[U-Boot-Users] [PATCH] 83xx: Add Vitesse VSC7385 firmware uploading
The Vitesse VSC7385 is a 5-port switch found on the Freescale MPC8349E-mITX and other boards. A small firwmare must be uploaded to its on-board memory before it can be enabled. This patch adds the code which uploads firmware (but not the firmware itself) and updates the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB boards to use that code.
Previously, this feature was provided by a U-Boot application that was made available only on Freescale BSPs. The VSC7385 firmware must still be obtained separately, but at least there is no longer a need for a separate application.
Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET. Also cleaned up the board header files to make selecting the VSC7385 easier to control.
Signed-off-by: Timur Tabi timur@freescale.com ---
This patch is for U-Boot 1.3.3
board/freescale/mpc8313erdb/mpc8313erdb.c | 21 ++++++ board/freescale/mpc8349itx/mpc8349itx.c | 15 ++++- board/freescale/mpc837xerdb/mpc837xerdb.c | 27 ++++++-- drivers/net/Makefile | 1 + drivers/net/vsc7385.c | 100 +++++++++++++++++++++++++++++ include/configs/MPC8313ERDB.h | 88 +++++++++++++++++-------- include/configs/MPC8349ITX.h | 33 +++++++--- include/configs/MPC837XERDB.h | 83 ++++++++++++++++-------- include/vsc7385.h | 13 ++++ 9 files changed, 310 insertions(+), 71 deletions(-) create mode 100644 drivers/net/vsc7385.c create mode 100644 include/vsc7385.h
diff --git a/board/freescale/mpc8313erdb/mpc8313erdb.c b/board/freescale/mpc8313erdb/mpc8313erdb.c index 42019fb..7cbdb7b 100644 --- a/board/freescale/mpc8313erdb/mpc8313erdb.c +++ b/board/freescale/mpc8313erdb/mpc8313erdb.c @@ -28,6 +28,7 @@ #endif #include <pci.h> #include <mpc83xx.h> +#include <vsc7385.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -98,6 +99,26 @@ void pci_init_board(void) mpc83xx_pci_init(1, reg, warmboot); }
+/* + * Miscellaneous late-boot configurations + * + * If a VSC7385 microcode image is present, then upload it. +*/ +int misc_init_r(void) +{ + int rc = 0; + +#ifdef CONFIG_VSC7385_IMAGE + if (vsc7385_upload_firmware((void *) CONFIG_VSC7385_IMAGE, + CONFIG_VSC7385_IMAGE_SIZE)) { + puts("Failure uploading VSC7385 microcode.\n"); + rc = 1; + } +#endif + + return rc; +} + #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/freescale/mpc8349itx/mpc8349itx.c b/board/freescale/mpc8349itx/mpc8349itx.c index 8c19ad6..5571248 100644 --- a/board/freescale/mpc8349itx/mpc8349itx.c +++ b/board/freescale/mpc8349itx/mpc8349itx.c @@ -26,6 +26,7 @@ #include <i2c.h> #include <spd.h> #include <miiphy.h> +#include <vsc7385.h>
#ifdef CONFIG_PCI #include <asm/mpc8349_pci.h> @@ -183,7 +184,7 @@ int checkboard(void) */ int misc_init_f(void) { -#ifdef CONFIG_VSC7385 +#ifdef CONFIG_VSC7385_ENET volatile u32 *vsc7385_cpuctrl;
/* 0x1c0c0 is the VSC7385 CPU Control (CPUCTRL) Register. The power up @@ -245,6 +246,8 @@ int misc_init_f(void) }
/* + * Miscellaneous late-boot configurations + * * Make sure the EEPROM has the HRCW correctly programmed. * Make sure the RTC is correctly programmed. * @@ -256,6 +259,8 @@ int misc_init_f(void) * * This function makes sure that the I2C EEPROM is programmed * correctly. + * + * If a VSC7385 microcode image is present, then upload it. */ int misc_init_r(void) { @@ -381,6 +386,14 @@ int misc_init_r(void) i2c_set_bus_num(orig_bus); #endif
+#ifdef CONFIG_VSC7385_IMAGE + if (vsc7385_upload_firmware((void *) CONFIG_VSC7385_IMAGE, + CONFIG_VSC7385_IMAGE_SIZE)) { + puts("Failure uploading VSC7385 microcode.\n"); + rc = 1; + } +#endif + return rc; }
diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 2d42595..1ab7be4 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -16,6 +16,8 @@ #include <i2c.h> #include <spd.h> #include <asm/io.h> +#include <vsc7385.h> + #if defined(CONFIG_SPD_EEPROM) #include <spd_sdram.h> #endif @@ -59,11 +61,6 @@ testdram(void) } #endif
-int board_early_init_f(void) -{ - return 0; -} - #if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRC) void ddr_enable_ecc(unsigned int dram_size); #endif @@ -138,6 +135,26 @@ int checkboard(void) return 0; }
void ft_board_setup(void *blob, bd_t *bd) diff --git a/drivers/net/Makefile b/drivers/net/Makefile index b9723fa..5ae7cb7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -57,6 +57,7 @@ COBJS-y += tigon3.o COBJS-y += tsec.o COBJS-y += tsi108_eth.o COBJS-y += uli526x.o +COBJS-y += vsc7385.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/vsc7385.c b/drivers/net/vsc7385.c new file mode 100644 index 0000000..39b077f --- /dev/null +++ b/drivers/net/vsc7385.c @@ -0,0 +1,100 @@ +/* + * Vitesse 7385 Switch Firmware Upload + * + * Author: Timur Tabi timur@freescale.com + * + * Copyright 2008 Freescale Semiconductor, Inc. This file is licensed + * under the terms of the GNU General Public License version 2. This + * program is licensed "as is" without any warranty of any kind, whether + * express or implied. + * + * This module uploads proprietary firmware for the Vitesse VSC7385 5-port + * switch. + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> + +#ifdef CONFIG_VSC7385_ENET + +/* + * Upload a Vitesse VSC7385 firmware image to the hardware + * + * This function takes a pointer to a VSC7385 firmware image and a size, and + * uploads that firmware to the VSC7385. + * + * This firmware is typically located at a board-specific flash address, + * and the size is typically 8KB. + * + * The firmware is Vitesse proprietary. + * + * Further details on the register information can be obtained from Vitesse. + */ +int vsc7385_upload_firmware(void *firmware, unsigned int size) +{ + u8 *fw = firmware; + + u32 *gloreset = (u32 *) (CFG_VSC7385_BASE + 0x1c050); + u32 *icpu_ctrl = (u32 *) (CFG_VSC7385_BASE + 0x1c040); + u32 *icpu_addr = (u32 *) (CFG_VSC7385_BASE + 0x1c044); + u32 *icpu_data = (u32 *) (CFG_VSC7385_BASE + 0x1c048); + u32 *chipid = (u32 *) (CFG_VSC7385_BASE + 0x1c060); + u32 *icpu_rom_map = (u32 *) (CFG_VSC7385_BASE + 0x1c070); + + unsigned int i; + int ret = 0; + + out_be32(gloreset, 3); + udelay(200); + + out_be32(icpu_ctrl, 142); + udelay(20); + + out_be32(icpu_rom_map, 1); + udelay(20); + + /* Write the firmware to I-RAM */ + out_be32(icpu_addr, 0); + udelay(20); + + for (i = 0; i < size; i++) { + out_be32(icpu_data, fw[i]); + udelay(20); + if (ctrlc()) + return -EINTR; + } + + /* Read back and compare */ + out_be32(icpu_addr, 0); + udelay(20); + + for (i = 0; i < size; i++) { + u8 value; + + value = (u8) in_be32(icpu_data); + udelay(20); + if (value != fw[i]) { + debug("VSC7385: Upload mismatch: address 0x%x, " + "read value 0x%x, image value 0x%x\n", + i, value, fw[i]); + + return -EIO; + } + if (ctrlc()) + break; + } + + out_be32(icpu_ctrl, 11); + udelay(20); + +#ifdef DEBUG + printf("VSC7385: Chip ID is %08x\n", in_be32(chipid)); + udelay(20); +#endif + + return 0; +} + +#endif diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index f12a3e6..9576fa5 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -38,6 +38,14 @@ #define CONFIG_PCI #define CONFIG_83XX_GENERIC_PCI
+#define CONFIG_MISC_INIT_R + +/* + * On-board devices + */ +#define CONFIG_VSC7385_ENET + + #ifdef CFG_66MHZ #define CONFIG_83XX_CLKIN 66666667 /* in Hz */ #elif defined(CFG_33MHZ) @@ -65,6 +73,22 @@ #define CFG_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */
/* + * Device configurations + */ + +/* Vitesse 7385 */ + +#ifdef CONFIG_VSC7385_ENET + +#define CONFIG_TSEC2 + +/* The flash address and size of the VSC7385 firmware image */ +#define CONFIG_VSC7385_IMAGE 0xFE7FE000 +#define CONFIG_VSC7385_IMAGE_SIZE 8192 + +#endif + +/* * DDR Setup */ #define CFG_DDR_BASE 0x00000000 /* DDR is system memory*/ @@ -214,19 +238,24 @@ #define CFG_LBLAWBAR1_PRELIM CFG_NAND_BASE #define CFG_LBLAWAR1_PRELIM 0x8000000E /* 32KB */
+/* local bus read write buffer mapping */ +#define CFG_BR3_PRELIM 0xFA000801 /* map at 0xFA000000 */ +#define CFG_OR3_PRELIM 0xFFFF8FF7 /* 32kB */ +#define CFG_LBLAWBAR3_PRELIM 0xFA000000 +#define CFG_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ + +/* Vitesse 7385 */ + #define CFG_VSC7385_BASE 0xF0000000
-#define CONFIG_VSC7385_ENET /* VSC7385 ethernet support */ +#ifdef CONFIG_VSC7385_ENET + #define CFG_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ #define CFG_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ #define CFG_LBLAWBAR2_PRELIM CFG_VSC7385_BASE/* Access window base at VSC7385 base */ #define CFG_LBLAWAR2_PRELIM 0x80000010 /* Access window size 128K */
-/* local bus read write buffer mapping */ -#define CFG_BR3_PRELIM 0xFA000801 /* map at 0xFA000000 */ -#define CFG_OR3_PRELIM 0xFFFF8FF7 /* 32kB */ -#define CFG_LBLAWBAR3_PRELIM 0xFA000000 -#define CFG_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +#endif
/* pass open firmware flat tree */ #define CONFIG_OF_LIBFDT 1 @@ -263,13 +292,6 @@ #define CFG_I2C_OFFSET 0x3000 #define CFG_I2C2_OFFSET 0x3100
-/* TSEC */ -#define CFG_TSEC1_OFFSET 0x24000 -#define CFG_TSEC1 (CFG_IMMR+CFG_TSEC1_OFFSET) -#define CFG_TSEC2_OFFSET 0x25000 -#define CFG_TSEC2 (CFG_IMMR+CFG_TSEC2_OFFSET) -#define CONFIG_NET_MULTI - /* * General PCI * Addresses are mapped 1-1. @@ -288,26 +310,31 @@ #define CFG_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */
/* - * TSEC configuration + * TSEC */ #define CONFIG_TSEC_ENET /* TSEC ethernet support */
-#ifndef CONFIG_NET_MULTI -#define CONFIG_NET_MULTI 1 -#endif - -#define CONFIG_GMII 1 /* MII PHY management */ -#define CONFIG_TSEC1 1 +#define CONFIG_NET_MULTI +#define CONFIG_GMII /* MII PHY management */
+#ifdef CONFIG_TSEC1 +#define CONFIG_HAS_ETH0 #define CONFIG_TSEC1_NAME "TSEC0" -#define CONFIG_TSEC2 1 +#define CFG_TSEC1_OFFSET 0x24000 +#define TSEC1_PHY_ADDR 0x1c +#define TSEC1_FLAGS TSEC_GIGABIT +#define TSEC1_PHYIDX 0 +#endif + +#ifdef CONFIG_TSEC2 +#define CONFIG_HAS_ETH1 #define CONFIG_TSEC2_NAME "TSEC1" -#define TSEC1_PHY_ADDR 0x1c -#define TSEC2_PHY_ADDR 4 -#define TSEC1_FLAGS TSEC_GIGABIT -#define TSEC2_FLAGS TSEC_GIGABIT -#define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 +#define CFG_TSEC2_OFFSET 0x25000 +#define TSEC2_PHY_ADDR 4 +#define TSEC2_FLAGS TSEC_GIGABIT +#define TSEC2_PHYIDX 0 +#endif +
/* Options are: TSEC[0-1] */ #define CONFIG_ETHPRIME "TSEC1" @@ -496,10 +523,13 @@ */ #define CONFIG_ENV_OVERWRITE
+#ifdef CONFIG_HAS_ETH0 #define CONFIG_ETHADDR 00:E0:0C:00:95:01 -#define CONFIG_HAS_ETH1 -#define CONFIG_HAS_ETH0 +#endif + +#ifdef CONFIG_HAS_ETH1 #define CONFIG_ETH1ADDR 00:E0:0C:00:95:02 +#endif
#define CONFIG_IPADDR 10.0.0.2 #define CONFIG_SERVERIP 10.0.0.1 diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 48c2736..0e50186 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -68,12 +68,16 @@
#define CFG_IMMR 0xE0000000 /* The IMMR is relocated to here */
+#define CONFIG_MISC_INIT_F +#define CONFIG_MISC_INIT_R
-/* On-board devices */ +/* + * On-board devices + */
#ifdef CONFIG_MPC8349ITX #define CONFIG_COMPACT_FLASH /* The CF card interface on the back of the board */ -#define CONFIG_VSC7385 /* The Vitesse 7385 5-port switch */ +#define CONFIG_VSC7385_ENET /* VSC7385 ethernet support */ #endif
#define CONFIG_PCI @@ -88,9 +92,6 @@ /* I2C */ #ifdef CONFIG_HARD_I2C
-#define CONFIG_MISC_INIT_F -#define CONFIG_MISC_INIT_R - #define CONFIG_FSL_I2C #define CONFIG_I2C_MULTI_BUS #define CONFIG_I2C_CMD_TREE @@ -190,6 +191,18 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CFG_FLASH_SIZE 16 /* FLASH size in MB */ #define CFG_FLASH_SIZE_SHIFT 4 /* log2 of the above value */
+/* Vitesse 7385 */ + +#ifdef CONFIG_VSC7385_ENET + +#define CONFIG_TSEC2 + +/* The flash address and size of the VSC7385 firmware image */ +#define CONFIG_VSC7385_IMAGE 0xFEFFE000 +#define CONFIG_VSC7385_IMAGE_SIZE 8192 + +#endif + /* * BRx, ORx, LBLAWBARx, and LBLAWARx */ @@ -205,10 +218,10 @@ boards, we say we have two, but don't display a message if we find only one. */
/* Vitesse 7385 */
-#ifdef CONFIG_VSC7385 - #define CFG_VSC7385_BASE 0xF8000000
+#ifdef CONFIG_VSC7385_ENET + #define CFG_BR1_PRELIM (CFG_VSC7385_BASE | BR_PS_8 | BR_V) #define CFG_OR1_PRELIM (OR_AM_128KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX | \ @@ -384,7 +397,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_HAS_ETH1 #define CONFIG_TSEC2_NAME "TSEC1" #define CFG_TSEC2_OFFSET 0x25000 -#define CONFIG_UNKNOWN_TSEC /* TSEC2 is proprietary */ + #define TSEC2_PHY_ADDR 4 #define TSEC2_PHYIDX 0 #define TSEC2_FLAGS TSEC_GIGABIT @@ -619,11 +632,11 @@ boards, we say we have two, but don't display a message if we find only one. */ */ #define CONFIG_ENV_OVERWRITE
-#ifdef CONFIG_TSEC1 +#ifdef CONFIG_HAS_ETH0 #define CONFIG_ETHADDR 00:E0:0C:00:8C:01 #endif
-#ifdef CONFIG_TSEC2 +#ifdef CONFIG_HAS_ETH1 #define CONFIG_ETH1ADDR 00:E0:0C:00:8C:02 #endif
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 2da4f29..066197f 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -32,6 +32,14 @@
#define CONFIG_PCI 1
+#define CONFIG_MISC_INIT_R + +/* + * On-board devices + */ +#define CONFIG_TSEC_ENET /* TSEC Ethernet support */ +#define CONFIG_VSC7385_ENET + /* * System Clock Setup */ @@ -118,6 +126,22 @@ #define CFG_IMMR 0xE0000000
/* + * Device configurations + */ + +/* Vitesse 7385 */ + +#ifdef CONFIG_VSC7385_ENET + +#define CONFIG_TSEC2 + +/* The flash address and size of the VSC7385 firmware image */ +#define CONFIG_VSC7385_IMAGE 0xFE7FE000 +#define CONFIG_VSC7385_IMAGE_SIZE 8192 + +#endif + +/* * DDR Setup */ #define CFG_DDR_BASE 0x00000000 /* DDR is system memory */ @@ -251,15 +275,19 @@ #define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-/* VSC7385 Gigabit Switch support */ -#define CONFIG_VSC7385_ENET +#ifdef CONFIG_VSC7385_ENET + #define CFG_BR2_PRELIM 0xf0000801 /* Base address */ #define CFG_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ #define CFG_LBLAWBAR2_PRELIM CFG_VSC7385_BASE /* Access Base */ #define CFG_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */
+#endif + /* * Serial Port */ @@ -324,43 +352,43 @@ #define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */
-#undef CONFIG_EEPRO100 #undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CFG_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */ #endif /* CONFIG_PCI */
-#ifndef CONFIG_NET_MULTI -#define CONFIG_NET_MULTI 1 -#endif - /* * TSEC */ -#define CONFIG_TSEC_ENET /* TSEC ethernet support */ -#define CFG_TSEC1_OFFSET 0x24000 -#define CFG_TSEC1 (CFG_IMMR+CFG_TSEC1_OFFSET) -#define CFG_TSEC2_OFFSET 0x25000 -#define CFG_TSEC2 (CFG_IMMR+CFG_TSEC2_OFFSET) +#ifdef CONFIG_TSEC_ENET
-/* - * TSEC ethernet configuration - */ -#define CONFIG_GMII 1 /* MII PHY management */ -#define CONFIG_TSEC1 1 +#define CONFIG_NET_MULTI +#define CONFIG_GMII /* MII PHY management */ + +#define CONFIG_TSEC1 + +#ifdef CONFIG_TSEC1 +#define CONFIG_HAS_ETH0 #define CONFIG_TSEC1_NAME "TSEC0" -#define CONFIG_TSEC2 1 -#define CONFIG_TSEC2_NAME "TSEC1" +#define CFG_TSEC1_OFFSET 0x24000 #define TSEC1_PHY_ADDR 2 -#define TSEC2_PHY_ADDR 0x1c #define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) -#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) #define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 +#endif
+#ifdef CONFIG_TSEC2 +#define CONFIG_HAS_ETH1 +#define CONFIG_TSEC2_NAME "TSEC1" +#define CFG_TSEC2_OFFSET 0x25000 +#define TSEC2_PHY_ADDR 0x1c +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_PHYIDX 0 +#endif
/* Options are: TSEC[0-1] */ #define CONFIG_ETHPRIME "TSEC0"
+#endif + /* * Environment */ @@ -529,10 +557,13 @@ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_HAS_ETH0 /* add support for "ethaddr" */ -#define CONFIG_ETHADDR 00:04:9f:ef:04:01 -#define CONFIG_HAS_ETH1 /* add support for "eth1addr" */ -#define CONFIG_ETH1ADDR 00:04:9f:ef:04:02 +#ifdef CONFIG_HAS_ETH0 +#define CONFIG_ETHADDR 00:04:9f:ef:04:01 +#endif + +#ifdef CONFIG_HAS_ETH1 +#define CONFIG_ETH1ADDR 00:04:9f:ef:04:02 +#endif
#define CONFIG_IPADDR 10.0.0.2 #define CONFIG_SERVERIP 10.0.0.1 diff --git a/include/vsc7385.h b/include/vsc7385.h new file mode 100644 index 0000000..0432499 --- /dev/null +++ b/include/vsc7385.h @@ -0,0 +1,13 @@ +/* + * Header file for vsc7385.c + * + * Author: Timur Tabi timur@freescale.com + * + * Copyright 2008 Freescale Semiconductor, Inc. This file is licensed + * under the terms of the GNU General Public License version 2. This + * program is licensed "as is" without any warranty of any kind, whether + * express or implied. + */ + +int vsc7385_upload_firmware(void *firmware, unsigned int size); +
I'd prefer firmware uploading bits remain apps (perhaps in examples/?) but I don't know the "U-Boot Philosophy" for this area..
drivers/net bits go through net maintainer, Ben Warren (separate patch).
- Vitesse 7385 Switch Firmware Upload
- Author: Timur Tabi timur@freescale.com
- Copyright 2008 Freescale Semiconductor, Inc. This file is licensed
- under the terms of the GNU General Public License version 2. This
- program is licensed "as is" without any warranty of any kind, whether
- express or implied.
- This module uploads proprietary firmware for the Vitesse VSC7385 5-port
- switch.
This breaks some archs.
- Upload a Vitesse VSC7385 firmware image to the hardware
- This function takes a pointer to a VSC7385 firmware image and a size, and
- uploads that firmware to the VSC7385.
- This firmware is typically located at a board-specific flash address,
- and the size is typically 8KB.
- The firmware is Vitesse proprietary.
- Further details on the register information can be obtained from Vitesse.
- u8 *fw = firmware;
- u32 *gloreset = (u32 *) (CFG_VSC7385_BASE + 0x1c050);
- u32 *icpu_ctrl = (u32 *) (CFG_VSC7385_BASE + 0x1c040);
- u32 *icpu_addr = (u32 *) (CFG_VSC7385_BASE + 0x1c044);
- u32 *icpu_data = (u32 *) (CFG_VSC7385_BASE + 0x1c048);
- u32 *chipid = (u32 *) (CFG_VSC7385_BASE + 0x1c060);
- u32 *icpu_rom_map = (u32 *) (CFG_VSC7385_BASE + 0x1c070);
- unsigned int i;
- int ret = 0;
- out_be32(gloreset, 3);
- udelay(200);
- out_be32(icpu_ctrl, 142);
- udelay(20);
- out_be32(icpu_rom_map, 1);
- udelay(20);
- out_be32(icpu_addr, 0);
- udelay(20);
- for (i = 0; i < size; i++) {
udelay(20);
if (ctrlc())
return -EINTR;
- /* Read back and compare */
- udelay(20);
u8 value;
udelay(20);
i, value, fw[i]);
return -EIO;
if (ctrlc())
break;
- out_be32(icpu_ctrl, 11);
- udelay(20);
+#ifdef DEBUG
- printf("VSC7385: Chip ID is %08x\n", in_be32(chipid));
- udelay(20);
who is the original author of this code?
Kim
The whole point behind this patch is to get rid of the currently application and make this a native feature of U-Boot.
In this regard, it is no different than my QE firmware patch.
I can break it into two patches.
Which ones? How? These header files look pretty harmless to me. What if I did this:
#include <config.h>
#include <common.h> #include <asm/io.h> #include <asm/errno.h>
One of our BSP developers. I took the code from his application and cleaned it up.
When loading the firmare is required (or desirable) in U-Boot, it should be integral part of U-Boot. Loading the switch FW might be needed for network operations in U-Boot, so it makes sense to me to add this to regular U-Boot code.
Hi Timur,
Just some nit-picking...
Is this switch able to pass traffic in a default configuration without this firmware or is it dead? <snip>
I'm not 100% convinced that this is network code, but my opinion isn't very strong and I can't really think of a better place (maybe device/misc or device/non_free?)
- switch.
I think Kim mentioned this will break some architectures. Just repeating it.
It looks to me that the data bus is 8 bits. Why are you defining registers as 32 bits and using 32-bit accessors?
- unsigned int i;
- int ret = 0;
- udelay(200);
When you write to the device, can you express the value in hex? It's quicker for the reader (who has Vitesse datasheets, of course) to figure out what you're doing.
- udelay(20);
- udelay(20);
- udelay(20);
udelay(20);
if (ctrlc())
return -EINTR;
- udelay(20);
u8 value;
udelay(20);
i, value, fw[i]);
return -EIO;
if (ctrlc())
break;
- udelay(20);
+#ifdef DEBUG
- udelay(20);
- On-board devices
- Device configurations
+/* Vitesse 7385 */
- DDR Setup
Like here, bits 19-20 are 01, meaning an 8-bit port
+/* Vitesse 7385 */
- General PCI
- Addresses are mapped 1-1.
- TSEC configuration
- TSEC
- On-board devices
+/* Vitesse 7385 */
- BRx, ORx, LBLAWBARx, and LBLAWARx
/* Vitesse 7385 */
Here you use mnemonics for describing the base register settings. I know it's not new code, but it would be nice to be consistent
- On-board devices
- System Clock Setup
+/* Vitesse 7385 */
- DDR Setup
+/* Vitesse 7385 */
- Serial Port
- TSEC
- TSEC ethernet configuration
- Environment
- Header file for vsc7385.c
Without the firmware, the switch is completely dead.
I'll move it to device/misc if you want. device/non_free doesn't exist so I don't want to create it.
Yeah, I'm still waiting for someone to tell me why. In the meantime, I've done this:
#include <config.h>
Beats me. The programming for this chip is really weird, the documentation is under NDA, and I didn't write the original code. Mine is a little prettier than the original (http://www.bitshrine.org/gpp/u-boot-1.2.0-mpc837xerdb-vsc7385-load.patch), but I'm not going to change the actual I/O operations.
Sure, I'll change it.
All of the Freescale header files could be scrubbed. I figured I was already making enough changes. They *should* be using mnemonics for everything.
Not every architecture has an io.h and an errno.h.
-Scott
OK, good to know. What a lovely feature.
Don't worry about it. drivers/net is OK
#include <config.h>
The problem is that you're artificially making this a PowerPC-only part. If you used 8-bit accessors endianness wouldn't matter and other architectures could use this without changes (notwithstanding the #includes...)
Cool, thanks.
Problem certainly not limited to Freescale code :)
Ok, I will try to figure out how to make 8-bit accesses work. I'll post an update later this week.
Thanks buddy. It should be pretty easy. Sorry for making this such a long and drawn-out process.
regards, Ben
participants (5)
Ben Warren
Kim Phillips
Scott Wood
Timur Tabi
