[U-Boot] Pull request #3 : u-boot-arm/master
Hi Wolfgang,
The following changes since commit a21c65115bd95572cc80092a31b0e9ecb8710e9f:
ARM: lib: Remove CONFIG_ARCH_CPU_INIT dependency (2012-07-20 14:24:08 +0200)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to f8f09dd40423b7f9ea0f0b810a8f5da9cd580a17:
ARM1136: Fix cache range checks (2012-07-21 23:24:25 +0200)
---------------------------------------------------------------- Anatolij Gustschin (1): mx28: Fix elftosb source link in README.mx28_common
Ashok (1): mx6: Make pad name macro consistent with the datasheet
Benoît Thébaudeau (1): ARM1136: Fix cache range checks
Fabio Estevam (1): doc: README.mx28_common: Add missing entry into Contents
arch/arm/cpu/arm1136/cpu.c | 6 +++--- arch/arm/include/asm/arch-mx6/mx6x_pins.h | 4 ++-- doc/README.mx28_common | 9 +++++---- 3 files changed, 10 insertions(+), 9 deletions(-)
Amicalement,
Dear Albert ARIBAUD,
In message 20120721232829.1fd76f12@lilith you wrote:
Hi Wolfgang,
ARM: lib: Remove CONFIG_ARCH_CPU_INIT dependency (2012-07-20 14:24:08 +02= 00)
Beno=C3=AEt Th=C3=A9baudeau (1): ARM1136: Fix cache range checks
Applied, thanks.
Albert ARIBAUD
