[U-Boot] [PATCH V2] ARM: tegra: expand all SPL sizes to be consistent
The size allocation for SPL is increased in all cases to match the already-expanded value used on Tegra124. This is both for general consistency, and because the seaboard build trips over the limit already when using one of the ARM compilers packaged with 14.04. For the record, when building Seaboard:
arm-linux-gnueabi- SPL is too big by 0x36 bytes arm-linux-gnueabihf- SPL fits by 0x2a bytes arm-none-eabi- SPL fits by 0xa bytes
(Those figures are from builds with the expanded SPL size allocation, relative to the non-expanded SPL size limit; they're better by about 6 bytes in the more constrained build.)
Fixes: ba521994229c ("tegra124: Expand SPL space by 8KB") Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Fix "111" vs "110" type in the updated values. Now, the new values really are consistent with T124. --- include/configs/tegra114-common.h | 2 +- include/configs/tegra20-common.h | 2 +- include/configs/tegra210-common.h | 2 +- include/configs/tegra30-common.h | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/tegra114-common.h b/include/configs/tegra114-common.h index 252e607d73f4..671071ba9810 100644 --- a/include/configs/tegra114-common.h +++ b/include/configs/tegra114-common.h @@ -34,7 +34,7 @@ /*----------------------------------------------------------------------- * Physical Memory Map */ -#define CONFIG_SYS_TEXT_BASE 0x8010E000 +#define CONFIG_SYS_TEXT_BASE 0x80110000
/* * Memory layout for where various images get loaded by boot scripts: diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index 0841f33bfc9e..00e85c48c41b 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -32,7 +32,7 @@ /*----------------------------------------------------------------------- * Physical Memory Map */ -#define CONFIG_SYS_TEXT_BASE 0x0010E000 +#define CONFIG_SYS_TEXT_BASE 0x00110000
/* * Memory layout for where various images get loaded by boot scripts: diff --git a/include/configs/tegra210-common.h b/include/configs/tegra210-common.h index e6c815212d7b..8f35a7bf3dc6 100644 --- a/include/configs/tegra210-common.h +++ b/include/configs/tegra210-common.h @@ -26,7 +26,7 @@ /*----------------------------------------------------------------------- * Physical Memory Map */ -#define CONFIG_SYS_TEXT_BASE 0x8010E000 +#define CONFIG_SYS_TEXT_BASE 0x80110000
/* Generic Interrupt Controller */ #define CONFIG_GICV2 diff --git a/include/configs/tegra30-common.h b/include/configs/tegra30-common.h index 3e8e3c1e5bd9..9afd86484bb2 100644 --- a/include/configs/tegra30-common.h +++ b/include/configs/tegra30-common.h @@ -31,7 +31,7 @@ /*----------------------------------------------------------------------- * Physical Memory Map */ -#define CONFIG_SYS_TEXT_BASE 0x8010E000 +#define CONFIG_SYS_TEXT_BASE 0x80110000
Stephen Warren
