[U-Boot] [PATCH v2] mx6qsabresd: Fix booting the kernel from SDHC3
Since commit de7d02aeb (mx6qsabresd: add usdhc2 and usdhc4 support) SDHC3 device node is no longer 0, which breaks loading a uImage from SDHC3.
Fix it by adapting the default environment to use CONFIG_SYS_MMC_ENV_DEV as the correct mmc node for loading the kernel from.
While at it, go back to using SDHC3 as the default mmc, since we have Yocto images that generate an SD card containing U-boot,kernel and rootfs, so it is more convenient to keep using SDHC3 as it was originally.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Properly expand mmcdev macro - Improve commit log
include/configs/mx6qsabre_common.h | 2 +- include/configs/mx6qsabresd.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6qsabre_common.h index bd2fb10..5d03b3d 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6qsabre_common.h @@ -86,7 +86,7 @@ "console=" CONFIG_CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "mmcdev=0\0" \ + "mmcdev=" CONFIG_SYS_MMC_ENV_DEV "\0" \ "mmcpart=1\0" \ "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \ diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index a1d9285..ccb7751 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -27,7 +27,7 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_SYS_MMC_ENV_DEV 2 /* eMMC/uSDHC4 */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC3 */ #define CONFIG_SYS_MMC_ENV_PART 1 /* Boot partition 1 */ #endif
On Thu, Jan 10, 2013 at 2:19 PM, Fabio Estevam fabio.estevam@freescale.com wrote:
Acked-by: Otavio Salvador otavio@ossystems.com.br
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Stefano,
Sorry, please discard this one. Will send another version.
Fabio Estevam
Fabio Estevam
Otavio Salvador
