[U-Boot] [PATCH v2 08/11] x86: Move VGA option rom macros to Kconfig
Move X86_OPTION_ROM_FILE & X86_OPTION_ROM_ADDR to arch/x86/Kconfig and rename them to VGA_BIOS_FILE & VGA_BIOS_ADDR which depend on HAVE_VGA_BIOS. The new names are consistent with other x86 binary blob options like HAVE_FSP/FSP_FILE/FSP_ADDR.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
Makefile | 4 ++-- arch/x86/Kconfig | 22 ++++++++++++++++++++++ configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/minnowmax_defconfig | 1 + doc/README.x86 | 2 +- drivers/pci/pci_rom.c | 6 +++--- include/configs/minnowmax.h | 3 --- include/configs/x86-chromebook.h | 3 --- 9 files changed, 31 insertions(+), 12 deletions(-)
diff --git a/Makefile b/Makefile index 0a674bf..2601e87 100644 --- a/Makefile +++ b/Makefile @@ -1034,8 +1034,8 @@ ifneq ($(CONFIG_HAVE_CMC),) IFDTOOL_FLAGS += -w $(CONFIG_CMC_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_CMC_FILE) endif
-ifneq ($(CONFIG_X86_OPTION_ROM_ADDR),) -IFDTOOL_FLAGS += -w $(CONFIG_X86_OPTION_ROM_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_X86_OPTION_ROM_FILE) +ifneq ($(CONFIG_HAVE_VGA_BIOS),) +IFDTOOL_FLAGS += -w $(CONFIG_VGA_BIOS_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_VGA_BIOS_FILE) endif
quiet_cmd_ifdtool = IFDTOOL $@ diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 6b46ec4..0e308ce 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -293,6 +293,28 @@ config TSC_FREQ_IN_MHZ help The running frequency in MHz of Time-Stamp Counter (TSC).
+config HAVE_VGA_BIOS + bool "Add a VGA BIOS image" + help + Select this option if you have a VGA BIOS image that you would + like to add to your ROM. + +config VGA_BIOS_FILE + string "VGA BIOS image filename" + depends on HAVE_VGA_BIOS + default "vga.bin" + help + The filename of the VGA BIOS image in the board directory. + +config VGA_BIOS_ADDR + hex "VGA BIOS image location" + depends on HAVE_VGA_BIOS + default 0xfff90000 + help + The location of VGA BIOS image in the SPI flash. For example, base + address of 0xfff90000 indicates that the image will be put at offset + 0x90000 from the beginning of a 1MB flash device. + menu "System tables"
config GENERATE_PIRQ_TABLE diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 4f7f779..08743f0 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebook_link" CONFIG_TARGET_CHROMEBOOK_LINK=y CONFIG_HAVE_MRC=y +CONFIG_HAVE_VGA_BIOS=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CMD_NET=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 941033f..9cd422a 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebox_panther" CONFIG_TARGET_CHROMEBOX_PANTHER=y CONFIG_HAVE_MRC=y +CONFIG_HAVE_VGA_BIOS=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CMD_NET=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 744aca3..bfe2cdf 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="minnowmax" CONFIG_TARGET_MINNOWMAX=y CONFIG_HAVE_INTEL_ME=y +CONFIG_HAVE_VGA_BIOS=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/doc/README.x86 b/doc/README.x86 index 49d6e83..7f3914f 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -79,7 +79,7 @@ Find the following files: * ./northbridge/intel/sandybridge/systemagent-r6.bin
The 3rd one should be renamed to mrc.bin. -As for the video ROM, you can get it here [3]. +As for the video ROM, you can get it here [3] and rename it to vga.bin. Make sure all these binary blobs are put in the board directory.
Now you can build U-Boot and obtain u-boot.rom: diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 83c69a5..4a91033 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -79,8 +79,8 @@ static int pci_rom_probe(pci_dev_t dev, uint class, if (vendev != mapped_vendev) debug("Device ID mapped to %#08x\n", mapped_vendev);
-#ifdef CONFIG_X86_OPTION_ROM_ADDR - rom_address = CONFIG_X86_OPTION_ROM_ADDR; +#ifdef CONFIG_VGA_BIOS_ADDR + rom_address = CONFIG_VGA_BIOS_ADDR; #else
pci_read_config_dword(dev, PCI_ROM_ADDRESS, &rom_address); @@ -103,7 +103,7 @@ static int pci_rom_probe(pci_dev_t dev, uint class, if (le16_to_cpu(rom_header->signature) != PCI_ROM_HDR) { printf("Incorrect expansion ROM header signature %04x\n", le16_to_cpu(rom_header->signature)); -#ifndef CONFIG_X86_OPTION_ROM_ADDR +#ifndef CONFIG_VGA_BIOS_ADDR /* Disable expansion ROM address decoding */ pci_write_config_dword(dev, PCI_ROM_ADDRESS, rom_address); #endif diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 547765d..8ee84a6 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -52,9 +52,6 @@ #undef CONFIG_USB_MAX_CONTROLLER_COUNT #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
-#define CONFIG_X86_OPTION_ROM_FILE vga.bin -#define CONFIG_X86_OPTION_ROM_ADDR 0xfff90000 - #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index e0e7fca..408cbb1 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -26,9 +26,6 @@ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_PANTHERPOINT_AHCI_MOBILE}, \ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_LYNXPOINT_AHCI}
-#define CONFIG_X86_OPTION_ROM_FILE pci8086,0166.bin -#define CONFIG_X86_OPTION_ROM_ADDR 0xfff90000 - #define CONFIG_PCI_MEM_BUS 0xe0000000 #define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS #define CONFIG_PCI_MEM_SIZE 0x10000000
Changes in v2: None
Applied to u-boot-x86, thanks!
Bin Meng
