[PATCH] mmc: zynq_sdhci: Add weak function prototype
zynqmp_pm_is_function_supported() which checks feature support on som, which is implemented in firmware_zynqmp.c driver. As mini configuration does not use firmware driver, so create a weak function to avoid compilation error on zynqmp mini configuration.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Acked-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/mmc/zynq_sdhci.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index a59d96c6bdad..e978b6798854 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -79,6 +79,11 @@ __weak int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, return 0; }
+__weak int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id) +{ + return 1; +} + #if defined(CONFIG_ARCH_ZYNQMP) || defined(CONFIG_ARCH_VERSAL) /* Default settings for ZynqMP Clock Phases */ static const u32 zynqmp_iclk_phases[] = {0, 63, 63, 0, 63, 0,
st 27. 4. 2022 v 10:27 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
return 1;
#if defined(CONFIG_ARCH_ZYNQMP) || defined(CONFIG_ARCH_VERSAL) /* Default settings for ZynqMP Clock Phases */ static const u32 zynqmp_iclk_phases[] = {0, 63, 63, 0, 63, 0, -- 2.36.0
Applied. M
Reviewed-by: Jaehoon Chung jh80.chung@samsuhng.com
Best Regards, Jaehoon Chung
- return 1;
Jaehoon Chung
Michal Simek
Michal Simek
