[PATCH] Revert "gpio: qcom_pmic: add a quirk to skip GPIO configuration"
This reverts commit 19f000b72b2fa7e4540f7cdb91287aff594239bd.
The bug in writing was caused by a long-standing error in the SPMI driver which has since been fixed - c2de620d64d4 ("spmi: msm: fix version 5 support"). We can safely enable writing GPIO configuration now.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Tested on SDM845/pm8998 (OnePlus 6) --- drivers/gpio/qcom_pmic_gpio.c | 27 +++++---------------------- 1 file changed, 5 insertions(+), 22 deletions(-)
diff --git a/drivers/gpio/qcom_pmic_gpio.c b/drivers/gpio/qcom_pmic_gpio.c index 80fee841ee3f..f2ef4e5ce144 100644 --- a/drivers/gpio/qcom_pmic_gpio.c +++ b/drivers/gpio/qcom_pmic_gpio.c @@ -68,19 +68,8 @@
#define REG_EN_CTL 0x46 #define REG_EN_CTL_ENABLE (1 << 7)
-/** - * pmic_gpio_match_data - platform specific configuration - * - * @PMIC_MATCH_READONLY: treat all GPIOs as readonly, don't attempt to configure them. - * This is a workaround for an unknown bug on some platforms where trying to write the - * GPIO configuration registers causes the board to hang. - */ -enum pmic_gpio_quirks { - QCOM_PMIC_QUIRK_READONLY = (1 << 0), -}; - struct qcom_pmic_gpio_data { uint32_t pid; /* Peripheral ID on SPMI bus */ bool lv_mv_type; /* If subtype is GPIO_LV(0x10) or GPIO_MV(0x11) */ u32 pin_count; @@ -127,15 +116,10 @@ static int qcom_gpio_set_direction(struct udevice *dev, unsigned int offset, bool input, int value) { struct qcom_pmic_gpio_data *plat = dev_get_plat(dev); uint32_t gpio_base = plat->pid + REG_OFFSET(offset); - ulong quirks = dev_get_driver_data(dev); int ret = 0;
- /* Some PMICs don't like their GPIOs being configured */ - if (quirks & QCOM_PMIC_QUIRK_READONLY) - return 0; - /* Disable the GPIO */ ret = pmic_clrsetbits(dev->parent, gpio_base + REG_EN_CTL, REG_EN_CTL_ENABLE, 0); if (ret < 0) @@ -277,9 +261,8 @@ static const struct dm_gpio_ops qcom_gpio_ops = { static int qcom_gpio_bind(struct udevice *dev) {
struct qcom_pmic_gpio_data *plat = dev_get_plat(dev); - ulong quirks = dev_get_driver_data(dev); struct udevice *child; struct driver *drv; int ret;
@@ -291,9 +274,9 @@ static int qcom_gpio_bind(struct udevice *dev)
/* Bind the GPIO driver as a child of the PMIC. */ ret = device_bind_with_driver_data(dev, drv, dev->name, - quirks, dev_ofnode(dev), &child); + 0, dev_ofnode(dev), &child); if (ret) return log_msg_ret("bind", ret);
dev_set_plat(child, plat); @@ -360,13 +343,13 @@ static int qcom_gpio_probe(struct udevice *dev)
static const struct udevice_id qcom_gpio_ids[] = { { .compatible = "qcom,pm8916-gpio" }, { .compatible = "qcom,pm8994-gpio" }, /* 22 GPIO's */ - { .compatible = "qcom,pm8998-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, + { .compatible = "qcom,pm8998-gpio" }, { .compatible = "qcom,pms405-gpio" }, - { .compatible = "qcom,pm6125-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, - { .compatible = "qcom,pm8150-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, - { .compatible = "qcom,pm8550-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, + { .compatible = "qcom,pm6125-gpio" }, + { .compatible = "qcom,pm8150-gpio" }, + { .compatible = "qcom,pm8550-gpio" }, { } };
U_BOOT_DRIVER(qcom_pmic_gpio) = {
- pmic_gpio_match_data - platform specific configuration
- @PMIC_MATCH_READONLY: treat all GPIOs as readonly, don't attempt to configure them.
- This is a workaround for an unknown bug on some platforms where trying to write the
- GPIO configuration registers causes the board to hang.
- { .compatible = "qcom,pm8998-gpio" }, { .compatible = "qcom,pms405-gpio" },
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Applied, thanks!
[1/1] Revert "gpio: qcom_pmic: add a quirk to skip GPIO configuration" https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/25595a48...
Caleb Connolly
Neil Armstrong
