[PATCH 1/2] arm: mediatek: add mt8195 SOC support
The MediaTek MT8195 is a ARM64-based SoC with a quad-core Cortex-A73 and a quad-core Cortex-A53. It is including UART, SPI, USB3.0 device and hosts, SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
Signed-off-by: Fabien Parent fparent@baylibre.com Signed-off-by: Macpaul Lin macpaul.lin@mediatek.com --- MAINTAINERS | 2 + arch/arm/dts/mt8195.dtsi | 317 +++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 13 +- arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8195/Makefile | 3 + arch/arm/mach-mediatek/mt8195/init.c | 81 +++++++ 6 files changed, 416 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/mt8195.dtsi create mode 100644 arch/arm/mach-mediatek/mt8195/Makefile create mode 100644 arch/arm/mach-mediatek/mt8195/init.c
diff --git a/MAINTAINERS b/MAINTAINERS index 1cf99c1393..5528dd28c3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -362,8 +362,10 @@ ARM MEDIATEK M: Ryder Lee ryder.lee@mediatek.com M: Weijie Gao weijie.gao@mediatek.com M: Chunfeng Yun chunfeng.yun@mediatek.com +M: Macpaul Lin macpaul.lin@mediatek.com R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com S: Maintained +F: arch/arm/dts/mt8195.dtsi F: arch/arm/mach-mediatek/ F: arch/arm/include/asm/arch-mediatek/ F: board/mediatek/ diff --git a/arch/arm/dts/mt8195.dtsi b/arch/arm/dts/mt8195.dtsi new file mode 100644 index 0000000000..d28b038d57 --- /dev/null +++ b/arch/arm/dts/mt8195.dtsi @@ -0,0 +1,317 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Ben Ho ben.ho@mediatek.com + * Erin Lo erin.lo@mediatek.com + * Fabien Parent fparent@baylibre.com + * Macpaul Lin macpaul.lin@mediatek.com + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "mediatek,mt8195"; + interrupt-parent = <&sysirq>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu4>; + }; + core1 { + cpu = <&cpu5>; + }; + core2 { + cpu = <&cpu6>; + }; + core3 { + cpu = <&cpu7>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x000>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x001>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x002>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x003>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu4: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x100>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu5: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x101>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu6: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x102>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu7: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x103>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + }; + + clk26m: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + clock-output-names = "clk26m"; + }; + + mmc_source_clk: mmc-source-clk{ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <400000000>; + clock-output-names = "mmc_source_clk"; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + + watchdog: watchdog@10007000 { + compatible = "mediatek,mt8195-wdt", + "mediatek,wdt"; + reg = <0 0x10007000 0 0x100>; + status = "disabled"; + }; + + gic: interrupt-controller@c000000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <4>; + interrupt-parent = <&gic>; + interrupt-controller; + reg = <0 0x0c000000 0 0x40000>, /* GICD */ + <0 0x0c100000 0 0x200000>, /* GICR */ + <0 0x0c400000 0 0x2000>, /* GICC */ + <0 0x0c410000 0 0x1000>, /* GICH */ + <0 0x0c420000 0 0x2000>; /* GICV */ + + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu0 &cpu1 &cpu2 &cpu3>; + }; + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu4 &cpu5 &cpu6 &cpu7>; + }; + }; + }; + + sysirq: interrupt-controller@c530a80 { + compatible = "mediatek,mt8195-sysirq", + "mediatek,mt6577-sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0 0x0c530a80 0 0x50>; + }; + + topckgen: syscon@10000000 { + compatible = "mediatek,mt8195-topckgen", "syscon"; + reg = <0 0x10000000 0 0x1000>; + #clock-cells = <1>; + }; + + infracfg: syscon@10001000 { + compatible = "mediatek,mt8195-infracfg", "syscon"; + reg = <0 0x10001000 0 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: syscon@1000c000 { + compatible = "mediatek,mt8195-apmixedsys", "syscon"; + reg = <0 0x1000c000 0 0x1000>; + #clock-cells = <1>; + }; + + uart0: serial@11001100 { + compatible = "mediatek,mt8195-uart", + "mediatek,hsuart"; + reg = <0 0x11001100 0 0x1000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_LOW>; + clock-frequency = <26000000>; + clocks = <&clk26m>, <&clk26m>; + clock-names = "baud", "bus"; + status = "disabled"; + }; + + mmc0: mmc@11230000 { + compatible = "mediatek,mt8195-mmc", + "mediatek,mt8183-mmc"; + reg = <0 0x11230000 0 0x1000>, + <0 0x11f50000 0 0x1000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_LOW>; + clocks = <&mmc_source_clk>, + <&clk26m>, + <&clk26m>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + u3phy0: usb-phy@11f40000 { + compatible = "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e40000 0xe00>; + status = "okay"; + + u2port0: usb-phy@0 { + reg = <0 0x700>; + clocks = <&clk26m>, + <&clk26m>; + clock-names = "ref", "da_ref"; + #phy-cells = <1>; + status = "okay"; + }; + + u3port0: usb-phy@700 { + reg = <0x700 0x700>; + clocks = <&clk26m>, + <&clk26m>; + clock-names = "ref", "da_ref"; + #phy-cells = <1>; + status = "okay"; + }; + }; + + usb: usb@11200000 { + compatible ="mediatek,mt8195-mtu3", "mediatek,mtu3"; + reg = <0 0x11200000 0 0x3e00>, + <0 0x11203e00 0 0x0100>; + reg-names = "mac", "ippc"; + phys = <&u2port0 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "ref_ck", "mcu_ck"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + ssusb: ssusb@11200000 { + compatible = "mediatek,ssusb"; + reg = <0 0x11200000 0 0x3e00>; + reg-names = "mac"; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_LOW>; + status = "disabled"; + }; + + xhci0: xhci@11200000 { + compatible = "mediatek,mtk-xhci"; + reg = <0 0x11200000 0 0x1000>; + reg-names = "mac"; + interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + }; + + u3phy3: t-phy@11c50000 { + compatible = "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c50000 0x700>; + status = "okay"; + + u2port3: usb-phy@0 { + reg = <0x0 0x700>; + clocks = <&clk26m>; + clock-names = "ref"; + #phy-cells = <1>; + }; + }; + + xhci3: xhci3@112b0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112b0000 0 0x1000>, + <0 0x112b3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 536 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port3 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + usb2-lpm-disable; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 04aa2fd97f..3a2af1cdee 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -67,6 +67,15 @@ config TARGET_MT8183 SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
+config TARGET_MT8195 + bool "MediaTek MT8195 SoC" + select ARM64 + help + The MediaTek MT8195 is a ARM64-based SoC with a quad-core Cortex-A73 and + a quad-core Cortex-A53. It is including UART, SPI, USB3.0 device and hosts, + SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 + and LPDDR4 options. + config TARGET_MT8512 bool "MediaTek MT8512 M1 Board" select ARM64 @@ -105,6 +114,7 @@ config SYS_BOARD default "mt7981" if TARGET_MT7981 default "mt7986" if TARGET_MT7986 default "mt8183" if TARGET_MT8183 + default "mt8195" if TARGET_MT8195 default "mt8512" if TARGET_MT8512 default "mt8516" if TARGET_MT8516 default "mt8518" if TARGET_MT8518 @@ -122,6 +132,7 @@ config SYS_CONFIG_NAME default "mt7981" if TARGET_MT7981 default "mt7986" if TARGET_MT7986 default "mt8183" if TARGET_MT8183 + default "mt8195" if TARGET_MT8195 default "mt8512" if TARGET_MT8512 default "mt8516" if TARGET_MT8516 default "mt8518" if TARGET_MT8518 @@ -134,7 +145,7 @@ config SYS_CONFIG_NAME config MTK_BROM_HEADER_INFO string default "media=nor" if TARGET_MT8518 || TARGET_MT8512 || TARGET_MT7629 || TARGET_MT7622 - default "media=emmc" if TARGET_MT8516 || TARGET_MT8365 || TARGET_MT8183 + default "media=emmc" if TARGET_MT8516 || TARGET_MT8365 || TARGET_MT8183 || TARGET_MT8195 default "media=snand;nandinfo=2k+64" if TARGET_MT7981 || TARGET_MT7986 default "lk=1" if TARGET_MT7623
diff --git a/arch/arm/mach-mediatek/Makefile b/arch/arm/mach-mediatek/Makefile index fc85293f71..fbbb5431d1 100644 --- a/arch/arm/mach-mediatek/Makefile +++ b/arch/arm/mach-mediatek/Makefile @@ -10,5 +10,6 @@ obj-$(CONFIG_TARGET_MT7629) += mt7629/ obj-$(CONFIG_TARGET_MT7981) += mt7981/ obj-$(CONFIG_TARGET_MT7986) += mt7986/ obj-$(CONFIG_TARGET_MT8183) += mt8183/ +obj-$(CONFIG_TARGET_MT8195) += mt8195/ obj-$(CONFIG_TARGET_MT8516) += mt8516/ obj-$(CONFIG_TARGET_MT8518) += mt8518/ diff --git a/arch/arm/mach-mediatek/mt8195/Makefile b/arch/arm/mach-mediatek/mt8195/Makefile new file mode 100644 index 0000000000..886ab7e4eb --- /dev/null +++ b/arch/arm/mach-mediatek/mt8195/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += init.o diff --git a/arch/arm/mach-mediatek/mt8195/init.c b/arch/arm/mach-mediatek/mt8195/init.c new file mode 100644 index 0000000000..1eb4ade6c5 --- /dev/null +++ b/arch/arm/mach-mediatek/mt8195/init.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Macpaul Lin macpaul.lin@mediatek.com + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <ram.h> +#include <asm/arch/misc.h> +#include <asm/armv8/mmu.h> +#include <asm/sections.h> +#include <asm/system.h> +#include <dm/uclass.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = gd->ram_base; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int mtk_pll_early_init(void) +{ + return 0; +} + +int mtk_soc_early_init(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ + psci_system_reset(); +} + +int print_cpuinfo(void) +{ + printf("CPU: MediaTek MT8195\n"); + return 0; +} + +static struct mm_region mt8195_mem_map[] = { + { + /* DDR */ + .virt = 0x40000000UL, + .phys = 0x40000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_OUTER_SHARE, + }, { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + 0, + } +}; + +struct mm_region *mem_map = mt8195_mem_map;
Add mt8195-demo board support. This demo purpose board uses MediaTek's MT8195 SoC.
Signed-off-by: Fabien Parent fparent@baylibre.com Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com Signed-off-by: Macpaul Lin macpaul.lin@mediatek.com --- MAINTAINERS | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/mt8195-demo.dts | 109 ++++++++++++++++++++++++++++ board/mediatek/mt8195/MAINTAINERS | 6 ++ board/mediatek/mt8195/Makefile | 3 + board/mediatek/mt8195/mt8195_demo.c | 38 ++++++++++ configs/mt8195_demo_defconfig | 89 +++++++++++++++++++++++ include/configs/mt8195.h | 34 +++++++++ 8 files changed, 281 insertions(+) create mode 100644 arch/arm/dts/mt8195-demo.dts create mode 100644 board/mediatek/mt8195/MAINTAINERS create mode 100644 board/mediatek/mt8195/Makefile create mode 100644 board/mediatek/mt8195/mt8195_demo.c create mode 100644 configs/mt8195_demo_defconfig create mode 100644 include/configs/mt8195.h
diff --git a/MAINTAINERS b/MAINTAINERS index 5528dd28c3..5aaeeb02cb 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -389,6 +389,7 @@ F: drivers/watchdog/mtk_wdt.c F: drivers/net/mtk_eth.c F: drivers/net/mtk_eth.h F: drivers/reset/reset-mediatek.c +F: include/configs/mt8195.h F: tools/mtk_image.c F: tools/mtk_image.h F: tools/mtk_nand_headers.c diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 791838733c..994f7ebcc0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1271,6 +1271,7 @@ dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7986a-emmc-rfb.dtb \ mt7986b-emmc-rfb.dtb \ mt8183-pumpkin.dtb \ + mt8195-demo.dtb \ mt8512-bm1-emmc.dtb \ mt8516-pumpkin.dtb \ mt8518-ap1-emmc.dtb diff --git a/arch/arm/dts/mt8195-demo.dts b/arch/arm/dts/mt8195-demo.dts new file mode 100644 index 0000000000..bd0952b248 --- /dev/null +++ b/arch/arm/dts/mt8195-demo.dts @@ -0,0 +1,109 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre SAS. + * Author: Macpaul Lin macpaul.lin@mediatek.com + * Author: Fabien Parent fparent@baylibre.com + */ + +/dts-v1/; + +#include <config.h> +#include "mt8195.dtsi" + +/ { + model = "MediaTek MT8195 demo board"; + compatible = "mediatek,mt8195-demo", "mediatek,mt8195"; + + memory@40000000 { + device_type = "memory"; + reg = <0 0x40000000 0 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 2 MiB reserved for ARM Trusted Firmware (BL31) */ + bl31_secmon_reserved: secmon@54600000 { + no-map; + reg = <0 0x54600000 0x0 0x200000>; + }; + + /* 12 MiB reserved for OP-TEE (BL32) + * +-----------------------+ 0x43e0_0000 + * | SHMEM 2MiB | + * +-----------------------+ 0x43c0_0000 + * | | TA_RAM 8MiB | + * + TZDRAM +--------------+ 0x4340_0000 + * | | TEE_RAM 2MiB | + * +-----------------------+ 0x4320_0000 + */ + optee_reserved: optee@43200000 { + no-map; + reg = <0 0x43200000 0 0x00c00000>; + }; + }; + + chosen { + stdout-path = &uart0; + }; + + reg_1p8v: regulator-1p8v { + compatible = "regulator-fixed"; + regulator-name = "fixed-1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; +}; + +&watchdog { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&mmc0 { + bus-width = <4>; + max-frequency = <200000000>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + cap-mmc-hw-reset; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_1p8v>; + non-removable; + status = "okay"; +}; + +&usb { + status = "okay"; +}; + +&ssusb { + mediatek,force-vbus; + maximum-speed = "high-speed"; + dr_mode = "peripheral"; + status = "okay"; +}; + +&xhci0 { + status = "okay"; +}; + +&xhci3 { + status = "okay"; +}; diff --git a/board/mediatek/mt8195/MAINTAINERS b/board/mediatek/mt8195/MAINTAINERS new file mode 100644 index 0000000000..01fa25115d --- /dev/null +++ b/board/mediatek/mt8195/MAINTAINERS @@ -0,0 +1,6 @@ +MT8195 Demo +M: Macpaul Lin macpaul.lin@mediatek.com +S: Maintained +F: board/mediatek/mt8195 +F: include/configs/mt8195.h +F: configs/mt8195_demo_defconfig diff --git a/board/mediatek/mt8195/Makefile b/board/mediatek/mt8195/Makefile new file mode 100644 index 0000000000..7e94a87aea --- /dev/null +++ b/board/mediatek/mt8195/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += mt8195_demo.o diff --git a/board/mediatek/mt8195/mt8195_demo.c b/board/mediatek/mt8195/mt8195_demo.c new file mode 100644 index 0000000000..b95f5cf28d --- /dev/null +++ b/board/mediatek/mt8195/mt8195_demo.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 BayLibre SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <common.h> +#include <dm.h> +#include <net.h> +#include <asm/io.h> + +int board_init(void) +{ + struct udevice *dev; + int ret; + + if (CONFIG_IS_ENABLED(USB_GADGET)) { + ret = uclass_get_device(UCLASS_USB_GADGET_GENERIC, 0, &dev); + if (ret) { + pr_err("%s: Cannot find USB device\n", __func__); + return ret; + } + } + + if (CONFIG_IS_ENABLED(USB_ETHER)) + usb_ether_init(); + + printf("Disabling WDT\n"); + writel(0, 0x10007000); + + printf("Enabling SCP SRAM\n"); + for (unsigned int val = 0xFFFFFFFF; val != 0U;) { + val = val >> 1; + writel(val, 0x1072102C); + } + + return 0; +} diff --git a/configs/mt8195_demo_defconfig b/configs/mt8195_demo_defconfig new file mode 100644 index 0000000000..5b075b1a27 --- /dev/null +++ b/configs/mt8195_demo_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=13000000 +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_MEDIATEK=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="mt8195-demo" +CONFIG_TARGET_MT8195=y +CONFIG_DEBUG_UART_BASE=0x11001100 +CONFIG_DEBUG_UART_CLOCK=26000000 +# CONFIG_PSCI_RESET is not set +CONFIG_SYS_LOAD_ADDR=0x4c000000 +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="mt8195-demo" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_MEMORY is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_BLOCK_CACHE is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_ENV_IMPORT_FDT=y +CONFIG_DEVRES=y +CONFIG_CLK=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x4d000000 +CONFIG_FASTBOOT_BUF_SIZE=0x8000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +# CONFIG_INPUT is not set +# CONFIG_MMC_QUIRKS is not set +CONFIG_MMC_MTK=y +CONFIG_PHY=y +CONFIG_PHY_MTK_TPHY=y +CONFIG_BAUDRATE=921600 +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_MTK_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_MTK=y +CONFIG_USB_MTU3=y +CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0e8d +CONFIG_USB_GADGET_PRODUCT_NUM=0x201c +CONFIG_USB_ETHER=y +CONFIG_WDT=y +CONFIG_WDT_MTK=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/mt8195.h b/include/configs/mt8195.h new file mode 100644 index 0000000000..22bcf87794 --- /dev/null +++ b/include/configs/mt8195.h @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration for MT8195 based boards + * + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Fabien Parent macpaul.lin@mediatek.com + * Author: Fabien Parent fparent@baylibre.com + */ + +#ifndef __MT8195_H +#define __MT8195_H + +#include <linux/sizes.h> + +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_COM1 0x11002000 +#define CONFIG_SYS_NS16550_CLK 26000000 + +/* Environment settings */ +#include <config_distro_bootcmd.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#if !defined(CONFIG_EXTRA_ENV_SETTINGS) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "scriptaddr=0x40000000\0" \ + BOOTENV +#endif + +#endif
Hello! I'm not mediatek maintainer and if this patch series is not something important for me which should I review then please do not send me lot of these emails... As I would have time to review stuff which are important.
- Copyright (C) 2022 MediaTek Inc.
- Copyright (C) 2022 BayLibre, SAS
- Author: Ben Ho ben.ho@mediatek.com
Erin Lo <erin.lo@mediatek.com>
Fabien Parent <fparent@baylibre.com>
Macpaul Lin <macpaul.lin@mediatek.com>
- compatible = "mediatek,mt8195";
- interrupt-parent = <&sysirq>;
- #address-cells = <2>;
- #size-cells = <2>;
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
cluster1 {
core0 {
cpu = <&cpu4>;
core1 {
cpu = <&cpu5>;
core2 {
cpu = <&cpu6>;
core3 {
cpu = <&cpu7>;
cpu0: cpu@0 {
reg = <0x000>;
cpu1: cpu@1 {
reg = <0x001>;
cpu2: cpu@2 {
reg = <0x002>;
cpu3: cpu@3 {
reg = <0x003>;
cpu4: cpu@100 {
reg = <0x100>;
cpu5: cpu@101 {
reg = <0x101>;
cpu6: cpu@102 {
reg = <0x102>;
cpu7: cpu@103 {
reg = <0x103>;
- clk26m: oscillator {
#clock-cells = <0>;
- mmc_source_clk: mmc-source-clk{
#clock-cells = <0>;
- soc {
#size-cells = <2>;
ranges;
"mediatek,wdt";
ppi-partitions {
#clock-cells = <1>;
#clock-cells = <1>;
#clock-cells = <1>;
"mediatek,hsuart";
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0 0x700>;
clocks = <&clk26m>,
<&clk26m>;
#phy-cells = <1>;
status = "okay";
clocks = <&clk26m>,
<&clk26m>;
#phy-cells = <1>;
status = "okay";
usb: usb@11200000 {
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <2>;
ranges;
reg-names = "mac";
reg-names = "mac";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0x0 0x700>;
clocks = <&clk26m>;
#phy-cells = <1>;
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
usb2-lpm-disable;
- bool "MediaTek MT8195 SoC"
- select ARM64
- help
and LPDDR4 options.
- default "mt8195" if TARGET_MT8195 default "mt8512" if TARGET_MT8512 default "mt8516" if TARGET_MT8516 default "mt8518" if TARGET_MT8518
- default "media=emmc" if TARGET_MT8516 || TARGET_MT8365 || TARGET_MT8183 || TARGET_MT8195 default "media=snand;nandinfo=2k+64" if TARGET_MT7981 || TARGET_MT7986 default "lk=1" if TARGET_MT7623
- Author: Macpaul Lin macpaul.lin@mediatek.com
- Author: Fabien Parent fparent@baylibre.com
- int ret;
- ret = fdtdec_setup_memory_banksize();
- if (ret)
return ret;
- return fdtdec_setup_mem_size_base();
- gd->bd->bi_dram[0].start = gd->ram_base;
- gd->bd->bi_dram[0].size = gd->ram_size;
- psci_system_reset();
- printf("CPU: MediaTek MT8195\n");
/* DDR */
0,
2.18.0
I'm so sorry for bothering you and other developers. I've used ./scripts/get_maintainer.pl to check these 2 patches and found you all in the suggestion list.
Result: "Pali Rohár" pali@kernel.org (added_lines:16/253=6%,removed_lines:12/76=16%)
I'll remove Pali when I send next version. Who else don't want to be involved in these reviewing activities of MediaTek platforms, please let us know.
[deleted]
Thanks! Macpaul Lin
+ Tom - all
[deleted]
Thanks! Macpaul Lin
I think that this is improper configuration of that get_maintainer.pl script. As it currently spams tons of people. And it is not really a good idea to spam people about unrelated stuff. Tom, could you do something with it?
On Wed, Nov 09, 2022 at 09:09:28PM +0100, Pali Rohár wrote:
- Tom
- all
[deleted]
Thanks! Macpaul Lin
I've been waiting for someone to submit a patch to tweak .get_maintainers.conf based on what I think Sean suggested last time. But in this case I'm not even sure what file was suggesting you.
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
cluster1 {
core0 {
cpu = <&cpu4>;
core1 {
cpu = <&cpu5>;
core2 {
cpu = <&cpu6>;
core3 {
cpu = <&cpu7>;
cpu0: cpu@0 {
reg = <0x000>;
cpu1: cpu@1 {
reg = <0x001>;
cpu2: cpu@2 {
reg = <0x002>;
cpu3: cpu@3 {
reg = <0x003>;
cpu4: cpu@100 {
reg = <0x100>;
cpu5: cpu@101 {
reg = <0x101>;
cpu6: cpu@102 {
reg = <0x102>;
cpu7: cpu@103 {
reg = <0x103>;
#clock-cells = <0>;
#clock-cells = <0>;
- soc {
#size-cells = <2>;
ranges;
"mediatek,wdt";
ppi-partitions {
&cpu3>;
&cpu7>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"mediatek,hsuart";
<&clk26m>,
<&clk26m>;
change node name as t-phy as u3phy3?
prefer to add "mediatek,mt8195-tphy" before generic's
#size-cells = <1>;
status = "okay";
reg = <0 0x700>;
clocks = <&clk26m>,
<&clk26m>;
these two clocks are optional, if sw can't control it, no need add it here.
#phy-cells = <1>;
status = "okay";
clocks = <&clk26m>,
<&clk26m>;
ditto
#phy-cells = <1>;
status = "okay";
usb: usb@11200000 {
"mediatek,mtu3";
"mac" can be removed, the driver get it from the first child node
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <2>;
ranges;
reg-names = "mac";
reg-names = "mac";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"ref_ck", "mcu_ck";
add specific one
#size-cells = <1>;
status = "okay";
reg = <0x0 0x700>;
clocks = <&clk26m>;
#phy-cells = <1>;
change node name as xhci? prefer to use the same name
remove "mac"
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
usb2-lpm-disable;
+}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach- mediatek/Kconfig index 04aa2fd97f..3a2af1cdee 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -67,6 +67,15 @@ config TARGET_MT8183 SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
- select ARM64
- help
Cortex-A73 and
device and hosts,
LPDDR3
and LPDDR4 options.
TARGET_MT8183
diff --git a/arch/arm/mach-mediatek/Makefile b/arch/arm/mach- mediatek/Makefile index fc85293f71..fbbb5431d1 100644 --- a/arch/arm/mach-mediatek/Makefile +++ b/arch/arm/mach-mediatek/Makefile @@ -10,5 +10,6 @@ obj-$(CONFIG_TARGET_MT7629) += mt7629/ obj-$(CONFIG_TARGET_MT7981) += mt7981/ obj-$(CONFIG_TARGET_MT7986) += mt7986/ obj-$(CONFIG_TARGET_MT8183) += mt8183/ +obj-$(CONFIG_TARGET_MT8195) += mt8195/ obj-$(CONFIG_TARGET_MT8516) += mt8516/ obj-$(CONFIG_TARGET_MT8518) += mt8518/ diff --git a/arch/arm/mach-mediatek/mt8195/Makefile b/arch/arm/mach- mediatek/mt8195/Makefile new file mode 100644 index 0000000000..886ab7e4eb --- /dev/null +++ b/arch/arm/mach-mediatek/mt8195/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0
+obj-y += init.o diff --git a/arch/arm/mach-mediatek/mt8195/init.c b/arch/arm/mach- mediatek/mt8195/init.c new file mode 100644 index 0000000000..1eb4ade6c5 --- /dev/null +++ b/arch/arm/mach-mediatek/mt8195/init.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- int ret;
- if (ret)
return ret;
/* DDR */
0,
[deleted]
Got it, will fix it in next version.
Will fix it in next version.
#size-cells = <1>;
status = "okay";
reg = <0 0x700>;
clocks = <&clk26m>,
<&clk26m>;
MediaTek's clock driver developer will upstream clock driver when refactoring work has been completed. Before clock driver is applied to trunk, we can use clk26m only. Will fix it in next version.
#phy-cells = <1>;
status = "okay";
clocks = <&clk26m>,
<&clk26m>;
ditto
#phy-cells = <1>;
status = "okay";
usb: usb@11200000 {
"mediatek,mtu3";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <2>;
ranges;
reg-names = "mac";
reg-names = "mac";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"ref_ck", "mcu_ck";
add specific one
#size-cells = <1>;
status = "okay";
reg = <0x0 0x700>;
clocks = <&clk26m>;
#phy-cells = <1>;
Since there are other board manufacturers will use the other HOST ports, like xhci1 or xhci2 with USB mass storage function by their needs. I'll add these 2 node in dtsi in next version.
remove "mac"
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
usb2-lpm-disable;
- select ARM64
- help
Cortex-A73 and
device and hosts,
LPDDR3
and LPDDR4 options.
- config TARGET_MT8512 bool "MediaTek MT8512 M1 Board" select ARM64
TARGET_MT8183
- int ret;
- if (ret)
return ret;
/* DDR */
0,
Thanks a lot! Macpaul Lin
[deleted]
remove "mac"
Dear Chunfeng,
Unfortunately, if we remove "mac" register here for HOST only node like xhci3, the driver will complain about probing fail. Please check the following log.
=> usb start starting USB... Bus xhci3@112b0000: xhci-mtk xhci3@112b0000: failed to get xHCI base address probe failed, error -6 No working controllers found
I'll add "mac" back to HOST only nodes.
Thanks! Macpaul Lin
[deleted]
remove "mac"
Dear Chunfeng,
My bad, do need it for host only mode, sorry
Thanks! Macpaul Lin
--- MAINTAINERS | 2 + arch/arm/dts/mt8195.dtsi | 370 +++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 13 +- arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8195/Makefile | 3 + arch/arm/mach-mediatek/mt8195/init.c | 81 ++++++ 6 files changed, 469 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/mt8195.dtsi create mode 100644 arch/arm/mach-mediatek/mt8195/Makefile create mode 100644 arch/arm/mach-mediatek/mt8195/init.c
Changes for v2: - Correct node name to t-phy for u3phy0. - Add platform compatible string "mediatek,mt8195-tphy" to all usb phy nodes. - remove clock nodes that software cannot controlled in phy nodes. - Test and add back "mac" for HOST only xhci nodes.
diff --git a/MAINTAINERS b/MAINTAINERS index 1cf99c1393..5528dd28c3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -362,8 +362,10 @@ ARM MEDIATEK M: Ryder Lee ryder.lee@mediatek.com M: Weijie Gao weijie.gao@mediatek.com M: Chunfeng Yun chunfeng.yun@mediatek.com +M: Macpaul Lin macpaul.lin@mediatek.com R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com S: Maintained +F: arch/arm/dts/mt8195.dtsi F: arch/arm/mach-mediatek/ F: arch/arm/include/asm/arch-mediatek/ F: board/mediatek/ diff --git a/arch/arm/dts/mt8195.dtsi b/arch/arm/dts/mt8195.dtsi new file mode 100644 index 0000000000..33282d21d1 --- /dev/null +++ b/arch/arm/dts/mt8195.dtsi @@ -0,0 +1,370 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Ben Ho ben.ho@mediatek.com + * Erin Lo erin.lo@mediatek.com + * Fabien Parent fparent@baylibre.com + * Macpaul Lin macpaul.lin@mediatek.com + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "mediatek,mt8195"; + interrupt-parent = <&sysirq>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu4>; + }; + core1 { + cpu = <&cpu5>; + }; + core2 { + cpu = <&cpu6>; + }; + core3 { + cpu = <&cpu7>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x000>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x001>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x002>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x003>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu4: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x100>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu5: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x101>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu6: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x102>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu7: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x103>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + }; + + clk26m: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + clock-output-names = "clk26m"; + }; + + mmc_source_clk: mmc-source-clk{ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <400000000>; + clock-output-names = "mmc_source_clk"; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + + watchdog: watchdog@10007000 { + compatible = "mediatek,mt8195-wdt", + "mediatek,wdt"; + reg = <0 0x10007000 0 0x100>; + status = "disabled"; + }; + + gic: interrupt-controller@c000000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <4>; + interrupt-parent = <&gic>; + interrupt-controller; + reg = <0 0x0c000000 0 0x40000>, /* GICD */ + <0 0x0c100000 0 0x200000>, /* GICR */ + <0 0x0c400000 0 0x2000>, /* GICC */ + <0 0x0c410000 0 0x1000>, /* GICH */ + <0 0x0c420000 0 0x2000>; /* GICV */ + + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu0 &cpu1 &cpu2 &cpu3>; + }; + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu4 &cpu5 &cpu6 &cpu7>; + }; + }; + }; + + sysirq: interrupt-controller@c530a80 { + compatible = "mediatek,mt8195-sysirq", + "mediatek,mt6577-sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0 0x0c530a80 0 0x50>; + }; + + topckgen: syscon@10000000 { + compatible = "mediatek,mt8195-topckgen", "syscon"; + reg = <0 0x10000000 0 0x1000>; + #clock-cells = <1>; + }; + + infracfg: syscon@10001000 { + compatible = "mediatek,mt8195-infracfg", "syscon"; + reg = <0 0x10001000 0 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: syscon@1000c000 { + compatible = "mediatek,mt8195-apmixedsys", "syscon"; + reg = <0 0x1000c000 0 0x1000>; + #clock-cells = <1>; + }; + + uart0: serial@11001100 { + compatible = "mediatek,mt8195-uart", + "mediatek,hsuart"; + reg = <0 0x11001100 0 0x1000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_LOW>; + clock-frequency = <26000000>; + clocks = <&clk26m>, <&clk26m>; + clock-names = "baud", "bus"; + status = "disabled"; + }; + + mmc0: mmc@11230000 { + compatible = "mediatek,mt8195-mmc", + "mediatek,mt8183-mmc"; + reg = <0 0x11230000 0 0x1000>, + <0 0x11f50000 0 0x1000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_LOW>; + clocks = <&mmc_source_clk>, + <&clk26m>, + <&clk26m>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + u3phy0: t-phy@11f40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e40000 0xe00>; + status = "okay"; + + u2port0: usb-phy@0 { + reg = <0 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + + u3port0: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + }; + + usb: usb@11200000 { + compatible ="mediatek,mt8195-mtu3", "mediatek,mtu3"; + reg = <0 0x11203e00 0 0x0100>; + reg-names = "ippc"; + phys = <&u2port0 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "ref_ck", "mcu_ck"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + ssusb: ssusb@11200000 { + compatible = "mediatek,ssusb"; + reg = <0 0x11200000 0 0x3e00>; + reg-names = "mac"; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_LOW>; + status = "disabled"; + }; + + xhci0: xhci@11200000 { + compatible = "mediatek,mtk-xhci"; + reg = <0 0x11200000 0 0x1000>; + reg-names = "mac"; + interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + }; + + u3phy1: t-phy@11e30000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e30000 0xe00>; + status = "disabled"; + + u2port1: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + + u3port1: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + }; + }; + + xhci1: xhci1@11290000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x11290000 0 0x1000>, + <0 0x11293e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 530 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port1 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + + u3phy2: t-phy@11c40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c40000 0x700>; + status = "disabled"; + + u2port2: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci2: xhci2@112a0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112a0000 0 0x1000>, + <0 0x112a3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 533 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port2 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + status = "disabled"; + }; + + u3phy3: t-phy@11c50000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c50000 0x700>; + status = "okay"; + + u2port3: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci3: xhci3@112b0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112b0000 0 0x1000>, + <0 0x112b3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 536 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port3 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + usb2-lpm-disable; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 04aa2fd97f..3a2af1cdee 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -67,6 +67,15 @@ config TARGET_MT8183 SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
Changes for v2: - no change.
Changes for v2:
phy nodes.
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
cluster1 {
core0 {
cpu = <&cpu4>;
core1 {
cpu = <&cpu5>;
core2 {
cpu = <&cpu6>;
core3 {
cpu = <&cpu7>;
cpu0: cpu@0 {
reg = <0x000>;
cpu1: cpu@1 {
reg = <0x001>;
cpu2: cpu@2 {
reg = <0x002>;
cpu3: cpu@3 {
reg = <0x003>;
cpu4: cpu@100 {
reg = <0x100>;
cpu5: cpu@101 {
reg = <0x101>;
cpu6: cpu@102 {
reg = <0x102>;
cpu7: cpu@103 {
reg = <0x103>;
#clock-cells = <0>;
#clock-cells = <0>;
- soc {
#size-cells = <2>;
ranges;
"mediatek,wdt";
ppi-partitions {
&cpu3>;
&cpu7>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"mediatek,hsuart";
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0 0x700>;
#phy-cells = <1>;
status = "okay";
#phy-cells = <1>;
status = "okay";
usb: usb@11200000 {
"mediatek,mtu3";
reg-names = "ippc";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <2>;
ranges;
reg-names = "mac";
reg-names = "mac";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"ref_ck", "mcu_ck";
#size-cells = <1>;
reg = <0x0 0x700>;
#phy-cells = <1>;
#phy-cells = <1>;
Prefer to use 'xchi' as node name, but it's ok to use 'xhci1' as a label.
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"mcu_ck";
#size-cells = <1>;
reg = <0x0 0x700>;
#phy-cells = <1>;
xhci2: xhci@112a0000
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0x0 0x700>;
#phy-cells = <1>;
xhci3: xhci@112b0000
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
usb2-lpm-disable;
- select ARM64
- help
Cortex-A73 and
device and hosts,
LPDDR3
and LPDDR4 options.
TARGET_MT8183
- int ret;
- if (ret)
return ret;
/* DDR */
0,
Changes for v3: - Revise device node name from "xhciX: xhciX@" to "xhciX: xhci@".
diff --git a/MAINTAINERS b/MAINTAINERS index 1cf99c1393..5528dd28c3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -362,8 +362,10 @@ ARM MEDIATEK M: Ryder Lee ryder.lee@mediatek.com M: Weijie Gao weijie.gao@mediatek.com M: Chunfeng Yun chunfeng.yun@mediatek.com +M: Macpaul Lin macpaul.lin@mediatek.com R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com S: Maintained +F: arch/arm/dts/mt8195.dtsi F: arch/arm/mach-mediatek/ F: arch/arm/include/asm/arch-mediatek/ F: board/mediatek/ diff --git a/arch/arm/dts/mt8195.dtsi b/arch/arm/dts/mt8195.dtsi new file mode 100644 index 0000000000..33282d21d1 --- /dev/null +++ b/arch/arm/dts/mt8195.dtsi @@ -0,0 +1,370 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Ben Ho ben.ho@mediatek.com + * Erin Lo erin.lo@mediatek.com + * Fabien Parent fparent@baylibre.com + * Macpaul Lin macpaul.lin@mediatek.com + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "mediatek,mt8195"; + interrupt-parent = <&sysirq>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu4>; + }; + core1 { + cpu = <&cpu5>; + }; + core2 { + cpu = <&cpu6>; + }; + core3 { + cpu = <&cpu7>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x000>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x001>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x002>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x003>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu4: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x100>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu5: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x101>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu6: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x102>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu7: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x103>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + }; + + clk26m: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + clock-output-names = "clk26m"; + }; + + mmc_source_clk: mmc-source-clk{ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <400000000>; + clock-output-names = "mmc_source_clk"; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + + watchdog: watchdog@10007000 { + compatible = "mediatek,mt8195-wdt", + "mediatek,wdt"; + reg = <0 0x10007000 0 0x100>; + status = "disabled"; + }; + + gic: interrupt-controller@c000000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <4>; + interrupt-parent = <&gic>; + interrupt-controller; + reg = <0 0x0c000000 0 0x40000>, /* GICD */ + <0 0x0c100000 0 0x200000>, /* GICR */ + <0 0x0c400000 0 0x2000>, /* GICC */ + <0 0x0c410000 0 0x1000>, /* GICH */ + <0 0x0c420000 0 0x2000>; /* GICV */ + + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu0 &cpu1 &cpu2 &cpu3>; + }; + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu4 &cpu5 &cpu6 &cpu7>; + }; + }; + }; + + sysirq: interrupt-controller@c530a80 { + compatible = "mediatek,mt8195-sysirq", + "mediatek,mt6577-sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0 0x0c530a80 0 0x50>; + }; + + topckgen: syscon@10000000 { + compatible = "mediatek,mt8195-topckgen", "syscon"; + reg = <0 0x10000000 0 0x1000>; + #clock-cells = <1>; + }; + + infracfg: syscon@10001000 { + compatible = "mediatek,mt8195-infracfg", "syscon"; + reg = <0 0x10001000 0 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: syscon@1000c000 { + compatible = "mediatek,mt8195-apmixedsys", "syscon"; + reg = <0 0x1000c000 0 0x1000>; + #clock-cells = <1>; + }; + + uart0: serial@11001100 { + compatible = "mediatek,mt8195-uart", + "mediatek,hsuart"; + reg = <0 0x11001100 0 0x1000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_LOW>; + clock-frequency = <26000000>; + clocks = <&clk26m>, <&clk26m>; + clock-names = "baud", "bus"; + status = "disabled"; + }; + + mmc0: mmc@11230000 { + compatible = "mediatek,mt8195-mmc", + "mediatek,mt8183-mmc"; + reg = <0 0x11230000 0 0x1000>, + <0 0x11f50000 0 0x1000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_LOW>; + clocks = <&mmc_source_clk>, + <&clk26m>, + <&clk26m>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + u3phy0: t-phy@11f40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e40000 0xe00>; + status = "okay"; + + u2port0: usb-phy@0 { + reg = <0 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + + u3port0: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + }; + + usb: usb@11200000 { + compatible ="mediatek,mt8195-mtu3", "mediatek,mtu3"; + reg = <0 0x11203e00 0 0x0100>; + reg-names = "ippc"; + phys = <&u2port0 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "ref_ck", "mcu_ck"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + ssusb: ssusb@11200000 { + compatible = "mediatek,ssusb"; + reg = <0 0x11200000 0 0x3e00>; + reg-names = "mac"; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_LOW>; + status = "disabled"; + }; + + xhci0: xhci@11200000 { + compatible = "mediatek,mtk-xhci"; + reg = <0 0x11200000 0 0x1000>; + reg-names = "mac"; + interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + }; + + u3phy1: t-phy@11e30000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e30000 0xe00>; + status = "disabled"; + + u2port1: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + + u3port1: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + }; + }; + + xhci1: xhci@11290000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x11290000 0 0x1000>, + <0 0x11293e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 530 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port1 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + + u3phy2: t-phy@11c40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c40000 0x700>; + status = "disabled"; + + u2port2: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci2: xhci@112a0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112a0000 0 0x1000>, + <0 0x112a3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 533 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port2 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + status = "disabled"; + }; + + u3phy3: t-phy@11c50000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c50000 0x700>; + status = "okay"; + + u2port3: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci3: xhci@112b0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112b0000 0 0x1000>, + <0 0x112b3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 536 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port3 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + usb2-lpm-disable; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 04aa2fd97f..3a2af1cdee 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -67,6 +67,15 @@ config TARGET_MT8183 SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
Changes for v2 and v3: - no change.
[snip]
This is unused, I believe. But when trying to build with current next I get: Error: Load Address must be set. Error: Bad parameters for image type
Please rebase on top of current next and repost, thanks!
[snip]
Sorry for the noise, this failed due to another patch that needs to be reworked instead.
[snip]
Welp, I should have finished my re-testing. The patch that broke phycore-rk3288 and I assumed broke this platform too, did not break this platform, there's still some other problem here.
[snip]
Thanks for the information, will send patch v4 later.
I've tested it on uboot/next and got the following result.
$ make ARCH=arm phycore-rk3288_defconfig $ make ARCH=arm scripts/kconfig/conf --syncconfig Kconfig UPD include/config.h CFG u-boot.cfg GEN include/autoconf.mk GEN include/autoconf.mk.dep CFG spl/u-boot.cfg GEN spl/include/autoconf.mk UPD include/config/uboot.release UPD include/generated/version_autogenerated.h UPD include/generated/timestamp_autogenerated.h UPD include/generated/dt.h ENVC include/generated/env.txt ENVP include/generated/env.in ENVT include/generated/environment.h CC lib/asm-offsets.s cc1: error: bad value (‘generic-armv7-a’) for ‘-mtune=’ switch cc1: note: valid arguments to ‘-mtune=’ switch are: nocona core2 nehalem corei7 westmere sandybridge corei7-avx ivybridge core-avx-i haswell core-avx2 broadwell skylake skylake-avx512 bonnell atom silvermont slm knl intel x86-64 eden-x2 nano nano-1000 nano-2000 nano-3000 nano-x2 eden-x4 nano-x4 k8 k8-sse3 opteron opteron-sse3 athlon64 athlon64-sse3 athlon-fx amdfam10 barcelona bdver1 bdver2 bdver3 bdver4 znver1 btver1 btver2 generic scripts/Makefile.build:147: recipe for target 'lib/asm-offsets.s' failed make[1]: *** [lib/asm-offsets.s] Error 1 Makefile:1932: recipe for target 'prepare0' failed make: *** [prepare0] Error 2
I'm not sure should I test it on custodian tree: arm/next, too. This failure seems not related to the 2nd patch of mt8195-demo board.
Thanks Macpaul Lin
[snip]
You don't pass ARCH= when building U-Boot, and you didn't set CROSS_COMPILE to your arm32 compiler, so that's why it failed there. v4 shows the same problem as v3 for me, so please make sure to build and boot v5, thanks.
Changes for v2:
phy nodes.
Changes for v3:
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
cluster1 {
core0 {
cpu = <&cpu4>;
core1 {
cpu = <&cpu5>;
core2 {
cpu = <&cpu6>;
core3 {
cpu = <&cpu7>;
cpu0: cpu@0 {
reg = <0x000>;
cpu1: cpu@1 {
reg = <0x001>;
cpu2: cpu@2 {
reg = <0x002>;
cpu3: cpu@3 {
reg = <0x003>;
cpu4: cpu@100 {
reg = <0x100>;
cpu5: cpu@101 {
reg = <0x101>;
cpu6: cpu@102 {
reg = <0x102>;
cpu7: cpu@103 {
reg = <0x103>;
#clock-cells = <0>;
#clock-cells = <0>;
- soc {
#size-cells = <2>;
ranges;
"mediatek,wdt";
ppi-partitions {
&cpu3>;
&cpu7>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"syscon";
#clock-cells = <1>;
"mediatek,hsuart";
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0 0x700>;
#phy-cells = <1>;
status = "okay";
#phy-cells = <1>;
status = "okay";
usb: usb@11200000 {
"mediatek,mtu3";
reg-names = "ippc";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <2>;
ranges;
reg-names = "mac";
reg-names = "mac";
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"ref_ck", "mcu_ck";
#size-cells = <1>;
reg = <0x0 0x700>;
#phy-cells = <1>;
#phy-cells = <1>;
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>,
<&clk26m>;
"mcu_ck";
#size-cells = <1>;
reg = <0x0 0x700>;
#phy-cells = <1>;
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
#size-cells = <1>;
status = "okay";
reg = <0x0 0x700>;
#phy-cells = <1>;
clocks = <&clk26m>,
<&clk26m>,
<&clk26m>;
usb2-lpm-disable;
For usb part:
Reviewed-by: Chunfeng Yun chunfeng.yun@mediatek.com
Thanks a lot
- select ARM64
- help
Cortex-A73 and
device and hosts,
LPDDR3
and LPDDR4 options.
TARGET_MT8183
- int ret;
- if (ret)
return ret;
/* DDR */
0,
Signed-off-by: Fabien Parent fparent@baylibre.com Signed-off-by: Macpaul Lin macpaul.lin@mediatek.com --- MAINTAINERS | 2 + arch/arm/dts/mt8195.dtsi | 370 +++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 13 +- arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8195/Makefile | 3 + arch/arm/mach-mediatek/mt8195/init.c | 81 ++++++ 6 files changed, 469 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/mt8195.dtsi create mode 100644 arch/arm/mach-mediatek/mt8195/Makefile create mode 100644 arch/arm/mach-mediatek/mt8195/init.c
Changes for v4: - No change.
diff --git a/MAINTAINERS b/MAINTAINERS index 75b27bc1cc..f2fe78dfc7 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -363,8 +363,10 @@ ARM MEDIATEK M: Ryder Lee ryder.lee@mediatek.com M: Weijie Gao weijie.gao@mediatek.com M: Chunfeng Yun chunfeng.yun@mediatek.com +M: Macpaul Lin macpaul.lin@mediatek.com R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com S: Maintained +F: arch/arm/dts/mt8195.dtsi F: arch/arm/mach-mediatek/ F: arch/arm/include/asm/arch-mediatek/ F: board/mediatek/ diff --git a/arch/arm/dts/mt8195.dtsi b/arch/arm/dts/mt8195.dtsi new file mode 100644 index 0000000000..bb6dead834 --- /dev/null +++ b/arch/arm/dts/mt8195.dtsi @@ -0,0 +1,370 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Ben Ho ben.ho@mediatek.com + * Erin Lo erin.lo@mediatek.com + * Fabien Parent fparent@baylibre.com + * Macpaul Lin macpaul.lin@mediatek.com + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "mediatek,mt8195"; + interrupt-parent = <&sysirq>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu4>; + }; + core1 { + cpu = <&cpu5>; + }; + core2 { + cpu = <&cpu6>; + }; + core3 { + cpu = <&cpu7>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x000>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x001>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x002>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x003>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu4: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x100>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu5: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x101>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu6: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x102>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu7: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x103>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + }; + + clk26m: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + clock-output-names = "clk26m"; + }; + + mmc_source_clk: mmc-source-clk{ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <400000000>; + clock-output-names = "mmc_source_clk"; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + + watchdog: watchdog@10007000 { + compatible = "mediatek,mt8195-wdt", + "mediatek,wdt"; + reg = <0 0x10007000 0 0x100>; + status = "disabled"; + }; + + gic: interrupt-controller@c000000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <4>; + interrupt-parent = <&gic>; + interrupt-controller; + reg = <0 0x0c000000 0 0x40000>, /* GICD */ + <0 0x0c100000 0 0x200000>, /* GICR */ + <0 0x0c400000 0 0x2000>, /* GICC */ + <0 0x0c410000 0 0x1000>, /* GICH */ + <0 0x0c420000 0 0x2000>; /* GICV */ + + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu0 &cpu1 &cpu2 &cpu3>; + }; + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu4 &cpu5 &cpu6 &cpu7>; + }; + }; + }; + + sysirq: interrupt-controller@c530a80 { + compatible = "mediatek,mt8195-sysirq", + "mediatek,mt6577-sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0 0x0c530a80 0 0x50>; + }; + + topckgen: syscon@10000000 { + compatible = "mediatek,mt8195-topckgen", "syscon"; + reg = <0 0x10000000 0 0x1000>; + #clock-cells = <1>; + }; + + infracfg: syscon@10001000 { + compatible = "mediatek,mt8195-infracfg", "syscon"; + reg = <0 0x10001000 0 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: syscon@1000c000 { + compatible = "mediatek,mt8195-apmixedsys", "syscon"; + reg = <0 0x1000c000 0 0x1000>; + #clock-cells = <1>; + }; + + uart0: serial@11001100 { + compatible = "mediatek,mt8195-uart", + "mediatek,hsuart"; + reg = <0 0x11001100 0 0x1000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_LOW>; + clock-frequency = <26000000>; + clocks = <&clk26m>, <&clk26m>; + clock-names = "baud", "bus"; + status = "disabled"; + }; + + mmc0: mmc@11230000 { + compatible = "mediatek,mt8195-mmc", + "mediatek,mt8183-mmc"; + reg = <0 0x11230000 0 0x1000>, + <0 0x11f50000 0 0x1000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_LOW>; + clocks = <&mmc_source_clk>, + <&clk26m>, + <&clk26m>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + u3phy0: t-phy@11f40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e40000 0xe00>; + status = "okay"; + + u2port0: usb-phy@0 { + reg = <0 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + + u3port0: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + status = "okay"; + }; + }; + + usb: usb@11200000 { + compatible ="mediatek,mt8195-mtu3", "mediatek,mtu3"; + reg = <0 0x11203e00 0 0x0100>; + reg-names = "ippc"; + phys = <&u2port0 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "ref_ck", "mcu_ck"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + ssusb: ssusb@11200000 { + compatible = "mediatek,ssusb"; + reg = <0 0x11200000 0 0x3e00>; + reg-names = "mac"; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_LOW>; + status = "disabled"; + }; + + xhci0: xhci@11200000 { + compatible = "mediatek,mtk-xhci"; + reg = <0 0x11200000 0 0x1000>; + reg-names = "mac"; + interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + }; + + u3phy1: t-phy@11e30000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11e30000 0xe00>; + status = "disabled"; + + u2port1: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + + u3port1: usb-phy@700 { + reg = <0x700 0x700>; + #phy-cells = <1>; + }; + }; + + xhci1: xhci@11290000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x11290000 0 0x1000>, + <0 0x11293e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 530 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port1 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck", "mcu_ck"; + status = "disabled"; + }; + + u3phy2: t-phy@11c40000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c40000 0x700>; + status = "disabled"; + + u2port2: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci2: xhci@112a0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112a0000 0 0x1000>, + <0 0x112a3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 533 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port2 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + status = "disabled"; + }; + + u3phy3: t-phy@11c50000 { + compatible = "mediatek,mt8195-tphy", "mediatek,generic-tphy-v2"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x11c50000 0x700>; + status = "okay"; + + u2port3: usb-phy@0 { + reg = <0x0 0x700>; + #phy-cells = <1>; + }; + }; + + xhci3: xhci@112b0000 { + compatible = "mediatek,mt8195-xhci", + "mediatek,mtk-xhci"; + reg = <0 0x112b0000 0 0x1000>, + <0 0x112b3e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 536 IRQ_TYPE_LEVEL_HIGH>; + phys = <&u2port3 PHY_TYPE_USB2>; + clocks = <&clk26m>, + <&clk26m>, + <&clk26m>; + clock-names = "sys_ck", "xhci_ck", "ref_ck"; + usb2-lpm-disable; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 04aa2fd97f..3a2af1cdee 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -67,6 +67,15 @@ config TARGET_MT8183 SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 and LPDDR4 options.
Signed-off-by: Fabien Parent fparent@baylibre.com Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com Signed-off-by: Macpaul Lin macpaul.lin@mediatek.com --- MAINTAINERS | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/mt8195-demo.dts | 109 ++++++++++++++++++++++++++++ board/mediatek/mt8195/MAINTAINERS | 6 ++ board/mediatek/mt8195/Makefile | 3 + board/mediatek/mt8195/mt8195_demo.c | 38 ++++++++++ configs/mt8195_demo_defconfig | 89 +++++++++++++++++++++++ include/configs/mt8195.h | 28 +++++++ 8 files changed, 275 insertions(+) create mode 100644 arch/arm/dts/mt8195-demo.dts create mode 100644 board/mediatek/mt8195/MAINTAINERS create mode 100644 board/mediatek/mt8195/Makefile create mode 100644 board/mediatek/mt8195/mt8195_demo.c create mode 100644 configs/mt8195_demo_defconfig create mode 100644 include/configs/mt8195.h
Changes for v4: - Remove CONFIG_SYS_NS16550 related settings in mt8195.h - Tested with u-boot/next.
diff --git a/MAINTAINERS b/MAINTAINERS index f2fe78dfc7..3c7db798be 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -390,6 +390,7 @@ F: drivers/watchdog/mtk_wdt.c F: drivers/net/mtk_eth.c F: drivers/net/mtk_eth.h F: drivers/reset/reset-mediatek.c +F: include/configs/mt8195.h F: tools/mtk_image.c F: tools/mtk_image.h F: tools/mtk_nand_headers.c diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b3baaf4829..5ab10ac3db 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1278,6 +1278,7 @@ dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7986a-emmc-rfb.dtb \ mt7986b-emmc-rfb.dtb \ mt8183-pumpkin.dtb \ + mt8195-demo.dtb \ mt8512-bm1-emmc.dtb \ mt8516-pumpkin.dtb \ mt8518-ap1-emmc.dtb diff --git a/arch/arm/dts/mt8195-demo.dts b/arch/arm/dts/mt8195-demo.dts new file mode 100644 index 0000000000..bd0952b248 --- /dev/null +++ b/arch/arm/dts/mt8195-demo.dts @@ -0,0 +1,109 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre SAS. + * Author: Macpaul Lin macpaul.lin@mediatek.com + * Author: Fabien Parent fparent@baylibre.com + */ + +/dts-v1/; + +#include <config.h> +#include "mt8195.dtsi" + +/ { + model = "MediaTek MT8195 demo board"; + compatible = "mediatek,mt8195-demo", "mediatek,mt8195"; + + memory@40000000 { + device_type = "memory"; + reg = <0 0x40000000 0 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 2 MiB reserved for ARM Trusted Firmware (BL31) */ + bl31_secmon_reserved: secmon@54600000 { + no-map; + reg = <0 0x54600000 0x0 0x200000>; + }; + + /* 12 MiB reserved for OP-TEE (BL32) + * +-----------------------+ 0x43e0_0000 + * | SHMEM 2MiB | + * +-----------------------+ 0x43c0_0000 + * | | TA_RAM 8MiB | + * + TZDRAM +--------------+ 0x4340_0000 + * | | TEE_RAM 2MiB | + * +-----------------------+ 0x4320_0000 + */ + optee_reserved: optee@43200000 { + no-map; + reg = <0 0x43200000 0 0x00c00000>; + }; + }; + + chosen { + stdout-path = &uart0; + }; + + reg_1p8v: regulator-1p8v { + compatible = "regulator-fixed"; + regulator-name = "fixed-1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; +}; + +&watchdog { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&mmc0 { + bus-width = <4>; + max-frequency = <200000000>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + cap-mmc-hw-reset; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_1p8v>; + non-removable; + status = "okay"; +}; + +&usb { + status = "okay"; +}; + +&ssusb { + mediatek,force-vbus; + maximum-speed = "high-speed"; + dr_mode = "peripheral"; + status = "okay"; +}; + +&xhci0 { + status = "okay"; +}; + +&xhci3 { + status = "okay"; +}; diff --git a/board/mediatek/mt8195/MAINTAINERS b/board/mediatek/mt8195/MAINTAINERS new file mode 100644 index 0000000000..01fa25115d --- /dev/null +++ b/board/mediatek/mt8195/MAINTAINERS @@ -0,0 +1,6 @@ +MT8195 Demo +M: Macpaul Lin macpaul.lin@mediatek.com +S: Maintained +F: board/mediatek/mt8195 +F: include/configs/mt8195.h +F: configs/mt8195_demo_defconfig diff --git a/board/mediatek/mt8195/Makefile b/board/mediatek/mt8195/Makefile new file mode 100644 index 0000000000..7e94a87aea --- /dev/null +++ b/board/mediatek/mt8195/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += mt8195_demo.o diff --git a/board/mediatek/mt8195/mt8195_demo.c b/board/mediatek/mt8195/mt8195_demo.c new file mode 100644 index 0000000000..b95f5cf28d --- /dev/null +++ b/board/mediatek/mt8195/mt8195_demo.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 BayLibre SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <common.h> +#include <dm.h> +#include <net.h> +#include <asm/io.h> + +int board_init(void) +{ + struct udevice *dev; + int ret; + + if (CONFIG_IS_ENABLED(USB_GADGET)) { + ret = uclass_get_device(UCLASS_USB_GADGET_GENERIC, 0, &dev); + if (ret) { + pr_err("%s: Cannot find USB device\n", __func__); + return ret; + } + } + + if (CONFIG_IS_ENABLED(USB_ETHER)) + usb_ether_init(); + + printf("Disabling WDT\n"); + writel(0, 0x10007000); + + printf("Enabling SCP SRAM\n"); + for (unsigned int val = 0xFFFFFFFF; val != 0U;) { + val = val >> 1; + writel(val, 0x1072102C); + } + + return 0; +} diff --git a/configs/mt8195_demo_defconfig b/configs/mt8195_demo_defconfig new file mode 100644 index 0000000000..5b075b1a27 --- /dev/null +++ b/configs/mt8195_demo_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=13000000 +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_MEDIATEK=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="mt8195-demo" +CONFIG_TARGET_MT8195=y +CONFIG_DEBUG_UART_BASE=0x11001100 +CONFIG_DEBUG_UART_CLOCK=26000000 +# CONFIG_PSCI_RESET is not set +CONFIG_SYS_LOAD_ADDR=0x4c000000 +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="mt8195-demo" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_MEMORY is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_BLOCK_CACHE is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_ENV_IMPORT_FDT=y +CONFIG_DEVRES=y +CONFIG_CLK=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x4d000000 +CONFIG_FASTBOOT_BUF_SIZE=0x8000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +# CONFIG_INPUT is not set +# CONFIG_MMC_QUIRKS is not set +CONFIG_MMC_MTK=y +CONFIG_PHY=y +CONFIG_PHY_MTK_TPHY=y +CONFIG_BAUDRATE=921600 +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_MTK_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_MTK=y +CONFIG_USB_MTU3=y +CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0e8d +CONFIG_USB_GADGET_PRODUCT_NUM=0x201c +CONFIG_USB_ETHER=y +CONFIG_WDT=y +CONFIG_WDT_MTK=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/mt8195.h b/include/configs/mt8195.h new file mode 100644 index 0000000000..bc067647c0 --- /dev/null +++ b/include/configs/mt8195.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration for MT8195 based boards + * + * Copyright (C) 2022 MediaTek Inc. + * Copyright (C) 2022 BayLibre, SAS + * Author: Fabien Parent macpaul.lin@mediatek.com + * Author: Fabien Parent fparent@baylibre.com + */ + +#ifndef __MT8195_H +#define __MT8195_H + +#include <linux/sizes.h> + +/* Environment settings */ +#include <config_distro_bootcmd.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#if !defined(CONFIG_EXTRA_ENV_SETTINGS) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "scriptaddr=0x40000000\0" \ + BOOTENV +#endif + +#endif
Chunfeng Yun (云春峰)
Macpaul Lin
Pali Rohár
