[U-Boot] [PATCH] xilinx: zynqmp: Use strlen only if env_get doesn't return null
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Add check if boot_targets exists in environment and then generate new_targets env accordingly. Performing strlen on null address causes it to fail with exception if isolation is enabled with DDR address zero as secure. It works with out isolation enabled as zero is valid address but it may lead to junk values in boot_targets. This patch fixes the issue by checking return value of env_get so that it generate boot_targets properly.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynqmp/zynqmp.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index c198a4d92063..8b6c0ea46698 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -346,6 +346,7 @@ int board_late_init(void) u8 bootmode; const char *mode; char *new_targets; + char *env_targets; int ret;
if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { @@ -418,10 +419,16 @@ int board_late_init(void) * One terminating char + one byte for space between mode * and default boot_targets */ - new_targets = calloc(1, strlen(mode) + - strlen(env_get("boot_targets")) + 2); + env_targets = env_get("boot_targets"); + if (env_targets) { + new_targets = calloc(1, strlen(mode) + + strlen(env_targets) + 2); + sprintf(new_targets, "%s %s", mode, env_targets); + } else { + new_targets = calloc(1, strlen(mode) + 2); + sprintf(new_targets, "%s", mode); + }
- sprintf(new_targets, "%s %s", mode, env_get("boot_targets")); env_set("boot_targets", new_targets);
Michal Simek
