[U-Boot] [v2 PATCH 0/12] arm, at91, spl: add spl support for the taurus and corvus boards
This patchset add SPL support for the AT91SAM9G20 based taurus board, and the AT91SAM9M10G45 based corvus board from siemens, and replaces the at91bootstrap code.
The boot.bin which replaces the at91bootstrap image can created with mkimage:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
For other SoC this step is done in one step ... should we add this also for AT91 based boards?
For example add a "u-boot.at91" target in the Makefile?
This patchset is based on the common updates for the taurus and corvus board:
Patchwork [U-Boot] arm, at91: add generic board support for the taurus and corvus board http://patchwork.ozlabs.org/patch/395398/ (now in mainline)
Patchwork [U-Boot] arm, at91: add spi dataflash support for the taurus board http://patchwork.ozlabs.org/patch/395400/
Changes in v2: - rebased against d58a9451e7339ed4cf2b2627e534611f427fb791 - spi, atmel: move CONFIG_SYS_SPI_WRITE_TOUT into common header new in v2 - add comment from Jagan Teki: - remove spi_init_f() from board file - remove CONFIG_SYS_SPI_WRITE_TOUT from board config file instead define a default in the spi driver -> new patch for v2 - add Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com - add comment from Andreas Biessmann: rename "MPDDRC_CR_EBISHARE" to "MPDDRC_CR_DQMS_SHARED" - add comment from scott wood: move nand_erase_one into "include/nand.h" and rename it to spl_nand_erase_one
Heiko Schocher (12): spi, atmel: move CONFIG_SYS_SPI_WRITE_TOUT into common header arm, at91: add spi dataflash support for the taurus board arm, at91, mpddrc: fix typo in ddr2_init() arm, at91: compile mpddrc ram init code also for AT91SAM9M10G45 arm, at91: add missing ddr2 cr register MPDDRC_CR_EBISHARE define spl, nand: add option to boot raw u-boot.bin image only mtd: atmel_nand: add missign include spl, nand, atmel_nand: add erase one block function spl, mtd, nand, atmel_nand: invert device ready pin logic arm, spl, at91: add at91sam9260 and at91sam9g45 spl support arm, at91, spl: add spl support for the taurus board arm, spl, at91: add spl support for the corvus board
README | 4 + arch/arm/Kconfig | 2 + arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 22 +++ arch/arm/cpu/arm926ejs/at91/clock.c | 60 +++++++ arch/arm/cpu/armv7/at91/clock.c | 27 +++ arch/arm/cpu/at91-common/Makefile | 7 +- arch/arm/cpu/at91-common/mpddrc.c | 14 +- arch/arm/cpu/at91-common/sdram.c | 77 +++++++++ arch/arm/cpu/at91-common/spl.c | 185 +++++++++++++++------ arch/arm/include/asm/arch-at91/at91_common.h | 4 + arch/arm/include/asm/arch-at91/at91_pmc.h | 5 +- arch/arm/include/asm/arch-at91/at91sam9260.h | 1 + .../arm/include/asm/arch-at91/at91sam9260_matrix.h | 5 + arch/arm/include/asm/arch-at91/at91sam9_sdramc.h | 22 ++- arch/arm/include/asm/arch-at91/atmel_mpddrc.h | 1 + board/siemens/corvus/board.c | 109 ++++++++++-- board/siemens/taurus/taurus.c | 91 ++++++++-- common/spl/spl.c | 15 +- common/spl/spl_nand.c | 13 ++ configs/corvus_defconfig | 5 +- configs/taurus_defconfig | 5 +- drivers/mtd/nand/atmel_nand.c | 40 ++++- drivers/spi/atmel_spi.h | 4 + include/configs/afeb9260.h | 1 - include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/corvus.h | 54 +++++- include/configs/ethernut5.h | 1 - include/configs/meesc.h | 1 - include/configs/otc570.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/sbc35_a9g20.h | 1 - include/configs/taurus.h | 64 ++++++- include/configs/tny_a9260.h | 1 - include/configs/usb_a9263.h | 1 - include/nand.h | 1 + include/spl.h | 1 + 40 files changed, 746 insertions(+), 105 deletions(-) create mode 100644 arch/arm/cpu/at91-common/sdram.c
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h and define a default value. Delete this define in the board config files, where it is possible (all boards use currently the same value).
Signed-off-by: Heiko Schocher hs@denx.de ---
Changes in v2: rebased against d58a9451e7339ed4cf2b2627e534611f427fb791 new in v2
drivers/spi/atmel_spi.h | 4 ++++ include/configs/afeb9260.h | 1 - include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/ethernut5.h | 1 - include/configs/meesc.h | 1 - include/configs/otc570.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/sbc35_a9g20.h | 1 - include/configs/tny_a9260.h | 1 - include/configs/usb_a9263.h | 1 - 14 files changed, 4 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/atmel_spi.h b/drivers/spi/atmel_spi.h index d240945..1538a23 100644 --- a/drivers/spi/atmel_spi.h +++ b/drivers/spi/atmel_spi.h @@ -94,3 +94,7 @@ static inline struct atmel_spi_slave *to_atmel_spi(struct spi_slave *slave) readl(as->regs + ATMEL_SPI_##reg) #define spi_writel(as, reg, value) \ writel(value, as->regs + ATMEL_SPI_##reg) + +#if !defined(CONFIG_SYS_SPI_WRITE_TOUT) +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +#endif diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 14bac15..932a309 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -77,7 +77,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 73917b0..72247cc 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -135,7 +135,6 @@ #ifndef CONFIG_AT91SAM9G20EK_2MMC #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 226f8c1..cb16bda 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -107,7 +107,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH -#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index b666d94..fa19e8b 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -119,7 +119,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define AT91_SPI_CLK 15000000 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index b8d5dd1..d5f0197 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -100,7 +100,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define AT91_SPI_CLK 15000000 diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 4c69af6..ce61a16 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -78,7 +78,6 @@
/* SPI */ #define CONFIG_ATMEL_SPI -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #define AT91_SPI_CLK 15000000
/* Serial port */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 86ce5f2..955d0e2 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -124,7 +124,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH # define CONFIG_ATMEL_DATAFLASH_SPI # define CONFIG_HAS_DATAFLASH -# define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) # define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 # define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ # define AT91_SPI_CLK 15000000 diff --git a/include/configs/otc570.h b/include/configs/otc570.h index 629967d..2390beb 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -174,7 +174,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH # define CONFIG_ATMEL_DATAFLASH_SPI # define CONFIG_HAS_DATAFLASH -# define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) # define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 # define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ # define AT91_SPI_CLK 15000000 diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 4a71927..0746056 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -202,7 +202,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index d9c04d1..f0f12af 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -216,7 +216,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define AT91_SPI_CLK 15000000 diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index a1b5751..e7c35ec 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -80,7 +80,6 @@ #define CONFIG_SPI #define CONFIG_CMD_SPI #define CONFIG_ATMEL_SPI -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ)
#define CONFIG_CMD_EEPROM #define CONFIG_SPI_M95XXX diff --git a/include/configs/tny_a9260.h b/include/configs/tny_a9260.h index 32f6b00..79c7fc5 100644 --- a/include/configs/tny_a9260.h +++ b/include/configs/tny_a9260.h @@ -85,7 +85,6 @@ #define CONFIG_SPI #define CONFIG_CMD_SPI #define CONFIG_ATMEL_SPI -#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ)
#define CONFIG_CMD_EEPROM #define CONFIG_SPI_M95XXX diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 3c54870..84571f6 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -85,7 +85,6 @@ /* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH -#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 #define AT91_SPI_CLK 8000000
Changes in v2: - add comment from Jagan Teki: - remove spi_init_f() from board file - remove CONFIG_SYS_SPI_WRITE_TOUT from board config file instead define a default in the spi driver -> new patch for v2
board/siemens/taurus/taurus.c | 18 ++++++++++++++++++ include/configs/taurus.h | 10 ++++++++++ 2 files changed, 28 insertions(+)
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 673b302..76609c7 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -22,6 +22,8 @@ #include <asm/arch/gpio.h> #include <asm/arch/at91sam9_sdramc.h> #include <atmel_mci.h> +#include <asm/arch/at91_spi.h> +#include <spi.h>
#include <net.h> #include <netdev.h> @@ -127,6 +129,21 @@ int board_early_init_f(void) return 0; }
+int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + at91_set_gpio_value(TAURUS_SPI_CS_PIN, 0); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + at91_set_gpio_value(TAURUS_SPI_CS_PIN, 1); +} + int board_init(void) { /* adress of boot parameters */ @@ -139,6 +156,7 @@ int board_init(void) #ifdef CONFIG_MACB taurus_macb_hw_init(); #endif + at91_spi0_hw_init(TAURUS_SPI_MASK);
return 0; } diff --git a/include/configs/taurus.h b/include/configs/taurus.h index aadf4cd..ba9496f 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -127,6 +127,16 @@ #define CONFIG_USB_STORAGE #endif
+/* SPI EEPROM */ +#define CONFIG_SPI +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_ATMEL_SPI +#define CONFIG_SPI_FLASH_STMICRO +#define TAURUS_SPI_MASK (1 << 4) +#define TAURUS_SPI_CS_PIN AT91_PIN_PA3 + /* load address */ #define CONFIG_SYS_LOAD_ADDR 0x22000000
use the configure value for computing the ba_off value not the value from the cr register. This leaded in a wrong ram configuration on the upcoming corvus spl board support.
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Changes in v2: add Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
arch/arm/cpu/at91-common/mpddrc.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/at91-common/mpddrc.c b/arch/arm/cpu/at91-common/mpddrc.c index 8136396..76668d2 100644 --- a/arch/arm/cpu/at91-common/mpddrc.c +++ b/arch/arm/cpu/at91-common/mpddrc.c @@ -26,7 +26,8 @@ int ddr2_init(const unsigned int ram_address, /* Compute bank offset according to NC in configuration register */ ba_off = (mpddr_value->cr & ATMEL_MPDDRC_CR_NC_MASK) + 9; if (!(mpddr_value->cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED)) - ba_off += ((mpddr->cr & ATMEL_MPDDRC_CR_NR_MASK) >> 2) + 11; + ba_off += ((mpddr_value->cr & ATMEL_MPDDRC_CR_NR_MASK) >> 2) + + 11;
ba_off += (mpddr_value->md & ATMEL_MPDDRC_MD_DBW_MASK) ? 1 : 2;
Hi Heiko,
+ 11;
As Andreas suggested, can we ignore the 80 character's warning here?
Best Regards, Bo Shen
Hello Bo,
Am 31.10.2014 02:55, schrieb Bo Shen:
Hi Heiko,
- ba_off += ((mpddr_value->cr & ATMEL_MPDDRC_CR_NR_MASK) >> 2)
- 11;
Ok, changes this ... so I send a v3.
bye, Heiko
- compile mpddrc ram init code also for AT91SAM9M10G45 based boards. - in CONFIG_SAMA5D3 case, look for the ATMEL_MPDDRC_CR_DECOD_INTERLEAVED in the cr configuration
arch/arm/cpu/at91-common/Makefile | 6 +++++- arch/arm/cpu/at91-common/mpddrc.c | 11 ++++++++++- 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/at91-common/Makefile b/arch/arm/cpu/at91-common/Makefile index 5b97838..f62863a 100644 --- a/arch/arm/cpu/at91-common/Makefile +++ b/arch/arm/cpu/at91-common/Makefile @@ -9,4 +9,8 @@ #
obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o -obj-$(CONFIG_SPL_BUILD) += mpddrc.o spl.o +ifneq ($(CONFIG_SPL_BUILD),) +obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o +obj-$(CONFIG_SAMA5D3) += mpddrc.o +obj-y += spl.o +endif diff --git a/arch/arm/cpu/at91-common/mpddrc.c b/arch/arm/cpu/at91-common/mpddrc.c index 76668d2..602e71e 100644 --- a/arch/arm/cpu/at91-common/mpddrc.c +++ b/arch/arm/cpu/at91-common/mpddrc.c @@ -17,6 +17,15 @@ static inline void atmel_mpddr_op(int mode, u32 ram_address) writel(0, ram_address); }
+static int ddr2_decodtype_is_seq(u32 cr) +{ +#if defined(CONFIG_SAMA5D3) + if (cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED) + return 0; +#endif + return 1; +} + int ddr2_init(const unsigned int ram_address, const struct atmel_mpddr *mpddr_value) { @@ -25,7 +34,7 @@ int ddr2_init(const unsigned int ram_address,
/* Compute bank offset according to NC in configuration register */ ba_off = (mpddr_value->cr & ATMEL_MPDDRC_CR_NC_MASK) + 9; - if (!(mpddr_value->cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED)) + if (ddr2_decodtype_is_seq(mpddr_value->cr)) ba_off += ((mpddr_value->cr & ATMEL_MPDDRC_CR_NR_MASK) >> 2) + 11;
Changes in v2: add comment from Andreas Biessmann: - rename "MPDDRC_CR_EBISHARE" to "MPDDRC_CR_DQMS_SHARED"
arch/arm/include/asm/arch-at91/atmel_mpddrc.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-at91/atmel_mpddrc.h b/arch/arm/include/asm/arch-at91/atmel_mpddrc.h index 5741f6e..130a85a 100644 --- a/arch/arm/include/asm/arch-at91/atmel_mpddrc.h +++ b/arch/arm/include/asm/arch-at91/atmel_mpddrc.h @@ -57,6 +57,7 @@ int ddr2_init(const unsigned int ram_address, #define ATMEL_MPDDRC_CR_DIC_DS (0x1 << 8) #define ATMEL_MPDDRC_CR_DIS_DLL (0x1 << 9) #define ATMEL_MPDDRC_CR_OCD_DEFAULT (0x7 << 12) +#define ATMEL_MPDDRC_CR_DQMS_SHARED (0x1 << 16) #define ATMEL_MPDDRC_CR_ENRDM_ON (0x1 << 17) #define ATMEL_MPDDRC_CR_NB_8BANKS (0x1 << 20) #define ATMEL_MPDDRC_CR_NDQS_DISABLED (0x1 << 21)
enable to boot only a raw u-boot.bin image from nand with the CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on boards where spl space is low.
--- on the siemens taurus board, this option saved 0x14d bytes
README | 4 ++++ common/spl/spl.c | 15 ++++++++++----- common/spl/spl_nand.c | 13 +++++++++++++ include/spl.h | 1 + 4 files changed, 28 insertions(+), 5 deletions(-)
diff --git a/README b/README index 7b5538e..a34902b 100644 --- a/README +++ b/README @@ -3605,6 +3605,10 @@ FIT uImage format: Support for the MTD subsystem within SPL. Useful for environment on NAND support within SPL.
+ CONFIG_SPL_NAND_RAW_ONLY + Support to boot only raw u-boot.bin images. Use this only + if you need to save space. + CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT Set for the SPL on PPC mpc8xxx targets, support for drivers/ddr/fsl/libddr.o in SPL binary. diff --git a/common/spl/spl.c b/common/spl/spl.c index d85bab3..f01a21c 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -62,6 +62,15 @@ __weak void spl_board_prepare_for_linux(void) /* Nothing to do! */ }
+void spl_set_header_raw_uboot(void) +{ + spl_image.size = CONFIG_SYS_MONITOR_LEN; + spl_image.entry_point = CONFIG_SYS_UBOOT_START; + spl_image.load_addr = CONFIG_SYS_TEXT_BASE; + spl_image.os = IH_OS_U_BOOT; + spl_image.name = "U-Boot"; +} + void spl_parse_image_header(const struct image_header *header) { u32 header_size = sizeof(struct image_header); @@ -93,11 +102,7 @@ void spl_parse_image_header(const struct image_header *header) /* Signature not found - assume u-boot.bin */ debug("mkimage signature not found - ih_magic = %x\n", header->ih_magic); - spl_image.size = CONFIG_SYS_MONITOR_LEN; - spl_image.entry_point = CONFIG_SYS_UBOOT_START; - spl_image.load_addr = CONFIG_SYS_TEXT_BASE; - spl_image.os = IH_OS_U_BOOT; - spl_image.name = "U-Boot"; + spl_set_header_raw_uboot(); } }
diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 9b200bc..b7801cb 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -10,6 +10,18 @@ #include <asm/io.h> #include <nand.h>
+#if defined(CONFIG_SPL_NAND_RAW_ONLY) +void spl_nand_load_image(void) +{ + nand_init(); + + nand_spl_load_image(CONFIG_SYS_NAND_U_BOOT_OFFS, + CONFIG_SYS_NAND_U_BOOT_SIZE, + (void *)CONFIG_SYS_NAND_U_BOOT_DST); + spl_set_header_raw_uboot(); + nand_deselect(); +} +#else void spl_nand_load_image(void) { struct image_header *header; @@ -82,3 +94,4 @@ void spl_nand_load_image(void) spl_image.size, (void *)spl_image.load_addr); nand_deselect(); } +#endif diff --git a/include/spl.h b/include/spl.h index 16b3566..b2e5bf7 100644 --- a/include/spl.h +++ b/include/spl.h @@ -35,6 +35,7 @@ extern struct spl_image_info spl_image; void preloader_console_init(void); u32 spl_boot_device(void); u32 spl_boot_mode(void); +void spl_set_header_raw_uboot(void); void spl_parse_image_header(const struct image_header *header); void spl_board_prepare_for_linux(void); void __noreturn jump_to_image_linux(void *arg);
using this driver in SPL code with CONFIG_SPL_NAND_ECC configured leads in an compileerror. Fix this.
drivers/mtd/nand/atmel_nand.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 9114a86..d506e42 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -18,6 +18,7 @@ #include <malloc.h> #include <nand.h> #include <watchdog.h> +#include <linux/mtd/nand_ecc.h>
#ifdef CONFIG_ATMEL_NAND_HWECC
erase one nand block in spl code. keep it simple, as size matters This is used on the upcoming taurus spl support.
Changes in v2: add comment from scott wood: - move nand_erase_one into "include/nand.h" and rename it to spl_nand_erase_one
drivers/mtd/nand/atmel_nand.c | 33 +++++++++++++++++++++++++++++++++ include/nand.h | 1 + 2 files changed, 34 insertions(+)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index d506e42..d6d6f85 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -1274,6 +1274,39 @@ static int nand_read_page(int block, int page, void *dst)
return 0; } + +int spl_nand_erase_one(int block, int page) +{ + struct nand_chip *this = mtd.priv; + void (*hwctrl)(struct mtd_info *mtd, int cmd, + unsigned int ctrl) = this->cmd_ctrl; + int page_addr; + + if (nand_chip.select_chip) + nand_chip.select_chip(&mtd, 0); + + page_addr = page + block * CONFIG_SYS_NAND_PAGE_COUNT; + hwctrl(&mtd, NAND_CMD_ERASE1, NAND_CTRL_CLE | NAND_CTRL_CHANGE); + /* Row address */ + hwctrl(&mtd, (page_addr & 0xff), NAND_CTRL_ALE | NAND_CTRL_CHANGE); + hwctrl(&mtd, ((page_addr >> 8) & 0xff), + NAND_CTRL_ALE | NAND_CTRL_CHANGE); +#ifdef CONFIG_SYS_NAND_5_ADDR_CYCLE + /* One more address cycle for devices > 128MiB */ + hwctrl(&mtd, (page_addr >> 16) & 0x0f, + NAND_CTRL_ALE | NAND_CTRL_CHANGE); +#endif + + hwctrl(&mtd, NAND_CMD_ERASE2, NAND_CTRL_CLE | NAND_CTRL_CHANGE); + udelay(2000); + + while (!this->dev_ready(&mtd)) + ; + + nand_deselect(); + + return 0; +} #else static int nand_read_page(int block, int page, void *dst) { diff --git a/include/nand.h b/include/nand.h index fc735d1..15e31ab 100644 --- a/include/nand.h +++ b/include/nand.h @@ -167,3 +167,4 @@ __attribute__((noreturn)) void nand_boot(void); #define ENV_OFFSET_SIZE 8 int get_nand_env_oob(nand_info_t *nand, unsigned long *result); #endif +int spl_nand_erase_one(int block, int page);
Acked-by: Scott Wood scottwood@freescale.com
-Scott
device ready pin is signalling that the device is ready on state 1 not on 0. Simmiliar as it is in drivers/mtd/nand/nand_spl_simple.c
drivers/mtd/nand/atmel_nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index d6d6f85..3b6093a 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -1188,7 +1188,7 @@ static int nand_command(int block, int page, uint32_t offs, u8 cmd) void (*hwctrl)(struct mtd_info *mtd, int cmd, unsigned int ctrl) = this->cmd_ctrl;
- while (this->dev_ready(&mtd)) + while (!this->dev_ready(&mtd)) ;
if (cmd == NAND_CMD_READOOB) { @@ -1213,7 +1213,7 @@ static int nand_command(int block, int page, uint32_t offs, u8 cmd) hwctrl(&mtd, NAND_CMD_READSTART, NAND_CTRL_CLE | NAND_CTRL_CHANGE); hwctrl(&mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE);
return 0; @@ -1353,7 +1353,7 @@ int at91_nand_wait_ready(struct mtd_info *mtd)
udelay(this->chip_delay);
- return 0; + return 1; }
int board_nand_init(struct nand_chip *nand)
-Scott
add support for using spl code on at91sam9260 and at91sam9g45 based boards.
Changes in v2: None
arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 22 +++ arch/arm/cpu/arm926ejs/at91/clock.c | 60 +++++++ arch/arm/cpu/armv7/at91/clock.c | 27 +++ arch/arm/cpu/at91-common/Makefile | 1 + arch/arm/cpu/at91-common/sdram.c | 77 +++++++++ arch/arm/cpu/at91-common/spl.c | 185 +++++++++++++++------ arch/arm/include/asm/arch-at91/at91_common.h | 4 + arch/arm/include/asm/arch-at91/at91_pmc.h | 5 +- arch/arm/include/asm/arch-at91/at91sam9260.h | 1 + .../arm/include/asm/arch-at91/at91sam9260_matrix.h | 5 + arch/arm/include/asm/arch-at91/at91sam9_sdramc.h | 22 ++- 11 files changed, 359 insertions(+), 50 deletions(-) create mode 100644 arch/arm/cpu/at91-common/sdram.c
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c index cae4abc..7a7fd7d 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -8,8 +8,10 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> +#include <asm/arch/at91sam9_sdramc.h> #include <asm/arch/gpio.h>
/* @@ -207,3 +209,23 @@ void at91_mci_hw_init(void) #endif } #endif + +void at91_sdram_hw_init(void) +{ + at91_set_a_periph(AT91_PIO_PORTC, 16, 0); + at91_set_a_periph(AT91_PIO_PORTC, 17, 0); + at91_set_a_periph(AT91_PIO_PORTC, 18, 0); + at91_set_a_periph(AT91_PIO_PORTC, 19, 0); + at91_set_a_periph(AT91_PIO_PORTC, 20, 0); + at91_set_a_periph(AT91_PIO_PORTC, 21, 0); + at91_set_a_periph(AT91_PIO_PORTC, 22, 0); + at91_set_a_periph(AT91_PIO_PORTC, 23, 0); + at91_set_a_periph(AT91_PIO_PORTC, 24, 0); + at91_set_a_periph(AT91_PIO_PORTC, 25, 0); + at91_set_a_periph(AT91_PIO_PORTC, 26, 0); + at91_set_a_periph(AT91_PIO_PORTC, 27, 0); + at91_set_a_periph(AT91_PIO_PORTC, 28, 0); + at91_set_a_periph(AT91_PIO_PORTC, 29, 0); + at91_set_a_periph(AT91_PIO_PORTC, 30, 0); + at91_set_a_periph(AT91_PIO_PORTC, 31, 0); +} diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index 31315b5..f363982 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -187,3 +187,63 @@ int at91_clock_init(unsigned long main_clock)
return 0; } + +#if !defined(AT91_PLL_LOCK_TIMEOUT) +#define AT91_PLL_LOCK_TIMEOUT 1000000 +#endif + +void at91_plla_init(u32 pllar) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + int timeout = AT91_PLL_LOCK_TIMEOUT; + + writel(pllar, &pmc->pllar); + while (!(readl(&pmc->sr) & (AT91_PMC_LOCKA | AT91_PMC_MCKRDY))) { + timeout--; + if (timeout == 0) + break; + } +} +void at91_pllb_init(u32 pllbr) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + int timeout = AT91_PLL_LOCK_TIMEOUT; + + writel(pllbr, &pmc->pllbr); + while (!(readl(&pmc->sr) & (AT91_PMC_LOCKB | AT91_PMC_MCKRDY))) { + timeout--; + if (timeout == 0) + break; + } +} + +void at91_mck_init(u32 mckr) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + int timeout = AT91_PLL_LOCK_TIMEOUT; + u32 tmp; + + tmp = readl(&pmc->mckr); + tmp &= ~(AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_MASK | + AT91_PMC_MCKR_CSS_MASK); + tmp |= mckr & (AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_MASK | + AT91_PMC_MCKR_CSS_MASK); + writel(tmp, &pmc->mckr); + + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) { + timeout--; + if (timeout == 0) + break; + } +} + +void at91_periph_clk_enable(int id) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(1 << id, &pmc->pcer); +} diff --git a/arch/arm/cpu/armv7/at91/clock.c b/arch/arm/cpu/armv7/at91/clock.c index 36ed4a6..363081a 100644 --- a/arch/arm/cpu/armv7/at91/clock.c +++ b/arch/arm/cpu/armv7/at91/clock.c @@ -111,6 +111,33 @@ int at91_clock_init(unsigned long main_clock) return 0; }
+void at91_plla_init(u32 pllar) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(pllar, &pmc->pllar); + while (!(readl(&pmc->sr) & (AT91_PMC_LOCKA | AT91_PMC_MCKRDY))) + ; +} + +void at91_mck_init(u32 mckr) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + u32 tmp; + + tmp = readl(&pmc->mckr); + tmp &= ~(AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_2); + tmp |= mckr & (AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_2); + writel(tmp, &pmc->mckr); + + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; +} + void at91_periph_clk_enable(int id) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; diff --git a/arch/arm/cpu/at91-common/Makefile b/arch/arm/cpu/at91-common/Makefile index f62863a..5bdfb6a 100644 --- a/arch/arm/cpu/at91-common/Makefile +++ b/arch/arm/cpu/at91-common/Makefile @@ -10,6 +10,7 @@
obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o ifneq ($(CONFIG_SPL_BUILD),) +obj-$(CONFIG_AT91SAM9G20) += sdram.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o obj-$(CONFIG_SAMA5D3) += mpddrc.o obj-y += spl.o diff --git a/arch/arm/cpu/at91-common/sdram.c b/arch/arm/cpu/at91-common/sdram.c new file mode 100644 index 0000000..5758b06 --- /dev/null +++ b/arch/arm/cpu/at91-common/sdram.c @@ -0,0 +1,77 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91sam9_sdramc.h> +#include <asm/arch/gpio.h> + +int sdramc_initialize(unsigned int sdram_address, const struct sdramc_reg *p) +{ + struct sdramc_reg *reg = (struct sdramc_reg *)ATMEL_BASE_SDRAMC; + unsigned int i; + + /* SDRAM feature must be in the configuration register */ + writel(p->cr, ®->cr); + + /* The SDRAM memory type must be set in the Memory Device Register */ + writel(p->mdr, ®->mdr); + + /* + * The minimum pause of 200 us is provided to precede any single + * toggle + */ + for (i = 0; i < 1000; i++) + ; + + /* A NOP command is issued to the SDRAM devices */ + writel(AT91_SDRAMC_MODE_NOP, ®->mr); + writel(0x00000000, sdram_address); + + /* An All Banks Precharge command is issued to the SDRAM devices */ + writel(AT91_SDRAMC_MODE_PRECHARGE, ®->mr); + writel(0x00000000, sdram_address); + + for (i = 0; i < 10000; i++) + ; + + /* Eight auto-refresh cycles are provided */ + for (i = 0; i < 8; i++) { + writel(AT91_SDRAMC_MODE_REFRESH, ®->mr); + writel(0x00000001 + i, sdram_address + 4 + 4 * i); + } + + /* + * A Mode Register set (MRS) cyscle is issued to program the + * SDRAM parameters(TCSR, PASR, DS) + */ + writel(AT91_SDRAMC_MODE_LMR, ®->mr); + writel(0xcafedede, sdram_address + 0x24); + + /* + * The application must go into Normal Mode, setting Mode + * to 0 in the Mode Register and perform a write access at + * any location in the SDRAM. + */ + writel(AT91_SDRAMC_MODE_NORMAL, ®->mr); + writel(0x00000000, sdram_address); /* Perform Normal mode */ + + /* + * Write the refresh rate into the count field in the SDRAMC + * Refresh Timer Rgister. + */ + writel(p->tr, ®->tr); + + return 0; +} diff --git a/arch/arm/cpu/at91-common/spl.c b/arch/arm/cpu/at91-common/spl.c index 674a470..5c9a3ad 100644 --- a/arch/arm/cpu/at91-common/spl.c +++ b/arch/arm/cpu/at91-common/spl.c @@ -8,11 +8,18 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> +#if !defined(CONFIG_SAMA5D3) +#include <asm/arch/at91sam9_matrix.h> +#endif +#include <asm/arch/at91_pit.h> #include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> #include <asm/arch/at91_wdt.h> #include <asm/arch/clk.h> #include <spl.h>
+DECLARE_GLOBAL_DATA_PTR; + static void at91_disable_wdt(void) { struct at91_wdt *wdt = (struct at91_wdt *)ATMEL_BASE_WDT; @@ -20,6 +27,33 @@ static void at91_disable_wdt(void) writel(AT91_WDT_MR_WDDIS, &wdt->mr); }
+u32 spl_boot_device(void) +{ +#ifdef CONFIG_SYS_USE_MMC + return BOOT_DEVICE_MMC1; +#elif CONFIG_SYS_USE_NANDFLASH + return BOOT_DEVICE_NAND; +#elif CONFIG_SYS_USE_SERIALFLASH + return BOOT_DEVICE_SPI; +#endif + return BOOT_DEVICE_NONE; +} + +u32 spl_boot_mode(void) +{ + switch (spl_boot_device()) { +#ifdef CONFIG_SYS_USE_MMC + case BOOT_DEVICE_MMC1: + return MMCSD_MODE_FS; + break; +#endif + case BOOT_DEVICE_NONE: + default: + hang(); + } +} + +#if defined(CONFIG_SAMA5D3) static void switch_to_main_crystal_osc(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; @@ -57,77 +91,134 @@ static void switch_to_main_crystal_osc(void) writel(tmp, &pmc->mor); }
-void at91_plla_init(u32 pllar) +void s_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + switch_to_main_crystal_osc();
- writel(pllar, &pmc->pllar); - while (!(readl(&pmc->sr) & (AT91_PMC_LOCKA | AT91_PMC_MCKRDY))) - ; -} + /* disable watchdog */ + at91_disable_wdt();
-void at91_mck_init(u32 mckr) -{ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - u32 tmp; + /* PMC configuration */ + at91_pmc_init();
- tmp = readl(&pmc->mckr); - tmp &= ~(AT91_PMC_MCKR_PRES_MASK | - AT91_PMC_MCKR_MDIV_MASK | - AT91_PMC_MCKR_PLLADIV_2); - tmp |= mckr & (AT91_PMC_MCKR_PRES_MASK | - AT91_PMC_MCKR_MDIV_MASK | - AT91_PMC_MCKR_PLLADIV_2); - writel(tmp, &pmc->mckr); + at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK);
- while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) - ; -} + timer_init();
+ board_early_init_f();
-u32 spl_boot_device(void) + preloader_console_init(); + + mem_init(); +} +#else +static void enable_ext_reset(void) { -#ifdef CONFIG_SYS_USE_MMC - return BOOT_DEVICE_MMC1; -#elif CONFIG_SYS_USE_NANDFLASH - return BOOT_DEVICE_NAND; -#elif CONFIG_SYS_USE_SERIALFLASH - return BOOT_DEVICE_SPI; -#endif - return BOOT_DEVICE_NONE; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + + writel(AT91_RSTC_KEY | AT91_RSTC_MR_URSTEN, &rstc->mr); }
-u32 spl_boot_mode(void) +#if defined(CONFIG_ATMEL_MATRIX_INIT) +static void matrix_init(void) { - switch (spl_boot_device()) { -#ifdef CONFIG_SYS_USE_MMC - case BOOT_DEVICE_MMC1: - return MMCSD_MODE_FS; - break; + struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; + + writel((readl(&mat->scfg[3]) & (~AT91_MATRIX_SLOT_CYCLE)) + | AT91_MATRIX_SLOT_CYCLE_(0x40), + &mat->scfg[3]); +} #endif - case BOOT_DEVICE_NONE: - default: - hang(); + +void lowlevel_clock_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + if (!(readl(&pmc->sr) & AT91_PMC_MOSCS)) { + /* Enable Main Oscillator */ + writel(AT91_PMC_MOSCS | (0x40 << 8), &pmc->mor); + + /* Wait until Main Oscillator is stable */ + while (!(readl(&pmc->sr) & AT91_PMC_MOSCS)) + ; } + + /* After stabilization, switch to Main Oscillator */ + if ((readl(&pmc->mckr) & AT91_PMC_CSS) == AT91_PMC_CSS_SLOW) { + unsigned long tmp; + + tmp = readl(&pmc->mckr); + tmp &= ~AT91_PMC_CSS; + tmp |= AT91_PMC_CSS_MAIN; + writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; + + tmp &= ~AT91_PMC_PRES; + tmp |= AT91_PMC_PRES_1; + writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; + } + + return; }
-void s_init(void) +void __weak at91_spl_board_init(void) { - switch_to_main_crystal_osc(); +}
- /* disable watchdog */ +void spl_board_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + lowlevel_clock_init(); at91_disable_wdt();
- /* PMC configuration */ - at91_pmc_init(); + /* + * At this stage the main oscillator is supposed to be enabled + * PCK = MCK = MOSC + */ + writel(0x00, &pmc->pllicpr);
- at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK); + /* Configure PLLA = MOSC * (PLL_MULA + 1) / PLL_DIVA */ + at91_plla_init(CONFIG_SYS_AT91_PLLA);
- timer_init(); + /* PCK = PLLA = 2 * MCK */ + at91_mck_init(CONFIG_SYS_MCKR);
- board_early_init_f(); + /* Switch MCK on PLLA output */ + at91_mck_init(CONFIG_SYS_MCKR_CSS); + +#if defined(CONFIG_SYS_AT91_PLLB) + /* Configure PLLB */ + at91_pllb_init(CONFIG_SYS_AT91_PLLB); +#endif + + /* Enable External Reset */ + enable_ext_reset();
+#if defined(CONFIG_ATMEL_MATRIX_INIT) + /* Initialize matrix */ + matrix_init(); +#endif + + gd->arch.mck_rate_hz = CONFIG_SYS_MASTER_CLOCK; + /* + * init timer long enough for using in spl. + */ + timer_init(); + + /* enable clocks for all PIOs */ + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + /* init console */ + at91_seriald_hw_init(); preloader_console_init();
mem_init(); + + at91_spl_board_init(); } +#endif diff --git a/arch/arm/include/asm/arch-at91/at91_common.h b/arch/arm/include/asm/arch-at91/at91_common.h index 59e2f43..2d94090 100644 --- a/arch/arm/include/asm/arch-at91/at91_common.h +++ b/arch/arm/include/asm/arch-at91/at91_common.h @@ -23,9 +23,13 @@ void at91_udp_hw_init(void); void at91_uhp_hw_init(void); void at91_lcd_hw_init(void); void at91_plla_init(u32 pllar); +void at91_pllb_init(u32 pllar); void at91_mck_init(u32 mckr); void at91_pmc_init(void); void mem_init(void); void at91_phy_reset(void); +void at91_sdram_hw_init(void); +void at91_mck_init(u32 mckr); +void at91_spl_board_init(void);
#endif /* AT91_COMMON_H */ diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index 27331ff..5f64583 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -95,7 +95,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_CSS_MAIN 0x00000001 #define AT91_PMC_MCKR_CSS_PLLA 0x00000002 #define AT91_PMC_MCKR_CSS_PLLB 0x00000003 -#define AT91_PMC_MCKR_CSS_MASK 0x00000003 +#define AT91_PMC_MCKR_CSS_MASK 0x00000007
#ifdef CONFIG_SAMA5D3 #define AT91_PMC_MCKR_PRES_1 0x00000000 @@ -114,7 +114,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_PRES_16 0x00000010 #define AT91_PMC_MCKR_PRES_32 0x00000014 #define AT91_PMC_MCKR_PRES_64 0x00000018 -#define AT91_PMC_MCKR_PRES_MASK 0x0000001C +#define AT91_PMC_MCKR_PRES_MASK 0x0000003C #endif
#ifdef CONFIG_AT91RM9200 @@ -133,6 +133,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_MDIV_MASK 0x00000300 #endif
+#define AT91_PMC_MCKR_PLLADIV_MASK 0x00003000 #define AT91_PMC_MCKR_PLLADIV_1 0x00000000 #define AT91_PMC_MCKR_PLLADIV_2 0x00001000
diff --git a/arch/arm/include/asm/arch-at91/at91sam9260.h b/arch/arm/include/asm/arch-at91/at91sam9260.h index 2e902ee..1e613fa 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9260.h +++ b/arch/arm/include/asm/arch-at91/at91sam9260.h @@ -95,6 +95,7 @@ #define ATMEL_BASE_SDRAMC 0xffffea00 #define ATMEL_BASE_SMC 0xffffec00 #define ATMEL_BASE_MATRIX 0xffffee00 +#define ATMEL_BASE_CCFG 0xffffef14 #define ATMEL_BASE_AIC 0xfffff000 #define ATMEL_BASE_DBGU 0xfffff200 #define ATMEL_BASE_PIOA 0xfffff400 diff --git a/arch/arm/include/asm/arch-at91/at91sam9260_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9260_matrix.h index 4755fa1..dc61f48 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9260_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9260_matrix.h @@ -61,5 +61,10 @@ struct at91_matrix { #define AT91_MATRIX_DBPUC (1 << 8) #define AT91_MATRIX_VDDIOMSEL_1_8V (0 << 16) #define AT91_MATRIX_VDDIOMSEL_3_3V (1 << 16) +#define AT91_MATRIX_EBI_IOSR_SEL (1 << 17) + +/* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) +#define AT91_MATRIX_SLOT_CYCLE_(x) (x << 0)
#endif diff --git a/arch/arm/include/asm/arch-at91/at91sam9_sdramc.h b/arch/arm/include/asm/arch-at91/at91sam9_sdramc.h index 5c98cc7..3a076c6 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9_sdramc.h +++ b/arch/arm/include/asm/arch-at91/at91sam9_sdramc.h @@ -25,6 +25,21 @@ #define AT91_ASM_SDRAMC_CR (ATMEL_BASE_SDRAMC + 0x08) #define AT91_ASM_SDRAMC_MDR (ATMEL_BASE_SDRAMC + 0x24)
+#else +struct sdramc_reg { + u32 mr; + u32 tr; + u32 cr; + u32 lpr; + u32 ier; + u32 idr; + u32 imr; + u32 isr; + u32 mdr; +}; + +int sdramc_initialize(unsigned int sdram_address, + const struct sdramc_reg *p); #endif
/* SDRAM Controller (SDRAMC) registers */ @@ -62,11 +77,17 @@ #define AT91_SDRAMC_DBW_32 (0 << 7) #define AT91_SDRAMC_DBW_16 (1 << 7) #define AT91_SDRAMC_TWR (0xf << 8) /* Write Recovery Delay */ +#define AT91_SDRAMC_TWR_VAL(x) (x << 8) #define AT91_SDRAMC_TRC (0xf << 12) /* Row Cycle Delay */ +#define AT91_SDRAMC_TRC_VAL(x) (x << 12) #define AT91_SDRAMC_TRP (0xf << 16) /* Row Precharge Delay */ +#define AT91_SDRAMC_TRP_VAL(x) (x << 16) #define AT91_SDRAMC_TRCD (0xf << 20) /* Row to Column Delay */ +#define AT91_SDRAMC_TRCD_VAL(x) (x << 20) #define AT91_SDRAMC_TRAS (0xf << 24) /* Active to Precharge Delay */ +#define AT91_SDRAMC_TRAS_VAL(x) (x << 24) #define AT91_SDRAMC_TXSR (0xf << 28) /* Exit Self Refresh to Active Delay */ +#define AT91_SDRAMC_TXSR_VAL(x) (x << 28)
#define AT91_SDRAMC_LPR (ATMEL_BASE_SDRAMC + 0x10) /* SDRAM Controller Low Power Register */ #define AT91_SDRAMC_LPCB (3 << 0) /* Low-power Configurations */ @@ -93,5 +114,4 @@ #define AT91_SDRAMC_MD_SDRAM 0 #define AT91_SDRAMC_MD_LOW_POWER_SDRAM 1
- #endif
Hi Heiko,
Where this come from, CSS only two bits.
Ditto
#endif
Hello Bo,
Am 30.10.2014 11:17, schrieb Bo Shen:
Hi Heiko,
Good question ... looked again into the doc, it is only two bits.
Ditto
Hmm... no idea, why I changed this ... good catch!
Is the rest of the patch (and the patchserie OK) ?
Then I can send a v3 ...
bye, Heiko
Hi Heiko,
On 10/30/2014 07:41 PM, Heiko Schocher wrote:
Hello Bo,
Hi Heiko,
Ditto
Except one suggestion and nitpick sent just now, the rest patch seems good. For this whole series: Reviewed-by: Bo Shen voice.shen@atmel.com
bye, Heiko
Hi Heiko,
I am thinking, whether it be better to keep this file as two copy? This will remove #ifdef, although a little code duplication.
If this solution acceptable, some suggestion as following: - for armv5 (arm926ejs, now at91 series), named it spl_at91.c, - for armv7 (cortex-a5, now, sama5d3), named it spl_atmel.c? (As for arm9 series, we have at91 prefix for SoC name, and for armv7 SoC, we don't have at91 prefix, and it now changed to Atmel Smart)
- static void at91_disable_wdt(void) { struct at91_wdt *wdt = (struct at91_wdt *)ATMEL_BASE_WDT;
break;
- default:
hang();
- at91_disable_wdt();
- u32 tmp;
- at91_pmc_init();
timer_init();
- preloader_console_init();
- mem_init();
-#endif
- struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC;
- writel(AT91_RSTC_KEY | AT91_RSTC_MR_URSTEN, &rstc->mr); }
break;
- struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- writel((readl(&mat->scfg[3]) & (~AT91_MATRIX_SLOT_CYCLE))
&mat->scfg[3]);
+} #endif
- default:
hang();
- if (!(readl(&pmc->sr) & AT91_PMC_MOSCS)) {
- /* After stabilization, switch to Main Oscillator */
- if ((readl(&pmc->mckr) & AT91_PMC_CSS) == AT91_PMC_CSS_SLOW) {
unsigned long tmp;
- return; }
- lowlevel_clock_init(); at91_disable_wdt();
- at91_pmc_init();
* PCK = MCK = MOSC
- writel(0x00, &pmc->pllicpr);
- /* Configure PLLA = MOSC * (PLL_MULA + 1) / PLL_DIVA */
- at91_plla_init(CONFIG_SYS_AT91_PLLA);
- timer_init();
- /* PCK = PLLA = 2 * MCK */
- at91_mck_init(CONFIG_SYS_MCKR);
- /* Switch MCK on PLLA output */
- at91_mck_init(CONFIG_SYS_MCKR_CSS);
- /* Configure PLLB */
- at91_pllb_init(CONFIG_SYS_AT91_PLLB);
- /* Enable External Reset */
- enable_ext_reset();
- /* Initialize matrix */
- matrix_init();
Can this also be weak function? And put matrix_init() code to SoC/board related file.
timer_init();
/* init console */
mem_init();
Hello Bo,
Am 31.10.2014 02:50, schrieb Bo Shen:
Hi Heiko,
Ok, I look into this.
at91_disable_wdt();
- at91_pmc_init();
- At this stage the main oscillator is supposed to be enabled
- PCK = MCK = MOSC
- timer_init();
- matrix_init();
Changed.
Thanks!
bye, Heiko
Dear Bo Shen,
I agree that we should try and minimize #ifdef's, but code duplication is even worse.
replaces the at91bootstrap code with SPL code.
make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader.
Changes in v2: - rename function "nand_erase_one" to "spl_nand_erase_one" as Scott Wood suggested
arch/arm/Kconfig | 1 + board/siemens/taurus/taurus.c | 73 +++++++++++++++++++++++++++++++++++++------ configs/taurus_defconfig | 5 +-- include/configs/taurus.h | 54 +++++++++++++++++++++++++++++++- 4 files changed, 120 insertions(+), 13 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7b20fab..abe1317 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -128,6 +128,7 @@ config TARGET_CORVUS bool "Support corvus"
config TARGET_TAURUS + select SUPPORT_SPL bool "Support taurus"
config TARGET_STAMP9G20 diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 76609c7..2a4f40f 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -21,6 +21,8 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/at91sam9_sdramc.h> +#include <asm/arch/clk.h> +#include <linux/mtd/nand.h> #include <atmel_mci.h> #include <asm/arch/at91_spi.h> #include <spi.h> @@ -30,7 +32,6 @@
-#ifdef CONFIG_CMD_NAND static void taurus_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; @@ -63,15 +64,68 @@ static void taurus_nand_hw_init(void) /* Enable NandFlash */ at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); } + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ + taurus_nand_hw_init(); + + /* Configure recovery button PINs */ + at91_set_gpio_input(AT91_PIN_PA31, 1); + + /* check if button is pressed */ + if (at91_get_gpio_value(AT91_PIN_PA31) == 0) { + u32 boot_device; + + debug("Recovery button pressed\n"); + boot_device = spl_boot_device(); + switch (boot_device) { +#ifdef CONFIG_SPL_NAND_SUPPORT + case BOOT_DEVICE_NAND: + nand_init(); + spl_nand_erase_one(0, 0); + break; +#endif + } + } +} + +void mem_init(void) +{ + struct at91_matrix *ma = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct sdramc_reg setting; + + at91_sdram_hw_init(); + setting.cr = (AT91_SDRAMC_NC_9 | + AT91_SDRAMC_NR_13 | + AT91_SDRAMC_CAS_3 | + AT91_SDRAMC_NB_4 | + AT91_SDRAMC_DBW_32 | + AT91_SDRAMC_TWR_VAL(3) | + AT91_SDRAMC_TRC_VAL(9) | + AT91_SDRAMC_TRP_VAL(3) | + AT91_SDRAMC_TRCD_VAL(3) | + AT91_SDRAMC_TRAS_VAL(6) | + AT91_SDRAMC_TXSR_VAL(10)); + setting.mdr = AT91_SDRAMC_MD_SDRAM; + setting.tr = (CONFIG_SYS_MASTER_CLOCK * 7) / 1000000; + + + writel(readl(&ma->ebicsa) | AT91_MATRIX_CS1A_SDRAMC | + AT91_MATRIX_VDDIOMSEL_3_3V | AT91_MATRIX_EBI_IOSR_SEL, + &ma->ebicsa); + sdramc_initialize(ATMEL_BASE_CS1, &setting); +} #endif
#ifdef CONFIG_MACB static void taurus_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* Enable EMAC clock */ - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0);
/* * Disable pull-up on: @@ -119,12 +173,12 @@ int board_mmc_init(bd_t *bd)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC), - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + + at91_seriald_hw_init();
return 0; } @@ -149,7 +203,6 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_seriald_hw_init(); #ifdef CONFIG_CMD_NAND taurus_nand_hw_init(); #endif diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 9870048..438e25d 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS" -CONFIG_ARM=y -CONFIG_TARGET_TAURUS=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_TAURUS=y diff --git a/include/configs/taurus.h b/include/configs/taurus.h index ba9496f..21d60c1 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -34,7 +34,7 @@ */
-#define CONFIG_SYS_TEXT_BASE 0x23f00000 +#define CONFIG_SYS_TEXT_BASE 0x21000000
/* ARM asynchronous clock */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ @@ -168,4 +168,56 @@ #define CONFIG_SYS_MALLOC_LEN \ ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
+/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x0 +#define CONFIG_SPL_MAX_SIZE (11 * 1024) +#define CONFIG_SPL_STACK (16 * 1024) + +#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_BSS_MAX_SIZE (3 * 1024) + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SYS_USE_NANDFLASH 1 +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_RAW_ONLY +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#define CONFIG_SYS_NAND_SIZE (256*1024*1024) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63, } + + +#define CONFIG_SPL_ATMEL_SIZE +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define AT91_PLL_LOCK_TIMEOUT 1000000 +#define CONFIG_SYS_AT91_PLLA 0x202A3F01 +#define CONFIG_SYS_MCKR 0x1300 +#define CONFIG_SYS_MCKR_CSS (0x02 | CONFIG_SYS_MCKR) +#define CONFIG_SYS_AT91_PLLB 0x10193F05 + +#define CONFIG_ATMEL_MATRIX_INIT #endif
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
Changes in v2: - rename function "nand_erase_one" to "spl_nand_erase_one" as Scott Wood suggested - add comment from Andreas Biessmann: rename "MPDDRC_CR_EBISHARE" to "MPDDRC_CR_DQMS_SHARED"
arch/arm/Kconfig | 1 + board/siemens/corvus/board.c | 109 ++++++++++++++++++++++++++++++++++++++----- configs/corvus_defconfig | 5 +- include/configs/corvus.h | 54 +++++++++++++++++++-- 4 files changed, 151 insertions(+), 18 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index abe1317..ff2d84c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -125,6 +125,7 @@ config TARGET_PM9G45 bool "Support pm9g45"
config TARGET_CORVUS + select SUPPORT_SPL bool "Support corvus"
config TARGET_TAURUS diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index f1e93ef..0a11540 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -31,12 +31,10 @@
-#ifdef CONFIG_CMD_NAND static void corvus_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ @@ -63,22 +61,111 @@ static void corvus_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOC, &pmc->pcer); - - /* Configure RDY/BSY */ - at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + at91_periph_clk_enable(ATMEL_ID_PIOC);
/* Enable NandFlash */ at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); } + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ + /* + * For on the sam9m10g45ek board, the chip wm9711 stay in the test + * mode, so it need do some action to exit mode. + */ + at91_set_gpio_output(AT91_PIN_PD7, 0); + at91_set_gpio_output(AT91_PIN_PD8, 0); + at91_set_pio_pullup(AT91_PIO_PORTD, 7, 1); + at91_set_pio_pullup(AT91_PIO_PORTD, 8, 1); + at91_set_pio_pullup(AT91_PIO_PORTA, 12, 1); + at91_set_pio_pullup(AT91_PIO_PORTA, 13, 1); + at91_set_pio_pullup(AT91_PIO_PORTA, 15, 1); + + corvus_nand_hw_init(); + + /* Configure recovery button PINs */ + at91_set_gpio_input(AT91_PIN_PB7, 1); + + /* check if button is pressed */ + if (at91_get_gpio_value(AT91_PIN_PB7) == 0) { + u32 boot_device; + + debug("Recovery button pressed\n"); + boot_device = spl_boot_device(); + switch (boot_device) { +#ifdef CONFIG_SPL_NAND_SUPPORT + case BOOT_DEVICE_NAND: + nand_init(); + spl_nand_erase_one(0, 0); + break; #endif + } + } +}
-#ifdef CONFIG_CMD_USB -static void taurus_usb_hw_init(void) +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_14 | + ATMEL_MPDDRC_CR_DIC_DS | + ATMEL_MPDDRC_CR_DQMS_SHARED | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3); + ddr2->rtr = 0x24b; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET |/* 6*7.5 = 45 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET |/* 2*7.5 = 15 ns */ + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | /* 2*7.5 = 15 ns */ + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | /* 8*7.5 = 75 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | /* 2*7.5 = 15 ns */ + 1 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | /* 1*7.5= 7.5 ns*/ + 1 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | /* 1 clk cycle */ + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); /* 2 clk cycles */ + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | /* 2*7.5 = 15 ns */ + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 16 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 14 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (1 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 0 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddr ddr2; + unsigned long csa; + + ddr2_conf(&ddr2);
- writel(1 << ATMEL_ID_PIODE, &pmc->pcer); + /* enable DDR2 clock */ + writel(0x4, &pmc->scer); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&mat->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + csa &= ~AT91_MATRIX_EBI_VDDIOMSEL_3_3V; + writel(csa, &mat->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_CS6, &ddr2); +} +#endif + +#ifdef CONFIG_CMD_USB +static void taurus_usb_hw_init(void) +{ + at91_periph_clk_enable(ATMEL_ID_PIODE);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); @@ -88,10 +175,8 @@ static void taurus_usb_hw_init(void) #ifdef CONFIG_MACB static void corvus_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* Enable clock */ - writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC);
/* * Disable pull-up on: diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 3fc8edb..5d60847 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" -CONFIG_ARM=y -CONFIG_TARGET_CORVUS=y ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_CORVUS=y diff --git a/include/configs/corvus.h b/include/configs/corvus.h index eb1584d..5b50c1d 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -19,7 +19,6 @@ #define MACH_TYPE_CORVUS 2066
#define CONFIG_SYS_GENERIC_BOARD - /* * Warning: changing CONFIG_SYS_TEXT_BASE requires * adapting the initial boot program. @@ -27,7 +26,7 @@ * hex number here! */
-#define CONFIG_SYS_TEXT_BASE 0x73f00000 +#define CONFIG_SYS_TEXT_BASE 0x72000000
#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
@@ -107,8 +106,6 @@ /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 -#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8 - #endif
/* Ethernet */ @@ -159,5 +156,54 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + \ 128*1024, 0x1000) +/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE (12 * 1024) +#define CONFIG_SPL_STACK (16 * 1024) + +#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_BSS_MAX_SIZE (2 * 1024) + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_RAW_ONLY +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#define CONFIG_SYS_NAND_SIZE (256*1024*1024) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63, } + +#define CONFIG_SPL_ATMEL_SIZE +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define AT91_PLL_LOCK_TIMEOUT 1000000 +#define CONFIG_SYS_AT91_PLLA 0x20c73f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define ATMEL_BASE_MPDDRC ATMEL_BASE_DDRSDRC0
#endif
Bo Shen
Heiko Schocher
Scott Wood
