[PATCH] board: gateworks: venice: add imx8mm-gw7904 support
The GW7904 is based on the i.MX 8M Mini SoC featuring: - LPDDR4 DRAM - eMMC FLASH - microSD connector with UHS support - LIS2DE12 3-axis accelerometer - Gateworks System Controller - IMX8M FEC - 2x RS232 off-board connectors - PMIC - 10x bi-color LED's - 1x miniPCIe socket with PCIe and USB2.0 - 802.3at Class 4 PoE - 10-30VDC input via barrel-jack
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mm-venice-gw7904-u-boot.dtsi | 46 + arch/arm/dts/imx8mm-venice-gw7904.dts | 884 ++++++++++++++++++ board/gateworks/venice/spl.c | 3 +- 4 files changed, 933 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mm-venice-gw7904-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw7904.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7330121dbaba..14f66da1865e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -952,6 +952,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-venice-gw7901.dtb \ imx8mm-venice-gw7902.dtb \ imx8mm-venice-gw7903.dtb \ + imx8mm-venice-gw7904.dtb \ imx8mm-verdin-wifi-dev.dtb \ phycore-imx8mm.dtb \ imx8mn-bsh-smm-s2.dtb \ diff --git a/arch/arm/dts/imx8mm-venice-gw7904-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw7904-u-boot.dtsi new file mode 100644 index 000000000000..aa1153fbf879 --- /dev/null +++ b/arch/arm/dts/imx8mm-venice-gw7904-u-boot.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Gateworks Corporation + */ + +#include "imx8mm-venice-u-boot.dtsi" + +&gpio1 { + rs232en { + gpio-hog; + output-low; + gpios = <12 GPIO_ACTIVE_HIGH>; + line-name = "rs232_en#"; + }; +}; + +&gpio5 { + pci_wdis { + gpio-hog; + output-high; + gpios = <12 GPIO_ACTIVE_HIGH>; + line-name = "pci_wdis#"; + }; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 25 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + phy-reset-post-delay = <300>; +}; + +&pinctrl_fec1 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw7904.dts b/arch/arm/dts/imx8mm-venice-gw7904.dts new file mode 100644 index 000000000000..2b68fb3e43d1 --- /dev/null +++ b/arch/arm/dts/imx8mm-venice-gw7904.dts @@ -0,0 +1,884 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2022 Gateworks Corporation + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/phy/phy-imx8-pcie.h> + +#include "imx8mm.dtsi" + +/ { + model = "Gateworks Venice GW7904 i.MX8MM board"; + compatible = "gateworks,imx8mm-gw7904", "fsl,imx8mm"; + + chosen { + stdout-path = &uart2; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-0 { + label = "user_pb"; + gpios = <&gpio 2 GPIO_ACTIVE_LOW>; + linux,code = <BTN_0>; + }; + + key-1 { + label = "user_pb1x"; + linux,code = <BTN_1>; + interrupt-parent = <&gsc>; + interrupts = <0>; + }; + + key-2 { + label = "key_erased"; + linux,code = <BTN_2>; + interrupt-parent = <&gsc>; + interrupts = <1>; + }; + + key-3 { + label = "eeprom_wp"; + linux,code = <BTN_3>; + interrupt-parent = <&gsc>; + interrupts = <2>; + }; + + key-4 { + label = "switch_hold"; + linux,code = <BTN_5>; + interrupt-parent = <&gsc>; + interrupts = <7>; + }; + }; + + led-controller { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led-0 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led01_grn"; + gpios = <&gpioled 0 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led01_yel"; + gpios = <&gpioled 1 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-2 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led02_grn"; + gpios = <&gpioled 2 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-3 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led02_yel"; + gpios = <&gpioled 3 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-4 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led03_grn"; + gpios = <&gpioled 4 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-5 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led03_yel"; + gpios = <&gpioled 5 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-6 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led04_grn"; + gpios = <&gpioled 6 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-7 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led04_yel"; + gpios = <&gpioled 7 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-8 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led05_grn"; + gpios = <&gpioled 8 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-9 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led05_yel"; + gpios = <&gpioled 9 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-10 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led06_grn"; + gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-11 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + label = "led06_red"; + gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-12 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led07_grn"; + gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-13 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + label = "led07_red"; + gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-14 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led08_grn"; + gpios = <&gpioled 10 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-15 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led08_yel"; + gpios = <&gpioled 11 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-16 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led09_grn"; + gpios = <&gpioled 12 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-17 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led09_yel"; + gpios = <&gpioled 13 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-18 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "led10_grn"; + gpios = <&gpioled 14 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-19 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + label = "led10_yel"; + gpios = <&gpioled 15 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + }; + + pcie0_refclk: pcie0-refclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; +}; + +&A53_0 { + cpu-supply = <&buck2>; +}; + +&A53_1 { + cpu-supply = <&buck2>; +}; + +&A53_2 { + cpu-supply = <&buck2>; +}; + +&A53_3 { + cpu-supply = <&buck2>; +}; + +&ddrc { + operating-points-v2 = <&ddrc_opp_table>; + + ddrc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-25M { + opp-hz = /bits/ 64 <25000000>; + }; + + opp-100M { + opp-hz = /bits/ 64 <100000000>; + }; + + opp-750M { + opp-hz = /bits/ 64 <750000000>; + }; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + local-mac-address = [00 00 00 00 00 00]; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; +}; + +&gpio1 { + gpio-line-names = "", "", "", "", "", "", "", "", + "", "", "", "", "rs232_en#", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio5 { + gpio-line-names = "", "", "", "", "", "", "", "", + "", "", "", "", "pci_wdis#", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + gsc: gsc@20 { + compatible = "gw,gsc"; + reg = <0x20>; + pinctrl-0 = <&pinctrl_gsc>; + interrupt-parent = <&gpio4>; + interrupts = <26 IRQ_TYPE_EDGE_FALLING>; + interrupt-controller; + #interrupt-cells = <1>; + + adc { + compatible = "gw,gsc-adc"; + #address-cells = <1>; + #size-cells = <0>; + + channel@6 { + gw,mode = <0>; + reg = <0x06>; + label = "temp"; + }; + + channel@82 { + gw,mode = <2>; + reg = <0x82>; + label = "vin"; + gw,voltage-divider-ohms = <22100 1000>; + gw,voltage-offset-microvolt = <700000>; + }; + + channel@84 { + gw,mode = <2>; + reg = <0x84>; + label = "vdd_5p0"; + gw,voltage-divider-ohms = <10000 10000>; + }; + + channel@86 { + gw,mode = <2>; + reg = <0x86>; + label = "vdd_3p3"; + gw,voltage-divider-ohms = <10000 10000>; + }; + + channel@88 { + gw,mode = <2>; + reg = <0x88>; + label = "vdd_0p9"; + }; + + channel@8c { + gw,mode = <2>; + reg = <0x8c>; + label = "vdd_soc"; + }; + + channel@8e { + gw,mode = <2>; + reg = <0x8e>; + label = "vdd_arm"; + }; + + channel@90 { + gw,mode = <2>; + reg = <0x90>; + label = "vdd_1p8"; + }; + + channel@92 { + gw,mode = <2>; + reg = <0x92>; + label = "vdd_dram"; + }; + + channel@a2 { + gw,mode = <2>; + reg = <0xa2>; + label = "vdd_gsc"; + gw,voltage-divider-ohms = <10000 10000>; + }; + }; + }; + + gpio: gpio@23 { + compatible = "nxp,pca9555"; + reg = <0x23>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gsc>; + interrupts = <4>; + }; + + eeprom@50 { + compatible = "atmel,24c02"; + reg = <0x50>; + pagesize = <16>; + }; + + eeprom@51 { + compatible = "atmel,24c02"; + reg = <0x51>; + pagesize = <16>; + }; + + eeprom@52 { + compatible = "atmel,24c02"; + reg = <0x52>; + pagesize = <16>; + }; + + eeprom@53 { + compatible = "atmel,24c02"; + reg = <0x53>; + pagesize = <16>; + }; + + rtc@68 { + compatible = "dallas,ds1672"; + reg = <0x68>; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio3>; + interrupts = <8 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + #clock-cells = <0>; + clocks = <&osc_32k 0>; + clock-output-names = "clk-32k-out"; + + regulators { + /* vdd_soc: 0.805-0.900V (typ=0.8V) */ + BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + /* vdd_arm: 0.805-1.0V (typ=0.9V) */ + buck2: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + }; + + /* vdd_0p9: 0.805-1.0V (typ=0.9V) */ + BUCK3 { + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_3p3 */ + BUCK4 { + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_1p8 */ + BUCK5 { + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_dram */ + BUCK6 { + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + /* nvcc_snvs_1p8 */ + LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <1900000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_snvs_0p8 */ + LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdda_1p8 */ + LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + accelerometer@19 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_accel>; + compatible = "st,lis2de12"; + reg = <0x19>; + st,drdy-int-pin = <1>; + interrupt-parent = <&gpio1>; + interrupts = <15 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "INT1"; + }; +}; + +&i2c4 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + gpioled: gpio@27 { + compatible = "nxp,pca9555"; + reg = <0x27>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&pcie_phy { + fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; + fsl,clkreq-unsupported; + clocks = <&pcie0_refclk>; + clock-names = "ref"; + status = "okay"; +}; + +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie0>; + reset-gpio = <&gpio5 11 GPIO_ACTIVE_LOW>; + clocks = <&clk IMX8MM_CLK_PCIE1_ROOT>, <&clk IMX8MM_CLK_PCIE1_AUX>, + <&pcie0_refclk>; + clock-names = "pcie", "pcie_aux", "pcie_bus"; + assigned-clocks = <&clk IMX8MM_CLK_PCIE1_AUX>, + <&clk IMX8MM_CLK_PCIE1_CTRL>; + assigned-clock-rates = <10000000>, <250000000>; + assigned-clock-parents = <&clk IMX8MM_SYS_PLL2_50M>, + <&clk IMX8MM_SYS_PLL2_250M>; + status = "okay"; +}; + +/* off-board RS232 */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +/* console */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* off-board RS232 */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "host"; + disable-over-current; + status = "okay"; +}; + +/* microSD */ +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + bus-width = <4>; + vmmc-supply = <®_3p3v>; + status = "okay"; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x40000041 /* RS232# */ + MX8MM_IOMUXC_ECSPI2_MISO_GPIO5_IO12 0x40000041 /* PCI_WDIS# */ + >; + }; + + pinctrl_accel: accelgrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x159 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MM_IOMUXC_SAI2_TXFS_GPIO4_IO24 0x19 /* IRQ# */ + MX8MM_IOMUXC_SAI2_TXC_GPIO4_IO25 0x19 /* RST# */ + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x40000019 + MX8MM_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x40000019 + MX8MM_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x40000019 + MX8MM_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x40000019 + >; + }; + + pinctrl_gsc: gscgrp { + fsl,pins = < + MX8MM_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x159 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_pcie0: pciegrp { + fsl,pins = < + MX8MM_IOMUXC_ECSPI2_MOSI_GPIO5_IO11 0x41 + >; + }; + + pinctrl_pmic: pmicgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_DATA02_GPIO3_IO8 0x41 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MM_IOMUXC_UART1_RXD_UART1_DCE_RX 0x140 + MX8MM_IOMUXC_UART1_TXD_UART1_DCE_TX 0x140 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MM_IOMUXC_UART3_RXD_UART3_DCE_RX 0x140 + MX8MM_IOMUXC_UART3_TXD_UART3_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2-gpiogrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CD_B_GPIO2_IO12 0x1c4 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index 98931c04754e..e06de8bb54c7 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -172,7 +172,8 @@ static int power_init_board(void)
else if ((!strncmp(model, "GW7901", 6)) || (!strncmp(model, "GW7902", 6)) || - (!strncmp(model, "GW7903", 6))) { + (!strncmp(model, "GW7903", 6)) || + (!strncmp(model, "GW7904", 6))) { if (!strncmp(model, "GW7902", 6)) ret = uclass_get_device_by_seq(UCLASS_I2C, 0, &bus); else
- LPDDR4 DRAM
- eMMC FLASH
- IMX8M FEC
- PMIC
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
