[PATCH v1 0/2] Add roc-rk3328-cc support
This serie add support for roc-rk33239 board from Firefly/Libre Computer: - add missing L2 cache entry in rk3328 dts - add roc-rk3328-cc board support
With this we can successfully boot the board with mainline U-Boot and binary blob firmwares. Boot with ATF and TPL/SPL partially works: TPL works fine but SPL fails to find a bootable device.
I didn't used the DTS from Linux kernel: USB2 fails in that case, this should be corrected but maybe later?
Note: sorry if this serie has been send twice, but I had issue with my email server...
Loic Devulder (2): rockchip: rk3328: dts: add L2 cache entry rockchip: rk3328: add roc-rk3328-cc support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 16 ++ arch/arm/dts/rk3328-roc-cc.dts | 260 +++++++++++++++++++++++++ arch/arm/dts/rk3328.dtsi | 25 ++- arch/arm/mach-rockchip/rk3328/Kconfig | 1 - board/rockchip/evb_rk3328/MAINTAINERS | 6 + configs/roc-cc-rk3328_defconfig | 95 +++++++++ doc/README.rockchip | 9 +- 8 files changed, 408 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/rk3328-roc-cc-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-roc-cc.dts create mode 100644 configs/roc-cc-rk3328_defconfig
Add missing L2 cache entry in dts to avoid warning during Linux kernel boot.
Signed-off-by: Loic Devulder ldevulder@suse.com --- arch/arm/dts/rk3328.dtsi | 25 ++++++++++++++++++++++++- 1 file changed, 24 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi index 060c84e6c0..7334eb124d 100644 --- a/arch/arm/dts/rk3328.dtsi +++ b/arch/arm/dts/rk3328.dtsi @@ -38,7 +38,10 @@ compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x0>; enable-method = "psci"; -// clocks = <&cru ARMCLK>; + clocks = <&cru ARMCLK>; + #cooling-cells = <2>; + dynamic-power-coefficient = <120>; + next-level-cache = <&l2>; operating-points-v2 = <&cpu0_opp_table>; }; cpu1: cpu@1 { @@ -46,19 +49,39 @@ compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x1>; enable-method = "psci"; + clocks = <&cru ARMCLK>; + #cooling-cells = <2>; + dynamic-power-coefficient = <120>; + next-level-cache = <&l2>; + operating-points-v2 = <&cpu0_opp_table>; }; cpu2: cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x2>; enable-method = "psci"; + clocks = <&cru ARMCLK>; + #cooling-cells = <2>; + dynamic-power-coefficient = <120>; + next-level-cache = <&l2>; + operating-points-v2 = <&cpu0_opp_table>; }; cpu3: cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x3>; enable-method = "psci"; + clocks = <&cru ARMCLK>; + #cooling-cells = <2>; + dynamic-power-coefficient = <120>; + next-level-cache = <&l2>; + operating-points-v2 = <&cpu0_opp_table>; }; + + l2: l2-cache0 { + compatible = "cache"; + }; + };
cpu0_opp_table: opp_table0 {
Hi Loic,
Does this also appear at kernel dts? If yes, you can say it's sync from kernel and provide
the kernel commit number here.
Thanks,
- Kever
}; cpu1: cpu@1 {next-level-cache = <&l2>; operating-points-v2 = <&cpu0_opp_table>;
l2: l2-cache0 {
ROC-RK3328-CC is a board made by Firefly/Libre Computer based on rk3328 SoC: - 2 USB2.0 Host port - 1 USB3.0 Host port - 1 HDMI port - 2 10/100M eth port - 1GB or 2GB DDR4 - UART to USB debug port
This port is based on evb-rk3328 already available in U-Boot.
Signed-off-by: Loic Devulder ldevulder@suse.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 16 ++ arch/arm/dts/rk3328-roc-cc.dts | 260 +++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3328/Kconfig | 1 - board/rockchip/evb_rk3328/MAINTAINERS | 6 + configs/roc-cc-rk3328_defconfig | 95 +++++++++ doc/README.rockchip | 9 +- 7 files changed, 384 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3328-roc-cc-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-roc-cc.dts create mode 100644 configs/roc-cc-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 4fee5cc489..db4b987c4c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -104,7 +104,8 @@ dtb-$(CONFIG_ROCKCHIP_RK3308) += \
dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ - rk3328-rock64.dtb + rk3328-rock64.dtb \ + rk3328-roc-cc.dtb
dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-lion.dtb \ diff --git a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi new file mode 100644 index 0000000000..cf3452ea94 --- /dev/null +++ b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd + */ + +#include "rk3328-u-boot.dtsi" +#include "rk3328-sdram-ddr4-666.dtsi" +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; + +&usb_host0_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3328-roc-cc.dts b/arch/arm/dts/rk3328-roc-cc.dts new file mode 100644 index 0000000000..2bfb261bad --- /dev/null +++ b/arch/arm/dts/rk3328-roc-cc.dts @@ -0,0 +1,260 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + */ + +/dts-v1/; +#include "rk3328.dtsi" + +/ { + model = "Firefly ROC-RK3328-CC"; + compatible = "firefly,roc-rk3328-cc", "rockchip,rk3328"; + + chosen { + stdout-path = &uart2; + }; + + gmac_clkin: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac_clkin"; + #clock-cells = <0>; + }; + + vcc3v3_sdmmc: sdmmc-pwren { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + gpio = <&gpio0 30 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + }; + + vcc5v0_otg: vcc5v0-otg-drv { + compatible = "regulator-fixed"; + enable-active-high; + regulator-name = "vcc5v0_otg"; + gpio = <&gpio1 26 GPIO_ACTIVE_HIGH>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_host_xhci: vcc5v0-host-xhci-drv { + status = "disabled"; //usb host xhci and usb otg use the same gpio to enable power + compatible = "regulator-fixed"; + enable-active-high; + regulator-name = "vcc5v0_host_xhci"; + gpio = <&gpio0 26 GPIO_ACTIVE_HIGH>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + }; +}; + +&saradc { + status = "okay"; +}; + +&uart2 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; + status = "okay"; +}; + +&emmc { + u-boot,dm-pre-reloc; + bus-width = <8>; + cap-mmc-highspeed; + supports-emmc; + disable-wp; + non-removable; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; + status = "okay"; +}; + +&gmac2io { + phy-supply = <&vcc_phy>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; + assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmiim1_pins>; + tx_delay = <0x26>; + rx_delay = <0x11>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb20_otg { + vbus-supply = <&vcc5v0_otg>; + status = "okay"; +}; + +&usb_host0_xhci { + vbus-supply = <&vcc5v0_host_xhci>; + status = "okay"; + maximum-speed = "high-speed"; +}; + +&i2c1 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk805: pmic@18 { + compatible = "rockchip,rk805"; + status = "okay"; + reg = <0x18>; + interrupt-parent = <&gpio1>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + gpio-controller; + #gpio-cells = <2>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + + pwrkey { + status = "okay"; + }; + + led1 { + label = "standby"; + }; + + led2 { + label = "power"; + }; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vdd_18: LDO_REG1 { + regulator-name = "vdd_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_18emmc: LDO_REG2 { + regulator-name = "vcc_18emmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; /* gpio1_d0 */ + }; + }; +}; diff --git a/arch/arm/mach-rockchip/rk3328/Kconfig b/arch/arm/mach-rockchip/rk3328/Kconfig index d13a169022..7fc4af9a4d 100644 --- a/arch/arm/mach-rockchip/rk3328/Kconfig +++ b/arch/arm/mach-rockchip/rk3328/Kconfig @@ -40,5 +40,4 @@ config TPL_STACK default 0xff098000
source "board/rockchip/evb_rk3328/Kconfig" - endif diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index c661d2e06a..86aefc801a 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -10,3 +10,9 @@ M: Matwey V. Kornilov matwey.kornilov@gmail.com S: Maintained F: configs/rock64-rk3328_defconfig F: arch/arm/dts/rk3328-rock64-u-boot.dtsi + +ROC-RK3328-CC +M: Loic Devulder ldevulder@suse.com +S: Maintained +F: configs/roc-rk3328-cc_defconfig +F: arch/arm/dts/rk3328-roc-cc-u-boot.dtsi diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig new file mode 100644 index 0000000000..2ea4616401 --- /dev/null +++ b/configs/roc-cc-rk3328_defconfig @@ -0,0 +1,95 @@ +CONFIG_SMBIOS_MANUFACTURER="firefly" +CONFIG_SMBIOS_PRODUCT_NAME="roc-rk3328-cc" +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-roc-cc.dtb" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3328-roc-cc" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y diff --git a/doc/README.rockchip b/doc/README.rockchip index 9b699b9ae5..9aeee37900 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -52,12 +52,13 @@ Two RK3308 boards are supported: - EVB RK3308 - use evb-rk3308 configuration - ROC-CC-RK3308 - use roc-cc-rk3308 configuration
-Two RK3328 board are supported: +Three RK3328 boards are supported:
- - EVB RK3328 - use evb-rk3328_defconfig - - Pine64 Rock64 board - use rock64-rk3328_defconfig + - EVB RK3328 - use evb_rk3328 configuration + - Pine64 Rock64 board - use rock64-rk3328 configuration + - ROC-RK3328-CC - use roc-cc-rk3328 configuration
-Size RK3399 boards are supported (aarch64): +Six RK3399 boards are supported (aarch64):
- EBV RK3399 - use evb_rk3399 configuration - Firefly RK3399 - use the firefly_rk3399 configuration
- 1 HDMI port
- 1GB or 2GB DDR4
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3328-rock64.dtb
rk3328-rock64.dtb \
rk3328-roc-cc.dtb
- (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd
- chosen {
+&usb_host0_xhci {
- status = "okay";
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- model = "Firefly ROC-RK3328-CC";
- compatible = "firefly,roc-rk3328-cc", "rockchip,rk3328";
- chosen {
- gmac_clkin: external-gmac-clock {
#clock-cells = <0>;
- vcc3v3_sdmmc: sdmmc-pwren {
regulator-boot-on;
- vcc5v0_otg: vcc5v0-otg-drv {
enable-active-high;
- vcc5v0_host_xhci: vcc5v0-host-xhci-drv {
enable-active-high;
- vcc_phy: vcc-phy-regulator {
regulator-boot-on;
- adc-keys {
+&saradc {
- status = "okay";
+&uart2 {
- u-boot,dm-pre-reloc;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- card-detect-delay = <200>;
- disable-wp;
- num-slots = <1>;
- pinctrl-names = "default";
- pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>;
- status = "okay";
+&emmc {
- bus-width = <8>;
- supports-emmc;
- disable-wp;
- non-removable;
- num-slots = <1>;
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>;
- status = "okay";
+&gmac2io {
phy-mode = "rgmii";
tx_delay = <0x26>;
rx_delay = <0x11>;
status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb20_otg {
- vbus-supply = <&vcc5v0_otg>;
- status = "okay";
+&usb_host0_xhci {
- vbus-supply = <&vcc5v0_host_xhci>;
- status = "okay";
- maximum-speed = "high-speed";
+&i2c1 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk805: pmic@18 {
status = "okay";
reg = <0x18>;
wakeup-source;
gpio-controller;
#gpio-cells = <2>;
#clock-cells = <1>;
pwrkey {
status = "okay";
led1 {
label = "standby";
led2 {
label = "power";
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vdd_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
+&pinctrl {
- pmic {
rockchip,pins =
- endif
I have tpl/spl fully enabled on this device privately. The SPL fails to find a boot device when booted from the sdcard. It successfully boots from emmc though. I believe this is due to the 3.3/1.8 mode switch.
Have you tested off emmc with your patch?
-- 2.25.0
Actually this is due to no power being supplied to the card.
The SD card's VCC is driven by a switched regulator, which is controlled by SDMMC0_PWREN, and is also pulled down externally. The enable line is active low. The bootrom does not touch the line, but the MMC driver in U-boot sets PWREN in the MMC controller, which I assume changes the state of SDMMC0_PWREN.
My solution was to simply mux the pin over to GPIO, instead of being controlled through the MMC controller, the latter being the default. The GPIO default state is input, and so the external pull-down works to keep the power enabled. This is done by creating spl_board_init() especially for this board, so essentially creating another target.
I suppose the other way to do it is to enable a bunch of stuff such as regulators and GPIO in SPL, and also do proper pinmuxing, i.e. not throwing away pinctrl properties in the SPL device tree.
My work also includes syncing the rk3328 device tree files from the Linux kernel, along with some cleanups. If Loic and Kever are OK with another series, I can send it out.
Regards ChenYu
-- 2.25.0
Chen-Yu Tsai
Kever Yang
Loic Devulder
Peter Geis
