[GIT PULL] Please pull u-boot-imx-next-20241217
Hi Tom,
Please pull from u-boot-imx/next, thanks.
The following changes since commit 8aab7730c1c26192b0e4218fbf2f6009f955cb88:
Merge patch series "Hyperflash Boot fixes for J7200/J721E" (2024-12-14 09:34:27 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-next-20241217
for you to fetch changes up to 7cf57825eb4366a474ee0a13ef690d460f8c4775:
imx: hab: fix srktool -c usage by removing spaces (2024-12-16 14:35:58 -0300)
u-boot-imx-next-20241217 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/23877
- Add support for Apalis iMX8 1300MHz version. - Don't advertise Gbit on (R)MII on the FEC controller. - Fix srktool -c usage by removing spaces. ---------------------------------------------------------------- Alexander Sverdlin (1): net: fec: phy: Don't advertise Gbit on (R)MII
Christoph Fritz (1): imx: hab: fix srktool -c usage by removing spaces
Stefan Eichenberger (5): toradex: tdx-cfg-block: set apalis imx8dxp to always disabled toradex: tdx-cfg-block: increase indentation for longer defines toradex: tdx-cfg-block: add new apalis imx8 pids toradex: apalis-imx8: simplify module version handling imx: mach: imx8: fdt: set correct frequencies for the industrial SoC
arch/arm/mach-imx/imx8/fdt.c | 132 +++++++++++++++++++++++ board/toradex/apalis-imx8/apalis-imx8.c | 19 ++-- board/toradex/common/tdx-cfg-block.c | 183 ++++++++++++++++---------------- board/toradex/common/tdx-cfg-block.h | 5 + doc/imx/habv4/introduction_habv4.txt | 8 +- drivers/net/fec_mxc.c | 12 +++ 6 files changed, 254 insertions(+), 105 deletions(-)
On Tue, Dec 17, 2024 at 07:54:33AM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
