[U-Boot] [PATCH v2] ARM: vf610: use strcpy for soc environment variable
To create the soc environment variable we concatenate two strings on the stack. So far, strcat has been used for the first string as well as for the second string. Since the variable on the stack is not initialized, the first strcat may not start using the first entry in the character array. This then could lead to an buffer overflow on the stack.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
Changes in v2: - Re-based and re-send.
arch/arm/cpu/armv7/vf610/generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index 08b9ef4..50eb0c6 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -322,7 +322,7 @@ int arch_misc_init(void) { char soc[6];
- strcat(soc, "vf"); + strcpy(soc, "vf"); strcat(soc, soc_type); setenv("soc", soc);
Changes in v2:
- strcpy(soc, "vf"); strcat(soc, soc_type); setenv("soc", soc);
Best regards, Stefano Babic
Marcel Ziswiler
Stefano Babic
