurses-devel) and try again." 1>&2 + echo " *** Install ncurses (ncurses-devel or libncurses-dev " 1>&2 + echo " *** depending on your distribution) and try again." 1>&2 echo " *** " 1>&2 exit 1 fi diff --git a/scripts/kconfig/mconf.c b/scripts/kconfig/mconf.c index 315ce2c7cb9d..c829be8bb19f 100644 --- a/scripts/kconfig/mconf.c +++ b/scripts/kconfig/mconf.c @@ -246,7 +246,7 @@ search_help[] = N_( " Selected by: BAR [=n]\n" "-----------------------------------------------------------------\n" "o The line 'Type:' shows the type of the configuration option for\n" - " this symbol (boolean, tristate, string, ...)\n" + " this symbol (bool, tristate, string, ...)\n" "o The line 'Prompt:' shows the text used in the menu structure for\n" " this symbol\n" "o The 'Defined at' line tells at what file / line number the symbol\n" diff --git a/scripts/kconfig/menu.c b/scripts/kconfig/menu.c index e9357931b47d..5c5c1374b151 100644 --- a/scripts/kconfig/menu.c +++ b/scripts/kconfig/menu.c @@ -62,13 +62,8 @@ void menu_add_entry(struct symbol *sym) menu_add_symbol(P_SYMBOL, sym, NULL); }
-void menu_end_entry(void) -{ -} - struct menu *menu_add_menu(void) { - menu_end_entry(); last_entry_ptr = ¤t_entry->list; return current_menu = current_entry; } @@ -79,19 +74,23 @@ void menu_end_menu(void) current_menu = current_menu->parent; }
-static struct expr *menu_check_dep(struct expr *e) +/* + * Rewrites 'm' to 'm' && MODULES, so that it evaluates to 'n' when running + * without modules + */ +static struct expr *rewrite_m(struct expr *e) { if (!e) return e;
switch (e->type) { case E_NOT: - e->left.expr = menu_check_dep(e->left.expr); + e->left.expr = rewrite_m(e->left.expr); break; case E_OR: case E_AND: - e->left.expr = menu_check_dep(e->left.expr); - e->right.expr = menu_check_dep(e->right.expr); + e->left.expr = rewrite_m(e->left.expr); + e->right.expr = rewrite_m(e->right.expr); break; case E_SYMBOL: /* change 'm' into 'm' && MODULES */ @@ -106,7 +105,7 @@ static struct expr *menu_check_dep(struct expr *e)
void menu_add_dep(struct expr *dep) { - current_entry->dep = expr_alloc_and(current_entry->dep, menu_check_dep(dep)); + current_entry->dep = expr_alloc_and(current_entry->dep, dep); }
void menu_set_type(int type) @@ -131,7 +130,7 @@ static struct property *menu_add_prop(enum prop_type type, char *prompt, struct
prop->menu = current_entry; prop->expr = expr; - prop->visible.expr = menu_check_dep(dep); + prop->visible.expr = dep;
if (prompt) { if (isspace(*prompt)) { @@ -213,6 +212,7 @@ void menu_add_option(int token, char *arg) sym_defconfig_list = current_entry->sym; else if (sym_defconfig_list != current_entry->sym) zconf_error("trying to redefine defconfig symbol"); + sym_defconfig_list->flags |= SYMBOL_AUTO; break; case T_OPT_ENV: prop_add_env(arg); @@ -252,6 +252,16 @@ static void sym_check_prop(struct symbol *sym) "'%s': number is invalid", sym->name); } + if (sym_is_choice(sym)) { + struct property *choice_prop = + sym_get_choice_prop(sym2); + + if (!choice_prop || + prop_get_symbol(choice_prop) != sym) + prop_warn(prop, + "choice default symbol '%s' is not contained in the choice", + sym2->name); + } break; case P_SELECT: case P_IMPLY: @@ -260,13 +270,13 @@ static void sym_check_prop(struct symbol *sym) if (sym->type != S_BOOLEAN && sym->type != S_TRISTATE) prop_warn(prop, "config symbol '%s' uses %s, but is " - "not boolean or tristate", sym->name, use); + "not bool or tristate", sym->name, use); else if (sym2->type != S_UNKNOWN && sym2->type != S_BOOLEAN && sym2->type != S_TRISTATE) prop_warn(prop, "'%s' has wrong type. '%s' only " - "accept arguments of boolean and " + "accept arguments of bool and " "tristate type", sym2->name, use); break; case P_RANGE: @@ -292,6 +302,11 @@ void menu_finalize(struct menu *parent)
sym = parent->sym; if (parent->list) { + /* + * This menu node has children. We (recursively) process them + * and propagate parent dependencies before moving on. + */ + if (sym && sym_is_choice(sym)) { if (sym->type == S_UNKNOWN) { /* find the first choice value to find out choice type */ @@ -309,30 +324,83 @@ void menu_finalize(struct menu *parent) if (menu->sym && menu->sym->type == S_UNKNOWN) menu_set_type(sym->type); } + + /* + * Use the choice itself as the parent dependency of + * the contained items. This turns the mode of the + * choice into an upper bound on the visibility of the + * choice value symbols. + */ parentdep = expr_alloc_symbol(sym); } else if (parent->prompt) + /* Menu node for 'menu' */ parentdep = parent->prompt->visible.expr; else + /* Menu node for 'if' */ parentdep = parent->dep;
+ /* For each child menu node... */ for (menu = parent->list; menu; menu = menu->next) { - basedep = expr_transform(menu->dep); + /* + * Propagate parent dependencies to the child menu + * node, also rewriting and simplifying expressions + */ + basedep = rewrite_m(menu->dep); + basedep = expr_transform(basedep); basedep = expr_alloc_and(expr_copy(parentdep), basedep); basedep = expr_eliminate_dups(basedep); menu->dep = basedep; + if (menu->sym) + /* + * Note: For symbols, all prompts are included + * too in the symbol's own property list + */ prop = menu->sym->prop; else + /* + * For non-symbol menu nodes, we just need to + * handle the prompt + */ prop = menu->prompt; + + /* For each property... */ for (; prop; prop = prop->next) { if (prop->menu != menu) + /* + * Two possibilities: + * + * 1. The property lacks dependencies + * and so isn't location-specific, + * e.g. an 'option' + * + * 2. The property belongs to a symbol + * defined in multiple locations and + * is from some other location. It + * will be handled there in that + * case. + * + * Skip the property. + */ continue; - dep = expr_transform(prop->visible.expr); + + /* + * Propagate parent dependencies to the + * property's condition, rewriting and + * simplifying expressions at the same time + */ + dep = rewrite_m(prop->visible.expr); + dep = expr_transform(dep); dep = expr_alloc_and(expr_copy(basedep), dep); dep = expr_eliminate_dups(dep); if (menu->sym && menu->sym->type != S_TRISTATE) dep = expr_trans_bool(dep); prop->visible.expr = dep; + + /* + * Handle selects and implies, which modify the + * dependencies of the selected/implied symbol + */ if (prop->type == P_SELECT) { struct symbol *es = prop_get_symbol(prop); es->rev_dep.expr = expr_alloc_or(es->rev_dep.expr, @@ -344,34 +412,81 @@ void menu_finalize(struct menu *parent) } } } + + if (sym && sym_is_choice(sym)) + expr_free(parentdep); + + /* + * Recursively process children in the same fashion before + * moving on + */ for (menu = parent->list; menu; menu = menu->next) menu_finalize(menu); } else if (sym) { + /* + * Automatic submenu creation. If sym is a symbol and A, B, C, + * ... are consecutive items (symbols, menus, ifs, etc.) that + * all depend on sym, then the following menu structure is + * created: + * + * sym + * +-A + * +-B + * +-C + * ... + * + * This also works recursively, giving the following structure + * if A is a symbol and B depends on A: + * + * sym + * +-A + * | +-B + * +-C + * ... + */ + basedep = parent->prompt ? parent->prompt->visible.expr : NULL; basedep = expr_trans_compare(basedep, E_UNEQUAL, &symbol_no); basedep = expr_eliminate_dups(expr_transform(basedep)); + + /* Examine consecutive elements after sym */ last_menu = NULL; for (menu = parent->next; menu; menu = menu->next) { dep = menu->prompt ? menu->prompt->visible.expr : menu->dep; if (!expr_contains_symbol(dep, sym)) + /* No dependency, quit */ break; if (expr_depends_symbol(dep, sym)) + /* Absolute dependency, put in submenu */ goto next; + + /* + * Also consider it a dependency on sym if our + * dependencies contain sym and are a "superset" of + * sym's dependencies, e.g. '(sym || Q) && R' when sym + * depends on R. + * + * Note that 'R' might be from an enclosing menu or if, + * making this a more common case than it might seem. + */ dep = expr_trans_compare(dep, E_UNEQUAL, &symbol_no); dep = expr_eliminate_dups(expr_transform(dep)); dep2 = expr_copy(basedep); expr_eliminate_eq(&dep, &dep2); expr_free(dep); if (!expr_is_yes(dep2)) { + /* Not superset, quit */ expr_free(dep2); break; } + /* Superset, put in submenu */ expr_free(dep2); next: menu_finalize(menu); menu->parent = parent; last_menu = menu; } + expr_free(basedep); if (last_menu) { parent->list = parent->next; parent->next = last_menu->next; @@ -420,6 +535,35 @@ void menu_finalize(struct menu *parent) *ep = expr_alloc_one(E_LIST, NULL); (*ep)->right.sym = menu->sym; } + + /* + * This code serves two purposes: + * + * (1) Flattening 'if' blocks, which do not specify a submenu + * and only add dependencies. + * + * (Automatic submenu creation might still create a submenu + * from an 'if' before this code runs.) + * + * (2) "Undoing" any automatic submenus created earlier below + * promptless symbols. + * + * Before: + * + * A + * if ... (or promptless symbol) + * +-B + * +-C + * D + * + * After: + * + * A + * if ... (or promptless symbol) + * B + * C + * D + */ if (menu->list && (!menu->prompt || !menu->prompt->text)) { for (last_menu = menu->list; ; last_menu = last_menu->next) { last_menu->parent = parent; @@ -444,6 +588,15 @@ void menu_finalize(struct menu *parent) sym->flags |= SYMBOL_WARNED; }
+ /* + * For non-optional choices, add a reverse dependency (corresponding to + * a select) of '<visibility> && m'. This prevents the user from + * setting the choice mode to 'n' when the choice is visible. + * + * This would also work for non-choice symbols, but only non-optional + * choices clear SYMBOL_OPTIONAL as of writing. Choices are implemented + * as a type of symbol. + */ if (sym && !sym_is_optional(sym) && parent->prompt) { sym->rev_dep.expr = expr_alloc_or(sym->rev_dep.expr, expr_alloc_and(parent->prompt->visible.expr, @@ -675,16 +828,16 @@ static void get_symbol_str(struct gstr *r, struct symbol *sym,
get_symbol_props_str(r, sym, P_SELECT, _(" Selects: ")); if (sym->rev_dep.expr) { - str_append(r, _(" Selected by: ")); - expr_gstr_print(sym->rev_dep.expr, r); - str_append(r, "\n"); + expr_gstr_print_revdep(sym->rev_dep.expr, r, yes, " Selected by [y]:\n"); + expr_gstr_print_revdep(sym->rev_dep.expr, r, mod, " Selected by [m]:\n"); + expr_gstr_print_revdep(sym->rev_dep.expr, r, no, " Selected by [n]:\n"); }
get_symbol_props_str(r, sym, P_IMPLY, _(" Implies: ")); if (sym->implied.expr) { - str_append(r, _(" Implied by: ")); - expr_gstr_print(sym->implied.expr, r); - str_append(r, "\n"); + expr_gstr_print_revdep(sym->implied.expr, r, yes, " Implied by [y]:\n"); + expr_gstr_print_revdep(sym->implied.expr, r, mod, " Implied by [m]:\n"); + expr_gstr_print_revdep(sym->implied.expr, r, no, " Implied by [n]:\n"); }
str_append(r, "\n\n"); diff --git a/scripts/kconfig/nconf.c b/scripts/kconfig/nconf.c index a9bc5334a478..003114779815 100644 --- a/scripts/kconfig/nconf.c +++ b/scripts/kconfig/nconf.c @@ -271,7 +271,7 @@ static struct mitem k_menu_items[MAX_MENU_ITEMS]; static int items_num; static int global_exit; /* the currently selected button */ -const char *current_instructions = menu_instructions; +static const char *current_instructions = menu_instructions;
static char *dialog_input_result; static int dialog_input_result_len; @@ -305,7 +305,7 @@ struct function_keys { };
static const int function_keys_num = 9; -struct function_keys function_keys[] = { +static struct function_keys function_keys[] = { { .key_str = "F1", .func = "Help", @@ -508,7 +508,7 @@ static int get_mext_match(const char *match_str, match_f flag) index = (index + items_num) % items_num; while (true) { char *str = k_menu_items[index].str; - if (strcasestr(str, match_str) != 0) + if (strcasestr(str, match_str) != NULL) return index; if (flag == FIND_NEXT_MATCH_UP || flag == MATCH_TINKER_PATTERN_UP) @@ -1067,7 +1067,7 @@ static int do_match(int key, struct match_state *state, int *ans)
static void conf(struct menu *menu) { - struct menu *submenu = 0; + struct menu *submenu = NULL; const char *prompt = menu_get_prompt(menu); struct symbol *sym; int res; @@ -1234,7 +1234,7 @@ static void show_help(struct menu *menu) static void conf_choice(struct menu *menu) { const char *prompt = _(menu_get_prompt(menu)); - struct menu *child = 0; + struct menu *child = NULL; struct symbol *active; int selected_index = 0; int last_top_row = 0; @@ -1456,7 +1456,7 @@ static void conf_save(void) } }
-void setup_windows(void) +static void setup_windows(void) { int lines, columns;
diff --git a/scripts/kconfig/nconf.gui.c b/scripts/kconfig/nconf.gui.c index 4b2f44c20caf..88874acfda36 100644 --- a/scripts/kconfig/nconf.gui.c +++ b/scripts/kconfig/nconf.gui.c @@ -6,6 +6,7 @@ * */ #include "nconf.h" +#include "lkc.h"
/* a list of all the different widgets we use */ attributes_t attributes[ATTR_MAX+1] = {0}; @@ -129,7 +130,7 @@ static void no_colors_theme(void) mkattrn(FUNCTION_TEXT, A_REVERSE); }
-void set_colors() +void set_colors(void) { start_color(); use_default_colors(); @@ -192,7 +193,7 @@ const char *get_line(const char *text, int line_no) int lines = 0;
if (!text) - return 0; + return NULL;
for (i = 0; text[i] != '\0' && lines < line_no; i++) if (text[i] == '\n') @@ -374,7 +375,7 @@ int dialog_inputbox(WINDOW *main_window,
if (strlen(init)+1 > *result_len) { *result_len = strlen(init)+1; - *resultp = result = realloc(result, *result_len); + *resultp = result = xrealloc(result, *result_len); }
/* find the widest line of msg: */ diff --git a/scripts/kconfig/nconf.h b/scripts/kconfig/nconf.h index 0d5261705ef5..9f6f21d3b0d4 100644 --- a/scripts/kconfig/nconf.h +++ b/scripts/kconfig/nconf.h @@ -15,7 +15,7 @@ #include <string.h> #include <unistd.h> #include <locale.h> -#include <curses.h> +#include <ncurses.h> #include <menu.h> #include <panel.h> #include <form.h> @@ -24,8 +24,6 @@ #include <time.h> #include <sys/time.h>
-#include "ncurses.h" - #define max(a, b) ({\ typeof(a) _a = a;\ typeof(b) _b = b;\ diff --git a/scripts/kconfig/streamline_config.pl b/scripts/kconfig/streamline_config.pl index b8c7b29affc5..a2e83ab17de3 100755 --- a/scripts/kconfig/streamline_config.pl +++ b/scripts/kconfig/streamline_config.pl @@ -1,4 +1,4 @@ -#!/usr/bin/perl -w +#!/usr/bin/env perl # # Copyright 2005-2009 - Steven Rostedt # Licensed under the terms of the GNU GPL License version 2 @@ -42,6 +42,7 @@ # mv config_strip .config # make oldconfig # +use warnings; use strict; use Getopt::Long;
diff --git a/scripts/kconfig/symbol.c b/scripts/kconfig/symbol.c index 3c8bd9bb4267..f0b2e3b3102d 100644 --- a/scripts/kconfig/symbol.c +++ b/scripts/kconfig/symbol.c @@ -77,7 +77,7 @@ const char *sym_type_name(enum symbol_type type) { switch (type) { case S_BOOLEAN: - return "boolean"; + return "bool"; case S_TRISTATE: return "tristate"; case S_INT: @@ -183,7 +183,7 @@ static void sym_validate_range(struct symbol *sym) sprintf(str, "%lld", val2); else sprintf(str, "0x%llx", val2); - sym->curr.val = strdup(str); + sym->curr.val = xstrdup(str); }
static void sym_set_changed(struct symbol *sym) @@ -243,7 +243,7 @@ static void sym_calc_visibility(struct symbol *sym) tri = yes; if (sym->dir_dep.expr) tri = expr_calc_value(sym->dir_dep.expr); - if (tri == mod) + if (tri == mod && sym_get_type(sym) == S_BOOLEAN) tri = yes; if (sym->dir_dep.tri != tri) { sym->dir_dep.tri = tri; @@ -333,6 +333,27 @@ static struct symbol *sym_calc_choice(struct symbol *sym) return def_sym; }
+static void sym_warn_unmet_dep(struct symbol *sym) +{ + struct gstr gs = str_new(); + + str_printf(&gs, + "\nWARNING: unmet direct dependencies detected for %s\n", + sym->name); + str_printf(&gs, + " Depends on [%c]: ", + sym->dir_dep.tri == mod ? 'm' : 'n'); + expr_gstr_print(sym->dir_dep.expr, &gs); + str_printf(&gs, "\n"); + + expr_gstr_print_revdep(sym->rev_dep.expr, &gs, yes, + " Selected by [y]:\n"); + expr_gstr_print_revdep(sym->rev_dep.expr, &gs, mod, + " Selected by [m]:\n"); + + fputs(str_get(&gs), stderr); +} + void sym_calc_value(struct symbol *sym) { struct symbol_value newval, oldval; @@ -371,11 +392,13 @@ void sym_calc_value(struct symbol *sym) sym->curr.tri = no; return; } - if (!sym_is_choice_value(sym)) - sym->flags &= ~SYMBOL_WRITE; + sym->flags &= ~SYMBOL_WRITE;
sym_calc_visibility(sym);
+ if (sym->visible != no) + sym->flags |= SYMBOL_WRITE; + /* set default if recursively called */ sym->curr = newval;
@@ -390,7 +413,6 @@ void sym_calc_value(struct symbol *sym) /* if the symbol is visible use the user value * if available, otherwise try the default value */ - sym->flags |= SYMBOL_WRITE; if (sym_has_value(sym)) { newval.tri = EXPR_AND(sym->def[S_DEF_USER].tri, sym->visible); @@ -402,9 +424,10 @@ void sym_calc_value(struct symbol *sym) if (!sym_is_choice(sym)) { prop = sym_get_default_prop(sym); if (prop) { - sym->flags |= SYMBOL_WRITE; newval.tri = EXPR_AND(expr_calc_value(prop->expr), prop->visible.tri); + if (newval.tri != no) + sym->flags |= SYMBOL_WRITE; } if (sym->implied.tri != no) { sym->flags |= SYMBOL_WRITE; @@ -412,18 +435,8 @@ void sym_calc_value(struct symbol *sym) } } calc_newval: - if (sym->dir_dep.tri == no && sym->rev_dep.tri != no) { - struct expr *e; - e = expr_simplify_unmet_dep(sym->rev_dep.expr, - sym->dir_dep.expr); - fprintf(stderr, "warning: ("); - expr_fprint(e, stderr); - fprintf(stderr, ") selects %s which has unmet direct dependencies (", - sym->name); - expr_fprint(sym->dir_dep.expr, stderr); - fprintf(stderr, ")\n"); - expr_free(e); - } + if (sym->dir_dep.tri < sym->rev_dep.tri) + sym_warn_unmet_dep(sym); newval.tri = EXPR_OR(newval.tri, sym->rev_dep.tri); } if (newval.tri == mod && @@ -433,12 +446,9 @@ void sym_calc_value(struct symbol *sym) case S_STRING: case S_HEX: case S_INT: - if (sym->visible != no) { - sym->flags |= SYMBOL_WRITE; - if (sym_has_value(sym)) { - newval.val = sym->def[S_DEF_USER].val; - break; - } + if (sym->visible != no && sym_has_value(sym)) { + newval.val = sym->def[S_DEF_USER].val; + break; } prop = sym_get_default_prop(sym); if (prop) { @@ -851,7 +861,7 @@ struct symbol *sym_lookup(const char *name, int flags) : !(symbol->flags & (SYMBOL_CONST|SYMBOL_CHOICE)))) return symbol; } - new_name = strdup(name); + new_name = xstrdup(name); } else { new_name = NULL; hash = 0; @@ -901,12 +911,16 @@ struct symbol *sym_find(const char *name) * name to be expanded shall be prefixed by a '$'. Unknown symbol expands to * the empty string. */ -const char *sym_expand_string_value(const char *in) +char *sym_expand_string_value(const char *in) { const char *src; char *res; size_t reslen;
+ /* + * Note: 'in' might come from a token that's about to be + * freed, so make sure to always allocate a new string + */ reslen = strlen(in) + 1; res = xmalloc(reslen); res[0] = '\0'; @@ -934,7 +948,7 @@ const char *sym_expand_string_value(const char *in) newlen = strlen(res) + strlen(symval) + strlen(src) + 1; if (newlen > reslen) { reslen = newlen; - res = realloc(res, reslen); + res = xrealloc(res, reslen); }
strcat(res, symval); @@ -1150,8 +1164,7 @@ static void sym_check_print_recursive(struct symbol *last_sym) if (stack->sym == last_sym) fprintf(stderr, "%s:%d:error: recursive dependency detected!\n", prop->file->name, prop->lineno); - fprintf(stderr, "For a resolution refer to Documentation/kbuild/kconfig-language.txt\n"); - fprintf(stderr, "subsection "Kconfig recursive dependency limitations"\n"); + if (stack->expr) { fprintf(stderr, "%s:%d:\tsymbol %s %s value contains %s\n", prop->file->name, prop->lineno, @@ -1181,6 +1194,11 @@ static void sym_check_print_recursive(struct symbol *last_sym) } }
+ fprintf(stderr, + "For a resolution refer to Documentation/kbuild/kconfig-language.txt\n" + "subsection "Kconfig recursive dependency limitations"\n" + "\n"); + if (check_top == &cv_stack) dep_stack_remove(); } @@ -1215,7 +1233,7 @@ static struct symbol *sym_check_expr_deps(struct expr *e) default: break; } - printf("Oops! How to check %d?\n", e->type); + fprintf(stderr, "Oops! How to check %d?\n", e->type); return NULL; }
diff --git a/scripts/kconfig/tests/auto_submenu/Kconfig b/scripts/kconfig/tests/auto_submenu/Kconfig new file mode 100644 index 000000000000..c17bf2caa7e6 --- /dev/null +++ b/scripts/kconfig/tests/auto_submenu/Kconfig @@ -0,0 +1,50 @@ +config A + bool "A" + default y + +config A0 + bool "A0" + depends on A + default y + help + This depends on A, so should be a submenu of A. + +config A0_0 + bool "A1_0" + depends on A0 + help + Submenus are created recursively. + This should be a submenu of A0. + +config A1 + bool "A1" + depends on A + default y + help + This should line up with A0. + +choice + prompt "choice" + depends on A1 + help + Choice should become a submenu as well. + +config A1_0 + bool "A1_0" + +config A1_1 + bool "A1_1" + +endchoice + +config B + bool "B" + help + This is independent of A. + +config C + bool "C" + depends on A + help + This depends on A, but not a consecutive item, so can/should not + be a submenu. diff --git a/scripts/kconfig/tests/auto_submenu/__init__.py b/scripts/kconfig/tests/auto_submenu/__init__.py new file mode 100644 index 000000000000..32e79b85faeb --- /dev/null +++ b/scripts/kconfig/tests/auto_submenu/__init__.py @@ -0,0 +1,12 @@ +""" +Create submenu for symbols that depend on the preceding one. + +If a symbols has dependency on the preceding symbol, the menu entry +should become the submenu of the preceding one, and displayed with +deeper indentation. +""" + + +def test(conf): + assert conf.oldaskconfig() == 0 + assert conf.stdout_contains('expected_stdout') diff --git a/scripts/kconfig/tests/auto_submenu/expected_stdout b/scripts/kconfig/tests/auto_submenu/expected_stdout new file mode 100644 index 000000000000..bf5236f39a56 --- /dev/null +++ b/scripts/kconfig/tests/auto_submenu/expected_stdout @@ -0,0 +1,10 @@ +A (A) [Y/n/?] (NEW) + A0 (A0) [Y/n/?] (NEW) + A1_0 (A0_0) [N/y/?] (NEW) + A1 (A1) [Y/n/?] (NEW) + choice + > 1. A1_0 (A1_0) (NEW) + 2. A1_1 (A1_1) (NEW) + choice[1-2?]: +B (B) [N/y/?] (NEW) +C (C) [N/y/?] (NEW) diff --git a/scripts/kconfig/tests/choice/Kconfig b/scripts/kconfig/tests/choice/Kconfig new file mode 100644 index 000000000000..cc60e9ce2c03 --- /dev/null +++ b/scripts/kconfig/tests/choice/Kconfig @@ -0,0 +1,54 @@ +config MODULES + bool "Enable loadable module support" + option modules + default y + +choice + prompt "boolean choice" + default BOOL_CHOICE1 + +config BOOL_CHOICE0 + bool "choice 0" + +config BOOL_CHOICE1 + bool "choice 1" + +endchoice + +choice + prompt "optional boolean choice" + optional + default OPT_BOOL_CHOICE1 + +config OPT_BOOL_CHOICE0 + bool "choice 0" + +config OPT_BOOL_CHOICE1 + bool "choice 1" + +endchoice + +choice + prompt "tristate choice" + default TRI_CHOICE1 + +config TRI_CHOICE0 + tristate "choice 0" + +config TRI_CHOICE1 + tristate "choice 1" + +endchoice + +choice + prompt "optional tristate choice" + optional + default OPT_TRI_CHOICE1 + +config OPT_TRI_CHOICE0 + tristate "choice 0" + +config OPT_TRI_CHOICE1 + tristate "choice 1" + +endchoice diff --git a/scripts/kconfig/tests/choice/__init__.py b/scripts/kconfig/tests/choice/__init__.py new file mode 100644 index 000000000000..9edcc5262134 --- /dev/null +++ b/scripts/kconfig/tests/choice/__init__.py @@ -0,0 +1,40 @@ +""" +Basic choice tests. + +The handling of 'choice' is a bit complicated part in Kconfig. + +The behavior of 'y' choice is intuitive. If choice values are tristate, +the choice can be 'm' where each value can be enabled independently. +Also, if a choice is marked as 'optional', the whole choice can be +invisible. +""" + + +def test_oldask0(conf): + assert conf.oldaskconfig() == 0 + assert conf.stdout_contains('oldask0_expected_stdout') + + +def test_oldask1(conf): + assert conf.oldaskconfig('oldask1_config') == 0 + assert conf.stdout_contains('oldask1_expected_stdout') + + +def test_allyes(conf): + assert conf.allyesconfig() == 0 + assert conf.config_contains('allyes_expected_config') + + +def test_allmod(conf): + assert conf.allmodconfig() == 0 + assert conf.config_contains('allmod_expected_config') + + +def test_allno(conf): + assert conf.allnoconfig() == 0 + assert conf.config_contains('allno_expected_config') + + +def test_alldef(conf): + assert conf.alldefconfig() == 0 + assert conf.config_contains('alldef_expected_config') diff --git a/scripts/kconfig/tests/choice/alldef_expected_config b/scripts/kconfig/tests/choice/alldef_expected_config new file mode 100644 index 000000000000..7a754bf4be94 --- /dev/null +++ b/scripts/kconfig/tests/choice/alldef_expected_config @@ -0,0 +1,5 @@ +CONFIG_MODULES=y +# CONFIG_BOOL_CHOICE0 is not set +CONFIG_BOOL_CHOICE1=y +# CONFIG_TRI_CHOICE0 is not set +# CONFIG_TRI_CHOICE1 is not set diff --git a/scripts/kconfig/tests/choice/allmod_expected_config b/scripts/kconfig/tests/choice/allmod_expected_config new file mode 100644 index 000000000000..f1f5dcdb7923 --- /dev/null +++ b/scripts/kconfig/tests/choice/allmod_expected_config @@ -0,0 +1,9 @@ +CONFIG_MODULES=y +# CONFIG_BOOL_CHOICE0 is not set +CONFIG_BOOL_CHOICE1=y +# CONFIG_OPT_BOOL_CHOICE0 is not set +CONFIG_OPT_BOOL_CHOICE1=y +CONFIG_TRI_CHOICE0=m +CONFIG_TRI_CHOICE1=m +CONFIG_OPT_TRI_CHOICE0=m +CONFIG_OPT_TRI_CHOICE1=m diff --git a/scripts/kconfig/tests/choice/allno_expected_config b/scripts/kconfig/tests/choice/allno_expected_config new file mode 100644 index 000000000000..b88ee7a43136 --- /dev/null +++ b/scripts/kconfig/tests/choice/allno_expected_config @@ -0,0 +1,5 @@ +# CONFIG_MODULES is not set +# CONFIG_BOOL_CHOICE0 is not set +CONFIG_BOOL_CHOICE1=y +# CONFIG_TRI_CHOICE0 is not set +CONFIG_TRI_CHOICE1=y diff --git a/scripts/kconfig/tests/choice/allyes_expected_config b/scripts/kconfig/tests/choice/allyes_expected_config new file mode 100644 index 000000000000..e5a062a1157c --- /dev/null +++ b/scripts/kconfig/tests/choice/allyes_expected_config @@ -0,0 +1,9 @@ +CONFIG_MODULES=y +# CONFIG_BOOL_CHOICE0 is not set +CONFIG_BOOL_CHOICE1=y +# CONFIG_OPT_BOOL_CHOICE0 is not set +CONFIG_OPT_BOOL_CHOICE1=y +# CONFIG_TRI_CHOICE0 is not set +CONFIG_TRI_CHOICE1=y +# CONFIG_OPT_TRI_CHOICE0 is not set +CONFIG_OPT_TRI_CHOICE1=y diff --git a/scripts/kconfig/tests/choice/oldask0_expected_stdout b/scripts/kconfig/tests/choice/oldask0_expected_stdout new file mode 100644 index 000000000000..b251bba9698b --- /dev/null +++ b/scripts/kconfig/tests/choice/oldask0_expected_stdout @@ -0,0 +1,10 @@ +Enable loadable module support (MODULES) [Y/n/?] (NEW) +boolean choice + 1. choice 0 (BOOL_CHOICE0) (NEW) +> 2. choice 1 (BOOL_CHOICE1) (NEW) +choice[1-2?]: +optional boolean choice [N/y/?] (NEW) +tristate choice [M/y/?] (NEW) + choice 0 (TRI_CHOICE0) [N/m/?] (NEW) + choice 1 (TRI_CHOICE1) [N/m/?] (NEW) +optional tristate choice [N/m/y/?] (NEW) diff --git a/scripts/kconfig/tests/choice/oldask1_config b/scripts/kconfig/tests/choice/oldask1_config new file mode 100644 index 000000000000..b67bfe3c641f --- /dev/null +++ b/scripts/kconfig/tests/choice/oldask1_config @@ -0,0 +1,2 @@ +# CONFIG_MODULES is not set +CONFIG_OPT_BOOL_CHOICE0=y diff --git a/scripts/kconfig/tests/choice/oldask1_expected_stdout b/scripts/kconfig/tests/choice/oldask1_expected_stdout new file mode 100644 index 000000000000..c2125e9bf96a --- /dev/null +++ b/scripts/kconfig/tests/choice/oldask1_expected_stdout @@ -0,0 +1,15 @@ +Enable loadable module support (MODULES) [N/y/?] +boolean choice + 1. choice 0 (BOOL_CHOICE0) (NEW) +> 2. choice 1 (BOOL_CHOICE1) (NEW) +choice[1-2?]: +optional boolean choice [Y/n/?] (NEW) +optional boolean choice +> 1. choice 0 (OPT_BOOL_CHOICE0) + 2. choice 1 (OPT_BOOL_CHOICE1) (NEW) +choice[1-2?]: +tristate choice + 1. choice 0 (TRI_CHOICE0) (NEW) +> 2. choice 1 (TRI_CHOICE1) (NEW) +choice[1-2?]: +optional tristate choice [N/y/?] diff --git a/scripts/kconfig/tests/choice_value_with_m_dep/Kconfig b/scripts/kconfig/tests/choice_value_with_m_dep/Kconfig new file mode 100644 index 000000000000..11ac25c26040 --- /dev/null +++ b/scripts/kconfig/tests/choice_value_with_m_dep/Kconfig @@ -0,0 +1,19 @@ +config MODULES + def_bool y + option modules + +config DEP + tristate + default m + +choice + prompt "Tristate Choice" + +config CHOICE0 + tristate "Choice 0" + +config CHOICE1 + tristate "Choice 1" + depends on DEP + +endchoice diff --git a/scripts/kconfig/tests/choice_value_with_m_dep/__init__.py b/scripts/kconfig/tests/choice_value_with_m_dep/__init__.py new file mode 100644 index 000000000000..f8d728c7b101 --- /dev/null +++ b/scripts/kconfig/tests/choice_value_with_m_dep/__init__.py @@ -0,0 +1,15 @@ +""" +Hide tristate choice values with mod dependency in y choice. + +If tristate choice values depend on symbols set to 'm', they should be +hidden when the choice containing them is changed from 'm' to 'y' +(i.e. exclusive choice). + +Related Linux commit: fa64e5f6a35efd5e77d639125d973077ca506074 +""" + + +def test(conf): + assert conf.oldaskconfig('config', 'y') == 0 + assert conf.config_contains('expected_config') + assert conf.stdout_contains('expected_stdout') diff --git a/scripts/kconfig/tests/choice_value_with_m_dep/config b/scripts/kconfig/tests/choice_value_with_m_dep/config new file mode 100644 index 000000000000..3a126b7a2546 --- /dev/null +++ b/scripts/kconfig/tests/choice_value_with_m_dep/config @@ -0,0 +1,2 @@ +CONFIG_CHOICE0=m +CONFIG_CHOICE1=m diff --git a/scripts/kconfig/tests/choice_value_with_m_dep/expected_config b/scripts/kconfig/tests/choice_value_with_m_dep/expected_config new file mode 100644 index 000000000000..4d07b449540e --- /dev/null +++ b/scripts/kconfig/tests/choice_value_with_m_dep/expected_config @@ -0,0 +1,3 @@ +CONFIG_MODULES=y +CONFIG_DEP=m +CONFIG_CHOICE0=y diff --git a/scripts/kconfig/tests/choice_value_with_m_dep/expected_stdout b/scripts/kconfig/tests/choice_value_with_m_dep/expected_stdout new file mode 100644 index 000000000000..2b50ab65c86a --- /dev/null +++ b/scripts/kconfig/tests/choice_value_with_m_dep/expected_stdout @@ -0,0 +1,4 @@ +Tristate Choice [M/y/?] y +Tristate Choice +> 1. Choice 0 (CHOICE0) +choice[1]: 1 diff --git a/scripts/kconfig/tests/conftest.py b/scripts/kconfig/tests/conftest.py new file mode 100644 index 000000000000..0345ef6e3273 --- /dev/null +++ b/scripts/kconfig/tests/conftest.py @@ -0,0 +1,291 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2018 Masahiro Yamada yamada.masahiro@socionext.com +# + +""" +Kconfig unit testing framework. + +This provides fixture functions commonly used from test files. +""" + +import os +import pytest +import shutil +import subprocess +import tempfile + +CONF_PATH = os.path.abspath(os.path.join('scripts', 'kconfig', 'conf')) + + +class Conf: + """Kconfig runner and result checker. + + This class provides methods to run text-based interface of Kconfig + (scripts/kconfig/conf) and retrieve the resulted configuration, + stdout, and stderr. It also provides methods to compare those + results with expectations. + """ + + def __init__(self, request): + """Create a new Conf instance. + + request: object to introspect the requesting test module + """ + # the directory of the test being run + self._test_dir = os.path.dirname(str(request.fspath)) + + # runners + def _run_conf(self, mode, dot_config=None, out_file='.config', + interactive=False, in_keys=None, extra_env={}): + """Run text-based Kconfig executable and save the result. + + mode: input mode option (--oldaskconfig, --defconfig=<file> etc.) + dot_config: .config file to use for configuration base + out_file: file name to contain the output config data + interactive: flag to specify the interactive mode + in_keys: key inputs for interactive modes + extra_env: additional environments + returncode: exit status of the Kconfig executable + """ + command = [CONF_PATH, mode, 'Kconfig'] + + # Override 'srctree' environment to make the test as the top directory + extra_env['srctree'] = self._test_dir + + # Run Kconfig in a temporary directory. + # This directory is automatically removed when done. + with tempfile.TemporaryDirectory() as temp_dir: + + # if .config is given, copy it to the working directory + if dot_config: + shutil.copyfile(os.path.join(self._test_dir, dot_config), + os.path.join(temp_dir, '.config')) + + ps = subprocess.Popen(command, + stdin=subprocess.PIPE, + stdout=subprocess.PIPE, + stderr=subprocess.PIPE, + cwd=temp_dir, + env=dict(os.environ, **extra_env)) + + # If input key sequence is given, feed it to stdin. + if in_keys: + ps.stdin.write(in_keys.encode('utf-8')) + + while ps.poll() is None: + # For interactive modes such as oldaskconfig, oldconfig, + # send 'Enter' key until the program finishes. + if interactive: + ps.stdin.write(b'\n') + + self.retcode = ps.returncode + self.stdout = ps.stdout.read().decode() + self.stderr = ps.stderr.read().decode() + + # Retrieve the resulted config data only when .config is supposed + # to exist. If the command fails, the .config does not exist. + # 'listnewconfig' does not produce .config in the first place. + if self.retcode == 0 and out_file: + with open(os.path.join(temp_dir, out_file)) as f: + self.config = f.read() + else: + self.config = None + + # Logging: + # Pytest captures the following information by default. In failure + # of tests, the captured log will be displayed. This will be useful to + # figure out what has happened. + + print("[command]\n{}\n".format(' '.join(command))) + + print("[retcode]\n{}\n".format(self.retcode)) + + print("[stdout]") + print(self.stdout) + + print("[stderr]") + print(self.stderr) + + if self.config is not None: + print("[output for '{}']".format(out_file)) + print(self.config) + + return self.retcode + + def oldaskconfig(self, dot_config=None, in_keys=None): + """Run oldaskconfig. + + dot_config: .config file to use for configuration base (optional) + in_key: key inputs (optional) + returncode: exit status of the Kconfig executable + """ + return self._run_conf('--oldaskconfig', dot_config=dot_config, + interactive=True, in_keys=in_keys) + + def oldconfig(self, dot_config=None, in_keys=None): + """Run oldconfig. + + dot_config: .config file to use for configuration base (optional) + in_key: key inputs (optional) + returncode: exit status of the Kconfig executable + """ + return self._run_conf('--oldconfig', dot_config=dot_config, + interactive=True, in_keys=in_keys) + + def olddefconfig(self, dot_config=None): + """Run olddefconfig. + + dot_config: .config file to use for configuration base (optional) + returncode: exit status of the Kconfig executable + """ + return self._run_conf('--olddefconfig', dot_config=dot_config) + + def defconfig(self, defconfig): + """Run defconfig. + + defconfig: defconfig file for input + returncode: exit status of the Kconfig executable + """ + defconfig_path = os.path.join(self._test_dir, defconfig) + return self._run_conf('--defconfig={}'.format(defconfig_path)) + + def _allconfig(self, mode, all_config): + if all_config: + all_config_path = os.path.join(self._test_dir, all_config) + extra_env = {'KCONFIG_ALLCONFIG': all_config_path} + else: + extra_env = {} + + return self._run_conf('--{}config'.format(mode), extra_env=extra_env) + + def allyesconfig(self, all_config=None): + """Run allyesconfig. + + all_config: fragment config file for KCONFIG_ALLCONFIG (optional) + returncode: exit status of the Kconfig executable + """ + return self._allconfig('allyes', all_config) + + def allmodconfig(self, all_config=None): + """Run allmodconfig. + + all_config: fragment config file for KCONFIG_ALLCONFIG (optional) + returncode: exit status of the Kconfig executable + """ + return self._allconfig('allmod', all_config) + + def allnoconfig(self, all_config=None): + """Run allnoconfig. + + all_config: fragment config file for KCONFIG_ALLCONFIG (optional) + returncode: exit status of the Kconfig executable + """ + return self._allconfig('allno', all_config) + + def alldefconfig(self, all_config=None): + """Run alldefconfig. + + all_config: fragment config file for KCONFIG_ALLCONFIG (optional) + returncode: exit status of the Kconfig executable + """ + return self._allconfig('alldef', all_config) + + def randconfig(self, all_config=None): + """Run randconfig. + + all_config: fragment config file for KCONFIG_ALLCONFIG (optional) + returncode: exit status of the Kconfig executable + """ + return self._allconfig('rand', all_config) + + def savedefconfig(self, dot_config): + """Run savedefconfig. + + dot_config: .config file for input + returncode: exit status of the Kconfig executable + """ + return self._run_conf('--savedefconfig', out_file='defconfig') + + def listnewconfig(self, dot_config=None): + """Run listnewconfig. + + dot_config: .config file to use for configuration base (optional) + returncode: exit status of the Kconfig executable + """ + return self._run_conf('--listnewconfig', dot_config=dot_config, + out_file=None) + + # checkers + def _read_and_compare(self, compare, expected): + """Compare the result with expectation. + + compare: function to compare the result with expectation + expected: file that contains the expected data + """ + with open(os.path.join(self._test_dir, expected)) as f: + expected_data = f.read() + return compare(self, expected_data) + + def _contains(self, attr, expected): + return self._read_and_compare( + lambda s, e: getattr(s, attr).find(e) >= 0, + expected) + + def _matches(self, attr, expected): + return self._read_and_compare(lambda s, e: getattr(s, attr) == e, + expected) + + def config_contains(self, expected): + """Check if resulted configuration contains expected data. + + expected: file that contains the expected data + returncode: True if result contains the expected data, False otherwise + """ + return self._contains('config', expected) + + def config_matches(self, expected): + """Check if resulted configuration exactly matches expected data. + + expected: file that contains the expected data + returncode: True if result matches the expected data, False otherwise + """ + return self._matches('config', expected) + + def stdout_contains(self, expected): + """Check if resulted stdout contains expected data. + + expected: file that contains the expected data + returncode: True if result contains the expected data, False otherwise + """ + return self._contains('stdout', expected) + + def stdout_matches(self, expected): + """Check if resulted stdout exactly matches expected data. + + expected: file that contains the expected data + returncode: True if result matches the expected data, False otherwise + """ + return self._matches('stdout', expected) + + def stderr_contains(self, expected): + """Check if resulted stderr contains expected data. + + expected: file that contains the expected data + returncode: True if result contains the expected data, False otherwise + """ + return self._contains('stderr', expected) + + def stderr_matches(self, expected): + """Check if resulted stderr exactly matches expected data. + + expected: file that contains the expected data + returncode: True if result matches the expected data, False otherwise + """ + return self._matches('stderr', expected) + + +@pytest.fixture(scope="module") +def conf(request): + """Create a Conf instance and provide it to test functions.""" + return Conf(request) diff --git a/scripts/kconfig/tests/err_recursive_inc/Kconfig b/scripts/kconfig/tests/err_recursive_inc/Kconfig new file mode 100644 index 000000000000..0e4c8750ab65 --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/Kconfig @@ -0,0 +1 @@ +source "Kconfig.inc1" diff --git a/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc1 b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc1 new file mode 100644 index 000000000000..00e408d653fc --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc1 @@ -0,0 +1,4 @@ + + + +source "Kconfig.inc2" diff --git a/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc2 b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc2 new file mode 100644 index 000000000000..349ea2db15dc --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc2 @@ -0,0 +1,3 @@ + + +source "Kconfig.inc3" diff --git a/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc3 b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc3 new file mode 100644 index 000000000000..0e4c8750ab65 --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/Kconfig.inc3 @@ -0,0 +1 @@ +source "Kconfig.inc1" diff --git a/scripts/kconfig/tests/err_recursive_inc/__init__.py b/scripts/kconfig/tests/err_recursive_inc/__init__.py new file mode 100644 index 000000000000..0e4c839c54aa --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/__init__.py @@ -0,0 +1,10 @@ +""" +Detect recursive inclusion error. + +If recursive inclusion is detected, it should fail with error messages. +""" + + +def test(conf): + assert conf.oldaskconfig() != 0 + assert conf.stderr_contains('expected_stderr') diff --git a/scripts/kconfig/tests/err_recursive_inc/expected_stderr b/scripts/kconfig/tests/err_recursive_inc/expected_stderr new file mode 100644 index 000000000000..6b582eee2176 --- /dev/null +++ b/scripts/kconfig/tests/err_recursive_inc/expected_stderr @@ -0,0 +1,6 @@ +Recursive inclusion detected. +Inclusion path: + current file : Kconfig.inc1 + included from: Kconfig.inc3:1 + included from: Kconfig.inc2:3 + included from: Kconfig.inc1:4 diff --git a/scripts/kconfig/tests/inter_choice/Kconfig b/scripts/kconfig/tests/inter_choice/Kconfig new file mode 100644 index 000000000000..e44449f075df --- /dev/null +++ b/scripts/kconfig/tests/inter_choice/Kconfig @@ -0,0 +1,23 @@ +config MODULES + def_bool y + option modules + +choice + prompt "Choice" + +config CHOICE_VAL0 + tristate "Choice 0" + +config CHOIVE_VAL1 + tristate "Choice 1" + +endchoice + +choice + prompt "Another choice" + depends on CHOICE_VAL0 + +config DUMMY + bool "dummy" + +endchoice diff --git a/scripts/kconfig/tests/inter_choice/__init__.py b/scripts/kconfig/tests/inter_choice/__init__.py new file mode 100644 index 000000000000..5c7fc365ed40 --- /dev/null +++ b/scripts/kconfig/tests/inter_choice/__init__.py @@ -0,0 +1,14 @@ +""" +Do not affect user-assigned choice value by another choice. + +Handling of state flags for choices is complecated. In old days, +the defconfig result of a choice could be affected by another choice +if those choices interact by 'depends on', 'select', etc. + +Related Linux commit: fbe98bb9ed3dae23e320c6b113e35f129538d14a +""" + + +def test(conf): + assert conf.defconfig('defconfig') == 0 + assert conf.config_contains('expected_config') diff --git a/scripts/kconfig/tests/inter_choice/defconfig b/scripts/kconfig/tests/inter_choice/defconfig new file mode 100644 index 000000000000..162c4148e2a5 --- /dev/null +++ b/scripts/kconfig/tests/inter_choice/defconfig @@ -0,0 +1 @@ +CONFIG_CHOICE_VAL0=y diff --git a/scripts/kconfig/tests/inter_choice/expected_config b/scripts/kconfig/tests/inter_choice/expected_config new file mode 100644 index 000000000000..5dceefb054e3 --- /dev/null +++ b/scripts/kconfig/tests/inter_choice/expected_config @@ -0,0 +1,4 @@ +CONFIG_MODULES=y +CONFIG_CHOICE_VAL0=y +# CONFIG_CHOIVE_VAL1 is not set +CONFIG_DUMMY=y diff --git a/scripts/kconfig/tests/new_choice_with_dep/Kconfig b/scripts/kconfig/tests/new_choice_with_dep/Kconfig new file mode 100644 index 000000000000..53ef1b86e7bf --- /dev/null +++ b/scripts/kconfig/tests/new_choice_with_dep/Kconfig @@ -0,0 +1,37 @@ +config A + bool "A" + help + This is a new symbol. + +choice + prompt "Choice ?" + depends on A + help + "depends on A" has been newly added. + +config CHOICE_B + bool "Choice B" + +config CHOICE_C + bool "Choice C" + help + This is a new symbol, so should be asked. + +endchoice + +choice + prompt "Choice2 ?" + +config CHOICE_D + bool "Choice D" + +config CHOICE_E + bool "Choice E" + +config CHOICE_F + bool "Choice F" + depends on A + help + This is a new symbol, so should be asked. + +endchoice diff --git a/scripts/kconfig/tests/new_choice_with_dep/__init__.py b/scripts/kconfig/tests/new_choice_with_dep/__init__.py new file mode 100644 index 000000000000..f0e0ead0f32f --- /dev/null +++ b/scripts/kconfig/tests/new_choice_with_dep/__init__.py @@ -0,0 +1,14 @@ +""" +Ask new choice values when they become visible. + +If new choice values are added with new dependency, and they become +visible during user configuration, oldconfig should recognize them +as (NEW), and ask the user for choice. + +Related Linux commit: 5d09598d488f081e3be23f885ed65cbbe2d073b5 +""" + + +def test(conf): + assert conf.oldconfig('config', 'y') == 0 + assert conf.stdout_contains('expected_stdout') diff --git a/scripts/kconfig/tests/new_choice_with_dep/config b/scripts/kconfig/tests/new_choice_with_dep/config new file mode 100644 index 000000000000..47ef95d567fd --- /dev/null +++ b/scripts/kconfig/tests/new_choice_with_dep/config @@ -0,0 +1,3 @@ +CONFIG_CHOICE_B=y +# CONFIG_CHOICE_D is not set +CONFIG_CHOICE_E=y diff --git a/scripts/kconfig/tests/new_choice_with_dep/expected_stdout b/scripts/kconfig/tests/new_choice_with_dep/expected_stdout new file mode 100644 index 000000000000..74dc0bcb22bc --- /dev/null +++ b/scripts/kconfig/tests/new_choice_with_dep/expected_stdout @@ -0,0 +1,10 @@ +A (A) [N/y/?] (NEW) y + Choice ? + > 1. Choice B (CHOICE_B) + 2. Choice C (CHOICE_C) (NEW) + choice[1-2?]: +Choice2 ? + 1. Choice D (CHOICE_D) +> 2. Choice E (CHOICE_E) + 3. Choice F (CHOICE_F) (NEW) +choice[1-3?]: diff --git a/scripts/kconfig/tests/no_write_if_dep_unmet/Kconfig b/scripts/kconfig/tests/no_write_if_dep_unmet/Kconfig new file mode 100644 index 000000000000..c00b8fe54f45 --- /dev/null +++ b/scripts/kconfig/tests/no_write_if_dep_unmet/Kconfig @@ -0,0 +1,14 @@ +config A + bool "A" + +choice + prompt "Choice ?" + depends on A + +config CHOICE_B + bool "Choice B" + +config CHOICE_C + bool "Choice C" + +endchoice diff --git a/scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py b/scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py new file mode 100644 index 000000000000..207261b0fe00 --- /dev/null +++ b/scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py @@ -0,0 +1,19 @@ +""" +Do not write choice values to .config if the dependency is unmet. + +"# CONFIG_... is not set" should not be written into the .config file +for symbols with unmet dependency. + +This was not working correctly for choice values because choice needs +a bit different symbol computation. + +This checks that no unneeded "# COFIG_... is not set" is contained in +the .config file. + +Related Linux commit: cb67ab2cd2b8abd9650292c986c79901e3073a59 +""" + + +def test(conf): + assert conf.oldaskconfig('config', 'n') == 0 + assert conf.config_matches('expected_config') diff --git a/scripts/kconfig/tests/no_write_if_dep_unmet/config b/scripts/kconfig/tests/no_write_if_dep_unmet/config new file mode 100644 index 000000000000..abd280e2f616 --- /dev/null +++ b/scripts/kconfig/tests/no_write_if_dep_unmet/config @@ -0,0 +1 @@ +CONFIG_A=y diff --git a/scripts/kconfig/tests/no_write_if_dep_unmet/expected_config b/scripts/kconfig/tests/no_write_if_dep_unmet/expected_config new file mode 100644 index 000000000000..0d15e41da475 --- /dev/null +++ b/scripts/kconfig/tests/no_write_if_dep_unmet/expected_config @@ -0,0 +1,5 @@ +# +# Automatically generated file; DO NOT EDIT. +# Linux Kernel Configuration +# +# CONFIG_A is not set diff --git a/scripts/kconfig/tests/pytest.ini b/scripts/kconfig/tests/pytest.ini new file mode 100644 index 000000000000..85d7ce8e448b --- /dev/null +++ b/scripts/kconfig/tests/pytest.ini @@ -0,0 +1,7 @@ +[pytest] +addopts = --verbose + +# Pytest requires that test files have unique names, because pytest imports +# them as top-level modules. It is silly to prefix or suffix a test file with +# the directory name that contains it. Use __init__.py for all test files. +python_files = __init__.py diff --git a/scripts/kconfig/tests/rand_nested_choice/Kconfig b/scripts/kconfig/tests/rand_nested_choice/Kconfig new file mode 100644 index 000000000000..c591d512929f --- /dev/null +++ b/scripts/kconfig/tests/rand_nested_choice/Kconfig @@ -0,0 +1,33 @@ +choice + prompt "choice" + +config A + bool "A" + +config B + bool "B" + +if B +choice + prompt "sub choice" + +config C + bool "C" + +config D + bool "D" + +if D +choice + prompt "subsub choice" + +config E + bool "E" + +endchoice +endif # D + +endchoice +endif # B + +endchoice diff --git a/scripts/kconfig/tests/rand_nested_choice/__init__.py b/scripts/kconfig/tests/rand_nested_choice/__init__.py new file mode 100644 index 000000000000..e729a4e85218 --- /dev/null +++ b/scripts/kconfig/tests/rand_nested_choice/__init__.py @@ -0,0 +1,16 @@ +""" +Set random values recursively in nested choices. + +Kconfig can create a choice-in-choice structure by using 'if' statement. +randconfig should correctly set random choice values. + +Related Linux commit: 3b9a19e08960e5cdad5253998637653e592a3c29 +""" + + +def test(conf): + for i in range(20): + assert conf.randconfig() == 0 + assert (conf.config_contains('expected_stdout0') or + conf.config_contains('expected_stdout1') or + conf.config_contains('expected_stdout2')) diff --git a/scripts/kconfig/tests/rand_nested_choice/expected_stdout0 b/scripts/kconfig/tests/rand_nested_choice/expected_stdout0 new file mode 100644 index 000000000000..05450f3d4eb5 --- /dev/null +++ b/scripts/kconfig/tests/rand_nested_choice/expected_stdout0 @@ -0,0 +1,2 @@ +CONFIG_A=y +# CONFIG_B is not set diff --git a/scripts/kconfig/tests/rand_nested_choice/expected_stdout1 b/scripts/kconfig/tests/rand_nested_choice/expected_stdout1 new file mode 100644 index 000000000000..37ab29584157 --- /dev/null +++ b/scripts/kconfig/tests/rand_nested_choice/expected_stdout1 @@ -0,0 +1,4 @@ +# CONFIG_A is not set +CONFIG_B=y +CONFIG_C=y +# CONFIG_D is not set diff --git a/scripts/kconfig/tests/rand_nested_choice/expected_stdout2 b/scripts/kconfig/tests/rand_nested_choice/expected_stdout2 new file mode 100644 index 000000000000..849ff47e9848 --- /dev/null +++ b/scripts/kconfig/tests/rand_nested_choice/expected_stdout2 @@ -0,0 +1,5 @@ +# CONFIG_A is not set +CONFIG_B=y +# CONFIG_C is not set +CONFIG_D=y +CONFIG_E=y diff --git a/scripts/kconfig/tests/warn_recursive_dep/Kconfig b/scripts/kconfig/tests/warn_recursive_dep/Kconfig new file mode 100644 index 000000000000..a65bfcb7137e --- /dev/null +++ b/scripts/kconfig/tests/warn_recursive_dep/Kconfig @@ -0,0 +1,62 @@ +# depends on itself + +config A + bool "A" + depends on A + +# select itself + +config B + bool + select B + +# depends on each other + +config C1 + bool "C1" + depends on C2 + +config C2 + bool "C2" + depends on C1 + +# depends on and select + +config D1 + bool "D1" + depends on D2 + select D2 + +config D2 + bool + +# depends on and imply +# This is not recursive dependency + +config E1 + bool "E1" + depends on E2 + imply E2 + +config E2 + bool "E2" + +# property + +config F1 + bool "F1" + default F2 + +config F2 + bool "F2" + depends on F1 + +# menu + +menu "menu depending on its content" + depends on G + +config G + bool "G" + +endmenu diff --git a/scripts/kconfig/tests/warn_recursive_dep/__init__.py b/scripts/kconfig/tests/warn_recursive_dep/__init__.py new file mode 100644 index 000000000000..adb21951ba41 --- /dev/null +++ b/scripts/kconfig/tests/warn_recursive_dep/__init__.py @@ -0,0 +1,9 @@ +""" +Warn recursive inclusion. + +Recursive dependency should be warned. +""" + +def test(conf): + assert conf.oldaskconfig() == 0 + assert conf.stderr_contains('expected_stderr') diff --git a/scripts/kconfig/tests/warn_recursive_dep/expected_stderr b/scripts/kconfig/tests/warn_recursive_dep/expected_stderr new file mode 100644 index 000000000000..3de807dd9cb2 --- /dev/null +++ b/scripts/kconfig/tests/warn_recursive_dep/expected_stderr @@ -0,0 +1,30 @@ +Kconfig:9:error: recursive dependency detected! +Kconfig:9: symbol B is selected by B +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:3:error: recursive dependency detected! +Kconfig:3: symbol A depends on A +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:15:error: recursive dependency detected! +Kconfig:15: symbol C1 depends on C2 +Kconfig:19: symbol C2 depends on C1 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:30:error: recursive dependency detected! +Kconfig:30: symbol D2 is selected by D1 +Kconfig:25: symbol D1 depends on D2 +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:59:error: recursive dependency detected! +Kconfig:59: symbol G depends on G +For a resolution refer to Documentation/kbuild/kconfig-language.txt +subsection "Kconfig recursive dependency limitations" + +Kconfig:50:error: recursive dependency detected! +Kconfig:50: symbol F2 depends on F1 +Kconfig:48: symbol F1 default value contains F2 diff --git a/scripts/kconfig/util.c b/scripts/kconfig/util.c index 0e76042473cc..c6f6e21b809f 100644 --- a/scripts/kconfig/util.c +++ b/scripts/kconfig/util.c @@ -14,11 +14,11 @@ struct file *file_lookup(const char *name) { struct file *file; - const char *file_name = sym_expand_string_value(name); + char *file_name = sym_expand_string_value(name);
for (file = file_list; file; file = file->next) { if (!strcmp(name, file->name)) { - free((void *)file_name); + free(file_name); return file; } } @@ -104,7 +104,7 @@ void str_append(struct gstr *gs, const char *s) if (s) { l = strlen(gs->s) + strlen(s) + 1; if (l > gs->len) { - gs->s = realloc(gs->s, l); + gs->s = xrealloc(gs->s, l); gs->len = l; } strcat(gs->s, s); @@ -145,3 +145,23 @@ void *xcalloc(size_t nmemb, size_t size) fprintf(stderr, "Out of memory.\n"); exit(1); } + +void *xrealloc(void *p, size_t size) +{ + p = realloc(p, size); + if (p) + return p; + fprintf(stderr, "Out of memory.\n"); + exit(1); +} + +char *xstrdup(const char *s) +{ + char *p; + + p = strdup(s); + if (p) + return p; + fprintf(stderr, "Out of memory.\n"); + exit(1); +} diff --git a/scripts/kconfig/zconf.gperf b/scripts/kconfig/zconf.gperf deleted file mode 100644 index ead02edec936..000000000000 --- a/scripts/kconfig/zconf.gperf +++ /dev/null @@ -1,50 +0,0 @@ -%language=ANSI-C -%define hash-function-name kconf_id_hash -%define lookup-function-name kconf_id_lookup -%define string-pool-name kconf_id_strings -%compare-strncmp -%enum -%pic -%struct-type - -struct kconf_id; - -static const struct kconf_id *kconf_id_lookup(register const char *str, register unsigned int len); - -%% -mainmenu, T_MAINMENU, TF_COMMAND -menu, T_MENU, TF_COMMAND -endmenu, T_ENDMENU, TF_COMMAND -source, T_SOURCE, TF_COMMAND -choice, T_CHOICE, TF_COMMAND -endchoice, T_ENDCHOICE, TF_COMMAND -comment, T_COMMENT, TF_COMMAND -config, T_CONFIG, TF_COMMAND -menuconfig, T_MENUCONFIG, TF_COMMAND -help, T_HELP, TF_COMMAND ----help---, T_HELP, TF_COMMAND -if, T_IF, TF_COMMAND|TF_PARAM -endif, T_ENDIF, TF_COMMAND -depends, T_DEPENDS, TF_COMMAND -optional, T_OPTIONAL, TF_COMMAND -default, T_DEFAULT, TF_COMMAND, S_UNKNOWN -prompt, T_PROMPT, TF_COMMAND -tristate, T_TYPE, TF_COMMAND, S_TRISTATE -def_tristate, T_DEFAULT, TF_COMMAND, S_TRISTATE -bool, T_TYPE, TF_COMMAND, S_BOOLEAN -boolean, T_TYPE, TF_COMMAND, S_BOOLEAN -def_bool, T_DEFAULT, TF_COMMAND, S_BOOLEAN -int, T_TYPE, TF_COMMAND, S_INT -hex, T_TYPE, TF_COMMAND, S_HEX -string, T_TYPE, TF_COMMAND, S_STRING -select, T_SELECT, TF_COMMAND -imply, T_IMPLY, TF_COMMAND -range, T_RANGE, TF_COMMAND -visible, T_VISIBLE, TF_COMMAND -option, T_OPTION, TF_COMMAND -on, T_ON, TF_PARAM -modules, T_OPT_MODULES, TF_OPTION -defconfig_list, T_OPT_DEFCONFIG_LIST,TF_OPTION -env, T_OPT_ENV, TF_OPTION -allnoconfig_y, T_OPT_ALLNOCONFIG_Y,TF_OPTION -%% diff --git a/scripts/kconfig/zconf.hash.c_shipped b/scripts/kconfig/zconf.hash.c_shipped deleted file mode 100644 index d51b15de074a..000000000000 --- a/scripts/kconfig/zconf.hash.c_shipped +++ /dev/null @@ -1,297 +0,0 @@ -/* ANSI-C code produced by gperf version 3.0.4 */ -/* Command-line: gperf -t --output-file scripts/kconfig/zconf.hash.c_shipped -a -C -E -g -k '1,3,$' -p -t scripts/kconfig/zconf.gperf */ - -#if !((' ' == 32) && ('!' == 33) && ('"' == 34) && ('#' == 35) \ - && ('%' == 37) && ('&' == 38) && (''' == 39) && ('(' == 40) \ - && (')' == 41) && ('*' == 42) && ('+' == 43) && (',' == 44) \ - && ('-' == 45) && ('.' == 46) && ('/' == 47) && ('0' == 48) \ - && ('1' == 49) && ('2' == 50) && ('3' == 51) && ('4' == 52) \ - && ('5' == 53) && ('6' == 54) && ('7' == 55) && ('8' == 56) \ - && ('9' == 57) && (':' == 58) && (';' == 59) && ('<' == 60) \ - && ('=' == 61) && ('>' == 62) && ('?' == 63) && ('A' == 65) \ - && ('B' == 66) && ('C' == 67) && ('D' == 68) && ('E' == 69) \ - && ('F' == 70) && ('G' == 71) && ('H' == 72) && ('I' == 73) \ - && ('J' == 74) && ('K' == 75) && ('L' == 76) && ('M' == 77) \ - && ('N' == 78) && ('O' == 79) && ('P' == 80) && ('Q' == 81) \ - && ('R' == 82) && ('S' == 83) && ('T' == 84) && ('U' == 85) \ - && ('V' == 86) && ('W' == 87) && ('X' == 88) && ('Y' == 89) \ - && ('Z' == 90) && ('[' == 91) && ('\' == 92) && (']' == 93) \ - && ('^' == 94) && ('_' == 95) && ('a' == 97) && ('b' == 98) \ - && ('c' == 99) && ('d' == 100) && ('e' == 101) && ('f' == 102) \ - && ('g' == 103) && ('h' == 104) && ('i' == 105) && ('j' == 106) \ - && ('k' == 107) && ('l' == 108) && ('m' == 109) && ('n' == 110) \ - && ('o' == 111) && ('p' == 112) && ('q' == 113) && ('r' == 114) \ - && ('s' == 115) && ('t' == 116) && ('u' == 117) && ('v' == 118) \ - && ('w' == 119) && ('x' == 120) && ('y' == 121) && ('z' == 122) \ - && ('{' == 123) && ('|' == 124) && ('}' == 125) && ('~' == 126)) -/* The character set is not based on ISO-646. */ -#error "gperf generated tables don't work with this execution character set. Please report a bug to bug-gnu-gperf@gnu.org." -#endif - -#line 10 "scripts/kconfig/zconf.gperf" -struct kconf_id; - -static const struct kconf_id *kconf_id_lookup(register const char *str, register unsigned int len); -/* maximum key range = 71, duplicates = 0 */ - -#ifdef __GNUC__ -__inline -#else -#ifdef __cplusplus -inline -#endif -#endif -static unsigned int -kconf_id_hash (register const char *str, register unsigned int len) -{ - static const unsigned char asso_values[] = - { - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 0, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 10, 25, 25, - 0, 0, 0, 5, 0, 0, 73, 73, 5, 0, - 10, 5, 45, 73, 20, 20, 0, 15, 15, 73, - 20, 0, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73, 73, 73, 73, 73, - 73, 73, 73, 73, 73, 73 - }; - register int hval = len; - - switch (hval) - { - default: - hval += asso_values[(unsigned char)str[2]]; - /*FALLTHROUGH*/ - case 2: - case 1: - hval += asso_values[(unsigned char)str[0]]; - break; - } - return hval + asso_values[(unsigned char)str[len - 1]]; -} - -struct kconf_id_strings_t - { - char kconf_id_strings_str2[sizeof("if")]; - char kconf_id_strings_str3[sizeof("int")]; - char kconf_id_strings_str5[sizeof("endif")]; - char kconf_id_strings_str7[sizeof("default")]; - char kconf_id_strings_str8[sizeof("tristate")]; - char kconf_id_strings_str9[sizeof("endchoice")]; - char kconf_id_strings_str10[sizeof("---help---")]; - char kconf_id_strings_str12[sizeof("def_tristate")]; - char kconf_id_strings_str13[sizeof("def_bool")]; - char kconf_id_strings_str14[sizeof("defconfig_list")]; - char kconf_id_strings_str17[sizeof("on")]; - char kconf_id_strings_str18[sizeof("optional")]; - char kconf_id_strings_str21[sizeof("option")]; - char kconf_id_strings_str22[sizeof("endmenu")]; - char kconf_id_strings_str23[sizeof("mainmenu")]; - char kconf_id_strings_str25[sizeof("menuconfig")]; - char kconf_id_strings_str27[sizeof("modules")]; - char kconf_id_strings_str28[sizeof("allnoconfig_y")]; - char kconf_id_strings_str29[sizeof("menu")]; - char kconf_id_strings_str31[sizeof("select")]; - char kconf_id_strings_str32[sizeof("comment")]; - char kconf_id_strings_str33[sizeof("env")]; - char kconf_id_strings_str35[sizeof("range")]; - char kconf_id_strings_str36[sizeof("choice")]; - char kconf_id_strings_str39[sizeof("bool")]; - char kconf_id_strings_str41[sizeof("source")]; - char kconf_id_strings_str42[sizeof("visible")]; - char kconf_id_strings_str43[sizeof("hex")]; - char kconf_id_strings_str46[sizeof("config")]; - char kconf_id_strings_str47[sizeof("boolean")]; - char kconf_id_strings_str50[sizeof("imply")]; - char kconf_id_strings_str51[sizeof("string")]; - char kconf_id_strings_str54[sizeof("help")]; - char kconf_id_strings_str56[sizeof("prompt")]; - char kconf_id_strings_str72[sizeof("depends")]; - }; -static const struct kconf_id_strings_t kconf_id_strings_contents = - { - "if", - "int", - "endif", - "default", - "tristate", - "endchoice", - "---help---", - "def_tristate", - "def_bool", - "defconfig_list", - "on", - "optional", - "option", - "endmenu", - "mainmenu", - "menuconfig", - "modules", - "allnoconfig_y", - "menu", - "select", - "comment", - "env", - "range", - "choice", - "bool", - "source", - "visible", - "hex", - "config", - "boolean", - "imply", - "string", - "help", - "prompt", - "depends" - }; -#define kconf_id_strings ((const char *) &kconf_id_strings_contents) -#ifdef __GNUC__ -__inline -#if defined __GNUC_STDC_INLINE__ || defined __GNUC_GNU_INLINE__ -__attribute__ ((__gnu_inline__)) -#endif -#endif -const struct kconf_id * -kconf_id_lookup (register const char *str, register unsigned int len) -{ - enum - { - TOTAL_KEYWORDS = 35, - MIN_WORD_LENGTH = 2, - MAX_WORD_LENGTH = 14, - MIN_HASH_VALUE = 2, - MAX_HASH_VALUE = 72 - }; - - static const struct kconf_id wordlist[] = - { - {-1}, {-1}, -#line 26 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str2, T_IF, TF_COMMAND|TF_PARAM}, -#line 37 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str3, T_TYPE, TF_COMMAND, S_INT}, - {-1}, -#line 27 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str5, T_ENDIF, TF_COMMAND}, - {-1}, -#line 30 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str7, T_DEFAULT, TF_COMMAND, S_UNKNOWN}, -#line 32 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str8, T_TYPE, TF_COMMAND, S_TRISTATE}, -#line 20 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str9, T_ENDCHOICE, TF_COMMAND}, -#line 25 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str10, T_HELP, TF_COMMAND}, - {-1}, -#line 33 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str12, T_DEFAULT, TF_COMMAND, S_TRISTATE}, -#line 36 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str13, T_DEFAULT, TF_COMMAND, S_BOOLEAN}, -#line 47 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str14, T_OPT_DEFCONFIG_LIST,TF_OPTION}, - {-1}, {-1}, -#line 45 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str17, T_ON, TF_PARAM}, -#line 29 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str18, T_OPTIONAL, TF_COMMAND}, - {-1}, {-1}, -#line 44 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str21, T_OPTION, TF_COMMAND}, -#line 17 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str22, T_ENDMENU, TF_COMMAND}, -#line 15 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str23, T_MAINMENU, TF_COMMAND}, - {-1}, -#line 23 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str25, T_MENUCONFIG, TF_COMMAND}, - {-1}, -#line 46 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str27, T_OPT_MODULES, TF_OPTION}, -#line 49 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str28, T_OPT_ALLNOCONFIG_Y,TF_OPTION}, -#line 16 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str29, T_MENU, TF_COMMAND}, - {-1}, -#line 40 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str31, T_SELECT, TF_COMMAND}, -#line 21 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str32, T_COMMENT, TF_COMMAND}, -#line 48 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str33, T_OPT_ENV, TF_OPTION}, - {-1}, -#line 42 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str35, T_RANGE, TF_COMMAND}, -#line 19 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str36, T_CHOICE, TF_COMMAND}, - {-1}, {-1}, -#line 34 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str39, T_TYPE, TF_COMMAND, S_BOOLEAN}, - {-1}, -#line 18 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str41, T_SOURCE, TF_COMMAND}, -#line 43 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str42, T_VISIBLE, TF_COMMAND}, -#line 38 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str43, T_TYPE, TF_COMMAND, S_HEX}, - {-1}, {-1}, -#line 22 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str46, T_CONFIG, TF_COMMAND}, -#line 35 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str47, T_TYPE, TF_COMMAND, S_BOOLEAN}, - {-1}, {-1}, -#line 41 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str50, T_IMPLY, TF_COMMAND}, -#line 39 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str51, T_TYPE, TF_COMMAND, S_STRING}, - {-1}, {-1}, -#line 24 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str54, T_HELP, TF_COMMAND}, - {-1}, -#line 31 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str56, T_PROMPT, TF_COMMAND}, - {-1}, {-1}, {-1}, {-1}, {-1}, {-1}, {-1}, {-1}, {-1}, - {-1}, {-1}, {-1}, {-1}, {-1}, {-1}, -#line 28 "scripts/kconfig/zconf.gperf" - {(int)(long)&((struct kconf_id_strings_t *)0)->kconf_id_strings_str72, T_DEPENDS, TF_COMMAND} - }; - - if (len <= MAX_WORD_LENGTH && len >= MIN_WORD_LENGTH) - { - register int key = kconf_id_hash (str, len); - - if (key <= MAX_HASH_VALUE && key >= 0) - { - register int o = wordlist[key].name; - if (o >= 0) - { - register const char *s = o + kconf_id_strings; - - if (*str == *s && !strncmp (str + 1, s + 1, len - 1) && s[len] == '\0') - return &wordlist[key]; - } - } - } - return 0; -} -#line 50 "scripts/kconfig/zconf.gperf" - diff --git a/scripts/kconfig/zconf.l b/scripts/kconfig/zconf.l index c410d257da06..045093d827e1 100644 --- a/scripts/kconfig/zconf.l +++ b/scripts/kconfig/zconf.l @@ -1,5 +1,5 @@ %option nostdinit noyywrap never-interactive full ecs -%option 8bit nodefault perf-report perf-report +%option 8bit nodefault yylineno %option noinput %x COMMAND HELP STRING PARAM %{ @@ -52,7 +52,7 @@ static void append_string(const char *str, int size) if (new_size > text_asize) { new_size += START_STRSIZE - 1; new_size &= -START_STRSIZE; - text = realloc(text, new_size); + text = xrealloc(text, new_size); text_asize = new_size; } memcpy(text + text_size, str, size); @@ -83,7 +83,6 @@ n [A-Za-z0-9_-]
[ \t]*#.*\n | [ \t]*\n { - current_file->lineno++; return T_EOL; } [ \t]*#.* @@ -104,19 +103,18 @@ n [A-Za-z0-9_-] const struct kconf_id *id = kconf_id_lookup(yytext, yyleng); BEGIN(PARAM); current_pos.file = current_file; - current_pos.lineno = current_file->lineno; + current_pos.lineno = yylineno; if (id && id->flags & TF_COMMAND) { - zconflval.id = id; + yylval.id = id; return id->token; } alloc_string(yytext, yyleng); - zconflval.string = text; + yylval.string = text; return T_WORD; } . warn_ignored_character(*yytext); \n { BEGIN(INITIAL); - current_file->lineno++; return T_EOL; } } @@ -138,19 +136,19 @@ n [A-Za-z0-9_-] new_string(); BEGIN(STRING); } - \n BEGIN(INITIAL); current_file->lineno++; return T_EOL; + \n BEGIN(INITIAL); return T_EOL; ({n}|[/.])+ { const struct kconf_id *id = kconf_id_lookup(yytext, yyleng); if (id && id->flags & TF_PARAM) { - zconflval.id = id; + yylval.id = id; return id->token; } alloc_string(yytext, yyleng); - zconflval.string = text; + yylval.string = text; return T_WORD; } #.* /* comment */ - \\n current_file->lineno++; + \\n ; [[:blank:]]+ . warn_ignored_character(*yytext); <<EOF>> { @@ -161,7 +159,7 @@ n [A-Za-z0-9_-] <STRING>{ [^'"\\n]+/\n { append_string(yytext, yyleng); - zconflval.string = text; + yylval.string = text; return T_WORD_QUOTE; } [^'"\\n]+ { @@ -169,7 +167,7 @@ n [A-Za-z0-9_-] } \.?/\n { append_string(yytext + 1, yyleng - 1); - zconflval.string = text; + yylval.string = text; return T_WORD_QUOTE; } \.? { @@ -178,14 +176,15 @@ n [A-Za-z0-9_-] '|" { if (str == yytext[0]) { BEGIN(PARAM); - zconflval.string = text; + yylval.string = text; return T_WORD_QUOTE; } else append_string(yytext, 1); } \n { - printf("%s:%d:warning: multi-line strings not supported\n", zconf_curname(), zconf_lineno()); - current_file->lineno++; + fprintf(stderr, + "%s:%d:warning: multi-line strings not supported\n", + zconf_curname(), zconf_lineno()); BEGIN(INITIAL); return T_EOL; } @@ -218,12 +217,10 @@ n [A-Za-z0-9_-] } } [ \t]*\n/[^ \t\n] { - current_file->lineno++; zconf_endhelp(); return T_HELPTEXT; } [ \t]*\n { - current_file->lineno++; append_string("\n", 1); } [^ \t\n].* { @@ -261,7 +258,7 @@ void zconf_starthelp(void)
static void zconf_endhelp(void) { - zconflval.string = text; + yylval.string = text; BEGIN(INITIAL); }
@@ -294,7 +291,7 @@ void zconf_initscan(const char *name) { yyin = zconf_fopen(name); if (!yyin) { - printf("can't find file %s\n", name); + fprintf(stderr, "can't find file %s\n", name); exit(1); }
@@ -302,7 +299,7 @@ void zconf_initscan(const char *name) memset(current_buf, 0, sizeof(*current_buf));
current_file = file_lookup(name); - current_file->lineno = 1; + yylineno = 1; }
void zconf_nextfile(const char *name) @@ -315,35 +312,34 @@ void zconf_nextfile(const char *name) current_buf->state = YY_CURRENT_BUFFER; yyin = zconf_fopen(file->name); if (!yyin) { - printf("%s:%d: can't open file "%s"\n", - zconf_curname(), zconf_lineno(), file->name); + fprintf(stderr, "%s:%d: can't open file "%s"\n", + zconf_curname(), zconf_lineno(), file->name); exit(1); } yy_switch_to_buffer(yy_create_buffer(yyin, YY_BUF_SIZE)); buf->parent = current_buf; current_buf = buf;
- for (iter = current_file->parent; iter; iter = iter->parent ) { - if (!strcmp(current_file->name,iter->name) ) { - printf("%s:%d: recursive inclusion detected. " - "Inclusion path:\n current file : '%s'\n", - zconf_curname(), zconf_lineno(), - zconf_curname()); - iter = current_file->parent; - while (iter && \ - strcmp(iter->name,current_file->name)) { - printf(" included from: '%s:%d'\n", - iter->name, iter->lineno-1); + current_file->lineno = yylineno; + file->parent = current_file; + + for (iter = current_file; iter; iter = iter->parent) { + if (!strcmp(iter->name, file->name)) { + fprintf(stderr, + "Recursive inclusion detected.\n" + "Inclusion path:\n" + " current file : %s\n", file->name); + iter = file; + do { iter = iter->parent; - } - if (iter) - printf(" included from: '%s:%d'\n", - iter->name, iter->lineno+1); + fprintf(stderr, " included from: %s:%d\n", + iter->name, iter->lineno - 1); + } while (strcmp(iter->name, file->name)); exit(1); } } - file->lineno = 1; - file->parent = current_file; + + yylineno = 1; current_file = file; }
@@ -352,6 +348,8 @@ static void zconf_endfile(void) struct buffer *parent;
current_file = current_file->parent; + if (current_file) + yylineno = current_file->lineno;
parent = current_buf->parent; if (parent) { diff --git a/scripts/kconfig/zconf.lex.c_shipped b/scripts/kconfig/zconf.lex.c_shipped deleted file mode 100644 index 37fdf6123505..000000000000 --- a/scripts/kconfig/zconf.lex.c_shipped +++ /dev/null @@ -1,2473 +0,0 @@ - -#line 3 "scripts/kconfig/zconf.lex.c_shipped" - -#define YY_INT_ALIGNED short int - -/* A lexical scanner generated by flex */ - -#define yy_create_buffer zconf_create_buffer -#define yy_delete_buffer zconf_delete_buffer -#define yy_flex_debug zconf_flex_debug -#define yy_init_buffer zconf_init_buffer -#define yy_flush_buffer zconf_flush_buffer -#define yy_load_buffer_state zconf_load_buffer_state -#define yy_switch_to_buffer zconf_switch_to_buffer -#define yyin zconfin -#define yyleng zconfleng -#define yylex zconflex -#define yylineno zconflineno -#define yyout zconfout -#define yyrestart zconfrestart -#define yytext zconftext -#define yywrap zconfwrap -#define yyalloc zconfalloc -#define yyrealloc zconfrealloc -#define yyfree zconffree - -#define FLEX_SCANNER -#define YY_FLEX_MAJOR_VERSION 2 -#define YY_FLEX_MINOR_VERSION 5 -#define YY_FLEX_SUBMINOR_VERSION 35 -#if YY_FLEX_SUBMINOR_VERSION > 0 -#define FLEX_BETA -#endif - -/* First, we deal with platform-specific or compiler-specific issues. */ - -/* begin standard C headers. */ -#include <stdio.h> -#include <string.h> -#include <errno.h> -#include <stdlib.h> - -/* end standard C headers. */ - -/* flex integer type definitions */ - -#ifndef FLEXINT_H -#define FLEXINT_H - -/* C99 systems have <inttypes.h>. Non-C99 systems may or may not. */ - -#if defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L - -/* C99 says to define __STDC_LIMIT_MACROS before including stdint.h, - * if you want the limit (max/min) macros for int types. - */ -#ifndef __STDC_LIMIT_MACROS -#define __STDC_LIMIT_MACROS 1 -#endif - -#include <inttypes.h> -typedef int8_t flex_int8_t; -typedef uint8_t flex_uint8_t; -typedef int16_t flex_int16_t; -typedef uint16_t flex_uint16_t; -typedef int32_t flex_int32_t; -typedef uint32_t flex_uint32_t; -#else -typedef signed char flex_int8_t; -typedef short int flex_int16_t; -typedef int flex_int32_t; -typedef unsigned char flex_uint8_t; -typedef unsigned short int flex_uint16_t; -typedef unsigned int flex_uint32_t; - -/* Limits of integral types. */ -#ifndef INT8_MIN -#define INT8_MIN (-128) -#endif -#ifndef INT16_MIN -#define INT16_MIN (-32767-1) -#endif -#ifndef INT32_MIN -#define INT32_MIN (-2147483647-1) -#endif -#ifndef INT8_MAX -#define INT8_MAX (127) -#endif -#ifndef INT16_MAX -#define INT16_MAX (32767) -#endif -#ifndef INT32_MAX -#define INT32_MAX (2147483647) -#endif -#ifndef UINT8_MAX -#define UINT8_MAX (255U) -#endif -#ifndef UINT16_MAX -#define UINT16_MAX (65535U) -#endif -#ifndef UINT32_MAX -#define UINT32_MAX (4294967295U) -#endif - -#endif /* ! C99 */ - -#endif /* ! FLEXINT_H */ - -#ifdef __cplusplus - -/* The "const" storage-class-modifier is valid. */ -#define YY_USE_CONST - -#else /* ! __cplusplus */ - -/* C99 requires __STDC__ to be defined as 1. */ -#if defined (__STDC__) - -#define YY_USE_CONST - -#endif /* defined (__STDC__) */ -#endif /* ! __cplusplus */ - -#ifdef YY_USE_CONST -#define yyconst const -#else -#define yyconst -#endif - -/* Returned upon end-of-file. */ -#define YY_NULL 0 - -/* Promotes a possibly negative, possibly signed char to an unsigned - * integer for use as an array index. If the signed char is negative, - * we want to instead treat it as an 8-bit unsigned char, hence the - * double cast. - */ -#define YY_SC_TO_UI(c) ((unsigned int) (unsigned char) c) - -/* Enter a start condition. This macro really ought to take a parameter, - * but we do it the disgusting crufty way forced on us by the ()-less - * definition of BEGIN. - */ -#define BEGIN (yy_start) = 1 + 2 * - -/* Translate the current start state into a value that can be later handed - * to BEGIN to return to the state. The YYSTATE alias is for lex - * compatibility. - */ -#define YY_START (((yy_start) - 1) / 2) -#define YYSTATE YY_START - -/* Action number for EOF rule of a given start state. */ -#define YY_STATE_EOF(state) (YY_END_OF_BUFFER + state + 1) - -/* Special action meaning "start processing a new file". */ -#define YY_NEW_FILE zconfrestart(zconfin ) - -#define YY_END_OF_BUFFER_CHAR 0 - -/* Size of default input buffer. */ -#ifndef YY_BUF_SIZE -#ifdef __ia64__ -/* On IA-64, the buffer size is 16k, not 8k. - * Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case. - * Ditto for the __ia64__ case accordingly. - */ -#define YY_BUF_SIZE 32768 -#else -#define YY_BUF_SIZE 16384 -#endif /* __ia64__ */ -#endif - -/* The state buf must be large enough to hold one state per character in the main buffer. - */ -#define YY_STATE_BUF_SIZE ((YY_BUF_SIZE + 2) * sizeof(yy_state_type)) - -#ifndef YY_TYPEDEF_YY_BUFFER_STATE -#define YY_TYPEDEF_YY_BUFFER_STATE -typedef struct yy_buffer_state *YY_BUFFER_STATE; -#endif - -extern int zconfleng; - -extern FILE *zconfin, *zconfout; - -#define EOB_ACT_CONTINUE_SCAN 0 -#define EOB_ACT_END_OF_FILE 1 -#define EOB_ACT_LAST_MATCH 2 - - #define YY_LESS_LINENO(n) - -/* Return all but the first "n" matched characters back to the input stream. */ -#define yyless(n) \ - do \ - { \ - /* Undo effects of setting up zconftext. */ \ - int yyless_macro_arg = (n); \ - YY_LESS_LINENO(yyless_macro_arg);\ - *yy_cp = (yy_hold_char); \ - YY_RESTORE_YY_MORE_OFFSET \ - (yy_c_buf_p) = yy_cp = yy_bp + yyless_macro_arg - YY_MORE_ADJ; \ - YY_DO_BEFORE_ACTION; /* set up zconftext again */ \ - } \ - while ( 0 ) - -#define unput(c) yyunput( c, (yytext_ptr) ) - -#ifndef YY_TYPEDEF_YY_SIZE_T -#define YY_TYPEDEF_YY_SIZE_T -typedef size_t yy_size_t; -#endif - -#ifndef YY_STRUCT_YY_BUFFER_STATE -#define YY_STRUCT_YY_BUFFER_STATE -struct yy_buffer_state - { - FILE *yy_input_file; - - char *yy_ch_buf; /* input buffer */ - char *yy_buf_pos; /* current position in input buffer */ - - /* Size of input buffer in bytes, not including room for EOB - * characters. - */ - yy_size_t yy_buf_size; - - /* Number of characters read into yy_ch_buf, not including EOB - * characters. - */ - int yy_n_chars; - - /* Whether we "own" the buffer - i.e., we know we created it, - * and can realloc() it to grow it, and should free() it to - * delete it. - */ - int yy_is_our_buffer; - - /* Whether this is an "interactive" input source; if so, and - * if we're using stdio for input, then we want to use getc() - * instead of fread(), to make sure we stop fetching input after - * each newline. - */ - int yy_is_interactive; - - /* Whether we're considered to be at the beginning of a line. - * If so, '^' rules will be active on the next match, otherwise - * not. - */ - int yy_at_bol; - - int yy_bs_lineno; /**< The line count. */ - int yy_bs_column; /**< The column count. */ - - /* Whether to try to fill the input buffer when we reach the - * end of it. - */ - int yy_fill_buffer; - - int yy_buffer_status; - -#define YY_BUFFER_NEW 0 -#define YY_BUFFER_NORMAL 1 - /* When an EOF's been seen but there's still some text to process - * then we mark the buffer as YY_EOF_PENDING, to indicate that we - * shouldn't try reading from the input source any more. We might - * still have a bunch of tokens to match, though, because of - * possible backing-up. - * - * When we actually see the EOF, we change the status to "new" - * (via zconfrestart()), so that the user can continue scanning by - * just pointing zconfin at a new input file. - */ -#define YY_BUFFER_EOF_PENDING 2 - - }; -#endif /* !YY_STRUCT_YY_BUFFER_STATE */ - -/* Stack of input buffers. */ -static size_t yy_buffer_stack_top = 0; /**< index of top of stack. */ -static size_t yy_buffer_stack_max = 0; /**< capacity of stack. */ -static YY_BUFFER_STATE * yy_buffer_stack = 0; /**< Stack as an array. */ - -/* We provide macros for accessing buffer states in case in the - * future we want to put the buffer states in a more general - * "scanner state". - * - * Returns the top of the stack, or NULL. - */ -#define YY_CURRENT_BUFFER ( (yy_buffer_stack) \ - ? (yy_buffer_stack)[(yy_buffer_stack_top)] \ - : NULL) - -/* Same as previous macro, but useful when we know that the buffer stack is not - * NULL or when we need an lvalue. For internal use only. - */ -#define YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)] - -/* yy_hold_char holds the character lost when zconftext is formed. */ -static char yy_hold_char; -static int yy_n_chars; /* number of characters read into yy_ch_buf */ -int zconfleng; - -/* Points to current character in buffer. */ -static char *yy_c_buf_p = (char *) 0; -static int yy_init = 0; /* whether we need to initialize */ -static int yy_start = 0; /* start state number */ - -/* Flag which is used to allow zconfwrap()'s to do buffer switches - * instead of setting up a fresh zconfin. A bit of a hack ... - */ -static int yy_did_buffer_switch_on_eof; - -void zconfrestart (FILE *input_file ); -void zconf_switch_to_buffer (YY_BUFFER_STATE new_buffer ); -YY_BUFFER_STATE zconf_create_buffer (FILE *file,int size ); -void zconf_delete_buffer (YY_BUFFER_STATE b ); -void zconf_flush_buffer (YY_BUFFER_STATE b ); -void zconfpush_buffer_state (YY_BUFFER_STATE new_buffer ); -void zconfpop_buffer_state (void ); - -static void zconfensure_buffer_stack (void ); -static void zconf_load_buffer_state (void ); -static void zconf_init_buffer (YY_BUFFER_STATE b,FILE *file ); - -#define YY_FLUSH_BUFFER zconf_flush_buffer(YY_CURRENT_BUFFER ) - -YY_BUFFER_STATE zconf_scan_buffer (char *base,yy_size_t size ); -YY_BUFFER_STATE zconf_scan_string (yyconst char *yy_str ); -YY_BUFFER_STATE zconf_scan_bytes (yyconst char *bytes,int len ); - -void *zconfalloc (yy_size_t ); -void *zconfrealloc (void *,yy_size_t ); -void zconffree (void * ); - -#define yy_new_buffer zconf_create_buffer - -#define yy_set_interactive(is_interactive) \ - { \ - if ( ! YY_CURRENT_BUFFER ){ \ - zconfensure_buffer_stack (); \ - YY_CURRENT_BUFFER_LVALUE = \ - zconf_create_buffer(zconfin,YY_BUF_SIZE ); \ - } \ - YY_CURRENT_BUFFER_LVALUE->yy_is_interactive = is_interactive; \ - } - -#define yy_set_bol(at_bol) \ - { \ - if ( ! YY_CURRENT_BUFFER ){\ - zconfensure_buffer_stack (); \ - YY_CURRENT_BUFFER_LVALUE = \ - zconf_create_buffer(zconfin,YY_BUF_SIZE ); \ - } \ - YY_CURRENT_BUFFER_LVALUE->yy_at_bol = at_bol; \ - } - -#define YY_AT_BOL() (YY_CURRENT_BUFFER_LVALUE->yy_at_bol) - -/* Begin user sect3 */ - -#define zconfwrap(n) 1 -#define YY_SKIP_YYWRAP - -typedef unsigned char YY_CHAR; - -FILE *zconfin = (FILE *) 0, *zconfout = (FILE *) 0; - -typedef int yy_state_type; - -extern int zconflineno; - -int zconflineno = 1; - -extern char *zconftext; -#define yytext_ptr zconftext -static yyconst flex_int16_t yy_nxt[][18] = - { - { - 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0, 0, 0, 0, 0, 0, 0 - }, - - { - 11, 12, 13, 14, 12, 12, 15, 12, 12, 12, - 12, 12, 12, 12, 12, 12, 12, 12 - }, - - { - 11, 12, 13, 14, 12, 12, 15, 12, 12, 12, - 12, 12, 12, 12, 12, 12, 12, 12 - }, - - { - 11, 16, 16, 17, 16, 16, 16, 16, 16, 16, - 16, 18, 16, 16, 16, 16, 16, 16 - }, - - { - 11, 16, 16, 17, 16, 16, 16, 16, 16, 16, - 16, 18, 16, 16, 16, 16, 16, 16 - - }, - - { - 11, 19, 20, 21, 19, 19, 19, 19, 19, 19, - 19, 19, 19, 19, 19, 19, 19, 19 - }, - - { - 11, 19, 20, 21, 19, 19, 19, 19, 19, 19, - 19, 19, 19, 19, 19, 19, 19, 19 - }, - - { - 11, 22, 22, 23, 22, 24, 22, 22, 24, 22, - 22, 22, 22, 22, 22, 22, 25, 22 - }, - - { - 11, 22, 22, 23, 22, 24, 22, 22, 24, 22, - 22, 22, 22, 22, 22, 22, 25, 22 - }, - - { - 11, 26, 27, 28, 29, 30, 31, 32, 30, 33, - 34, 35, 35, 36, 37, 38, 39, 40 - - }, - - { - 11, 26, 27, 28, 29, 30, 31, 32, 30, 33, - 34, 35, 35, 36, 37, 38, 39, 40 - }, - - { - -11, -11, -11, -11, -11, -11, -11, -11, -11, -11, - -11, -11, -11, -11, -11, -11, -11, -11 - }, - - { - 11, -12, -12, -12, -12, -12, -12, -12, -12, -12, - -12, -12, -12, -12, -12, -12, -12, -12 - }, - - { - 11, -13, 41, 42, -13, -13, 43, -13, -13, -13, - -13, -13, -13, -13, -13, -13, -13, -13 - }, - - { - 11, -14, -14, -14, -14, -14, -14, -14, -14, -14, - -14, -14, -14, -14, -14, -14, -14, -14 - - }, - - { - 11, 44, 44, 45, 44, 44, 44, 44, 44, 44, - 44, 44, 44, 44, 44, 44, 44, 44 - }, - - { - 11, -16, -16, -16, -16, -16, -16, -16, -16, -16, - -16, -16, -16, -16, -16, -16, -16, -16 - }, - - { - 11, -17, -17, -17, -17, -17, -17, -17, -17, -17, - -17, -17, -17, -17, -17, -17, -17, -17 - }, - - { - 11, -18, -18, -18, -18, -18, -18, -18, -18, -18, - -18, 46, -18, -18, -18, -18, -18, -18 - }, - - { - 11, 47, 47, -19, 47, 47, 47, 47, 47, 47, - 47, 47, 47, 47, 47, 47, 47, 47 - - }, - - { - 11, -20, 48, 49, -20, -20, -20, -20, -20, -20, - -20, -20, -20, -20, -20, -20, -20, -20 - }, - - { - 11, 50, -21, -21, 50, 50, 50, 50, 50, 50, - 50, 50, 50, 50, 50, 50, 50, 50 - }, - - { - 11, 51, 51, 52, 51, -22, 51, 51, -22, 51, - 51, 51, 51, 51, 51, 51, -22, 51 - }, - - { - 11, -23, -23, -23, -23, -23, -23, -23, -23, -23, - -23, -23, -23, -23, -23, -23, -23, -23 - }, - - { - 11, -24, -24, -24, -24, -24, -24, -24, -24, -24, - -24, -24, -24, -24, -24, -24, -24, -24 - - }, - - { - 11, 53, 53, 54, 53, 53, 53, 53, 53, 53, - 53, 53, 53, 53, 53, 53, 53, 53 - }, - - { - 11, -26, -26, -26, -26, -26, -26, -26, -26, -26, - -26, -26, -26, -26, -26, -26, -26, -26 - }, - - { - 11, -27, 55, -27, -27, -27, -27, -27, -27, -27, - -27, -27, -27, -27, -27, -27, -27, -27 - }, - - { - 11, -28, -28, -28, -28, -28, -28, -28, -28, -28, - -28, -28, -28, -28, -28, -28, -28, -28 - }, - - { - 11, -29, -29, -29, -29, -29, -29, -29, -29, -29, - -29, -29, -29, -29, 56, -29, -29, -29 - - }, - - { - 11, -30, -30, -30, -30, -30, -30, -30, -30, -30, - -30, -30, -30, -30, -30, -30, -30, -30 - }, - - { - 11, 57, 57, -31, 57, 57, 57, 57, 57, 57, - 57, 57, 57, 57, 57, 57, 57, 57 - }, - - { - 11, -32, -32, -32, -32, -32, -32, 58, -32, -32, - -32, -32, -32, -32, -32, -32, -32, -32 - }, - - { - 11, -33, -33, -33, -33, -33, -33, -33, -33, -33, - -33, -33, -33, -33, -33, -33, -33, -33 - }, - - { - 11, -34, -34, -34, -34, -34, -34, -34, -34, -34, - -34, -34, -34, -34, -34, -34, -34, -34 - - }, - - { - 11, -35, -35, -35, -35, -35, -35, -35, -35, -35, - -35, 59, 59, -35, -35, -35, -35, -35 - }, - - { - 11, -36, -36, -36, -36, -36, -36, -36, -36, -36, - -36, -36, -36, -36, 60, -36, -36, -36 - }, - - { - 11, -37, -37, -37, -37, -37, -37, -37, -37, -37, - -37, -37, -37, -37, -37, -37, -37, -37 - }, - - { - 11, -38, -38, -38, -38, -38, -38, -38, -38, -38, - -38, -38, -38, -38, 61, -38, -38, -38 - }, - - { - 11, -39, -39, 62, -39, -39, -39, -39, -39, -39, - -39, -39, -39, -39, -39, -39, -39, -39 - - }, - - { - 11, -40, -40, -40, -40, -40, -40, -40, -40, -40, - -40, -40, -40, -40, -40, -40, -40, 63 - }, - - { - 11, -41, 41, 42, -41, -41, 43, -41, -41, -41, - -41, -41, -41, -41, -41, -41, -41, -41 - }, - - { - 11, -42, -42, -42, -42, -42, -42, -42, -42, -42, - -42, -42, -42, -42, -42, -42, -42, -42 - }, - - { - 11, 44, 44, 45, 44, 44, 44, 44, 44, 44, - 44, 44, 44, 44, 44, 44, 44, 44 - }, - - { - 11, 44, 44, 45, 44, 44, 44, 44, 44, 44, - 44, 44, 44, 44, 44, 44, 44, 44 - - }, - - { - 11, -45, -45, -45, -45, -45, -45, -45, -45, -45, - -45, -45, -45, -45, -45, -45, -45, -45 - }, - - { - 11, -46, -46, -46, -46, -46, -46, -46, -46, -46, - -46, 46, -46, -46, -46, -46, -46, -46 - }, - - { - 11, 47, 47, -47, 47, 47, 47, 47, 47, 47, - 47, 47, 47, 47, 47, 47, 47, 47 - }, - - { - 11, -48, 48, 49, -48, -48, -48, -48, -48, -48, - -48, -48, -48, -48, -48, -48, -48, -48 - }, - - { - 11, 50, -49, -49, 50, 50, 50, 50, 50, 50, - 50, 50, 50, 50, 50, 50, 50, 50 - - }, - - { - 11, -50, -50, -50, -50, -50, -50, -50, -50, -50, - -50, -50, -50, -50, -50, -50, -50, -50 - }, - - { - 11, 51, 51, 52, 51, -51, 51, 51, -51, 51, - 51, 51, 51, 51, 51, 51, -51, 51 - }, - - { - 11, -52, -52, -52, -52, -52, -52, -52, -52, -52, - -52, -52, -52, -52, -52, -52, -52, -52 - }, - - { - 11, -53, -53, 54, -53, -53, -53, -53, -53, -53, - -53, -53, -53, -53, -53, -53, -53, -53 - }, - - { - 11, -54, -54, -54, -54, -54, -54, -54, -54, -54, - -54, -54, -54, -54, -54, -54, -54, -54 - - }, - - { - 11, -55, 55, -55, -55, -55, -55, -55, -55, -55, - -55, -55, -55, -55, -55, -55, -55, -55 - }, - - { - 11, -56, -56, -56, -56, -56, -56, -56, -56, -56, - -56, -56, -56, -56, -56, -56, -56, -56 - }, - - { - 11, 57, 57, -57, 57, 57, 57, 57, 57, 57, - 57, 57, 57, 57, 57, 57, 57, 57 - }, - - { - 11, -58, -58, -58, -58, -58, -58, -58, -58, -58, - -58, -58, -58, -58, -58, -58, -58, -58 - }, - - { - 11, -59, -59, -59, -59, -59, -59, -59, -59, -59, - -59, 59, 59, -59, -59, -59, -59, -59 - - }, - - { - 11, -60, -60, -60, -60, -60, -60, -60, -60, -60, - -60, -60, -60, -60, -60, -60, -60, -60 - }, - - { - 11, -61, -61, -61, -61, -61, -61, -61, -61, -61, - -61, -61, -61, -61, -61, -61, -61, -61 - }, - - { - 11, -62, -62, -62, -62, -62, -62, -62, -62, -62, - -62, -62, -62, -62, -62, -62, -62, -62 - }, - - { - 11, -63, -63, -63, -63, -63, -63, -63, -63, -63, - -63, -63, -63, -63, -63, -63, -63, -63 - }, - - } ; - -static yy_state_type yy_get_previous_state (void ); -static yy_state_type yy_try_NUL_trans (yy_state_type current_state ); -static int yy_get_next_buffer (void ); -static void yy_fatal_error (yyconst char msg[] ); - -/* Done after the current pattern has been matched and before the - * corresponding action - sets up zconftext. - */ -#define YY_DO_BEFORE_ACTION \ - (yytext_ptr) = yy_bp; \ - zconfleng = (size_t) (yy_cp - yy_bp); \ - (yy_hold_char) = *yy_cp; \ - *yy_cp = '\0'; \ - (yy_c_buf_p) = yy_cp; - -#define YY_NUM_RULES 37 -#define YY_END_OF_BUFFER 38 -/* This struct is not used in this scanner, - but its presence is necessary. */ -struct yy_trans_info - { - flex_int32_t yy_verify; - flex_int32_t yy_nxt; - }; -static yyconst flex_int16_t yy_accept[64] = - { 0, - 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 38, 5, 4, 2, 3, 7, 8, 6, 36, 33, - 35, 28, 32, 31, 30, 26, 25, 21, 13, 20, - 23, 26, 11, 12, 22, 18, 14, 19, 26, 26, - 4, 2, 3, 3, 1, 6, 36, 33, 35, 34, - 28, 27, 30, 29, 25, 15, 23, 9, 22, 16, - 17, 24, 10 - } ; - -static yyconst flex_int32_t yy_ec[256] = - { 0, - 1, 1, 1, 1, 1, 1, 1, 1, 2, 3, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 2, 4, 5, 6, 1, 1, 7, 8, 9, - 10, 1, 1, 1, 11, 12, 12, 11, 11, 11, - 11, 11, 11, 11, 11, 11, 11, 1, 1, 13, - 14, 15, 1, 1, 11, 11, 11, 11, 11, 11, - 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, - 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, - 1, 16, 1, 1, 11, 1, 11, 11, 11, 11, - - 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, - 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, - 11, 11, 1, 17, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1 - } ; - -extern int zconf_flex_debug; -int zconf_flex_debug = 0; - -/* The intent behind this definition is that it'll catch - * any uses of REJECT which flex missed. - */ -#define REJECT reject_used_but_not_detected -#define yymore() yymore_used_but_not_detected -#define YY_MORE_ADJ 0 -#define YY_RESTORE_YY_MORE_OFFSET -char *zconftext; -#define YY_NO_INPUT 1 - -/* - * Copyright (C) 2002 Roman Zippel zippel@linux-m68k.org - * Released under the terms of the GNU GPL v2.0. - */ - -#include <limits.h> -#include <stdio.h> -#include <stdlib.h> -#include <string.h> -#include <unistd.h> - -#include "lkc.h" - -#define START_STRSIZE 16 - -static struct { - struct file *file; - int lineno; -} current_pos; - -static char *text; -static int text_size, text_asize; - -struct buffer { - struct buffer *parent; - YY_BUFFER_STATE state; -}; - -struct buffer *current_buf; - -static int last_ts, first_ts; - -static void zconf_endhelp(void); -static void zconf_endfile(void); - -static void new_string(void) -{ - text = xmalloc(START_STRSIZE); - text_asize = START_STRSIZE; - text_size = 0; - *text = 0; -} - -static void append_string(const char *str, int size) -{ - int new_size = text_size + size + 1; - if (new_size > text_asize) { - new_size += START_STRSIZE - 1; - new_size &= -START_STRSIZE; - text = realloc(text, new_size); - text_asize = new_size; - } - memcpy(text + text_size, str, size); - text_size += size; - text[text_size] = 0; -} - -static void alloc_string(const char *str, int size) -{ - text = xmalloc(size + 1); - memcpy(text, str, size); - text[size] = 0; -} - -static void warn_ignored_character(char chr) -{ - fprintf(stderr, - "%s:%d:warning: ignoring unsupported character '%c'\n", - zconf_curname(), zconf_lineno(), chr); -} - -#define INITIAL 0 -#define COMMAND 1 -#define HELP 2 -#define STRING 3 -#define PARAM 4 - -#ifndef YY_NO_UNISTD_H -/* Special case for "unistd.h", since it is non-ANSI. We include it way - * down here because we want the user's section 1 to have been scanned first. - * The user has a chance to override it with an option. - */ -#include <unistd.h> -#endif - -#ifndef YY_EXTRA_TYPE -#define YY_EXTRA_TYPE void * -#endif - -static int yy_init_globals (void ); - -/* Accessor methods to globals. - These are made visible to non-reentrant scanners for convenience. */ - -int zconflex_destroy (void ); - -int zconfget_debug (void ); - -void zconfset_debug (int debug_flag ); - -YY_EXTRA_TYPE zconfget_extra (void ); - -void zconfset_extra (YY_EXTRA_TYPE user_defined ); - -FILE *zconfget_in (void ); - -void zconfset_in (FILE * in_str ); - -FILE *zconfget_out (void ); - -void zconfset_out (FILE * out_str ); - -int zconfget_leng (void ); - -char *zconfget_text (void ); - -int zconfget_lineno (void ); - -void zconfset_lineno (int line_number ); - -/* Macros after this point can all be overridden by user definitions in - * section 1. - */ - -#ifndef YY_SKIP_YYWRAP -#ifdef __cplusplus -extern "C" int zconfwrap (void ); -#else -extern int zconfwrap (void ); -#endif -#endif - - static void yyunput (int c,char *buf_ptr ); - -#ifndef yytext_ptr -static void yy_flex_strncpy (char *,yyconst char *,int ); -#endif - -#ifdef YY_NEED_STRLEN -static int yy_flex_strlen (yyconst char * ); -#endif - -#ifndef YY_NO_INPUT - -#ifdef __cplusplus -static int yyinput (void ); -#else -static int input (void ); -#endif - -#endif - -/* Amount of stuff to slurp up with each read. */ -#ifndef YY_READ_BUF_SIZE -#ifdef __ia64__ -/* On IA-64, the buffer size is 16k, not 8k */ -#define YY_READ_BUF_SIZE 16384 -#else -#define YY_READ_BUF_SIZE 8192 -#endif /* __ia64__ */ -#endif - -/* Copy whatever the last rule matched to the standard output. */ -#ifndef ECHO -/* This used to be an fputs(), but since the string might contain NUL's, - * we now use fwrite(). - */ -#define ECHO do { if (fwrite( zconftext, zconfleng, 1, zconfout )) {} } while (0) -#endif - -/* Gets input and stuffs it into "buf". number of characters read, or YY_NULL, - * is returned in "result". - */ -#ifndef YY_INPUT -#define YY_INPUT(buf,result,max_size) \ - errno=0; \ - while ( (result = read( fileno(zconfin), (char *) buf, max_size )) < 0 ) \ - { \ - if( errno != EINTR) \ - { \ - YY_FATAL_ERROR( "input in flex scanner failed" ); \ - break; \ - } \ - errno=0; \ - clearerr(zconfin); \ - }\ -\ - -#endif - -/* No semi-colon after return; correct usage is to write "yyterminate();" - - * we don't want an extra ';' after the "return" because that will cause - * some compilers to complain about unreachable statements. - */ -#ifndef yyterminate -#define yyterminate() return YY_NULL -#endif - -/* Number of entries by which start-condition stack grows. */ -#ifndef YY_START_STACK_INCR -#define YY_START_STACK_INCR 25 -#endif - -/* Report a fatal error. */ -#ifndef YY_FATAL_ERROR -#define YY_FATAL_ERROR(msg) yy_fatal_error( msg ) -#endif - -/* end tables serialization structures and prototypes */ - -/* Default declaration of generated scanner - a define so the user can - * easily add parameters. - */ -#ifndef YY_DECL -#define YY_DECL_IS_OURS 1 - -extern int zconflex (void); - -#define YY_DECL int zconflex (void) -#endif /* !YY_DECL */ - -/* Code executed at the beginning of each rule, after zconftext and zconfleng - * have been set up. - */ -#ifndef YY_USER_ACTION -#define YY_USER_ACTION -#endif - -/* Code executed at the end of each rule. */ -#ifndef YY_BREAK -#define YY_BREAK break; -#endif - -#define YY_RULE_SETUP \ - YY_USER_ACTION - -/** The main scanner function which does all the work. - */ -YY_DECL -{ - register yy_state_type yy_current_state; - register char *yy_cp, *yy_bp; - register int yy_act; - - int str = 0; - int ts, i; - - if ( !(yy_init) ) - { - (yy_init) = 1; - -#ifdef YY_USER_INIT - YY_USER_INIT; -#endif - - if ( ! (yy_start) ) - (yy_start) = 1; /* first start state */ - - if ( ! zconfin ) - zconfin = stdin; - - if ( ! zconfout ) - zconfout = stdout; - - if ( ! YY_CURRENT_BUFFER ) { - zconfensure_buffer_stack (); - YY_CURRENT_BUFFER_LVALUE = - zconf_create_buffer(zconfin,YY_BUF_SIZE ); - } - - zconf_load_buffer_state( ); - } - - while ( 1 ) /* loops until end-of-file is reached */ - { - yy_cp = (yy_c_buf_p); - - /* Support of zconftext. */ - *yy_cp = (yy_hold_char); - - /* yy_bp points to the position in yy_ch_buf of the start of - * the current run. - */ - yy_bp = yy_cp; - - yy_current_state = (yy_start); -yy_match: - while ( (yy_current_state = yy_nxt[yy_current_state][ yy_ec[YY_SC_TO_UI(*yy_cp)] ]) > 0 ) - ++yy_cp; - - yy_current_state = -yy_current_state; - -yy_find_action: - yy_act = yy_accept[yy_current_state]; - - YY_DO_BEFORE_ACTION; - -do_action: /* This label is used only to access EOF actions. */ - - switch ( yy_act ) - { /* beginning of action switch */ -case 1: -/* rule 1 can match eol */ -case 2: -/* rule 2 can match eol */ -YY_RULE_SETUP -{ - current_file->lineno++; - return T_EOL; -} - YY_BREAK -case 3: -YY_RULE_SETUP - - YY_BREAK -case 4: -YY_RULE_SETUP -{ - BEGIN(COMMAND); -} - YY_BREAK -case 5: -YY_RULE_SETUP -{ - unput(zconftext[0]); - BEGIN(COMMAND); -} - YY_BREAK - -case 6: -YY_RULE_SETUP -{ - const struct kconf_id *id = kconf_id_lookup(zconftext, zconfleng); - BEGIN(PARAM); - current_pos.file = current_file; - current_pos.lineno = current_file->lineno; - if (id && id->flags & TF_COMMAND) { - zconflval.id = id; - return id->token; - } - alloc_string(zconftext, zconfleng); - zconflval.string = text; - return T_WORD; - } - YY_BREAK -case 7: -YY_RULE_SETUP -warn_ignored_character(*zconftext); - YY_BREAK -case 8: -/* rule 8 can match eol */ -YY_RULE_SETUP -{ - BEGIN(INITIAL); - current_file->lineno++; - return T_EOL; - } - YY_BREAK - -case 9: -YY_RULE_SETUP -return T_AND; - YY_BREAK -case 10: -YY_RULE_SETUP -return T_OR; - YY_BREAK -case 11: -YY_RULE_SETUP -return T_OPEN_PAREN; - YY_BREAK -case 12: -YY_RULE_SETUP -return T_CLOSE_PAREN; - YY_BREAK -case 13: -YY_RULE_SETUP -return T_NOT; - YY_BREAK -case 14: -YY_RULE_SETUP -return T_EQUAL; - YY_BREAK -case 15: -YY_RULE_SETUP -return T_UNEQUAL; - YY_BREAK -case 16: -YY_RULE_SETUP -return T_LESS_EQUAL; - YY_BREAK -case 17: -YY_RULE_SETUP -return T_GREATER_EQUAL; - YY_BREAK -case 18: -YY_RULE_SETUP -return T_LESS; - YY_BREAK -case 19: -YY_RULE_SETUP -return T_GREATER; - YY_BREAK -case 20: -YY_RULE_SETUP -{ - str = zconftext[0]; - new_string(); - BEGIN(STRING); - } - YY_BREAK -case 21: -/* rule 21 can match eol */ -YY_RULE_SETUP -BEGIN(INITIAL); current_file->lineno++; return T_EOL; - YY_BREAK -case 22: -YY_RULE_SETUP -{ - const struct kconf_id *id = kconf_id_lookup(zconftext, zconfleng); - if (id && id->flags & TF_PARAM) { - zconflval.id = id; - return id->token; - } - alloc_string(zconftext, zconfleng); - zconflval.string = text; - return T_WORD; - } - YY_BREAK -case 23: -YY_RULE_SETUP -/* comment */ - YY_BREAK -case 24: -/* rule 24 can match eol */ -YY_RULE_SETUP -current_file->lineno++; - YY_BREAK -case 25: -YY_RULE_SETUP - - YY_BREAK -case 26: -YY_RULE_SETUP -warn_ignored_character(*zconftext); - YY_BREAK -case YY_STATE_EOF(PARAM): -{ - BEGIN(INITIAL); - } - YY_BREAK - -case 27: -/* rule 27 can match eol */ -*yy_cp = (yy_hold_char); /* undo effects of setting up zconftext */ -(yy_c_buf_p) = yy_cp -= 1; -YY_DO_BEFORE_ACTION; /* set up zconftext again */ -YY_RULE_SETUP -{ - append_string(zconftext, zconfleng); - zconflval.string = text; - return T_WORD_QUOTE; - } - YY_BREAK -case 28: -YY_RULE_SETUP -{ - append_string(zconftext, zconfleng); - } - YY_BREAK -case 29: -/* rule 29 can match eol */ -*yy_cp = (yy_hold_char); /* undo effects of setting up zconftext */ -(yy_c_buf_p) = yy_cp -= 1; -YY_DO_BEFORE_ACTION; /* set up zconftext again */ -YY_RULE_SETUP -{ - append_string(zconftext + 1, zconfleng - 1); - zconflval.string = text; - return T_WORD_QUOTE; - } - YY_BREAK -case 30: -YY_RULE_SETUP -{ - append_string(zconftext + 1, zconfleng - 1); - } - YY_BREAK -case 31: -YY_RULE_SETUP -{ - if (str == zconftext[0]) { - BEGIN(PARAM); - zconflval.string = text; - return T_WORD_QUOTE; - } else - append_string(zconftext, 1); - } - YY_BREAK -case 32: -/* rule 32 can match eol */ -YY_RULE_SETUP -{ - printf("%s:%d:warning: multi-line strings not supported\n", zconf_curname(), zconf_lineno()); - current_file->lineno++; - BEGIN(INITIAL); - return T_EOL; - } - YY_BREAK -case YY_STATE_EOF(STRING): -{ - BEGIN(INITIAL); - } - YY_BREAK - -case 33: -YY_RULE_SETUP -{ - ts = 0; - for (i = 0; i < zconfleng; i++) { - if (zconftext[i] == '\t') - ts = (ts & ~7) + 8; - else - ts++; - } - last_ts = ts; - if (first_ts) { - if (ts < first_ts) { - zconf_endhelp(); - return T_HELPTEXT; - } - ts -= first_ts; - while (ts > 8) { - append_string(" ", 8); - ts -= 8; - } - append_string(" ", ts); - } - } - YY_BREAK -case 34: -/* rule 34 can match eol */ -*yy_cp = (yy_hold_char); /* undo effects of setting up zconftext */ -(yy_c_buf_p) = yy_cp -= 1; -YY_DO_BEFORE_ACTION; /* set up zconftext again */ -YY_RULE_SETUP -{ - current_file->lineno++; - zconf_endhelp(); - return T_HELPTEXT; - } - YY_BREAK -case 35: -/* rule 35 can match eol */ -YY_RULE_SETUP -{ - current_file->lineno++; - append_string("\n", 1); - } - YY_BREAK -case 36: -YY_RULE_SETUP -{ - while (zconfleng) { - if ((zconftext[zconfleng-1] != ' ') && (zconftext[zconfleng-1] != '\t')) - break; - zconfleng--; - } - append_string(zconftext, zconfleng); - if (!first_ts) - first_ts = last_ts; - } - YY_BREAK -case YY_STATE_EOF(HELP): -{ - zconf_endhelp(); - return T_HELPTEXT; - } - YY_BREAK - -case YY_STATE_EOF(INITIAL): -case YY_STATE_EOF(COMMAND): -{ - if (current_file) { - zconf_endfile(); - return T_EOL; - } - fclose(zconfin); - yyterminate(); -} - YY_BREAK -case 37: -YY_RULE_SETUP -YY_FATAL_ERROR( "flex scanner jammed" ); - YY_BREAK - - case YY_END_OF_BUFFER: - { - /* Amount of text matched not including the EOB char. */ - int yy_amount_of_matched_text = (int) (yy_cp - (yytext_ptr)) - 1; - - /* Undo the effects of YY_DO_BEFORE_ACTION. */ - *yy_cp = (yy_hold_char); - YY_RESTORE_YY_MORE_OFFSET - - if ( YY_CURRENT_BUFFER_LVALUE->yy_buffer_status == YY_BUFFER_NEW ) - { - /* We're scanning a new file or input source. It's - * possible that this happened because the user - * just pointed zconfin at a new source and called - * zconflex(). If so, then we have to assure - * consistency between YY_CURRENT_BUFFER and our - * globals. Here is the right place to do so, because - * this is the first action (other than possibly a - * back-up) that will match for the new input source. - */ - (yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_n_chars; - YY_CURRENT_BUFFER_LVALUE->yy_input_file = zconfin; - YY_CURRENT_BUFFER_LVALUE->yy_buffer_status = YY_BUFFER_NORMAL; - } - - /* Note that here we test for yy_c_buf_p "<=" to the position - * of the first EOB in the buffer, since yy_c_buf_p will - * already have been incremented past the NUL character - * (since all states make transitions on EOB to the - * end-of-buffer state). Contrast this with the test - * in input(). - */ - if ( (yy_c_buf_p) <= &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] ) - { /* This was really a NUL. */ - yy_state_type yy_next_state; - - (yy_c_buf_p) = (yytext_ptr) + yy_amount_of_matched_text; - - yy_current_state = yy_get_previous_state( ); - - /* Okay, we're now positioned to make the NUL - * transition. We couldn't have - * yy_get_previous_state() go ahead and do it - * for us because it doesn't know how to deal - * with the possibility of jamming (and we don't - * want to build jamming into it because then it - * will run more slowly). - */ - - yy_next_state = yy_try_NUL_trans( yy_current_state ); - - yy_bp = (yytext_ptr) + YY_MORE_ADJ; - - if ( yy_next_state ) - { - /* Consume the NUL. */ - yy_cp = ++(yy_c_buf_p); - yy_current_state = yy_next_state; - goto yy_match; - } - - else - { - yy_cp = (yy_c_buf_p); - goto yy_find_action; - } - } - - else switch ( yy_get_next_buffer( ) ) - { - case EOB_ACT_END_OF_FILE: - { - (yy_did_buffer_switch_on_eof) = 0; - - if ( zconfwrap( ) ) - { - /* Note: because we've taken care in - * yy_get_next_buffer() to have set up - * zconftext, we can now set up - * yy_c_buf_p so that if some total - * hoser (like flex itself) wants to - * call the scanner after we return the - * YY_NULL, it'll still work - another - * YY_NULL will get returned. - */ - (yy_c_buf_p) = (yytext_ptr) + YY_MORE_ADJ; - - yy_act = YY_STATE_EOF(YY_START); - goto do_action; - } - - else - { - if ( ! (yy_did_buffer_switch_on_eof) ) - YY_NEW_FILE; - } - break; - } - - case EOB_ACT_CONTINUE_SCAN: - (yy_c_buf_p) = - (yytext_ptr) + yy_amount_of_matched_text; - - yy_current_state = yy_get_previous_state( ); - - yy_cp = (yy_c_buf_p); - yy_bp = (yytext_ptr) + YY_MORE_ADJ; - goto yy_match; - - case EOB_ACT_LAST_MATCH: - (yy_c_buf_p) = - &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)]; - - yy_current_state = yy_get_previous_state( ); - - yy_cp = (yy_c_buf_p); - yy_bp = (yytext_ptr) + YY_MORE_ADJ; - goto yy_find_action; - } - break; - } - - default: - YY_FATAL_ERROR( - "fatal flex scanner internal error--no action found" ); - } /* end of action switch */ - } /* end of scanning one token */ -} /* end of zconflex */ - -/* yy_get_next_buffer - try to read in a new buffer - * - * Returns a code representing an action: - * EOB_ACT_LAST_MATCH - - * EOB_ACT_CONTINUE_SCAN - continue scanning from current position - * EOB_ACT_END_OF_FILE - end of file - */ -static int yy_get_next_buffer (void) -{ - register char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf; - register char *source = (yytext_ptr); - register int number_to_move, i; - int ret_val; - - if ( (yy_c_buf_p) > &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] ) - YY_FATAL_ERROR( - "fatal flex scanner internal error--end of buffer missed" ); - - if ( YY_CURRENT_BUFFER_LVALUE->yy_fill_buffer == 0 ) - { /* Don't try to fill the buffer, so this is an EOF. */ - if ( (yy_c_buf_p) - (yytext_ptr) - YY_MORE_ADJ == 1 ) - { - /* We matched a single character, the EOB, so - * treat this as a final EOF. - */ - return EOB_ACT_END_OF_FILE; - } - - else - { - /* We matched some text prior to the EOB, first - * process it. - */ - return EOB_ACT_LAST_MATCH; - } - } - - /* Try to read more data. */ - - /* First move last chars to start of buffer. */ - number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr)) - 1; - - for ( i = 0; i < number_to_move; ++i ) - *(dest++) = *(source++); - - if ( YY_CURRENT_BUFFER_LVALUE->yy_buffer_status == YY_BUFFER_EOF_PENDING ) - /* don't do the read, it's not guaranteed to return an EOF, - * just force an EOF - */ - YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars) = 0; - - else - { - int num_to_read = - YY_CURRENT_BUFFER_LVALUE->yy_buf_size - number_to_move - 1; - - while ( num_to_read <= 0 ) - { /* Not enough room in the buffer - grow it. */ - - /* just a shorter name for the current buffer */ - YY_BUFFER_STATE b = YY_CURRENT_BUFFER; - - int yy_c_buf_p_offset = - (int) ((yy_c_buf_p) - b->yy_ch_buf); - - if ( b->yy_is_our_buffer ) - { - int new_size = b->yy_buf_size * 2; - - if ( new_size <= 0 ) - b->yy_buf_size += b->yy_buf_size / 8; - else - b->yy_buf_size *= 2; - - b->yy_ch_buf = (char *) - /* Include room in for 2 EOB chars. */ - zconfrealloc((void *) b->yy_ch_buf,b->yy_buf_size + 2 ); - } - else - /* Can't grow it, we don't own it. */ - b->yy_ch_buf = 0; - - if ( ! b->yy_ch_buf ) - YY_FATAL_ERROR( - "fatal error - scanner input buffer overflow" ); - - (yy_c_buf_p) = &b->yy_ch_buf[yy_c_buf_p_offset]; - - num_to_read = YY_CURRENT_BUFFER_LVALUE->yy_buf_size - - number_to_move - 1; - - } - - if ( num_to_read > YY_READ_BUF_SIZE ) - num_to_read = YY_READ_BUF_SIZE; - - /* Read in more data. */ - YY_INPUT( (&YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[number_to_move]), - (yy_n_chars), (size_t) num_to_read ); - - YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars); - } - - if ( (yy_n_chars) == 0 ) - { - if ( number_to_move == YY_MORE_ADJ ) - { - ret_val = EOB_ACT_END_OF_FILE; - zconfrestart(zconfin ); - } - - else - { - ret_val = EOB_ACT_LAST_MATCH; - YY_CURRENT_BUFFER_LVALUE->yy_buffer_status = - YY_BUFFER_EOF_PENDING; - } - } - - else - ret_val = EOB_ACT_CONTINUE_SCAN; - - if ((yy_size_t) ((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) { - /* Extend the array by 50%, plus the number we really need. */ - yy_size_t new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1); - YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) zconfrealloc((void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf,new_size ); - if ( ! YY_CURRENT_BUFFER_LVALUE->yy_ch_buf ) - YY_FATAL_ERROR( "out of dynamic memory in yy_get_next_buffer()" ); - } - - (yy_n_chars) += number_to_move; - YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] = YY_END_OF_BUFFER_CHAR; - YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] = YY_END_OF_BUFFER_CHAR; - - (yytext_ptr) = &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[0]; - - return ret_val; -} - -/* yy_get_previous_state - get the state just before the EOB char was reached */ - - static yy_state_type yy_get_previous_state (void) -{ - register yy_state_type yy_current_state; - register char *yy_cp; - - yy_current_state = (yy_start); - - for ( yy_cp = (yytext_ptr) + YY_MORE_ADJ; yy_cp < (yy_c_buf_p); ++yy_cp ) - { - yy_current_state = yy_nxt[yy_current_state][(*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1)]; - } - - return yy_current_state; -} - -/* yy_try_NUL_trans - try to make a transition on the NUL character - * - * synopsis - * next_state = yy_try_NUL_trans( current_state ); - */ - static yy_state_type yy_try_NUL_trans (yy_state_type yy_current_state ) -{ - register int yy_is_jam; - - yy_current_state = yy_nxt[yy_current_state][1]; - yy_is_jam = (yy_current_state <= 0); - - return yy_is_jam ? 0 : yy_current_state; -} - - static void yyunput (int c, register char * yy_bp ) -{ - register char *yy_cp; - - yy_cp = (yy_c_buf_p); - - /* undo effects of setting up zconftext */ - *yy_cp = (yy_hold_char); - - if ( yy_cp < YY_CURRENT_BUFFER_LVALUE->yy_ch_buf + 2 ) - { /* need to shift things up to make room */ - /* +2 for EOB chars. */ - register int number_to_move = (yy_n_chars) + 2; - register char *dest = &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[ - YY_CURRENT_BUFFER_LVALUE->yy_buf_size + 2]; - register char *source = - &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[number_to_move]; - - while ( source > YY_CURRENT_BUFFER_LVALUE->yy_ch_buf ) - *--dest = *--source; - - yy_cp += (int) (dest - source); - yy_bp += (int) (dest - source); - YY_CURRENT_BUFFER_LVALUE->yy_n_chars = - (yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_buf_size; - - if ( yy_cp < YY_CURRENT_BUFFER_LVALUE->yy_ch_buf + 2 ) - YY_FATAL_ERROR( "flex scanner push-back overflow" ); - } - - *--yy_cp = (char) c; - - (yytext_ptr) = yy_bp; - (yy_hold_char) = *yy_cp; - (yy_c_buf_p) = yy_cp; -} - -#ifndef YY_NO_INPUT -#ifdef __cplusplus - static int yyinput (void) -#else - static int input (void) -#endif - -{ - int c; - - *(yy_c_buf_p) = (yy_hold_char); - - if ( *(yy_c_buf_p) == YY_END_OF_BUFFER_CHAR ) - { - /* yy_c_buf_p now points to the character we want to return. - * If this occurs *before* the EOB characters, then it's a - * valid NUL; if not, then we've hit the end of the buffer. - */ - if ( (yy_c_buf_p) < &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars)] ) - /* This was really a NUL. */ - *(yy_c_buf_p) = '\0'; - - else - { /* need more input */ - int offset = (yy_c_buf_p) - (yytext_ptr); - ++(yy_c_buf_p); - - switch ( yy_get_next_buffer( ) ) - { - case EOB_ACT_LAST_MATCH: - /* This happens because yy_g_n_b() - * sees that we've accumulated a - * token and flags that we need to - * try matching the token before - * proceeding. But for input(), - * there's no matching to consider. - * So convert the EOB_ACT_LAST_MATCH - * to EOB_ACT_END_OF_FILE. - */ - - /* Reset buffer status. */ - zconfrestart(zconfin ); - - /*FALLTHROUGH*/ - - case EOB_ACT_END_OF_FILE: - { - if ( zconfwrap( ) ) - return EOF; - - if ( ! (yy_did_buffer_switch_on_eof) ) - YY_NEW_FILE; -#ifdef __cplusplus - return yyinput(); -#else - return input(); -#endif - } - - case EOB_ACT_CONTINUE_SCAN: - (yy_c_buf_p) = (yytext_ptr) + offset; - break; - } - } - } - - c = *(unsigned char *) (yy_c_buf_p); /* cast for 8-bit char's */ - *(yy_c_buf_p) = '\0'; /* preserve zconftext */ - (yy_hold_char) = *++(yy_c_buf_p); - - return c; -} -#endif /* ifndef YY_NO_INPUT */ - -/** Immediately switch to a different input stream. - * @param input_file A readable stream. - * - * @note This function does not reset the start condition to @c INITIAL . - */ - void zconfrestart (FILE * input_file ) -{ - - if ( ! YY_CURRENT_BUFFER ){ - zconfensure_buffer_stack (); - YY_CURRENT_BUFFER_LVALUE = - zconf_create_buffer(zconfin,YY_BUF_SIZE ); - } - - zconf_init_buffer(YY_CURRENT_BUFFER,input_file ); - zconf_load_buffer_state( ); -} - -/** Switch to a different input buffer. - * @param new_buffer The new input buffer. - * - */ - void zconf_switch_to_buffer (YY_BUFFER_STATE new_buffer ) -{ - - /* TODO. We should be able to replace this entire function body - * with - * zconfpop_buffer_state(); - * zconfpush_buffer_state(new_buffer); - */ - zconfensure_buffer_stack (); - if ( YY_CURRENT_BUFFER == new_buffer ) - return; - - if ( YY_CURRENT_BUFFER ) - { - /* Flush out information for old buffer. */ - *(yy_c_buf_p) = (yy_hold_char); - YY_CURRENT_BUFFER_LVALUE->yy_buf_pos = (yy_c_buf_p); - YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars); - } - - YY_CURRENT_BUFFER_LVALUE = new_buffer; - zconf_load_buffer_state( ); - - /* We don't actually know whether we did this switch during - * EOF (zconfwrap()) processing, but the only time this flag - * is looked at is after zconfwrap() is called, so it's safe - * to go ahead and always set it. - */ - (yy_did_buffer_switch_on_eof) = 1; -} - -static void zconf_load_buffer_state (void) -{ - (yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_n_chars; - (yytext_ptr) = (yy_c_buf_p) = YY_CURRENT_BUFFER_LVALUE->yy_buf_pos; - zconfin = YY_CURRENT_BUFFER_LVALUE->yy_input_file; - (yy_hold_char) = *(yy_c_buf_p); -} - -/** Allocate and initialize an input buffer state. - * @param file A readable stream. - * @param size The character buffer size in bytes. When in doubt, use @c YY_BUF_SIZE. - * - * @return the allocated buffer state. - */ - YY_BUFFER_STATE zconf_create_buffer (FILE * file, int size ) -{ - YY_BUFFER_STATE b; - - b = (YY_BUFFER_STATE) zconfalloc(sizeof( struct yy_buffer_state ) ); - if ( ! b ) - YY_FATAL_ERROR( "out of dynamic memory in zconf_create_buffer()" ); - - b->yy_buf_size = size; - - /* yy_ch_buf has to be 2 characters longer than the size given because - * we need to put in 2 end-of-buffer characters. - */ - b->yy_ch_buf = (char *) zconfalloc(b->yy_buf_size + 2 ); - if ( ! b->yy_ch_buf ) - YY_FATAL_ERROR( "out of dynamic memory in zconf_create_buffer()" ); - - b->yy_is_our_buffer = 1; - - zconf_init_buffer(b,file ); - - return b; -} - -/** Destroy the buffer. - * @param b a buffer created with zconf_create_buffer() - * - */ - void zconf_delete_buffer (YY_BUFFER_STATE b ) -{ - - if ( ! b ) - return; - - if ( b == YY_CURRENT_BUFFER ) /* Not sure if we should pop here. */ - YY_CURRENT_BUFFER_LVALUE = (YY_BUFFER_STATE) 0; - - if ( b->yy_is_our_buffer ) - zconffree((void *) b->yy_ch_buf ); - - zconffree((void *) b ); -} - -/* Initializes or reinitializes a buffer. - * This function is sometimes called more than once on the same buffer, - * such as during a zconfrestart() or at EOF. - */ - static void zconf_init_buffer (YY_BUFFER_STATE b, FILE * file ) - -{ - int oerrno = errno; - - zconf_flush_buffer(b ); - - b->yy_input_file = file; - b->yy_fill_buffer = 1; - - /* If b is the current buffer, then zconf_init_buffer was _probably_ - * called from zconfrestart() or through yy_get_next_buffer. - * In that case, we don't want to reset the lineno or column. - */ - if (b != YY_CURRENT_BUFFER){ - b->yy_bs_lineno = 1; - b->yy_bs_column = 0; - } - - b->yy_is_interactive = 0; - - errno = oerrno; -} - -/** Discard all buffered characters. On the next scan, YY_INPUT will be called. - * @param b the buffer state to be flushed, usually @c YY_CURRENT_BUFFER. - * - */ - void zconf_flush_buffer (YY_BUFFER_STATE b ) -{ - if ( ! b ) - return; - - b->yy_n_chars = 0; - - /* We always need two end-of-buffer characters. The first causes - * a transition to the end-of-buffer state. The second causes - * a jam in that state. - */ - b->yy_ch_buf[0] = YY_END_OF_BUFFER_CHAR; - b->yy_ch_buf[1] = YY_END_OF_BUFFER_CHAR; - - b->yy_buf_pos = &b->yy_ch_buf[0]; - - b->yy_at_bol = 1; - b->yy_buffer_status = YY_BUFFER_NEW; - - if ( b == YY_CURRENT_BUFFER ) - zconf_load_buffer_state( ); -} - -/** Pushes the new state onto the stack. The new state becomes - * the current state. This function will allocate the stack - * if necessary. - * @param new_buffer The new state. - * - */ -void zconfpush_buffer_state (YY_BUFFER_STATE new_buffer ) -{ - if (new_buffer == NULL) - return; - - zconfensure_buffer_stack(); - - /* This block is copied from zconf_switch_to_buffer. */ - if ( YY_CURRENT_BUFFER ) - { - /* Flush out information for old buffer. */ - *(yy_c_buf_p) = (yy_hold_char); - YY_CURRENT_BUFFER_LVALUE->yy_buf_pos = (yy_c_buf_p); - YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars); - } - - /* Only push if top exists. Otherwise, replace top. */ - if (YY_CURRENT_BUFFER) - (yy_buffer_stack_top)++; - YY_CURRENT_BUFFER_LVALUE = new_buffer; - - /* copied from zconf_switch_to_buffer. */ - zconf_load_buffer_state( ); - (yy_did_buffer_switch_on_eof) = 1; -} - -/** Removes and deletes the top of the stack, if present. - * The next element becomes the new top. - * - */ -void zconfpop_buffer_state (void) -{ - if (!YY_CURRENT_BUFFER) - return; - - zconf_delete_buffer(YY_CURRENT_BUFFER ); - YY_CURRENT_BUFFER_LVALUE = NULL; - if ((yy_buffer_stack_top) > 0) - --(yy_buffer_stack_top); - - if (YY_CURRENT_BUFFER) { - zconf_load_buffer_state( ); - (yy_did_buffer_switch_on_eof) = 1; - } -} - -/* Allocates the stack if it does not exist. - * Guarantees space for at least one push. - */ -static void zconfensure_buffer_stack (void) -{ - int num_to_alloc; - - if (!(yy_buffer_stack)) { - - /* First allocation is just for 2 elements, since we don't know if this - * scanner will even need a stack. We use 2 instead of 1 to avoid an - * immediate realloc on the next call. - */ - num_to_alloc = 1; - (yy_buffer_stack) = (struct yy_buffer_state**)zconfalloc - (num_to_alloc * sizeof(struct yy_buffer_state*) - ); - if ( ! (yy_buffer_stack) ) - YY_FATAL_ERROR( "out of dynamic memory in zconfensure_buffer_stack()" ); - - memset((yy_buffer_stack), 0, num_to_alloc * sizeof(struct yy_buffer_state*)); - - (yy_buffer_stack_max) = num_to_alloc; - (yy_buffer_stack_top) = 0; - return; - } - - if ((yy_buffer_stack_top) >= ((yy_buffer_stack_max)) - 1){ - - /* Increase the buffer to prepare for a possible push. */ - int grow_size = 8 /* arbitrary grow size */; - - num_to_alloc = (yy_buffer_stack_max) + grow_size; - (yy_buffer_stack) = (struct yy_buffer_state**)zconfrealloc - ((yy_buffer_stack), - num_to_alloc * sizeof(struct yy_buffer_state*) - ); - if ( ! (yy_buffer_stack) ) - YY_FATAL_ERROR( "out of dynamic memory in zconfensure_buffer_stack()" ); - - /* zero only the new slots.*/ - memset((yy_buffer_stack) + (yy_buffer_stack_max), 0, grow_size * sizeof(struct yy_buffer_state*)); - (yy_buffer_stack_max) = num_to_alloc; - } -} - -/** Setup the input buffer state to scan directly from a user-specified character buffer. - * @param base the character buffer - * @param size the size in bytes of the character buffer - * - * @return the newly allocated buffer state object. - */ -YY_BUFFER_STATE zconf_scan_buffer (char * base, yy_size_t size ) -{ - YY_BUFFER_STATE b; - - if ( size < 2 || - base[size-2] != YY_END_OF_BUFFER_CHAR || - base[size-1] != YY_END_OF_BUFFER_CHAR ) - /* They forgot to leave room for the EOB's. */ - return 0; - - b = (YY_BUFFER_STATE) zconfalloc(sizeof( struct yy_buffer_state ) ); - if ( ! b ) - YY_FATAL_ERROR( "out of dynamic memory in zconf_scan_buffer()" ); - - b->yy_buf_size = size - 2; /* "- 2" to take care of EOB's */ - b->yy_buf_pos = b->yy_ch_buf = base; - b->yy_is_our_buffer = 0; - b->yy_input_file = 0; - b->yy_n_chars = b->yy_buf_size; - b->yy_is_interactive = 0; - b->yy_at_bol = 1; - b->yy_fill_buffer = 0; - b->yy_buffer_status = YY_BUFFER_NEW; - - zconf_switch_to_buffer(b ); - - return b; -} - -/** Setup the input buffer state to scan a string. The next call to zconflex() will - * scan from a @e copy of @a str. - * @param yystr a NUL-terminated string to scan - * - * @return the newly allocated buffer state object. - * @note If you want to scan bytes that may contain NUL values, then use - * zconf_scan_bytes() instead. - */ -YY_BUFFER_STATE zconf_scan_string (yyconst char * yystr ) -{ - - return zconf_scan_bytes(yystr,strlen(yystr) ); -} - -/** Setup the input buffer state to scan the given bytes. The next call to zconflex() will - * scan from a @e copy of @a bytes. - * @param yybytes the byte buffer to scan - * @param _yybytes_len the number of bytes in the buffer pointed to by @a bytes. - * - * @return the newly allocated buffer state object. - */ -YY_BUFFER_STATE zconf_scan_bytes (yyconst char * yybytes, int _yybytes_len ) -{ - YY_BUFFER_STATE b; - char *buf; - yy_size_t n; - int i; - - /* Get memory for full buffer, including space for trailing EOB's. */ - n = _yybytes_len + 2; - buf = (char *) zconfalloc(n ); - if ( ! buf ) - YY_FATAL_ERROR( "out of dynamic memory in zconf_scan_bytes()" ); - - for ( i = 0; i < _yybytes_len; ++i ) - buf[i] = yybytes[i]; - - buf[_yybytes_len] = buf[_yybytes_len+1] = YY_END_OF_BUFFER_CHAR; - - b = zconf_scan_buffer(buf,n ); - if ( ! b ) - YY_FATAL_ERROR( "bad buffer in zconf_scan_bytes()" ); - - /* It's okay to grow etc. this buffer, and we should throw it - * away when we're done. - */ - b->yy_is_our_buffer = 1; - - return b; -} - -#ifndef YY_EXIT_FAILURE -#define YY_EXIT_FAILURE 2 -#endif - -static void yy_fatal_error (yyconst char* msg ) -{ - (void) fprintf( stderr, "%s\n", msg ); - exit( YY_EXIT_FAILURE ); -} - -/* Redefine yyless() so it works in section 3 code. */ - -#undef yyless -#define yyless(n) \ - do \ - { \ - /* Undo effects of setting up zconftext. */ \ - int yyless_macro_arg = (n); \ - YY_LESS_LINENO(yyless_macro_arg);\ - zconftext[zconfleng] = (yy_hold_char); \ - (yy_c_buf_p) = zconftext + yyless_macro_arg; \ - (yy_hold_char) = *(yy_c_buf_p); \ - *(yy_c_buf_p) = '\0'; \ - zconfleng = yyless_macro_arg; \ - } \ - while ( 0 ) - -/* Accessor methods (get/set functions) to struct members. */ - -/** Get the current line number. - * - */ -int zconfget_lineno (void) -{ - - return zconflineno; -} - -/** Get the input stream. - * - */ -FILE *zconfget_in (void) -{ - return zconfin; -} - -/** Get the output stream. - * - */ -FILE *zconfget_out (void) -{ - return zconfout; -} - -/** Get the length of the current token. - * - */ -int zconfget_leng (void) -{ - return zconfleng; -} - -/** Get the current token. - * - */ - -char *zconfget_text (void) -{ - return zconftext; -} - -/** Set the current line number. - * @param line_number - * - */ -void zconfset_lineno (int line_number ) -{ - - zconflineno = line_number; -} - -/** Set the input stream. This does not discard the current - * input buffer. - * @param in_str A readable stream. - * - * @see zconf_switch_to_buffer - */ -void zconfset_in (FILE * in_str ) -{ - zconfin = in_str ; -} - -void zconfset_out (FILE * out_str ) -{ - zconfout = out_str ; -} - -int zconfget_debug (void) -{ - return zconf_flex_debug; -} - -void zconfset_debug (int bdebug ) -{ - zconf_flex_debug = bdebug ; -} - -static int yy_init_globals (void) -{ - /* Initialization is the same as for the non-reentrant scanner. - * This function is called from zconflex_destroy(), so don't allocate here. - */ - - (yy_buffer_stack) = 0; - (yy_buffer_stack_top) = 0; - (yy_buffer_stack_max) = 0; - (yy_c_buf_p) = (char *) 0; - (yy_init) = 0; - (yy_start) = 0; - -/* Defined in main.c */ -#ifdef YY_STDINIT - zconfin = stdin; - zconfout = stdout; -#else - zconfin = (FILE *) 0; - zconfout = (FILE *) 0; -#endif - - /* For future reference: Set errno on error, since we are called by - * zconflex_init() - */ - return 0; -} - -/* zconflex_destroy is for both reentrant and non-reentrant scanners. */ -int zconflex_destroy (void) -{ - - /* Pop the buffer stack, destroying each element. */ - while(YY_CURRENT_BUFFER){ - zconf_delete_buffer(YY_CURRENT_BUFFER ); - YY_CURRENT_BUFFER_LVALUE = NULL; - zconfpop_buffer_state(); - } - - /* Destroy the stack itself. */ - zconffree((yy_buffer_stack) ); - (yy_buffer_stack) = NULL; - - /* Reset the globals. This is important in a non-reentrant scanner so the next time - * zconflex() is called, initialization will occur. */ - yy_init_globals( ); - - return 0; -} - -/* - * Internal utility routines. - */ - -#ifndef yytext_ptr -static void yy_flex_strncpy (char* s1, yyconst char * s2, int n ) -{ - register int i; - for ( i = 0; i < n; ++i ) - s1[i] = s2[i]; -} -#endif - -#ifdef YY_NEED_STRLEN -static int yy_flex_strlen (yyconst char * s ) -{ - register int n; - for ( n = 0; s[n]; ++n ) - ; - - return n; -} -#endif - -void *zconfalloc (yy_size_t size ) -{ - return (void *) malloc( size ); -} - -void *zconfrealloc (void * ptr, yy_size_t size ) -{ - /* The cast to (char *) in the following accommodates both - * implementations that use char* generic pointers, and those - * that use void* generic pointers. It works with the latter - * because both ANSI C and C++ allow castless assignment from - * any pointer type to void*, and deal with argument conversions - * as though doing an assignment. - */ - return (void *) realloc( (char *) ptr, size ); -} - -void zconffree (void * ptr ) -{ - free( (char *) ptr ); /* see zconfrealloc() for (char *) cast */ -} - -#define YYTABLES_NAME "yytables" - -void zconf_starthelp(void) -{ - new_string(); - last_ts = first_ts = 0; - BEGIN(HELP); -} - -static void zconf_endhelp(void) -{ - zconflval.string = text; - BEGIN(INITIAL); -} - -/* - * Try to open specified file with following names: - * ./name - * $(srctree)/name - * The latter is used when srctree is separate from objtree - * when compiling the kernel. - * Return NULL if file is not found. - */ -FILE *zconf_fopen(const char *name) -{ - char *env, fullname[PATH_MAX+1]; - FILE *f; - - f = fopen(name, "r"); - if (!f && name != NULL && name[0] != '/') { - env = getenv(SRCTREE); - if (env) { - sprintf(fullname, "%s/%s", env, name); - f = fopen(fullname, "r"); - } - } - return f; -} - -void zconf_initscan(const char *name) -{ - zconfin = zconf_fopen(name); - if (!zconfin) { - printf("can't find file %s\n", name); - exit(1); - } - - current_buf = xmalloc(sizeof(*current_buf)); - memset(current_buf, 0, sizeof(*current_buf)); - - current_file = file_lookup(name); - current_file->lineno = 1; -} - -void zconf_nextfile(const char *name) -{ - struct file *iter; - struct file *file = file_lookup(name); - struct buffer *buf = xmalloc(sizeof(*buf)); - memset(buf, 0, sizeof(*buf)); - - current_buf->state = YY_CURRENT_BUFFER; - zconfin = zconf_fopen(file->name); - if (!zconfin) { - printf("%s:%d: can't open file "%s"\n", - zconf_curname(), zconf_lineno(), file->name); - exit(1); - } - zconf_switch_to_buffer(zconf_create_buffer(zconfin,YY_BUF_SIZE)); - buf->parent = current_buf; - current_buf = buf; - - for (iter = current_file->parent; iter; iter = iter->parent ) { - if (!strcmp(current_file->name,iter->name) ) { - printf("%s:%d: recursive inclusion detected. " - "Inclusion path:\n current file : '%s'\n", - zconf_curname(), zconf_lineno(), - zconf_curname()); - iter = current_file->parent; - while (iter && \ - strcmp(iter->name,current_file->name)) { - printf(" included from: '%s:%d'\n", - iter->name, iter->lineno-1); - iter = iter->parent; - } - if (iter) - printf(" included from: '%s:%d'\n", - iter->name, iter->lineno+1); - exit(1); - } - } - file->lineno = 1; - file->parent = current_file; - current_file = file; -} - -static void zconf_endfile(void) -{ - struct buffer *parent; - - current_file = current_file->parent; - - parent = current_buf->parent; - if (parent) { - fclose(zconfin); - zconf_delete_buffer(YY_CURRENT_BUFFER); - zconf_switch_to_buffer(parent->state); - } - free(current_buf); - current_buf = parent; -} - -int zconf_lineno(void) -{ - return current_pos.lineno; -} - -const char *zconf_curname(void) -{ - return current_pos.file ? current_pos.file->name : "<none>"; -} - diff --git a/scripts/kconfig/zconf.tab.c_shipped b/scripts/kconfig/zconf.tab.c_shipped deleted file mode 100644 index 65b7515a577c..000000000000 --- a/scripts/kconfig/zconf.tab.c_shipped +++ /dev/null @@ -1,2471 +0,0 @@ -/* A Bison parser, made by GNU Bison 3.0.4. */ - -/* Bison implementation for Yacc-like parsers in C - - Copyright (C) 1984, 1989-1990, 2000-2015 Free Software Foundation, Inc. - - This program is free software: you can redistribute it and/or modify - it under the terms of the GNU General Public License as published by - the Free Software Foundation, either version 3 of the License, or - (at your option) any later version. - - This program is distributed in the hope that it will be useful, - but WITHOUT ANY WARRANTY; without even the implied warranty of - MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - GNU General Public License for more details. - - You should have received a copy of the GNU General Public License - along with this program. If not, see http://www.gnu.org/licenses/. */ - -/* As a special exception, you may create a larger work that contains - part or all of the Bison parser skeleton and distribute that work - under terms of your choice, so long as that work isn't itself a - parser generator using the skeleton or a modified version thereof - as a parser skeleton. Alternatively, if you modify or redistribute - the parser skeleton itself, you may (at your option) remove this - special exception, which will cause the skeleton and the resulting - Bison output files to be licensed under the GNU General Public - License without this special exception. - - This special exception was added by the Free Software Foundation in - version 2.2 of Bison. */ - -/* C LALR(1) parser skeleton written by Richard Stallman, by - simplifying the original so-called "semantic" parser. */ - -/* All symbols defined below should begin with yy or YY, to avoid - infringing on user name space. This should be done even for local - variables, as they might otherwise be expanded by user macros. - There are some unavoidable exceptions within include files to - define necessary library symbols; they are noted "INFRINGES ON - USER NAME SPACE" below. */ - -/* Identify Bison output. */ -#define YYBISON 1 - -/* Bison version. */ -#define YYBISON_VERSION "3.0.4" - -/* Skeleton name. */ -#define YYSKELETON_NAME "yacc.c" - -/* Pure parsers. */ -#define YYPURE 0 - -/* Push parsers. */ -#define YYPUSH 0 - -/* Pull parsers. */ -#define YYPULL 1 - - -/* Substitute the variable and function names. */ -#define yyparse zconfparse -#define yylex zconflex -#define yyerror zconferror -#define yydebug zconfdebug -#define yynerrs zconfnerrs - -#define yylval zconflval -#define yychar zconfchar - -/* Copy the first part of user declarations. */ - - -/* - * Copyright (C) 2002 Roman Zippel zippel@linux-m68k.org - * Released under the terms of the GNU GPL v2.0. - */ - -#include <ctype.h> -#include <stdarg.h> -#include <stdio.h> -#include <stdlib.h> -#include <string.h> -#include <stdbool.h> - -#include "lkc.h" - -#define printd(mask, fmt...) if (cdebug & (mask)) printf(fmt) - -#define PRINTD 0x0001 -#define DEBUG_PARSE 0x0002 - -int cdebug = PRINTD; - -extern int zconflex(void); -static void zconfprint(const char *err, ...); -static void zconf_error(const char *err, ...); -static void zconferror(const char *err); -static bool zconf_endtoken(const struct kconf_id *id, int starttoken, int endtoken); - -struct symbol *symbol_hash[SYMBOL_HASHSIZE]; - -static struct menu *current_menu, *current_entry; - - - - -# ifndef YY_NULLPTR -# if defined __cplusplus && 201103L <= __cplusplus -# define YY_NULLPTR nullptr -# else -# define YY_NULLPTR 0 -# endif -# endif - -/* Enabling verbose error messages. */ -#ifdef YYERROR_VERBOSE -# undef YYERROR_VERBOSE -# define YYERROR_VERBOSE 1 -#else -# define YYERROR_VERBOSE 0 -#endif - - -/* Debug traces. */ -#ifndef YYDEBUG -# define YYDEBUG 1 -#endif -#if YYDEBUG -extern int zconfdebug; -#endif - -/* Token type. */ -#ifndef YYTOKENTYPE -# define YYTOKENTYPE - enum yytokentype - { - T_MAINMENU = 258, - T_MENU = 259, - T_ENDMENU = 260, - T_SOURCE = 261, - T_CHOICE = 262, - T_ENDCHOICE = 263, - T_COMMENT = 264, - T_CONFIG = 265, - T_MENUCONFIG = 266, - T_HELP = 267, - T_HELPTEXT = 268, - T_IF = 269, - T_ENDIF = 270, - T_DEPENDS = 271, - T_OPTIONAL = 272, - T_PROMPT = 273, - T_TYPE = 274, - T_DEFAULT = 275, - T_SELECT = 276, - T_IMPLY = 277, - T_RANGE = 278, - T_VISIBLE = 279, - T_OPTION = 280, - T_ON = 281, - T_WORD = 282, - T_WORD_QUOTE = 283, - T_UNEQUAL = 284, - T_LESS = 285, - T_LESS_EQUAL = 286, - T_GREATER = 287, - T_GREATER_EQUAL = 288, - T_CLOSE_PAREN = 289, - T_OPEN_PAREN = 290, - T_EOL = 291, - T_OR = 292, - T_AND = 293, - T_EQUAL = 294, - T_NOT = 295 - }; -#endif - -/* Value type. */ -#if ! defined YYSTYPE && ! defined YYSTYPE_IS_DECLARED - -union YYSTYPE -{ - - - char *string; - struct file *file; - struct symbol *symbol; - struct expr *expr; - struct menu *menu; - const struct kconf_id *id; - - -}; - -typedef union YYSTYPE YYSTYPE; -# define YYSTYPE_IS_TRIVIAL 1 -# define YYSTYPE_IS_DECLARED 1 -#endif - - -extern YYSTYPE zconflval; - -int zconfparse (void); - - - -/* Copy the second part of user declarations. */ - - -/* Include zconf.hash.c here so it can see the token constants. */ -#include "zconf.hash.c" - - - -#ifdef short -# undef short -#endif - -#ifdef YYTYPE_UINT8 -typedef YYTYPE_UINT8 yytype_uint8; -#else -typedef unsigned char yytype_uint8; -#endif - -#ifdef YYTYPE_INT8 -typedef YYTYPE_INT8 yytype_int8; -#else -typedef signed char yytype_int8; -#endif - -#ifdef YYTYPE_UINT16 -typedef YYTYPE_UINT16 yytype_uint16; -#else -typedef unsigned short int yytype_uint16; -#endif - -#ifdef YYTYPE_INT16 -typedef YYTYPE_INT16 yytype_int16; -#else -typedef short int yytype_int16; -#endif - -#ifndef YYSIZE_T -# ifdef __SIZE_TYPE__ -# define YYSIZE_T __SIZE_TYPE__ -# elif defined size_t -# define YYSIZE_T size_t -# elif ! defined YYSIZE_T -# include <stddef.h> /* INFRINGES ON USER NAME SPACE */ -# define YYSIZE_T size_t -# else -# define YYSIZE_T unsigned int -# endif -#endif - -#define YYSIZE_MAXIMUM ((YYSIZE_T) -1) - -#ifndef YY_ -# if defined YYENABLE_NLS && YYENABLE_NLS -# if ENABLE_NLS -# include <libintl.h> /* INFRINGES ON USER NAME SPACE */ -# define YY_(Msgid) dgettext ("bison-runtime", Msgid) -# endif -# endif -# ifndef YY_ -# define YY_(Msgid) Msgid -# endif -#endif - -#ifndef YY_ATTRIBUTE -# if (defined __GNUC__ \ - && (2 < __GNUC__ || (__GNUC__ == 2 && 96 <= __GNUC_MINOR__))) \ - || defined __SUNPRO_C && 0x5110 <= __SUNPRO_C -# define YY_ATTRIBUTE(Spec) __attribute__(Spec) -# else -# define YY_ATTRIBUTE(Spec) /* empty */ -# endif -#endif - -#ifndef YY_ATTRIBUTE_PURE -# define YY_ATTRIBUTE_PURE YY_ATTRIBUTE ((__pure__)) -#endif - -#ifndef YY_ATTRIBUTE_UNUSED -# define YY_ATTRIBUTE_UNUSED YY_ATTRIBUTE ((__unused__)) -#endif - -#if !defined _Noreturn \ - && (!defined __STDC_VERSION__ || __STDC_VERSION__ < 201112) -# if defined _MSC_VER && 1200 <= _MSC_VER -# define _Noreturn __declspec (noreturn) -# else -# define _Noreturn YY_ATTRIBUTE ((__noreturn__)) -# endif -#endif - -/* Suppress unused-variable warnings by "using" E. */ -#if ! defined lint || defined __GNUC__ -# define YYUSE(E) ((void) (E)) -#else -# define YYUSE(E) /* empty */ -#endif - -#if defined __GNUC__ && 407 <= __GNUC__ * 100 + __GNUC_MINOR__ -/* Suppress an incorrect diagnostic about yylval being uninitialized. */ -# define YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN \ - _Pragma ("GCC diagnostic push") \ - _Pragma ("GCC diagnostic ignored "-Wuninitialized"")\ - _Pragma ("GCC diagnostic ignored "-Wmaybe-uninitialized"") -# define YY_IGNORE_MAYBE_UNINITIALIZED_END \ - _Pragma ("GCC diagnostic pop") -#else -# define YY_INITIAL_VALUE(Value) Value -#endif -#ifndef YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN -# define YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN -# define YY_IGNORE_MAYBE_UNINITIALIZED_END -#endif -#ifndef YY_INITIAL_VALUE -# define YY_INITIAL_VALUE(Value) /* Nothing. */ -#endif - - -#if ! defined yyoverflow || YYERROR_VERBOSE - -/* The parser invokes alloca or malloc; define the necessary symbols. */ - -# ifdef YYSTACK_USE_ALLOCA -# if YYSTACK_USE_ALLOCA -# ifdef __GNUC__ -# define YYSTACK_ALLOC __builtin_alloca -# elif defined __BUILTIN_VA_ARG_INCR -# include <alloca.h> /* INFRINGES ON USER NAME SPACE */ -# elif defined _AIX -# define YYSTACK_ALLOC __alloca -# elif defined _MSC_VER -# include <malloc.h> /* INFRINGES ON USER NAME SPACE */ -# define alloca _alloca -# else -# define YYSTACK_ALLOC alloca -# if ! defined _ALLOCA_H && ! defined EXIT_SUCCESS -# include <stdlib.h> /* INFRINGES ON USER NAME SPACE */ - /* Use EXIT_SUCCESS as a witness for stdlib.h. */ -# ifndef EXIT_SUCCESS -# define EXIT_SUCCESS 0 -# endif -# endif -# endif -# endif -# endif - -# ifdef YYSTACK_ALLOC - /* Pacify GCC's 'empty if-body' warning. */ -# define YYSTACK_FREE(Ptr) do { /* empty */; } while (0) -# ifndef YYSTACK_ALLOC_MAXIMUM - /* The OS might guarantee only one guard page at the bottom of the stack, - and a page size can be as small as 4096 bytes. So we cannot safely - invoke alloca (N) if N exceeds 4096. Use a slightly smaller number - to allow for a few compiler-allocated temporary stack slots. */ -# define YYSTACK_ALLOC_MAXIMUM 4032 /* reasonable circa 2006 */ -# endif -# else -# define YYSTACK_ALLOC YYMALLOC -# define YYSTACK_FREE YYFREE -# ifndef YYSTACK_ALLOC_MAXIMUM -# define YYSTACK_ALLOC_MAXIMUM YYSIZE_MAXIMUM -# endif -# if (defined __cplusplus && ! defined EXIT_SUCCESS \ - && ! ((defined YYMALLOC || defined malloc) \ - && (defined YYFREE || defined free))) -# include <stdlib.h> /* INFRINGES ON USER NAME SPACE */ -# ifndef EXIT_SUCCESS -# define EXIT_SUCCESS 0 -# endif -# endif -# ifndef YYMALLOC -# define YYMALLOC malloc -# if ! defined malloc && ! defined EXIT_SUCCESS -void *malloc (YYSIZE_T); /* INFRINGES ON USER NAME SPACE */ -# endif -# endif -# ifndef YYFREE -# define YYFREE free -# if ! defined free && ! defined EXIT_SUCCESS -void free (void *); /* INFRINGES ON USER NAME SPACE */ -# endif -# endif -# endif -#endif /* ! defined yyoverflow || YYERROR_VERBOSE */ - - -#if (! defined yyoverflow \ - && (! defined __cplusplus \ - || (defined YYSTYPE_IS_TRIVIAL && YYSTYPE_IS_TRIVIAL))) - -/* A type that is properly aligned for any stack member. */ -union yyalloc -{ - yytype_int16 yyss_alloc; - YYSTYPE yyvs_alloc; -}; - -/* The size of the maximum gap between one aligned stack and the next. */ -# define YYSTACK_GAP_MAXIMUM (sizeof (union yyalloc) - 1) - -/* The size of an array large to enough to hold all stacks, each with - N elements. */ -# define YYSTACK_BYTES(N) \ - ((N) * (sizeof (yytype_int16) + sizeof (YYSTYPE)) \ - + YYSTACK_GAP_MAXIMUM) - -# define YYCOPY_NEEDED 1 - -/* Relocate STACK from its old location to the new one. The - local variables YYSIZE and YYSTACKSIZE give the old and new number of - elements in the stack, and YYPTR gives the new location of the - stack. Advance YYPTR to a properly aligned location for the next - stack. */ -# define YYSTACK_RELOCATE(Stack_alloc, Stack) \ - do \ - { \ - YYSIZE_T yynewbytes; \ - YYCOPY (&yyptr->Stack_alloc, Stack, yysize); \ - Stack = &yyptr->Stack_alloc; \ - yynewbytes = yystacksize * sizeof (*Stack) + YYSTACK_GAP_MAXIMUM; \ - yyptr += yynewbytes / sizeof (*yyptr); \ - } \ - while (0) - -#endif - -#if defined YYCOPY_NEEDED && YYCOPY_NEEDED -/* Copy COUNT objects from SRC to DST. The source and destination do - not overlap. */ -# ifndef YYCOPY -# if defined __GNUC__ && 1 < __GNUC__ -# define YYCOPY(Dst, Src, Count) \ - __builtin_memcpy (Dst, Src, (Count) * sizeof (*(Src))) -# else -# define YYCOPY(Dst, Src, Count) \ - do \ - { \ - YYSIZE_T yyi; \ - for (yyi = 0; yyi < (Count); yyi++) \ - (Dst)[yyi] = (Src)[yyi]; \ - } \ - while (0) -# endif -# endif -#endif /* !YYCOPY_NEEDED */ - -/* YYFINAL -- State number of the termination state. */ -#define YYFINAL 11 -/* YYLAST -- Last index in YYTABLE. */ -#define YYLAST 301 - -/* YYNTOKENS -- Number of terminals. */ -#define YYNTOKENS 41 -/* YYNNTS -- Number of nonterminals. */ -#define YYNNTS 50 -/* YYNRULES -- Number of rules. */ -#define YYNRULES 124 -/* YYNSTATES -- Number of states. */ -#define YYNSTATES 204 - -/* YYTRANSLATE[YYX] -- Symbol number corresponding to YYX as returned - by yylex, with out-of-bounds checking. */ -#define YYUNDEFTOK 2 -#define YYMAXUTOK 295 - -#define YYTRANSLATE(YYX) \ - ((unsigned int) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK) - -/* YYTRANSLATE[TOKEN-NUM] -- Symbol number corresponding to TOKEN-NUM - as returned by yylex, without out-of-bounds checking. */ -static const yytype_uint8 yytranslate[] = -{ - 0, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, - 2, 2, 2, 2, 2, 2, 1, 2, 3, 4, - 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, - 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, - 35, 36, 37, 38, 39, 40 -}; - -#if YYDEBUG - /* YYRLINE[YYN] -- Source line where rule number YYN was defined. */ -static const yytype_uint16 yyrline[] = -{ - 0, 109, 109, 109, 111, 111, 113, 115, 116, 117, - 118, 119, 120, 124, 128, 128, 128, 128, 128, 128, - 128, 128, 128, 132, 133, 134, 135, 136, 137, 141, - 142, 148, 156, 162, 170, 180, 182, 183, 184, 185, - 186, 187, 190, 198, 204, 214, 220, 226, 232, 235, - 237, 248, 249, 254, 263, 268, 276, 279, 281, 282, - 283, 284, 285, 288, 294, 305, 311, 321, 323, 328, - 336, 344, 347, 349, 350, 351, 356, 363, 370, 375, - 383, 386, 388, 389, 390, 393, 401, 408, 415, 421, - 428, 430, 431, 432, 435, 443, 445, 446, 449, 456, - 458, 463, 464, 467, 468, 469, 473, 474, 477, 478, - 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, - 491, 494, 495, 498, 499 -}; -#endif - -#if YYDEBUG || YYERROR_VERBOSE || 0 -/* YYTNAME[SYMBOL-NUM] -- String name of the symbol SYMBOL-NUM. - First, the terminals, then, starting at YYNTOKENS, nonterminals. */ -static const char *const yytname[] = -{ - "$end", "error", "$undefined", "T_MAINMENU", "T_MENU", "T_ENDMENU", - "T_SOURCE", "T_CHOICE", "T_ENDCHOICE", "T_COMMENT", "T_CONFIG", - "T_MENUCONFIG", "T_HELP", "T_HELPTEXT", "T_IF", "T_ENDIF", "T_DEPENDS", - "T_OPTIONAL", "T_PROMPT", "T_TYPE", "T_DEFAULT", "T_SELECT", "T_IMPLY", - "T_RANGE", "T_VISIBLE", "T_OPTION", "T_ON", "T_WORD", "T_WORD_QUOTE", - "T_UNEQUAL", "T_LESS", "T_LESS_EQUAL", "T_GREATER", "T_GREATER_EQUAL", - "T_CLOSE_PAREN", "T_OPEN_PAREN", "T_EOL", "T_OR", "T_AND", "T_EQUAL", - "T_NOT", "$accept", "input", "start", "stmt_list", "option_name", - "common_stmt", "option_error", "config_entry_start", "config_stmt", - "menuconfig_entry_start", "menuconfig_stmt", "config_option_list", - "config_option", "symbol_option", "symbol_option_list", - "symbol_option_arg", "choice", "choice_entry", "choice_end", - "choice_stmt", "choice_option_list", "choice_option", "choice_block", - "if_entry", "if_end", "if_stmt", "if_block", "mainmenu_stmt", "menu", - "menu_entry", "menu_end", "menu_stmt", "menu_block", "source_stmt", - "comment", "comment_stmt", "help_start", "help", "depends_list", - "depends", "visibility_list", "visible", "prompt_stmt_opt", "prompt", - "end", "nl", "if_expr", "expr", "symbol", "word_opt", YY_NULLPTR -}; -#endif - -# ifdef YYPRINT -/* YYTOKNUM[NUM] -- (External) token number corresponding to the - (internal) symbol number NUM (which must be that of a token). */ -static const yytype_uint16 yytoknum[] = -{ - 0, 256, 257, 258, 259, 260, 261, 262, 263, 264, - 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, - 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, - 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, - 295 -}; -# endif - -#define YYPACT_NINF -92 - -#define yypact_value_is_default(Yystate) \ - (!!((Yystate) == (-92))) - -#define YYTABLE_NINF -88 - -#define yytable_value_is_error(Yytable_value) \ - 0 - - /* YYPACT[STATE-NUM] -- Index in YYTABLE of the portion describing - STATE-NUM. */ -static const yytype_int16 yypact[] = -{ - 17, 41, -92, 15, -92, 150, -92, 19, -92, -92, - -13, -92, 28, 41, 38, 41, 50, 47, 41, 79, - 82, 44, 76, -92, -92, -92, -92, -92, -92, -92, - -92, -92, 118, -92, 129, -92, -92, -92, -92, -92, - -92, -92, -92, -92, -92, -92, -92, -92, -92, -92, - -92, -92, 184, -92, -92, 107, -92, 111, -92, 113, - -92, 116, -92, 139, 140, 151, -92, -92, 44, 44, - 142, 256, -92, 160, 173, 27, 117, 80, 51, 255, - -15, 255, 217, -92, -92, -92, -92, -92, -92, -8, - -92, 44, 44, 107, 87, 87, 87, 87, 87, 87, - -92, -92, 174, 176, 187, 41, 41, 44, 188, 189, - 87, -92, 213, -92, -92, -92, -92, 206, -92, -92, - 193, 41, 41, 203, -92, -92, -92, -92, -92, -92, - -92, -92, -92, -92, -92, -92, -92, 229, -92, 241, - -92, -92, -92, -92, -92, -92, -92, -92, -92, -92, - 216, -92, -92, -92, -92, -92, -92, -92, -92, -92, - 44, 229, 222, 229, 64, 229, 229, 87, 31, 231, - -92, -92, 229, 236, 229, 44, -92, 145, 242, -92, - -92, 243, 244, 245, 229, 251, -92, -92, 247, -92, - 257, 125, -92, -92, -92, -92, -92, 260, 41, -92, - -92, -92, -92, -92 -}; - - /* YYDEFACT[STATE-NUM] -- Default reduction number in state STATE-NUM. - Performed when YYTABLE does not specify something else to do. Zero - means the default is an error. */ -static const yytype_uint8 yydefact[] = -{ - 6, 0, 106, 0, 3, 0, 6, 6, 101, 102, - 0, 1, 0, 0, 0, 0, 123, 0, 0, 0, - 0, 0, 0, 14, 19, 15, 16, 21, 17, 18, - 20, 22, 0, 23, 0, 7, 35, 26, 35, 27, - 57, 67, 8, 72, 24, 95, 81, 9, 28, 90, - 25, 10, 0, 107, 2, 76, 13, 0, 103, 0, - 124, 0, 104, 0, 0, 0, 121, 122, 0, 0, - 0, 110, 105, 0, 0, 0, 0, 0, 0, 0, - 90, 0, 0, 77, 85, 53, 86, 31, 33, 0, - 118, 0, 0, 69, 0, 0, 0, 0, 0, 0, - 11, 12, 0, 0, 0, 0, 99, 0, 0, 0, - 0, 49, 0, 41, 40, 36, 37, 0, 39, 38, - 0, 0, 99, 0, 61, 62, 58, 60, 59, 68, - 56, 55, 73, 75, 71, 74, 70, 108, 97, 0, - 96, 82, 84, 80, 83, 79, 92, 93, 91, 117, - 119, 120, 116, 111, 112, 113, 114, 115, 30, 88, - 0, 108, 0, 108, 108, 108, 108, 0, 0, 0, - 89, 65, 108, 0, 108, 0, 98, 0, 0, 42, - 100, 0, 0, 0, 108, 51, 48, 29, 0, 64, - 0, 109, 94, 43, 44, 45, 46, 0, 0, 50, - 63, 66, 47, 52 -}; - - /* YYPGOTO[NTERM-NUM]. */ -static const yytype_int16 yypgoto[] = -{ - -92, -92, 285, 291, -92, 32, -66, -92, -92, -92, - -92, 261, -92, -92, -92, -92, -92, -92, -92, 1, - -92, -92, -92, -92, -92, -92, -92, -92, -92, -92, - -92, 24, -92, -92, -92, -92, -92, 221, 220, -64, - -92, -92, 179, -1, 67, 0, 110, -67, -91, -92 -}; - - /* YYDEFGOTO[NTERM-NUM]. */ -static const yytype_int16 yydefgoto[] = -{ - -1, 3, 4, 5, 34, 35, 114, 36, 37, 38, - 39, 75, 115, 116, 168, 199, 40, 41, 130, 42, - 77, 126, 78, 43, 134, 44, 79, 6, 45, 46, - 143, 47, 81, 48, 49, 50, 117, 118, 82, 119, - 80, 140, 162, 163, 51, 7, 176, 70, 71, 61 -}; - - /* YYTABLE[YYPACT[STATE-NUM]] -- What to do in state STATE-NUM. If - positive, shift that token. If negative, reduce the rule whose - number is the opposite. If YYTABLE_NINF, syntax error. */ -static const yytype_int16 yytable[] = -{ - 10, 89, 90, 152, 153, 154, 155, 156, 157, 137, - 55, 125, 57, 128, 59, 11, 147, 63, 148, 167, - 1, 138, 1, 2, 150, 151, 149, -32, 102, 91, - 92, -32, -32, -32, -32, -32, -32, -32, -32, 103, - 164, -32, -32, 104, -32, 105, 106, 107, 108, 109, - 110, -32, 111, 2, 112, 53, 14, 15, 185, 17, - 18, 19, 20, 113, 56, 21, 22, 186, 8, 9, - 93, 66, 67, 147, 58, 148, 184, 60, 175, 68, - 133, 102, 142, 62, 69, -54, -54, 33, -54, -54, - -54, -54, 103, 177, -54, -54, 104, 120, 121, 122, - 123, 91, 92, 135, 161, 144, 64, 112, 191, 65, - 129, 132, 72, 141, 66, 67, 124, -34, 102, 73, - 172, -34, -34, -34, -34, -34, -34, -34, -34, 103, - 74, -34, -34, 104, -34, 105, 106, 107, 108, 109, - 110, -34, 111, 53, 112, 131, 136, 83, 145, 84, - -5, 12, 85, 113, 13, 14, 15, 16, 17, 18, - 19, 20, 91, 92, 21, 22, 23, 24, 25, 26, - 27, 28, 29, 30, 31, 86, 87, 32, 2, 91, - 92, 192, 91, 92, -4, 12, 33, 88, 13, 14, - 15, 16, 17, 18, 19, 20, 100, 203, 21, 22, - 23, 24, 25, 26, 27, 28, 29, 30, 31, 101, - 158, 32, 159, 160, 169, 165, 166, -87, 102, 170, - 33, -87, -87, -87, -87, -87, -87, -87, -87, 171, - 174, -87, -87, 104, -87, -87, -87, -87, -87, -87, - -87, -87, 102, 175, 112, -78, -78, -78, -78, -78, - -78, -78, -78, 146, 92, -78, -78, 104, 179, 13, - 14, 15, 16, 17, 18, 19, 20, 187, 112, 21, - 22, 178, 189, 180, 181, 182, 183, 146, 193, 194, - 195, 196, 188, 200, 190, 94, 95, 96, 97, 98, - 198, 33, 54, 201, 197, 99, 202, 52, 127, 76, - 139, 173 -}; - -static const yytype_uint8 yycheck[] = -{ - 1, 68, 69, 94, 95, 96, 97, 98, 99, 24, - 10, 77, 13, 77, 15, 0, 82, 18, 82, 110, - 3, 36, 3, 36, 91, 92, 34, 0, 1, 37, - 38, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 107, 14, 15, 16, 17, 18, 19, 20, 21, 22, - 23, 24, 25, 36, 27, 36, 5, 6, 27, 8, - 9, 10, 11, 36, 36, 14, 15, 36, 27, 28, - 70, 27, 28, 139, 36, 139, 167, 27, 14, 35, - 79, 1, 81, 36, 40, 5, 6, 36, 8, 9, - 10, 11, 12, 160, 14, 15, 16, 17, 18, 19, - 20, 37, 38, 79, 105, 81, 27, 27, 175, 27, - 78, 79, 36, 81, 27, 28, 36, 0, 1, 1, - 121, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 1, 14, 15, 16, 17, 18, 19, 20, 21, 22, - 23, 24, 25, 36, 27, 78, 79, 36, 81, 36, - 0, 1, 36, 36, 4, 5, 6, 7, 8, 9, - 10, 11, 37, 38, 14, 15, 16, 17, 18, 19, - 20, 21, 22, 23, 24, 36, 36, 27, 36, 37, - 38, 36, 37, 38, 0, 1, 36, 36, 4, 5, - 6, 7, 8, 9, 10, 11, 36, 198, 14, 15, - 16, 17, 18, 19, 20, 21, 22, 23, 24, 36, - 36, 27, 36, 26, 1, 27, 27, 0, 1, 13, - 36, 4, 5, 6, 7, 8, 9, 10, 11, 36, - 27, 14, 15, 16, 17, 18, 19, 20, 21, 22, - 23, 24, 1, 14, 27, 4, 5, 6, 7, 8, - 9, 10, 11, 36, 38, 14, 15, 16, 36, 4, - 5, 6, 7, 8, 9, 10, 11, 36, 27, 14, - 15, 161, 36, 163, 164, 165, 166, 36, 36, 36, - 36, 36, 172, 36, 174, 29, 30, 31, 32, 33, - 39, 36, 7, 36, 184, 39, 36, 6, 77, 38, - 80, 122 -}; - - /* YYSTOS[STATE-NUM] -- The (internal number of the) accessing - symbol of state STATE-NUM. */ -static const yytype_uint8 yystos[] = -{ - 0, 3, 36, 42, 43, 44, 68, 86, 27, 28, - 84, 0, 1, 4, 5, 6, 7, 8, 9, 10, - 11, 14, 15, 16, 17, 18, 19, 20, 21, 22, - 23, 24, 27, 36, 45, 46, 48, 49, 50, 51, - 57, 58, 60, 64, 66, 69, 70, 72, 74, 75, - 76, 85, 44, 36, 43, 86, 36, 84, 36, 84, - 27, 90, 36, 84, 27, 27, 27, 28, 35, 40, - 88, 89, 36, 1, 1, 52, 52, 61, 63, 67, - 81, 73, 79, 36, 36, 36, 36, 36, 36, 88, - 88, 37, 38, 86, 29, 30, 31, 32, 33, 39, - 36, 36, 1, 12, 16, 18, 19, 20, 21, 22, - 23, 25, 27, 36, 47, 53, 54, 77, 78, 80, - 17, 18, 19, 20, 36, 47, 62, 78, 80, 46, - 59, 85, 46, 60, 65, 72, 85, 24, 36, 79, - 82, 46, 60, 71, 72, 85, 36, 47, 80, 34, - 88, 88, 89, 89, 89, 89, 89, 89, 36, 36, - 26, 84, 83, 84, 88, 27, 27, 89, 55, 1, - 13, 36, 84, 83, 27, 14, 87, 88, 87, 36, - 87, 87, 87, 87, 89, 27, 36, 36, 87, 36, - 87, 88, 36, 36, 36, 36, 36, 87, 39, 56, - 36, 36, 36, 84 -}; - - /* YYR1[YYN] -- Symbol number of symbol that rule YYN derives. */ -static const yytype_uint8 yyr1[] = -{ - 0, 41, 42, 42, 43, 43, 44, 44, 44, 44, - 44, 44, 44, 44, 45, 45, 45, 45, 45, 45, - 45, 45, 45, 46, 46, 46, 46, 46, 46, 47, - 47, 48, 49, 50, 51, 52, 52, 52, 52, 52, - 52, 52, 53, 53, 53, 53, 53, 53, 54, 55, - 55, 56, 56, 57, 58, 59, 60, 61, 61, 61, - 61, 61, 61, 62, 62, 62, 62, 63, 63, 64, - 65, 66, 67, 67, 67, 67, 68, 69, 70, 71, - 72, 73, 73, 73, 73, 74, 75, 76, 77, 78, - 79, 79, 79, 79, 80, 81, 81, 81, 82, 83, - 83, 84, 84, 85, 85, 85, 86, 86, 87, 87, - 88, 88, 88, 88, 88, 88, 88, 88, 88, 88, - 88, 89, 89, 90, 90 -}; - - /* YYR2[YYN] -- Number of symbols on the right hand side of rule YYN. */ -static const yytype_uint8 yyr2[] = -{ - 0, 2, 2, 1, 2, 1, 0, 2, 2, 2, - 2, 4, 4, 3, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, - 2, 3, 2, 3, 2, 0, 2, 2, 2, 2, - 2, 2, 3, 4, 4, 4, 4, 5, 3, 0, - 3, 0, 2, 3, 2, 1, 3, 0, 2, 2, - 2, 2, 2, 4, 3, 2, 4, 0, 2, 3, - 1, 3, 0, 2, 2, 2, 3, 3, 3, 1, - 3, 0, 2, 2, 2, 3, 3, 2, 2, 2, - 0, 2, 2, 2, 4, 0, 2, 2, 2, 0, - 2, 1, 1, 2, 2, 2, 1, 2, 0, 2, - 1, 3, 3, 3, 3, 3, 3, 3, 2, 3, - 3, 1, 1, 0, 1 -}; - - -#define yyerrok (yyerrstatus = 0) -#define yyclearin (yychar = YYEMPTY) -#define YYEMPTY (-2) -#define YYEOF 0 - -#define YYACCEPT goto yyacceptlab -#define YYABORT goto yyabortlab -#define YYERROR goto yyerrorlab - - -#define YYRECOVERING() (!!yyerrstatus) - -#define YYBACKUP(Token, Value) \ -do \ - if (yychar == YYEMPTY) \ - { \ - yychar = (Token); \ - yylval = (Value); \ - YYPOPSTACK (yylen); \ - yystate = *yyssp; \ - goto yybackup; \ - } \ - else \ - { \ - yyerror (YY_("syntax error: cannot back up")); \ - YYERROR; \ - } \ -while (0) - -/* Error token number */ -#define YYTERROR 1 -#define YYERRCODE 256 - - - -/* Enable debugging if requested. */ -#if YYDEBUG - -# ifndef YYFPRINTF -# include <stdio.h> /* INFRINGES ON USER NAME SPACE */ -# define YYFPRINTF fprintf -# endif - -# define YYDPRINTF(Args) \ -do { \ - if (yydebug) \ - YYFPRINTF Args; \ -} while (0) - -/* This macro is provided for backward compatibility. */ -#ifndef YY_LOCATION_PRINT -# define YY_LOCATION_PRINT(File, Loc) ((void) 0) -#endif - - -# define YY_SYMBOL_PRINT(Title, Type, Value, Location) \ -do { \ - if (yydebug) \ - { \ - YYFPRINTF (stderr, "%s ", Title); \ - yy_symbol_print (stderr, \ - Type, Value); \ - YYFPRINTF (stderr, "\n"); \ - } \ -} while (0) - - -/*----------------------------------------. -| Print this symbol's value on YYOUTPUT. | -`----------------------------------------*/ - -static void -yy_symbol_value_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep) -{ - FILE *yyo = yyoutput; - YYUSE (yyo); - if (!yyvaluep) - return; -# ifdef YYPRINT - if (yytype < YYNTOKENS) - YYPRINT (yyoutput, yytoknum[yytype], *yyvaluep); -# endif - YYUSE (yytype); -} - - -/*--------------------------------. -| Print this symbol on YYOUTPUT. | -`--------------------------------*/ - -static void -yy_symbol_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep) -{ - YYFPRINTF (yyoutput, "%s %s (", - yytype < YYNTOKENS ? "token" : "nterm", yytname[yytype]); - - yy_symbol_value_print (yyoutput, yytype, yyvaluep); - YYFPRINTF (yyoutput, ")"); -} - -/*------------------------------------------------------------------. -| yy_stack_print -- Print the state stack from its BOTTOM up to its | -| TOP (included). | -`------------------------------------------------------------------*/ - -static void -yy_stack_print (yytype_int16 *yybottom, yytype_int16 *yytop) -{ - YYFPRINTF (stderr, "Stack now"); - for (; yybottom <= yytop; yybottom++) - { - int yybot = *yybottom; - YYFPRINTF (stderr, " %d", yybot); - } - YYFPRINTF (stderr, "\n"); -} - -# define YY_STACK_PRINT(Bottom, Top) \ -do { \ - if (yydebug) \ - yy_stack_print ((Bottom), (Top)); \ -} while (0) - - -/*------------------------------------------------. -| Report that the YYRULE is going to be reduced. | -`------------------------------------------------*/ - -static void -yy_reduce_print (yytype_int16 *yyssp, YYSTYPE *yyvsp, int yyrule) -{ - unsigned long int yylno = yyrline[yyrule]; - int yynrhs = yyr2[yyrule]; - int yyi; - YYFPRINTF (stderr, "Reducing stack by rule %d (line %lu):\n", - yyrule - 1, yylno); - /* The symbols being reduced. */ - for (yyi = 0; yyi < yynrhs; yyi++) - { - YYFPRINTF (stderr, " $%d = ", yyi + 1); - yy_symbol_print (stderr, - yystos[yyssp[yyi + 1 - yynrhs]], - &(yyvsp[(yyi + 1) - (yynrhs)]) - ); - YYFPRINTF (stderr, "\n"); - } -} - -# define YY_REDUCE_PRINT(Rule) \ -do { \ - if (yydebug) \ - yy_reduce_print (yyssp, yyvsp, Rule); \ -} while (0) - -/* Nonzero means print parse trace. It is left uninitialized so that - multiple parsers can coexist. */ -int yydebug; -#else /* !YYDEBUG */ -# define YYDPRINTF(Args) -# define YY_SYMBOL_PRINT(Title, Type, Value, Location) -# define YY_STACK_PRINT(Bottom, Top) -# define YY_REDUCE_PRINT(Rule) -#endif /* !YYDEBUG */ - - -/* YYINITDEPTH -- initial size of the parser's stacks. */ -#ifndef YYINITDEPTH -# define YYINITDEPTH 200 -#endif - -/* YYMAXDEPTH -- maximum size the stacks can grow to (effective only - if the built-in stack extension method is used). - - Do not make this value too large; the results are undefined if - YYSTACK_ALLOC_MAXIMUM < YYSTACK_BYTES (YYMAXDEPTH) - evaluated with infinite-precision integer arithmetic. */ - -#ifndef YYMAXDEPTH -# define YYMAXDEPTH 10000 -#endif - - -#if YYERROR_VERBOSE - -# ifndef yystrlen -# if defined __GLIBC__ && defined _STRING_H -# define yystrlen strlen -# else -/* Return the length of YYSTR. */ -static YYSIZE_T -yystrlen (const char *yystr) -{ - YYSIZE_T yylen; - for (yylen = 0; yystr[yylen]; yylen++) - continue; - return yylen; -} -# endif -# endif - -# ifndef yystpcpy -# if defined __GLIBC__ && defined _STRING_H && defined _GNU_SOURCE -# define yystpcpy stpcpy -# else -/* Copy YYSRC to YYDEST, returning the address of the terminating '\0' in - YYDEST. */ -static char * -yystpcpy (char *yydest, const char *yysrc) -{ - char *yyd = yydest; - const char *yys = yysrc; - - while ((*yyd++ = *yys++) != '\0') - continue; - - return yyd - 1; -} -# endif -# endif - -# ifndef yytnamerr -/* Copy to YYRES the contents of YYSTR after stripping away unnecessary - quotes and backslashes, so that it's suitable for yyerror. The - heuristic is that double-quoting is unnecessary unless the string - contains an apostrophe, a comma, or backslash (other than - backslash-backslash). YYSTR is taken from yytname. If YYRES is - null, do not copy; instead, return the length of what the result - would have been. */ -static YYSIZE_T -yytnamerr (char *yyres, const char *yystr) -{ - if (*yystr == '"') - { - YYSIZE_T yyn = 0; - char const *yyp = yystr; - - for (;;) - switch (*++yyp) - { - case ''': - case ',': - goto do_not_strip_quotes; - - case '\': - if (*++yyp != '\') - goto do_not_strip_quotes; - /* Fall through. */ - default: - if (yyres) - yyres[yyn] = *yyp; - yyn++; - break; - - case '"': - if (yyres) - yyres[yyn] = '\0'; - return yyn; - } - do_not_strip_quotes: ; - } - - if (! yyres) - return yystrlen (yystr); - - return yystpcpy (yyres, yystr) - yyres; -} -# endif - -/* Copy into *YYMSG, which is of size *YYMSG_ALLOC, an error message - about the unexpected token YYTOKEN for the state stack whose top is - YYSSP. - - Return 0 if *YYMSG was successfully written. Return 1 if *YYMSG is - not large enough to hold the message. In that case, also set - *YYMSG_ALLOC to the required number of bytes. Return 2 if the - required number of bytes is too large to store. */ -static int -yysyntax_error (YYSIZE_T *yymsg_alloc, char **yymsg, - yytype_int16 *yyssp, int yytoken) -{ - YYSIZE_T yysize0 = yytnamerr (YY_NULLPTR, yytname[yytoken]); - YYSIZE_T yysize = yysize0; - enum { YYERROR_VERBOSE_ARGS_MAXIMUM = 5 }; - /* Internationalized format string. */ - const char *yyformat = YY_NULLPTR; - /* Arguments of yyformat. */ - char const *yyarg[YYERROR_VERBOSE_ARGS_MAXIMUM]; - /* Number of reported tokens (one for the "unexpected", one per - "expected"). */ - int yycount = 0; - - /* There are many possibilities here to consider: - - If this state is a consistent state with a default action, then - the only way this function was invoked is if the default action - is an error action. In that case, don't check for expected - tokens because there are none. - - The only way there can be no lookahead present (in yychar) is if - this state is a consistent state with a default action. Thus, - detecting the absence of a lookahead is sufficient to determine - that there is no unexpected or expected token to report. In that - case, just report a simple "syntax error". - - Don't assume there isn't a lookahead just because this state is a - consistent state with a default action. There might have been a - previous inconsistent state, consistent state with a non-default - action, or user semantic action that manipulated yychar. - - Of course, the expected token list depends on states to have - correct lookahead information, and it depends on the parser not - to perform extra reductions after fetching a lookahead from the - scanner and before detecting a syntax error. Thus, state merging - (from LALR or IELR) and default reductions corrupt the expected - token list. However, the list is correct for canonical LR with - one exception: it will still contain any token that will not be - accepted due to an error action in a later state. - */ - if (yytoken != YYEMPTY) - { - int yyn = yypact[*yyssp]; - yyarg[yycount++] = yytname[yytoken]; - if (!yypact_value_is_default (yyn)) - { - /* Start YYX at -YYN if negative to avoid negative indexes in - YYCHECK. In other words, skip the first -YYN actions for - this state because they are default actions. */ - int yyxbegin = yyn < 0 ? -yyn : 0; - /* Stay within bounds of both yycheck and yytname. */ - int yychecklim = YYLAST - yyn + 1; - int yyxend = yychecklim < YYNTOKENS ? yychecklim : YYNTOKENS; - int yyx; - - for (yyx = yyxbegin; yyx < yyxend; ++yyx) - if (yycheck[yyx + yyn] == yyx && yyx != YYTERROR - && !yytable_value_is_error (yytable[yyx + yyn])) - { - if (yycount == YYERROR_VERBOSE_ARGS_MAXIMUM) - { - yycount = 1; - yysize = yysize0; - break; - } - yyarg[yycount++] = yytname[yyx]; - { - YYSIZE_T yysize1 = yysize + yytnamerr (YY_NULLPTR, yytname[yyx]); - if (! (yysize <= yysize1 - && yysize1 <= YYSTACK_ALLOC_MAXIMUM)) - return 2; - yysize = yysize1; - } - } - } - } - - switch (yycount) - { -# define YYCASE_(N, S) \ - case N: \ - yyformat = S; \ - break - YYCASE_(0, YY_("syntax error")); - YYCASE_(1, YY_("syntax error, unexpected %s")); - YYCASE_(2, YY_("syntax error, unexpected %s, expecting %s")); - YYCASE_(3, YY_("syntax error, unexpected %s, expecting %s or %s")); - YYCASE_(4, YY_("syntax error, unexpected %s, expecting %s or %s or %s")); - YYCASE_(5, YY_("syntax error, unexpected %s, expecting %s or %s or %s or %s")); -# undef YYCASE_ - } - - { - YYSIZE_T yysize1 = yysize + yystrlen (yyformat); - if (! (yysize <= yysize1 && yysize1 <= YYSTACK_ALLOC_MAXIMUM)) - return 2; - yysize = yysize1; - } - - if (*yymsg_alloc < yysize) - { - *yymsg_alloc = 2 * yysize; - if (! (yysize <= *yymsg_alloc - && *yymsg_alloc <= YYSTACK_ALLOC_MAXIMUM)) - *yymsg_alloc = YYSTACK_ALLOC_MAXIMUM; - return 1; - } - - /* Avoid sprintf, as that infringes on the user's name space. - Don't have undefined behavior even if the translation - produced a string with the wrong number of "%s"s. */ - { - char *yyp = *yymsg; - int yyi = 0; - while ((*yyp = *yyformat) != '\0') - if (*yyp == '%' && yyformat[1] == 's' && yyi < yycount) - { - yyp += yytnamerr (yyp, yyarg[yyi++]); - yyformat += 2; - } - else - { - yyp++; - yyformat++; - } - } - return 0; -} -#endif /* YYERROR_VERBOSE */ - -/*-----------------------------------------------. -| Release the memory associated to this symbol. | -`-----------------------------------------------*/ - -static void -yydestruct (const char *yymsg, int yytype, YYSTYPE *yyvaluep) -{ - YYUSE (yyvaluep); - if (!yymsg) - yymsg = "Deleting"; - YY_SYMBOL_PRINT (yymsg, yytype, yyvaluep, yylocationp); - - YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN - switch (yytype) - { - case 58: /* choice_entry */ - - { - fprintf(stderr, "%s:%d: missing end statement for this entry\n", - ((*yyvaluep).menu)->file->name, ((*yyvaluep).menu)->lineno); - if (current_menu == ((*yyvaluep).menu)) - menu_end_menu(); -} - - break; - - case 64: /* if_entry */ - - { - fprintf(stderr, "%s:%d: missing end statement for this entry\n", - ((*yyvaluep).menu)->file->name, ((*yyvaluep).menu)->lineno); - if (current_menu == ((*yyvaluep).menu)) - menu_end_menu(); -} - - break; - - case 70: /* menu_entry */ - - { - fprintf(stderr, "%s:%d: missing end statement for this entry\n", - ((*yyvaluep).menu)->file->name, ((*yyvaluep).menu)->lineno); - if (current_menu == ((*yyvaluep).menu)) - menu_end_menu(); -} - - break; - - - default: - break; - } - YY_IGNORE_MAYBE_UNINITIALIZED_END -} - - - - -/* The lookahead symbol. */ -int yychar; - -/* The semantic value of the lookahead symbol. */ -YYSTYPE yylval; -/* Number of syntax errors so far. */ -int yynerrs; - - -/*----------. -| yyparse. | -`----------*/ - -int -yyparse (void) -{ - int yystate; - /* Number of tokens to shift before error messages enabled. */ - int yyerrstatus; - - /* The stacks and their tools: - 'yyss': related to states. - 'yyvs': related to semantic values. - - Refer to the stacks through separate pointers, to allow yyoverflow - to reallocate them elsewhere. */ - - /* The state stack. */ - yytype_int16 yyssa[YYINITDEPTH]; - yytype_int16 *yyss; - yytype_int16 *yyssp; - - /* The semantic value stack. */ - YYSTYPE yyvsa[YYINITDEPTH]; - YYSTYPE *yyvs; - YYSTYPE *yyvsp; - - YYSIZE_T yystacksize; - - int yyn; - int yyresult; - /* Lookahead token as an internal (translated) token number. */ - int yytoken = 0; - /* The variables used to return semantic value and location from the - action routines. */ - YYSTYPE yyval; - -#if YYERROR_VERBOSE - /* Buffer for error messages, and its allocated size. */ - char yymsgbuf[128]; - char *yymsg = yymsgbuf; - YYSIZE_T yymsg_alloc = sizeof yymsgbuf; -#endif - -#define YYPOPSTACK(N) (yyvsp -= (N), yyssp -= (N)) - - /* The number of symbols on the RHS of the reduced rule. - Keep to zero when no symbol should be popped. */ - int yylen = 0; - - yyssp = yyss = yyssa; - yyvsp = yyvs = yyvsa; - yystacksize = YYINITDEPTH; - - YYDPRINTF ((stderr, "Starting parse\n")); - - yystate = 0; - yyerrstatus = 0; - yynerrs = 0; - yychar = YYEMPTY; /* Cause a token to be read. */ - goto yysetstate; - -/*------------------------------------------------------------. -| yynewstate -- Push a new state, which is found in yystate. | -`------------------------------------------------------------*/ - yynewstate: - /* In all cases, when you get here, the value and location stacks - have just been pushed. So pushing a state here evens the stacks. */ - yyssp++; - - yysetstate: - *yyssp = yystate; - - if (yyss + yystacksize - 1 <= yyssp) - { - /* Get the current used size of the three stacks, in elements. */ - YYSIZE_T yysize = yyssp - yyss + 1; - -#ifdef yyoverflow - { - /* Give user a chance to reallocate the stack. Use copies of - these so that the &'s don't force the real ones into - memory. */ - YYSTYPE *yyvs1 = yyvs; - yytype_int16 *yyss1 = yyss; - - /* Each stack pointer address is followed by the size of the - data in use in that stack, in bytes. This used to be a - conditional around just the two extra args, but that might - be undefined if yyoverflow is a macro. */ - yyoverflow (YY_("memory exhausted"), - &yyss1, yysize * sizeof (*yyssp), - &yyvs1, yysize * sizeof (*yyvsp), - &yystacksize); - - yyss = yyss1; - yyvs = yyvs1; - } -#else /* no yyoverflow */ -# ifndef YYSTACK_RELOCATE - goto yyexhaustedlab; -# else - /* Extend the stack our own way. */ - if (YYMAXDEPTH <= yystacksize) - goto yyexhaustedlab; - yystacksize *= 2; - if (YYMAXDEPTH < yystacksize) - yystacksize = YYMAXDEPTH; - - { - yytype_int16 *yyss1 = yyss; - union yyalloc *yyptr = - (union yyalloc *) YYSTACK_ALLOC (YYSTACK_BYTES (yystacksize)); - if (! yyptr) - goto yyexhaustedlab; - YYSTACK_RELOCATE (yyss_alloc, yyss); - YYSTACK_RELOCATE (yyvs_alloc, yyvs); -# undef YYSTACK_RELOCATE - if (yyss1 != yyssa) - YYSTACK_FREE (yyss1); - } -# endif -#endif /* no yyoverflow */ - - yyssp = yyss + yysize - 1; - yyvsp = yyvs + yysize - 1; - - YYDPRINTF ((stderr, "Stack size increased to %lu\n", - (unsigned long int) yystacksize)); - - if (yyss + yystacksize - 1 <= yyssp) - YYABORT; - } - - YYDPRINTF ((stderr, "Entering state %d\n", yystate)); - - if (yystate == YYFINAL) - YYACCEPT; - - goto yybackup; - -/*-----------. -| yybackup. | -`-----------*/ -yybackup: - - /* Do appropriate processing given the current state. Read a - lookahead token if we need one and don't already have one. */ - - /* First try to decide what to do without reference to lookahead token. */ - yyn = yypact[yystate]; - if (yypact_value_is_default (yyn)) - goto yydefault; - - /* Not known => get a lookahead token if don't already have one. */ - - /* YYCHAR is either YYEMPTY or YYEOF or a valid lookahead symbol. */ - if (yychar == YYEMPTY) - { - YYDPRINTF ((stderr, "Reading a token: ")); - yychar = yylex (); - } - - if (yychar <= YYEOF) - { - yychar = yytoken = YYEOF; - YYDPRINTF ((stderr, "Now at end of input.\n")); - } - else - { - yytoken = YYTRANSLATE (yychar); - YY_SYMBOL_PRINT ("Next token is", yytoken, &yylval, &yylloc); - } - - /* If the proper action on seeing token YYTOKEN is to reduce or to - detect an error, take that action. */ - yyn += yytoken; - if (yyn < 0 || YYLAST < yyn || yycheck[yyn] != yytoken) - goto yydefault; - yyn = yytable[yyn]; - if (yyn <= 0) - { - if (yytable_value_is_error (yyn)) - goto yyerrlab; - yyn = -yyn; - goto yyreduce; - } - - /* Count tokens shifted since error; after three, turn off error - status. */ - if (yyerrstatus) - yyerrstatus--; - - /* Shift the lookahead token. */ - YY_SYMBOL_PRINT ("Shifting", yytoken, &yylval, &yylloc); - - /* Discard the shifted token. */ - yychar = YYEMPTY; - - yystate = yyn; - YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN - *++yyvsp = yylval; - YY_IGNORE_MAYBE_UNINITIALIZED_END - - goto yynewstate; - - -/*-----------------------------------------------------------. -| yydefault -- do the default action for the current state. | -`-----------------------------------------------------------*/ -yydefault: - yyn = yydefact[yystate]; - if (yyn == 0) - goto yyerrlab; - goto yyreduce; - - -/*-----------------------------. -| yyreduce -- Do a reduction. | -`-----------------------------*/ -yyreduce: - /* yyn is the number of a rule to reduce with. */ - yylen = yyr2[yyn]; - - /* If YYLEN is nonzero, implement the default value of the action: - '$$ = $1'. - - Otherwise, the following line sets YYVAL to garbage. - This behavior is undocumented and Bison - users should not rely upon it. Assigning to YYVAL - unconditionally makes the parser a bit smaller, and it avoids a - GCC warning that YYVAL may be used uninitialized. */ - yyval = yyvsp[1-yylen]; - - - YY_REDUCE_PRINT (yyn); - switch (yyn) - { - case 10: - - { zconf_error("unexpected end statement"); } - - break; - - case 11: - - { zconf_error("unknown statement "%s"", (yyvsp[-2].string)); } - - break; - - case 12: - - { - zconf_error("unexpected option "%s"", kconf_id_strings + (yyvsp[-2].id)->name); -} - - break; - - case 13: - - { zconf_error("invalid statement"); } - - break; - - case 29: - - { zconf_error("unknown option "%s"", (yyvsp[-2].string)); } - - break; - - case 30: - - { zconf_error("invalid option"); } - - break; - - case 31: - - { - struct symbol *sym = sym_lookup((yyvsp[-1].string), 0); - sym->flags |= SYMBOL_OPTIONAL; - menu_add_entry(sym); - printd(DEBUG_PARSE, "%s:%d:config %s\n", zconf_curname(), zconf_lineno(), (yyvsp[-1].string)); -} - - break; - - case 32: - - { - menu_end_entry(); - printd(DEBUG_PARSE, "%s:%d:endconfig\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 33: - - { - struct symbol *sym = sym_lookup((yyvsp[-1].string), 0); - sym->flags |= SYMBOL_OPTIONAL; - menu_add_entry(sym); - printd(DEBUG_PARSE, "%s:%d:menuconfig %s\n", zconf_curname(), zconf_lineno(), (yyvsp[-1].string)); -} - - break; - - case 34: - - { - if (current_entry->prompt) - current_entry->prompt->type = P_MENU; - else - zconfprint("warning: menuconfig statement without prompt"); - menu_end_entry(); - printd(DEBUG_PARSE, "%s:%d:endconfig\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 42: - - { - menu_set_type((yyvsp[-2].id)->stype); - printd(DEBUG_PARSE, "%s:%d:type(%u)\n", - zconf_curname(), zconf_lineno(), - (yyvsp[-2].id)->stype); -} - - break; - - case 43: - - { - menu_add_prompt(P_PROMPT, (yyvsp[-2].string), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:prompt\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 44: - - { - menu_add_expr(P_DEFAULT, (yyvsp[-2].expr), (yyvsp[-1].expr)); - if ((yyvsp[-3].id)->stype != S_UNKNOWN) - menu_set_type((yyvsp[-3].id)->stype); - printd(DEBUG_PARSE, "%s:%d:default(%u)\n", - zconf_curname(), zconf_lineno(), - (yyvsp[-3].id)->stype); -} - - break; - - case 45: - - { - menu_add_symbol(P_SELECT, sym_lookup((yyvsp[-2].string), 0), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:select\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 46: - - { - menu_add_symbol(P_IMPLY, sym_lookup((yyvsp[-2].string), 0), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:imply\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 47: - - { - menu_add_expr(P_RANGE, expr_alloc_comp(E_RANGE,(yyvsp[-3].symbol), (yyvsp[-2].symbol)), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:range\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 50: - - { - const struct kconf_id *id = kconf_id_lookup((yyvsp[-1].string), strlen((yyvsp[-1].string))); - if (id && id->flags & TF_OPTION) - menu_add_option(id->token, (yyvsp[0].string)); - else - zconfprint("warning: ignoring unknown option %s", (yyvsp[-1].string)); - free((yyvsp[-1].string)); -} - - break; - - case 51: - - { (yyval.string) = NULL; } - - break; - - case 52: - - { (yyval.string) = (yyvsp[0].string); } - - break; - - case 53: - - { - struct symbol *sym = sym_lookup((yyvsp[-1].string), SYMBOL_CHOICE); - sym->flags |= SYMBOL_AUTO; - menu_add_entry(sym); - menu_add_expr(P_CHOICE, NULL, NULL); - printd(DEBUG_PARSE, "%s:%d:choice\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 54: - - { - (yyval.menu) = menu_add_menu(); -} - - break; - - case 55: - - { - if (zconf_endtoken((yyvsp[0].id), T_CHOICE, T_ENDCHOICE)) { - menu_end_menu(); - printd(DEBUG_PARSE, "%s:%d:endchoice\n", zconf_curname(), zconf_lineno()); - } -} - - break; - - case 63: - - { - menu_add_prompt(P_PROMPT, (yyvsp[-2].string), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:prompt\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 64: - - { - if ((yyvsp[-2].id)->stype == S_BOOLEAN || (yyvsp[-2].id)->stype == S_TRISTATE) { - menu_set_type((yyvsp[-2].id)->stype); - printd(DEBUG_PARSE, "%s:%d:type(%u)\n", - zconf_curname(), zconf_lineno(), - (yyvsp[-2].id)->stype); - } else - YYERROR; -} - - break; - - case 65: - - { - current_entry->sym->flags |= SYMBOL_OPTIONAL; - printd(DEBUG_PARSE, "%s:%d:optional\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 66: - - { - if ((yyvsp[-3].id)->stype == S_UNKNOWN) { - menu_add_symbol(P_DEFAULT, sym_lookup((yyvsp[-2].string), 0), (yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:default\n", - zconf_curname(), zconf_lineno()); - } else - YYERROR; -} - - break; - - case 69: - - { - printd(DEBUG_PARSE, "%s:%d:if\n", zconf_curname(), zconf_lineno()); - menu_add_entry(NULL); - menu_add_dep((yyvsp[-1].expr)); - (yyval.menu) = menu_add_menu(); -} - - break; - - case 70: - - { - if (zconf_endtoken((yyvsp[0].id), T_IF, T_ENDIF)) { - menu_end_menu(); - printd(DEBUG_PARSE, "%s:%d:endif\n", zconf_curname(), zconf_lineno()); - } -} - - break; - - case 76: - - { - menu_add_prompt(P_MENU, (yyvsp[-1].string), NULL); -} - - break; - - case 77: - - { - menu_add_entry(NULL); - menu_add_prompt(P_MENU, (yyvsp[-1].string), NULL); - printd(DEBUG_PARSE, "%s:%d:menu\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 78: - - { - (yyval.menu) = menu_add_menu(); -} - - break; - - case 79: - - { - if (zconf_endtoken((yyvsp[0].id), T_MENU, T_ENDMENU)) { - menu_end_menu(); - printd(DEBUG_PARSE, "%s:%d:endmenu\n", zconf_curname(), zconf_lineno()); - } -} - - break; - - case 85: - - { - printd(DEBUG_PARSE, "%s:%d:source %s\n", zconf_curname(), zconf_lineno(), (yyvsp[-1].string)); - zconf_nextfile((yyvsp[-1].string)); -} - - break; - - case 86: - - { - menu_add_entry(NULL); - menu_add_prompt(P_COMMENT, (yyvsp[-1].string), NULL); - printd(DEBUG_PARSE, "%s:%d:comment\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 87: - - { - menu_end_entry(); -} - - break; - - case 88: - - { - printd(DEBUG_PARSE, "%s:%d:help\n", zconf_curname(), zconf_lineno()); - zconf_starthelp(); -} - - break; - - case 89: - - { - current_entry->help = (yyvsp[0].string); -} - - break; - - case 94: - - { - menu_add_dep((yyvsp[-1].expr)); - printd(DEBUG_PARSE, "%s:%d:depends on\n", zconf_curname(), zconf_lineno()); -} - - break; - - case 98: - - { - menu_add_visibility((yyvsp[0].expr)); -} - - break; - - case 100: - - { - menu_add_prompt(P_PROMPT, (yyvsp[-1].string), (yyvsp[0].expr)); -} - - break; - - case 103: - - { (yyval.id) = (yyvsp[-1].id); } - - break; - - case 104: - - { (yyval.id) = (yyvsp[-1].id); } - - break; - - case 105: - - { (yyval.id) = (yyvsp[-1].id); } - - break; - - case 108: - - { (yyval.expr) = NULL; } - - break; - - case 109: - - { (yyval.expr) = (yyvsp[0].expr); } - - break; - - case 110: - - { (yyval.expr) = expr_alloc_symbol((yyvsp[0].symbol)); } - - break; - - case 111: - - { (yyval.expr) = expr_alloc_comp(E_LTH, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 112: - - { (yyval.expr) = expr_alloc_comp(E_LEQ, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 113: - - { (yyval.expr) = expr_alloc_comp(E_GTH, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 114: - - { (yyval.expr) = expr_alloc_comp(E_GEQ, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 115: - - { (yyval.expr) = expr_alloc_comp(E_EQUAL, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 116: - - { (yyval.expr) = expr_alloc_comp(E_UNEQUAL, (yyvsp[-2].symbol), (yyvsp[0].symbol)); } - - break; - - case 117: - - { (yyval.expr) = (yyvsp[-1].expr); } - - break; - - case 118: - - { (yyval.expr) = expr_alloc_one(E_NOT, (yyvsp[0].expr)); } - - break; - - case 119: - - { (yyval.expr) = expr_alloc_two(E_OR, (yyvsp[-2].expr), (yyvsp[0].expr)); } - - break; - - case 120: - - { (yyval.expr) = expr_alloc_two(E_AND, (yyvsp[-2].expr), (yyvsp[0].expr)); } - - break; - - case 121: - - { (yyval.symbol) = sym_lookup((yyvsp[0].string), 0); free((yyvsp[0].string)); } - - break; - - case 122: - - { (yyval.symbol) = sym_lookup((yyvsp[0].string), SYMBOL_CONST); free((yyvsp[0].string)); } - - break; - - case 123: - - { (yyval.string) = NULL; } - - break; - - - - default: break; - } - /* User semantic actions sometimes alter yychar, and that requires - that yytoken be updated with the new translation. We take the - approach of translating immediately before every use of yytoken. - One alternative is translating here after every semantic action, - but that translation would be missed if the semantic action invokes - YYABORT, YYACCEPT, or YYERROR immediately after altering yychar or - if it invokes YYBACKUP. In the case of YYABORT or YYACCEPT, an - incorrect destructor might then be invoked immediately. In the - case of YYERROR or YYBACKUP, subsequent parser actions might lead - to an incorrect destructor call or verbose syntax error message - before the lookahead is translated. */ - YY_SYMBOL_PRINT ("-> $$ =", yyr1[yyn], &yyval, &yyloc); - - YYPOPSTACK (yylen); - yylen = 0; - YY_STACK_PRINT (yyss, yyssp); - - *++yyvsp = yyval; - - /* Now 'shift' the result of the reduction. Determine what state - that goes to, based on the state we popped back to and the rule - number reduced by. */ - - yyn = yyr1[yyn]; - - yystate = yypgoto[yyn - YYNTOKENS] + *yyssp; - if (0 <= yystate && yystate <= YYLAST && yycheck[yystate] == *yyssp) - yystate = yytable[yystate]; - else - yystate = yydefgoto[yyn - YYNTOKENS]; - - goto yynewstate; - - -/*--------------------------------------. -| yyerrlab -- here on detecting error. | -`--------------------------------------*/ -yyerrlab: - /* Make sure we have latest lookahead translation. See comments at - user semantic actions for why this is necessary. */ - yytoken = yychar == YYEMPTY ? YYEMPTY : YYTRANSLATE (yychar); - - /* If not already recovering from an error, report this error. */ - if (!yyerrstatus) - { - ++yynerrs; -#if ! YYERROR_VERBOSE - yyerror (YY_("syntax error")); -#else -# define YYSYNTAX_ERROR yysyntax_error (&yymsg_alloc, &yymsg, \ - yyssp, yytoken) - { - char const *yymsgp = YY_("syntax error"); - int yysyntax_error_status; - yysyntax_error_status = YYSYNTAX_ERROR; - if (yysyntax_error_status == 0) - yymsgp = yymsg; - else if (yysyntax_error_status == 1) - { - if (yymsg != yymsgbuf) - YYSTACK_FREE (yymsg); - yymsg = (char *) YYSTACK_ALLOC (yymsg_alloc); - if (!yymsg) - { - yymsg = yymsgbuf; - yymsg_alloc = sizeof yymsgbuf; - yysyntax_error_status = 2; - } - else - { - yysyntax_error_status = YYSYNTAX_ERROR; - yymsgp = yymsg; - } - } - yyerror (yymsgp); - if (yysyntax_error_status == 2) - goto yyexhaustedlab; - } -# undef YYSYNTAX_ERROR -#endif - } - - - - if (yyerrstatus == 3) - { - /* If just tried and failed to reuse lookahead token after an - error, discard it. */ - - if (yychar <= YYEOF) - { - /* Return failure if at end of input. */ - if (yychar == YYEOF) - YYABORT; - } - else - { - yydestruct ("Error: discarding", - yytoken, &yylval); - yychar = YYEMPTY; - } - } - - /* Else will try to reuse lookahead token after shifting the error - token. */ - goto yyerrlab1; - - -/*---------------------------------------------------. -| yyerrorlab -- error raised explicitly by YYERROR. | -`---------------------------------------------------*/ -yyerrorlab: - - /* Pacify compilers like GCC when the user code never invokes - YYERROR and the label yyerrorlab therefore never appears in user - code. */ - if (/*CONSTCOND*/ 0) - goto yyerrorlab; - - /* Do not reclaim the symbols of the rule whose action triggered - this YYERROR. */ - YYPOPSTACK (yylen); - yylen = 0; - YY_STACK_PRINT (yyss, yyssp); - yystate = *yyssp; - goto yyerrlab1; - - -/*-------------------------------------------------------------. -| yyerrlab1 -- common code for both syntax error and YYERROR. | -`-------------------------------------------------------------*/ -yyerrlab1: - yyerrstatus = 3; /* Each real token shifted decrements this. */ - - for (;;) - { - yyn = yypact[yystate]; - if (!yypact_value_is_default (yyn)) - { - yyn += YYTERROR; - if (0 <= yyn && yyn <= YYLAST && yycheck[yyn] == YYTERROR) - { - yyn = yytable[yyn]; - if (0 < yyn) - break; - } - } - - /* Pop the current state because it cannot handle the error token. */ - if (yyssp == yyss) - YYABORT; - - - yydestruct ("Error: popping", - yystos[yystate], yyvsp); - YYPOPSTACK (1); - yystate = *yyssp; - YY_STACK_PRINT (yyss, yyssp); - } - - YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN - *++yyvsp = yylval; - YY_IGNORE_MAYBE_UNINITIALIZED_END - - - /* Shift the error token. */ - YY_SYMBOL_PRINT ("Shifting", yystos[yyn], yyvsp, yylsp); - - yystate = yyn; - goto yynewstate; - - -/*-------------------------------------. -| yyacceptlab -- YYACCEPT comes here. | -`-------------------------------------*/ -yyacceptlab: - yyresult = 0; - goto yyreturn; - -/*-----------------------------------. -| yyabortlab -- YYABORT comes here. | -`-----------------------------------*/ -yyabortlab: - yyresult = 1; - goto yyreturn; - -#if !defined yyoverflow || YYERROR_VERBOSE -/*-------------------------------------------------. -| yyexhaustedlab -- memory exhaustion comes here. | -`-------------------------------------------------*/ -yyexhaustedlab: - yyerror (YY_("memory exhausted")); - yyresult = 2; - /* Fall through. */ -#endif - -yyreturn: - if (yychar != YYEMPTY) - { - /* Make sure we have latest lookahead translation. See comments at - user semantic actions for why this is necessary. */ - yytoken = YYTRANSLATE (yychar); - yydestruct ("Cleanup: discarding lookahead", - yytoken, &yylval); - } - /* Do not reclaim the symbols of the rule whose action triggered - this YYABORT or YYACCEPT. */ - YYPOPSTACK (yylen); - YY_STACK_PRINT (yyss, yyssp); - while (yyssp != yyss) - { - yydestruct ("Cleanup: popping", - yystos[*yyssp], yyvsp); - YYPOPSTACK (1); - } -#ifndef yyoverflow - if (yyss != yyssa) - YYSTACK_FREE (yyss); -#endif -#if YYERROR_VERBOSE - if (yymsg != yymsgbuf) - YYSTACK_FREE (yymsg); -#endif - return yyresult; -} - - - -void conf_parse(const char *name) -{ - struct symbol *sym; - int i; - - zconf_initscan(name); - - sym_init(); - _menu_init(); - rootmenu.prompt = menu_add_prompt(P_MENU, "Linux Kernel Configuration", NULL); - - if (getenv("ZCONF_DEBUG")) - zconfdebug = 1; - zconfparse(); - if (zconfnerrs) - exit(1); - if (!modules_sym) - modules_sym = sym_find( "n" ); - - rootmenu.prompt->text = _(rootmenu.prompt->text); - rootmenu.prompt->text = sym_expand_string_value(rootmenu.prompt->text); - - menu_finalize(&rootmenu); - for_all_symbols(i, sym) { - if (sym_check_deps(sym)) - zconfnerrs++; - } - if (zconfnerrs) - exit(1); - sym_set_change_count(1); -} - -static const char *zconf_tokenname(int token) -{ - switch (token) { - case T_MENU: return "menu"; - case T_ENDMENU: return "endmenu"; - case T_CHOICE: return "choice"; - case T_ENDCHOICE: return "endchoice"; - case T_IF: return "if"; - case T_ENDIF: return "endif"; - case T_DEPENDS: return "depends"; - case T_VISIBLE: return "visible"; - } - return "<token>"; -} - -static bool zconf_endtoken(const struct kconf_id *id, int starttoken, int endtoken) -{ - if (id->token != endtoken) { - zconf_error("unexpected '%s' within %s block", - kconf_id_strings + id->name, zconf_tokenname(starttoken)); - zconfnerrs++; - return false; - } - if (current_menu->file != current_file) { - zconf_error("'%s' in different file than '%s'", - kconf_id_strings + id->name, zconf_tokenname(starttoken)); - fprintf(stderr, "%s:%d: location of the '%s'\n", - current_menu->file->name, current_menu->lineno, - zconf_tokenname(starttoken)); - zconfnerrs++; - return false; - } - return true; -} - -static void zconfprint(const char *err, ...) -{ - va_list ap; - - fprintf(stderr, "%s:%d: ", zconf_curname(), zconf_lineno()); - va_start(ap, err); - vfprintf(stderr, err, ap); - va_end(ap); - fprintf(stderr, "\n"); -} - -static void zconf_error(const char *err, ...) -{ - va_list ap; - - zconfnerrs++; - fprintf(stderr, "%s:%d: ", zconf_curname(), zconf_lineno()); - va_start(ap, err); - vfprintf(stderr, err, ap); - va_end(ap); - fprintf(stderr, "\n"); -} - -static void zconferror(const char *err) -{ - fprintf(stderr, "%s:%d: %s\n", zconf_curname(), zconf_lineno() + 1, err); -} - -static void print_quoted_string(FILE *out, const char *str) -{ - const char *p; - int len; - - putc('"', out); - while ((p = strchr(str, '"'))) { - len = p - str; - if (len) - fprintf(out, "%.*s", len, str); - fputs("\"", out); - str = p + 1; - } - fputs(str, out); - putc('"', out); -} - -static void print_symbol(FILE *out, struct menu *menu) -{ - struct symbol *sym = menu->sym; - struct property *prop; - - if (sym_is_choice(sym)) - fprintf(out, "\nchoice\n"); - else - fprintf(out, "\nconfig %s\n", sym->name); - switch (sym->type) { - case S_BOOLEAN: - fputs(" boolean\n", out); - break; - case S_TRISTATE: - fputs(" tristate\n", out); - break; - case S_STRING: - fputs(" string\n", out); - break; - case S_INT: - fputs(" integer\n", out); - break; - case S_HEX: - fputs(" hex\n", out); - break; - default: - fputs(" ???\n", out); - break; - } - for (prop = sym->prop; prop; prop = prop->next) { - if (prop->menu != menu) - continue; - switch (prop->type) { - case P_PROMPT: - fputs(" prompt ", out); - print_quoted_string(out, prop->text); - if (!expr_is_yes(prop->visible.expr)) { - fputs(" if ", out); - expr_fprint(prop->visible.expr, out); - } - fputc('\n', out); - break; - case P_DEFAULT: - fputs( " default ", out); - expr_fprint(prop->expr, out); - if (!expr_is_yes(prop->visible.expr)) { - fputs(" if ", out); - expr_fprint(prop->visible.expr, out); - } - fputc('\n', out); - break; - case P_CHOICE: - fputs(" #choice value\n", out); - break; - case P_SELECT: - fputs( " select ", out); - expr_fprint(prop->expr, out); - fputc('\n', out); - break; - case P_IMPLY: - fputs( " imply ", out); - expr_fprint(prop->expr, out); - fputc('\n', out); - break; - case P_RANGE: - fputs( " range ", out); - expr_fprint(prop->expr, out); - fputc('\n', out); - break; - case P_MENU: - fputs( " menu ", out); - print_quoted_string(out, prop->text); - fputc('\n', out); - break; - default: - fprintf(out, " unknown prop %d!\n", prop->type); - break; - } - } - if (menu->help) { - int len = strlen(menu->help); - while (menu->help[--len] == '\n') - menu->help[len] = 0; - fprintf(out, " help\n%s\n", menu->help); - } -} - -void zconfdump(FILE *out) -{ - struct property *prop; - struct symbol *sym; - struct menu *menu; - - menu = rootmenu.list; - while (menu) { - if ((sym = menu->sym)) - print_symbol(out, menu); - else if ((prop = menu->prompt)) { - switch (prop->type) { - case P_COMMENT: - fputs("\ncomment ", out); - print_quoted_string(out, prop->text); - fputs("\n", out); - break; - case P_MENU: - fputs("\nmenu ", out); - print_quoted_string(out, prop->text); - fputs("\n", out); - break; - default: - ; - } - if (!expr_is_yes(prop->visible.expr)) { - fputs(" depends ", out); - expr_fprint(prop->visible.expr, out); - fputc('\n', out); - } - } - - if (menu->list) - menu = menu->list; - else if (menu->next) - menu = menu->next; - else while ((menu = menu->parent)) { - if (menu->prompt && menu->prompt->type == P_MENU) - fputs("\nendmenu\n", out); - if (menu->next) { - menu = menu->next; - break; - } - } - } -} - -#include "zconf.lex.c" -#include "util.c" -#include "confdata.c" -#include "expr.c" -#include "symbol.c" -#include "menu.c" diff --git a/scripts/kconfig/zconf.y b/scripts/kconfig/zconf.y index 001305fa080b..ad6305b0f40c 100644 --- a/scripts/kconfig/zconf.y +++ b/scripts/kconfig/zconf.y @@ -20,10 +20,10 @@
-extern int zconflex(void); +int yylex(void); +static void yyerror(const char *err); static void zconfprint(const char *err, ...); static void zconf_error(const char *err, ...); -static void zconferror(const char *err); static bool zconf_endtoken(const struct kconf_id *id, int starttoken, int endtoken);
struct symbol *symbol_hash[SYMBOL_HASHSIZE]; @@ -85,6 +85,7 @@ static struct menu *current_menu, *current_entry; %nonassoc T_NOT
%type <string> prompt +%type <symbol> nonconst_symbol %type <symbol> symbol %type <expr> expr %type <expr> if_expr @@ -101,14 +102,34 @@ static struct menu *current_menu, *current_entry; } if_entry menu_entry choice_entry
%{ -/* Include zconf.hash.c here so it can see the token constants. */ -#include "zconf.hash.c" +/* Include kconf_id.c here so it can see the token constants. */ +#include "kconf_id.c" %}
%% input: nl start | start;
-start: mainmenu_stmt stmt_list | stmt_list; +start: mainmenu_stmt stmt_list | no_mainmenu_stmt stmt_list; + +/* mainmenu entry */ + +mainmenu_stmt: T_MAINMENU prompt nl +{ + menu_add_prompt(P_MENU, $2, NULL); +}; + +/* Default main menu, if there's no mainmenu entry */ + +no_mainmenu_stmt: /* empty */ +{ + /* + * Hack: Keep the main menu title on the heap so we can safely free it + * later regardless of whether it comes from the 'prompt' in + * mainmenu_stmt or here + */ + menu_add_prompt(P_MENU, xstrdup("Linux Kernel Configuration"), NULL); +}; +
stmt_list: /* empty */ @@ -119,7 +140,7 @@ stmt_list: | stmt_list T_WORD error T_EOL { zconf_error("unknown statement "%s"", $2); } | stmt_list option_name error T_EOL { - zconf_error("unexpected option "%s"", kconf_id_strings + $2->name); + zconf_error("unexpected option "%s"", $2->name); } | stmt_list error T_EOL { zconf_error("invalid statement"); } ; @@ -145,26 +166,23 @@ option_error:
/* config/menuconfig entry */
-config_entry_start: T_CONFIG T_WORD T_EOL +config_entry_start: T_CONFIG nonconst_symbol T_EOL { - struct symbol *sym = sym_lookup($2, 0); - sym->flags |= SYMBOL_OPTIONAL; - menu_add_entry(sym); - printd(DEBUG_PARSE, "%s:%d:config %s\n", zconf_curname(), zconf_lineno(), $2); + $2->flags |= SYMBOL_OPTIONAL; + menu_add_entry($2); + printd(DEBUG_PARSE, "%s:%d:config %s\n", zconf_curname(), zconf_lineno(), $2->name); };
config_stmt: config_entry_start config_option_list { - menu_end_entry(); printd(DEBUG_PARSE, "%s:%d:endconfig\n", zconf_curname(), zconf_lineno()); };
-menuconfig_entry_start: T_MENUCONFIG T_WORD T_EOL +menuconfig_entry_start: T_MENUCONFIG nonconst_symbol T_EOL { - struct symbol *sym = sym_lookup($2, 0); - sym->flags |= SYMBOL_OPTIONAL; - menu_add_entry(sym); - printd(DEBUG_PARSE, "%s:%d:menuconfig %s\n", zconf_curname(), zconf_lineno(), $2); + $2->flags |= SYMBOL_OPTIONAL; + menu_add_entry($2); + printd(DEBUG_PARSE, "%s:%d:menuconfig %s\n", zconf_curname(), zconf_lineno(), $2->name); };
menuconfig_stmt: menuconfig_entry_start config_option_list @@ -173,7 +191,6 @@ menuconfig_stmt: menuconfig_entry_start config_option_list current_entry->prompt->type = P_MENU; else zconfprint("warning: menuconfig statement without prompt"); - menu_end_entry(); printd(DEBUG_PARSE, "%s:%d:endconfig\n", zconf_curname(), zconf_lineno()); };
@@ -211,15 +228,15 @@ config_option: T_DEFAULT expr if_expr T_EOL $1->stype); };
-config_option: T_SELECT T_WORD if_expr T_EOL +config_option: T_SELECT nonconst_symbol if_expr T_EOL { - menu_add_symbol(P_SELECT, sym_lookup($2, 0), $3); + menu_add_symbol(P_SELECT, $2, $3); printd(DEBUG_PARSE, "%s:%d:select\n", zconf_curname(), zconf_lineno()); };
-config_option: T_IMPLY T_WORD if_expr T_EOL +config_option: T_IMPLY nonconst_symbol if_expr T_EOL { - menu_add_symbol(P_IMPLY, sym_lookup($2, 0), $3); + menu_add_symbol(P_IMPLY, $2, $3); printd(DEBUG_PARSE, "%s:%d:imply\n", zconf_curname(), zconf_lineno()); };
@@ -237,8 +254,10 @@ symbol_option_list: | symbol_option_list T_WORD symbol_option_arg { const struct kconf_id *id = kconf_id_lookup($2, strlen($2)); - if (id && id->flags & TF_OPTION) + if (id && id->flags & TF_OPTION) { menu_add_option(id->token, $3); + free($3); + } else zconfprint("warning: ignoring unknown option %s", $2); free($2); @@ -257,6 +276,7 @@ choice: T_CHOICE word_opt T_EOL sym->flags |= SYMBOL_AUTO; menu_add_entry(sym); menu_add_expr(P_CHOICE, NULL, NULL); + free($2); printd(DEBUG_PARSE, "%s:%d:choice\n", zconf_curname(), zconf_lineno()); };
@@ -308,10 +328,10 @@ choice_option: T_OPTIONAL T_EOL printd(DEBUG_PARSE, "%s:%d:optional\n", zconf_curname(), zconf_lineno()); };
-choice_option: T_DEFAULT T_WORD if_expr T_EOL +choice_option: T_DEFAULT nonconst_symbol if_expr T_EOL { if ($1->stype == S_UNKNOWN) { - menu_add_symbol(P_DEFAULT, sym_lookup($2, 0), $3); + menu_add_symbol(P_DEFAULT, $2, $3); printd(DEBUG_PARSE, "%s:%d:default\n", zconf_curname(), zconf_lineno()); } else @@ -351,13 +371,6 @@ if_block: | if_block choice_stmt ;
-/* mainmenu entry */ - -mainmenu_stmt: T_MAINMENU prompt nl -{ - menu_add_prompt(P_MENU, $2, NULL); -}; - /* menu entry */
menu: T_MENU prompt T_EOL @@ -394,6 +407,7 @@ source_stmt: T_SOURCE prompt T_EOL { printd(DEBUG_PARSE, "%s:%d:source %s\n", zconf_curname(), zconf_lineno(), $2); zconf_nextfile($2); + free($2); };
/* comment entry */ @@ -406,9 +420,7 @@ comment: T_COMMENT prompt T_EOL };
comment_stmt: comment depends_list -{ - menu_end_entry(); -}; +;
/* help option */
@@ -420,6 +432,17 @@ help_start: T_HELP T_EOL
help: help_start T_HELPTEXT { + if (current_entry->help) { + free(current_entry->help); + zconfprint("warning: '%s' defined with more than one help text -- only the last one will be used", + current_entry->sym->name ?: "<choice>"); + } + + /* Is the help text empty or all whitespace? */ + if ($2[strspn($2, " \f\n\r\t\v")] == '\0') + zconfprint("warning: '%s' defined with blank help text", + current_entry->sym->name ?: "<choice>"); + current_entry->help = $2; };
@@ -491,7 +514,10 @@ expr: symbol { $$ = expr_alloc_symbol($1); } | expr T_AND expr { $$ = expr_alloc_two(E_AND, $1, $3); } ;
-symbol: T_WORD { $$ = sym_lookup($1, 0); free($1); } +/* For symbol definitions, selects, etc., where quotes are not accepted */ +nonconst_symbol: T_WORD { $$ = sym_lookup($1, 0); free($1); }; + +symbol: nonconst_symbol | T_WORD_QUOTE { $$ = sym_lookup($1, SYMBOL_CONST); free($1); } ;
@@ -502,6 +528,7 @@ word_opt: /* empty */ { $$ = NULL; }
void conf_parse(const char *name) { + const char *tmp; struct symbol *sym; int i;
@@ -509,25 +536,26 @@ void conf_parse(const char *name)
sym_init(); _menu_init(); - rootmenu.prompt = menu_add_prompt(P_MENU, "Linux Kernel Configuration", NULL);
if (getenv("ZCONF_DEBUG")) - zconfdebug = 1; - zconfparse(); - if (zconfnerrs) + yydebug = 1; + yyparse(); + if (yynerrs) exit(1); if (!modules_sym) modules_sym = sym_find( "n" );
+ tmp = rootmenu.prompt->text; rootmenu.prompt->text = _(rootmenu.prompt->text); rootmenu.prompt->text = sym_expand_string_value(rootmenu.prompt->text); + free((char*)tmp);
menu_finalize(&rootmenu); for_all_symbols(i, sym) { if (sym_check_deps(sym)) - zconfnerrs++; + yynerrs++; } - if (zconfnerrs) + if (yynerrs) exit(1); sym_set_change_count(1); } @@ -551,17 +579,17 @@ static bool zconf_endtoken(const struct kconf_id *id, int starttoken, int endtok { if (id->token != endtoken) { zconf_error("unexpected '%s' within %s block", - kconf_id_strings + id->name, zconf_tokenname(starttoken)); - zconfnerrs++; + id->name, zconf_tokenname(starttoken)); + yynerrs++; return false; } if (current_menu->file != current_file) { zconf_error("'%s' in different file than '%s'", - kconf_id_strings + id->name, zconf_tokenname(starttoken)); + id->name, zconf_tokenname(starttoken)); fprintf(stderr, "%s:%d: location of the '%s'\n", current_menu->file->name, current_menu->lineno, zconf_tokenname(starttoken)); - zconfnerrs++; + yynerrs++; return false; } return true; @@ -582,7 +610,7 @@ static void zconf_error(const char *err, ...) { va_list ap;
- zconfnerrs++; + yynerrs++; fprintf(stderr, "%s:%d: ", zconf_curname(), zconf_lineno()); va_start(ap, err); vfprintf(stderr, err, ap); @@ -590,7 +618,7 @@ static void zconf_error(const char *err, ...) fprintf(stderr, "\n"); }
-static void zconferror(const char *err) +static void yyerror(const char *err) { fprintf(stderr, "%s:%d: %s\n", zconf_curname(), zconf_lineno() + 1, err); } @@ -623,7 +651,7 @@ static void print_symbol(FILE *out, struct menu *menu) fprintf(out, "\nconfig %s\n", sym->name); switch (sym->type) { case S_BOOLEAN: - fputs(" boolean\n", out); + fputs(" bool\n", out); break; case S_TRISTATE: fputs(" tristate\n", out);
After importing linux v4.16-rc1 commit 2c37e08464a8 ("kconfig: Warn if choice default is not in choice"), Kconfig complains:
scripts/kconfig/conf --syncconfig Kconfig board/eets/pdu001/Kconfig:22:warning: \ choice default symbol 'PDU001_RUN_LED_RED' \ is not contained in the choice
This looks to be caused by a typo. Fix it.
Fixes: 85ab0452fefc ("arm: add support for PDU001") Signed-off-by: Eugeniu Rosca erosca@de.adit-jv.com --- board/eets/pdu001/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/eets/pdu001/Kconfig b/board/eets/pdu001/Kconfig index f28ba6e7bff2..e64ae28875b1 100644 --- a/board/eets/pdu001/Kconfig +++ b/board/eets/pdu001/Kconfig @@ -19,7 +19,7 @@ config SYS_CONFIG_NAME
choice prompt "State of Run LED" - default PDU001_RUN_LED_RED + default RUN_LED_RED help The PDU001 has a bi-color (red/green) LED labeled 'Run' which can be used to indicate the operating state of the board. By
2018-05-12 8:40 GMT+09:00 Eugeniu Rosca erosca@de.adit-jv.com:
Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com
Hi Eugeniu,
Thanks for your great job!
Almost looks good to me except one missed re-sync. See below.
Align Kconfig to Linux 4.17-rc4 with minimal impact on non-kconfig files.
Previous Kconfig sync was done by commit bf7ab1e70fd762 ("kconfig: re-sync with Linux 4.10") and it achieved almost perfect alignment with a few (intended) exceptions, caused by below U-boot commits:
[A] v2015.04 5f9eb2207500 ("kbuild: remove scripts/multiconfig.sh") [B] v2015.07 20c20826efab ("Kconfig: Enable usage of escape char '' in string values") [C] v2016.01 da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") [D] v2016.03 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") [E] v2016.03 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.")
Here is the list of Kconfig commits which followed the v4.10 alignment:
[F] v2018.01 0931ed3c0d0f ("kconfig/symbol.c: use correct pointer type argument for sizeof") [G] v2018.03 1414e09b4f25 ("kconfig: revert change that was not needed for -Wformat-security") [H] v2018.05 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style")
Commit [F] was subsequently applied to Linux kernel as commit [I] with the same patch id, so it won't contribute to further misalignment.
[I] v4.15-rc1 88127dae6ed9 ("kconfig/symbol.c: use correct pointer type argument for sizeof")
Commit [G] is a Kconfig-specific revert of commit [E]. Commit [H] relocated and reformatted the license doing no functional change.
In summary, the only functional change that makes U-boot Kconfig diverge from Linux Kconfig is commit [B]. After a brief analysis, the purpose of [B] seems to be placing "\n" literals in string symbols like CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" in order to pass them directly to printf and expect correct output at runtime. Currently, Linux doesn't seem to have this requirement, so for the moment [B] looks like a U-boot specific feature/fix. From point of view of further Kconfig alignment and backporting efforts, it is highly desired that commits like [B] are propagated to Linux and any Kconfig fixes/features are contributed to Linux kernel first. This specific Kconfig re-sync just keeps [B] in place.
Contrary to 4.10 Kconfig re-sync (which achieves zero non-kconfig changes), 4.17-rc4 re-sync does some amount of updates in Kbuild (striving to keep them at minimum), due to a number of reasons:
- Kbuild is affected by the removal of Kconfig "*shipped" files and now requires flex and bison pre-installed on the host.
- PYTHON{2,3} variables are defined in top-level Makefile as prerequisite for running the newly developed Kconfig unit tests.
- silentoldconfig becomes an "internal implementation detail" deprecated for external use, being renamed to syncconfig.
The exact non-kconfig files touched by this commit are:
$ git show --format="" --stat -- ':!scripts/kconfig' .gitignore | 2 ++ Makefile | 9 +++++++-- scripts/Makefile.build | 11 +++++++++++ scripts/Makefile.lib | 41 ++++++++++++-----------------------------
The imported Linux commits touching the above files are:
c054be10ffdbd5 ("remove gperf left-overs from build system") 73a4f6dbe70a1b ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ("kbuild: prepare to remove C files pre-generated by flex and bison") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 911a91c39cabcb H ("kconfig: rename silentoldconfig to syncconfig") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e H ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 H ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") e9781b52d4e0e3 H ("kbuild: add PYTHON2 and PYTHON3 variables")
The commits marked with 'H' are assessed as "hard" (build will fail) prerequisites and the rest of them are assessed as "soft" prerequisites for the re-sync. In spite of relatively high number of non-H commits, they belong to this Kconfig update topic-wise and decrease the number of cherry pick conflicts for many commits in this series. Additional effort can be put in eliminating the soft prerequisites, if really needed.
The commits which contributed to this Kconfig re-sync are listed below. Whenever a conflict resolution has been performed (mostly by hand, but sometimes automatically by git), it is revealed by the '!' sign in the second column, which means a patch id mismatch between Linux and U-boot commits:
9be3213b14d44f ("gconfig: remove misleading parentheses around a condition") ff85a1a80e0034 ("kconfig: Check for libncurses before menuconfig") ad8181060788c8 ("kconfig: fix sparse warnings in nconfig") cb77f0d623ff33 ! ("scripts: Switch to more portable Perl shebang") bb3290d91695bb ! ("Remove gperf usage from toolchain") c054be10ffdbd5 ("remove gperf left-overs from build system") b24413180f5600 ! ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") 9059a3493efea6 ! ("kconfig: fix relational operators for bool and tristate symbols") 2c37e08464a850 ("kconfig: Warn if choice default is not in choice") 33ca1a24866373 ("kconfig: Document the 'menu' struct") 52aede4ba5efd1 ("kconfig: Document the 'symbol' struct") c873443430ebd1 ("kconfig: Sync zconf.y with zconf.tab.c_shipped") 9a826842ff2fbd ("kconfig: Rename menu_check_dep() to rewrite_m()") fa8cedaef814ce ("kconfig: Clarify expression rewriting") f77850d3fe0c96 ("kconfig: Clean up modules handling and fix crash") e3b03bf29d6b99 ("kconfig: display recursive dependency resolution hint just once") 73a4f6dbe70a1b ! ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ! ("kbuild: prepare to remove C files pre-generated by flex and bison") 29c833061c1d8c ("kconfig: generate lexer and parser during build instead of shipping") 26e47a3c11a25c ("kconfig: Don't leak symbol names during parsing") 24161a6711c945 ("kconfig: Don't leak 'source' filenames during parsing") bc28fe1d5ede88 ("kconfig: Don't leak 'option' arguments during parsing") 0724a7c32a54e3 ("kconfig: Don't leak main menus during parsing") ae7440ef0c8013 ("kconfig: Fix automatic menu creation mem leak") 5b1374b3b3c2fc ("kconfig: Fix expr_free() E_NOT leak") 7cf33f88e29410 ("kconfig: Fix choice symbol expression leak") 05cccce580456d ("kconfig: Document automatic submenu creation code") 0735f7e5def2ab ("kconfig: Document important expression functions") df60f4b92d3d0b ("kconfig: Remove menu_end_entry()") b92d804a51796b ("kconfig: drop 'boolean' keyword") 6479f327dea60d ("kconfig: Warn if there is more than one help text") 52e58a3caeba5d ("kconfig: make input_mode static") 5a3dc717b3c785 ("kconfig: make xfgets() really static") 84dd95d4f87a0d ("kconfig: make conf_unsaved a local variable of conf_read()") 765f4cdef6f80d ("kconfig: use default 'yy' prefix for lexer and parser") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ! ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 3e41ba05b6d60c ("kconfig: Document SYMBOL_OPTIONAL logic") d3465af60f4471 ("kconfig: Clarify choice dependency propagation") 9d1a9e8bc18bea ("kconfig: Document 'if' flattening logic") b53688014e3325 ("kconfig: Clarify menu and 'if' dependency propagation") d0fd0428ecf04b ("kconfig: fix make xconfig when gettext is missing") 312ee68752faaa ("kconfig: announce removal of oldnoconfig if used") 1ccb27143360bd ("kconfig: make "Selected by:" and "Implied by:" readable") cedd55d49dee94 ! ("kconfig: Remove silentoldconfig from help and docs; fix kconfig/conf's help") 1b9eda2e4892cb ("kconfig: Warn if help text is blank") cb67ab2cd2b8ab ("kconfig: do not write choice values when their dependency becomes n") 4f208f392103e8 ("kconfig: show '?' prompt even if no help text is available") cd58a91def2acc ("kconfig: remove 'config*' pattern from .gitignnore") d2a04648a5dbc3 ("kconfig: remove check_stdin()") f3ff6fb5db68bc ("kconfig: echo stdin to stdout if either is redirected") 9e3e10c725360b ("kconfig: send error messages to stderr") d717f24d8c6808 ("kconfig: add xrealloc() helper") 523ca58b7db2e3 ("kconfig: remove const qualifier from sym_expand_string_value()") cd81fc82b93fa4 ("kconfig: add xstrdup() helper") f4bc1eefc1608e ("kconfig: set SYMBOL_AUTO to the symbol marked with defconfig_list") bf0bbdcf100322 ("kconfig: Don't leak choice names during parsing") 1a90ce36c6eff6 ("kconfig: Update ncurses package names for menuconfig") 5ae6fcc4bb82bd ("kconfig: fix line number in recursive inclusion error message") 07a422bb213adb ! ("kbuild: restore autoksyms.h touch to the top Makefile") 9a47ceec543bfb ("kconfig: clean-up reverse dependency help implementation") d9119b5925a03b ("kconfig: Print reverse dependencies in groups") f467c5640c29ad ("kconfig: only write '# CONFIG_FOO is not set' for visible symbols") 59a80b5e892dde ("kconfig: do not call check_conf() for olddefconfig") 4bb3a5b085cd6f ("kconfig: remove unneeded input_mode test in conf()") 99f0b6578bab44 ("kconfig: remove redundant input_mode test for check_conf() loop") 2aad9b89621386 ("kconfig: hide irrelevant sub-menus for oldconfig") 81d2bc2273052e ("kconfig: invoke oldconfig instead of silentoldconfig from local*config") 911a91c39cabcb ! ("kconfig: rename silentoldconfig to syncconfig") 2a61625835c7c8 ! ("kconfig: remove redundant streamline_config.pl prerequisite") 022a4bf6b59dfd ("kconfig: tests: add framework for Kconfig unit testing") 1903c511905984 ("kconfig: tests: add basic choice tests") 49ac3c0c3aa3b7 ("kconfig: tests: test automatic submenu creation") b76960c0f6b25d ("kconfig: tests: test if new symbols in choice are asked") 930c429a656fdb ("kconfig: tests: check unneeded "is not set" with unmet dependency") ee236610653ede ("kconfig: tests: check visibility of tristate choice values in y choice") beaaddb625400e ("kconfig: tests: test defconfig when two choices interact") 3e4888c2e3d77d ("kconfig: tests: test randconfig for choice in choice") 29c434f367ea7b ("kconfig: tests: test if recursive dependencies are detected") e2c75e7667c737 ("kconfig: tests: test if recursive inclusion is detected") f622f827958162 ("kconfig: warn unmet direct dependency of tristate symbols selected by y") f8f69dc0b4e070 ("kconfig: make unmet dependency warnings readable") 26561514cc9def ("kconfig: do not include both curses.h and ncurses.h for nconfig") 32a94b8b0c3e5a ("kconfig: remove duplicated file name and lineno of recursive inclusion") 379a8eb8eb1a55 ("kconfig: detect recursive inclusion earlier") 18492685e479fd ("kconfig: use yylineno option instead of manual lineno increments") 59889300274569 ! (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ! ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e ! ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 ! ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 17baab68d337a0 ("kconfig: extend output of 'listnewconfig'") e9781b52d4e0e3 ! ("kbuild: add PYTHON2 and PYTHON3 variables")
The current Kconfig update generates below build-time warnings: YACC scripts/dtc/dtc-parser.tab.h scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] YACC scripts/dtc/dtc-parser.tab.c scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr]
This seems to happen because the Kbuild updates apparently didn't make room for both "*shipped"-based builds and flex/bison-based builds. A similar problem has been reported for genksyms parser in v4.17-rc1 commit 833e622459432e ("genksyms: generate lexer and parser during build instead of shipping"). I have figured out empirically that the warnings are healed after updating the in-tree U-boot DTC to upstream v1.4.6-9, same as done by Linux v4.17-rc1 commit 9130ba88464032 ("scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987"). Whether fixing the DTC-related yacc warnings should be done together with the Kconfig re-sync, I would like to hear from community.
I agree.
Re-sync of scripts/dtc/ should follow.
# Help text used by make help help: @echo ' config - Update current config utilising a line-oriented program' @@ -152,7 +169,6 @@ help: @echo ' oldconfig - Update current config utilising a provided .config as base' @echo ' localmodconfig - Update current config disabling modules not loaded' @echo ' localyesconfig - Update current config converting local mods to core'
@echo ' silentoldconfig - Same as oldconfig, but quietly, additionally update deps' @echo ' defconfig - New config with default from ARCH supplied defconfig' @echo ' savedefconfig - Save current config as ./defconfig (minimal config)' @echo ' allnoconfig - New config where all options are answered with no'
@@ -161,7 +177,7 @@ help: @echo ' alldefconfig - New config with all symbols set to default' @echo ' randconfig - New config with random answer to all options' @echo ' listnewconfig - List new options'
@echo ' olddefconfig - Same as silentoldconfig but sets new symbols to their'
@echo ' olddefconfig - Same as oldconfig but sets new symbols to their' @echo ' default value'
Linux commit cedd55d49dee added 'without prompting' after 'default value'
Could you do likewise please?
The other parts look good to me.
Hi Masahiro,
I agree.
Included in v2.
Missed that one! Fixed in v2. Thanks!
Best regards, Eugeniu.
Eugeniu Rosca
Eugeniu Rosca
Masahiro Yamada
