[PATCH 0/1] Add update available flag along with bootcount
From: Gireesh Hiremath Gireesh.Hiremath@in.bosch.com
By adding update_avalibale flag we wanted control the increment of bootcount, update_available flag is set from user space when there is upgrade in software which allow to increment of bootcount, otherwise no increment in the bootcount. Update_available and bootcount will be cleared after every successful boot from user space
version byte to handle the version number. to provide backward compatibility initial version number is 2.
RTC second scratch register[32-bit]: -zero byte hold boot count value -first byte hold update available state -second byte hold version -third byte hold magic number
Gireesh Hiremath (1): am335x, guardian: software update available status is stored in AM3352 RTC scracth register
configs/am335x_guardian_defconfig | 1 + drivers/bootcount/Kconfig | 27 ++++++++++++-- drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount_nvmem.c | 57 +++++++++++++++++++++++++++++ 4 files changed, 83 insertions(+), 3 deletions(-) create mode 100644 drivers/bootcount/bootcount_nvmem.c
Signed-off-by: Gireesh Hiremath Gireesh.Hiremath@in.bosch.com
Gbp-Pq: Topic apertis/guardian Gbp-Pq: Name am335x-guardian-software-update-available-status-is-store.patch --- configs/am335x_guardian_defconfig | 1 + drivers/bootcount/Kconfig | 27 ++++++++++++-- drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount_nvmem.c | 57 +++++++++++++++++++++++++++++ 4 files changed, 83 insertions(+), 3 deletions(-) create mode 100644 drivers/bootcount/bootcount_nvmem.c
diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index b5d8d80d14..c8336a8256 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -71,6 +71,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_SPL_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_AM33XX_NVMEM=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index b5ccea0d9c..d543061233 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -42,6 +42,25 @@ config BOOTCOUNT_AM33XX This requires the RTC clocks, etc, to be enabled prior to use and not all boards with this IP block on it will have the RTC in use.
+config BOOTCOUNT_AM33XX_NVMEM + bool "Boot counter in AM33XX RTC IP block with upgrade_available flag" + depends on AM33XX + select SPL_AM33XX_ENABLE_RTC32K_OSC if AM33XX + help + Add support for maintaining bootcount,upgrade_available, + version and BOOTMAGIC in a AM33xx RTC IP block + scratch register2. + + A bootcount driver for the RTC IP block found on many TI platforms. + This requires the RTC clocks, etc, to be enabled prior to use and + not all boards with this IP block on it will have the RTC in use. + + If there is upgrade in software then "upgrade_available" is 1, + "bootcount" is incremented otherwise "upgrade_available" and + "bootcount" is always 0. So the Userspace Application must set + the "upgrade_available" and "bootcount" variable to 0, if a boot + was successfully. + config BOOTCOUNT_ENV bool "Boot counter in environment" help @@ -177,16 +196,18 @@ config SYS_BOOTCOUNT_EXT_NAME
config SYS_BOOTCOUNT_ADDR hex "RAM address used for reading and writing the boot counter" - default 0x44E3E000 if BOOTCOUNT_AM33XX + default 0x44E3E000 if BOOTCOUNT_AM33XX || BOOTCOUNT_AM33XX_NVMEM default 0xE0115FF8 if ARCH_LS1043A || ARCH_LS1021A depends on BOOTCOUNT_AM33XX || BOOTCOUNT_GENERIC || BOOTCOUNT_EXT || \ - BOOTCOUNT_I2C + BOOTCOUNT_I2C || BOOTCOUNT_AM33XX_NVMEM help Set the address used for reading and writing the boot counter.
config SYS_BOOTCOUNT_MAGIC hex "Magic value for the boot counter" - default 0xB001C041 + default 0xB001C041 if BOOTCOUNT_AM33XX + default 0xB0 if BOOTCOUNT_AM33XX_NVMEM + depends on BOOTCOUNT_AM33XX || BOOTCOUNT_AM33XX_NVMEM help Set the magic value used for the boot counter.
diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index 51d860b00e..12658ffdce 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o obj-$(CONFIG_BOOTCOUNT_ENV) += bootcount_env.o obj-$(CONFIG_BOOTCOUNT_I2C) += bootcount_i2c.o obj-$(CONFIG_BOOTCOUNT_EXT) += bootcount_ext.o +obj-$(CONFIG_BOOTCOUNT_AM33XX_NVMEM) += bootcount_nvmem.o
obj-$(CONFIG_DM_BOOTCOUNT) += bootcount-uclass.o obj-$(CONFIG_DM_BOOTCOUNT_RTC) += rtc.o diff --git a/drivers/bootcount/bootcount_nvmem.c b/drivers/bootcount/bootcount_nvmem.c new file mode 100644 index 0000000000..5f266d5ec8 --- /dev/null +++ b/drivers/bootcount/bootcount_nvmem.c @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * (C) Copyright 2018 Robert Bosch Power Tools GmbH. + * + * A bootcount driver for the RTC IP block found on many TI platforms. + * This requires the RTC clocks, etc, to be enabled prior to use and + * not all boards with this IP block on it will have the RTC in use. + */ + +#include <bootcount.h> +#include <asm/davinci_rtc.h> + +#define BC_VERSION 2 + +void bootcount_store(ulong bootcount) +{ + u8 upgrade_available = 0; + ulong val = 0; + struct davinci_rtc *reg = + (struct davinci_rtc *)CONFIG_SYS_BOOTCOUNT_ADDR; + + val = raw_bootcount_load(®->scratch2); + upgrade_available = (val >> 8) & 0x000000ff; + + /* Only update bootcount during upgrade process */ + if (!upgrade_available) + bootcount = 0; + + val = (bootcount & 0x000000ff) | + (upgrade_available << 8) | + (BC_VERSION << 16) | + (CONFIG_SYS_BOOTCOUNT_MAGIC << 24); + + /* + * write RTC kick registers to enable write + * for RTC Scratch registers. Scratch register 2 is + * used for bootcount value. + */ + writel(RTC_KICK0R_WE, ®->kick0r); + writel(RTC_KICK1R_WE, ®->kick1r); + raw_bootcount_store(®->scratch2, val); +} + +ulong bootcount_load(void) +{ + unsigned long val = 0; + struct davinci_rtc *reg = + (struct davinci_rtc *)CONFIG_SYS_BOOTCOUNT_ADDR; + + val = raw_bootcount_load(®->scratch2); + if ((val >> 24) != CONFIG_SYS_BOOTCOUNT_MAGIC) + return 0; + else + return val & 0x000000ff; +}
Hmm..not sure what this is..
Cover letter is not needed for a single patch btw.
Please split driver and defconfig changes.
- bool "Boot counter in AM33XX RTC IP block with upgrade_available flag"
- depends on AM33XX
- help
scratch register2.
was successfully.
Isn't it possible to re-use drivers/bootcount/bootcount_davinci.c?
Thanks and regards, Lokesh
- default 0x44E3E000 if BOOTCOUNT_AM33XX || BOOTCOUNT_AM33XX_NVMEM default 0xE0115FF8 if ARCH_LS1043A || ARCH_LS1021A depends on BOOTCOUNT_AM33XX || BOOTCOUNT_GENERIC || BOOTCOUNT_EXT || \
BOOTCOUNT_I2C
help Set the address used for reading and writing the boot counter.BOOTCOUNT_I2C || BOOTCOUNT_AM33XX_NVMEM
- default 0xB001C041 if BOOTCOUNT_AM33XX
- default 0xB0 if BOOTCOUNT_AM33XX_NVMEM
- depends on BOOTCOUNT_AM33XX || BOOTCOUNT_AM33XX_NVMEM help Set the magic value used for the boot counter.
- (C) Copyright 2011
- Heiko Schocher, DENX Software Engineering, hs@denx.de.
- (C) Copyright 2018 Robert Bosch Power Tools GmbH.
- A bootcount driver for the RTC IP block found on many TI platforms.
- This requires the RTC clocks, etc, to be enabled prior to use and
- not all boards with this IP block on it will have the RTC in use.
- u8 upgrade_available = 0;
- ulong val = 0;
- struct davinci_rtc *reg =
- val = raw_bootcount_load(®->scratch2);
- upgrade_available = (val >> 8) & 0x000000ff;
- /* Only update bootcount during upgrade process */
- if (!upgrade_available)
bootcount = 0;
- val = (bootcount & 0x000000ff) |
- writel(RTC_KICK0R_WE, ®->kick0r);
- writel(RTC_KICK1R_WE, ®->kick1r);
- raw_bootcount_store(®->scratch2, val);
- unsigned long val = 0;
- if ((val >> 24) != CONFIG_SYS_BOOTCOUNT_MAGIC)
- else
Lokesh Vutla
