[PATCH] Rockchip board with DWC3 controller may lead to usb init function declared twice
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index c386b529..11866e6e 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -67,7 +67,7 @@ static struct dwc2_plat_otg_data otg_data = { .tx_fifo_sz = 128, };
-int board_usb_init(int index, enum usb_init_type init) +static int __board_usb_init(int index, enum usb_init_type init) { ofnode node; const char *mode; @@ -151,6 +151,13 @@ int board_usb_init(int index, enum usb_init_type init) } #endif /* CONFIG_USB_DWC3_GADGET */
+#else +int board_usb_init(int index, enum usb_init_type init) +{ + return __board_usb_init(&dwc3_device_data); +} + + #endif /* CONFIG_USB_GADGET */
#if CONFIG_IS_ENABLED(FASTBOOT)
Hi Janpieter,
Please add commit message to descript the issue you met and use the correct format in the subject.
Thanks,
- Kever
Janpieter Sollie
Kever Yang
